734-102
734-102
    WAGO(万可电子)
    P=3.5mm
    接线端子 间距:3.50mm 1x2P
734-102 数据手册
Printview: Female connector; 2-pole; pin spacing 3.5 mm / 0.138 in; 100% protected against mismating; codable - Item No.: 734-102 . Female connector; 2-pole; pin spacing 3.5 mm / 0.138 in; 100% protected against mismating; codable Item No.: 734-102 . Female connector; 2-pole; pin spacing 3.5 mm / 0.138 in; 100% protected against mismating; codable . Marking . Business data Supplier WAGO Item no. 734-102 GTIN / EAN 4044918492294 Content 1 Order amount 200 Customer item number . Notes Universal connection for all conductor typesEasy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuationStrain relief plates and housings for in-the-field assembly100% protected against mismatingCoding option available Technical data Miscellaneous No. of poles 2 Pin Spacing 3.5 mm / 0.138 in % Total number of connection points 2 Total number of potentials 2 Color light gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Female connector; 2-pole; pin spacing 3.5 mm / 0.138 in; 100% protected against mismating; codable - Item No.: 734-102 Technical data Pollution degree (1) 2 Rated voltage EN (1) [V] 160 [V] Rated surge voltage (1) [kV] 2.5 [kV] Nominal current [A] 10 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 320 [V] Rated surge voltage (2) [kV] 2.5 [kV] Nominal current (2) [A] 10 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 160 [V] Rated surge voltage (3) [kV] 2.5 [kV] Nominal current (3) [A] 10 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 1.5 mm² / 28 … 14 AWG Fine-stranded wires 1 0.08 … 1.5 mm² / 28 … 14 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 1.5 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 1.5 mm² / … Strip length 1 6 … 7 mm / 0.24 … 0.28 in Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 100 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load [MJ] 0.03 [MJ] Weight [g] 1.725 [g] Width 9.2 mm / 0.362 in Height 13.4 mm / 0.528 in Length 18.6 mm / 0.732 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Female connector; 2-pole; pin spacing 3.5 mm / 0.138 in; 100% protected against mismating; codable - Item No.: 734-102 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Female connector; 2-pole; pin spacing 3.5 mm / 0.138 in; 100% protected against mismating; codable - Item No.: 734-102 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
734-102 价格&库存
很抱歉,暂时无法提供与“734-102”相匹配的价格&库存,您可以联系我们找货
  • 1+45.723491+5.89845
  • 10+32.4599410+4.18742
  • 25+28.4553125+3.67081
  • 50+25.9683850+3.34999
  • 100+23.91986100+3.08573
  • 250+21.80135250+2.81243
  • 500+20.57298500+2.65397
  • 1000+19.606421000+2.52928
库存:3896
734-102
    • 1+6.58570
    • 200+5.92680
    • 400+5.92570
    库存:6
    734-102
      • 200+5.96075
      库存:1200
      734-102
      • 1+10.84320
      • 10+8.81280
      • 30+7.70040
      • 200+6.44760
      库存:261
