30FE-BT-VK-N
30FE-BT-VK-N
    JST
    FE Series 30 Position 1.25mm Top Entry FFC Connector
30FE-BT-VK-N 数据手册
FECONNECTOR 0.3mmピッチ NON- 1.25 mm pitch/Connectors for FFC FE CONNECTOR Specifications • Current rating: 1.0 A AC/DC • Voltage rating: 200 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 mΩ max. After environmental tests/ 30 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable FFC: Conductor pitch/ 1.25 mm Conductor width/ 0.8 mm Mating part thickness/ 0.30 ± 0.05 mm The FE connector ensures easy, secure connection of flexible flat cables (FFC). This compact connector is 4.8 mm wide, 7.5 mm high, and provides high contact pressure even though little force is required for insertion. The result is smooth insertion and reliable contact performance. The connector is useful in making personal computers, VCRs and car stereo systems smaller and lighter. ●L  ow insertion force and high contact pressure ● Snap-in connection ● Temporary board retention feature ® Note: FFC to be actually used should be checked for applicability. • Applicable PC board thickness: 1.2 to 1.6 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards ® ® Recognized E60389 Certified LR20812 ® PC board layout and Assembly layout Top entry type ® Side entry type Contact side 1.25±0.05 +0.1 φ0.8  0 7.5 Contact side Circuit No.1 2.5±0.05 4.8 7.5 φ0.8 +0.1  0 2.5±0.05 1.25±0.05 2.5±0.05 4.8 Circuit No.1 2.5±0.05 1.175 6.5 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 FE CONNECTOR Connector Model No. No. of circuits Top entry type Side entry type 4 04FE-BT-VK-N 04FE-ST-VK-N 5 05FE-BT-VK-N 05FE-ST-VK-N 6 06FE-BT-VK-N 06FE-ST-VK-N 7 07FE-BT-VK-N 07FE-ST-VK-N 8 08FE-BT-VK-N 08FE-ST-VK-N 9 09FE-BT-VK-N 09FE-ST-VK-N 10 10FE-BT-VK-N 10FE-ST-VK-N 11 11FE-BT-VK-N 11FE-ST-VK-N 12 12FE-BT-VK-N 12FE-ST-VK-N 13 13FE-BT-VK-N 13FE-ST-VK-N 14 14FE-BT-VK-N 14FE-ST-VK-N 15 15FE-BT-VK-N 15FE-ST-VK-N 16 16FE-BT-VK-N 16FE-ST-VK-N 17 17FE-BT-VK-N 17FE-ST-VK-N 18 18FE-BT-VK-N 18FE-ST-VK-N 19 19FE-BT-VK-N 19FE-ST-VK-N 20 20FE-BT-VK-N 20FE-ST-VK-N 21 21FE-BT-VK-N 21FE-ST-VK-N 22 22FE-BT-VK-N 22FE-ST-VK-N 23 23FE-BT-VK-N 23FE-ST-VK-N 24 24FE-BT-VK-N 24FE-ST-VK-N 25 25FE-BT-VK-N 25FE-ST-VK-N 26 26FE-BT-VK-N 26FE-ST-VK-N 27 27FE-BT-VK-N 27FE-ST-VK-N 28 28FE-BT-VK-N 28FE-ST-VK-N 29 29FE-BT-VK-N 29FE-ST-VK-N 30 30FE-BT-VK-N 30FE-ST-VK-N 31 31FE-BT-VK-N 31FE-ST-VK-N 32 32FE-BT-VK-N 32FE-ST-VK-N 33 33FE-BT-VK-N 33FE-ST-VK-N 34 34FE-BT-VK-N 34FE-ST-VK-N 35 35FE-BT-VK-N 35FE-ST-VK-N 36 36FE-BT-VK-N 36FE-ST-VK-N 37 37FE-BT-VK-N 37FE-ST-VK-N 38 38FE-BT-VK-N 38FE-ST-VK-N 39 39FE-BT-VK-N 39FE-ST-VK-N 40 40FE-BT-VK-N 40FE-ST-VK-N Top entry type 7.5 1.125 3.5 2.5 4.8 4.0 1.25 B C A 1.5 Circuit No.1 Circuit No.1 Side entry type 9.1 7.5 4.8 4.0 1.25 B C A Circuit No.1 3.1 1.5 2.5 Circuit No.1 Dimensions (mm) A B C 3.75 8.55 6.35 2,350 1,410 5.00 9.80 7.60 2,000 1,200 6.25 11.05 8.85 1,800 1,080 7.50 12.30 10.10 1,600 960 8.75 13.55 11.35 1,500 900 10.00 14.80 12.60 1,350 810 11.25 16.05 13.85 1,250 750 12.50 17.30 15.10 1,150 690 13.75 18.55 16.35 1,100 660 15.00 19.80 17.60 1,000 600 16.25 21.05 18.85  950 570 17.50 22.30 20.10  900 540 18.75 23.55 21.35  850 510 20.00 24.80 22.60  800 480 21.25 26.05 23.85  750 450 22.50 27.30 25.10  700 420 23.75 28.55 26.35  700 420 25.00 29.80 27.60  650 390 26.25 31.05 28.85  650 390 27.50 32.30 30.10  600 360 28.75 33.55 31.35  600 360 30.00 34.80 32.60  550 330 31.25 36.05 33.85  550 330 32.50 37.30 35.10 500 300 33.75 38.55 36.35 500 300 35.00 39.80 37.60  500 300 36.25 41.05 38.85 450 270 37.50 42.30 40.10 450 270 38.75 43.55 41.35  450 270 40.00 44.80 42.60 450 270 41.25 46.05 43.85 400 240 42.50 47.30 45.10 400 240 43.75 48.55 46.35 400 240 45.00 49.80 47.60 400 240 46.25 51.05 48.85 350 210 47.50 52.30 50.10 350 210 48.75 53.55 51.35 350 210 Material and Finish Contact: Copper alloy, tin-plated (reflow treatment) Housing: PBT, UL94V-0, white RoHS2 compliance Lead section dimensions of FFC +0.05 1.25×(N+1) -0.2 ±0.15 1.25×(N-1) 0.8 ±0.1 1.25 ±0.2 0.30 ±0.05 5.0min. 1.25 ±0.1 Conductor Insulator Note: N --- Number of circuits 2 (7.0) 1.25 ±0.2 Reinforcing layer Insulator Q'ty/box Top entry Side entry type type
30FE-BT-VK-N 价格&库存
很抱歉,暂时无法提供与“30FE-BT-VK-N”相匹配的价格&库存,您可以联系我们找货
30FE-BT-VK-N
    • 450+1.43230
    库存:2250
