Data sheet | Item number: 750-8214
Controller PFC200; 2nd Generation; 2 x ETHERNET, RS-232/-485, CAN,
CANopen
www.wago.com/750-8214
Color:
Item description
The PFC200 Controller is a compact PLC for the modular WAGO-I/O-SYSTEM. Besides network and fieldbus interfaces, the controller supports all
digital, analog and specialty modules found within the 750/753 Series.
Two ETHERNET interfaces and an integrated switch enable line topology wiring.
An integrated Webserver provides user configuration options, while displaying PFC200 status information.
30.10.2018 Page 1/11
Besides the processing industry and building automation, typical applications for the PFC200 include standard machinery and equipment control (e.
g., packaging, bottling and manufacturing systems, as well as textile, metal and wood processing machines).
Programming per IEC 61131-3
Programmable via WAGO-I/O-PRO V2.3 or e!COCKPIT
Direct connection of WAGO I/O modules
2 x ETHERNET (configurable), RS-232/-485, CAN, CANopen
Linux operating system with RT‐Preempt patch
Configuration via CODESYS, e!COCKPIT or Web-Based Management user interface
Maintenance-free
Data
Technical Data
Communication
CANopen
Modbus TCP
Ethernet
Modbus RTU
RS-232 serial interface
RS-485 interface
EtherNet/IP-Adapter (Slave), Bibliothek für e!RUNTIME
EtherCAT-Master (mit Zusatzlizenz)
MQTT
Ethernet protocol
DHCP
DNS
NTP
FTP
FTPS
SNMP
HTTP
HTTPS
SSH
Visualization
Web-Visu
Operating system
Real-time Linux (with RT-Preempt patch)
CPU
Cortex A8; 1 GHz
Programming languages per IEC 61131-3
Instruction List (IL)
Ladder Diagram (LD)
Function Block Diagram (FBD), Continuous Function Chart (CFC)
Structured Text (ST)
Sequential Function Chart (SFC)
Programming environment
e!COCKPIT (based on CODESYS V3)
WAGO-I/O-PRO V2.3 (based on CODESYS V2.3)
Configuration options
e!COCKPIT
WAGO-I/O-CHECK
Web-based management
e!RUNTIME library
CODESYS Library
Baud rate (communication/fieldbus 1)
10/100Mbit/s
30.10.2018 Page 2/11
CODESYS Library
10/100Mbit/s
Baud rate
ETHERNET: 10/100Mbit/s
Transmission medium (communication/fieldbus)
ETHERNET: Twisted Pair S-UTP; 100 Ω; Cat. 5; Line length (max.):
100 m
Main memory (RAM)
512 MB
Internal memory (flash)
4000 MB
Hardware non-volatile memory
128 Kbytes
Program memory
CODESYS V2: 16MByte; e!RUNTIME: 60MByte Program and data
memory (dynamically distributed)
Data memory
CODESYS V2: 64MByte; e!RUNTIME: 60MByte Program and data
Software non-volatile memory
128 Kbytes
Type of memory card
SD and SDHC up to 32 GB (All guaranteed properties are only valid
in connection with the WAGO 758-879/000-001 memory card.)
Memory card slot
Push-push mechanism, sealable cover lid
Number of modules per node max.
250
Number of I/O modules without bus extension max.
64
Input and output process image (internal) max.
1000Words/1000Words
Input and output process image (MODBUS) max.
1000Words/1000Words
Input and output process image (CAN) max.
2000Words/2000Words
Indicators
LED (SYS, RUN, I/O, U1 … U6) red/green/orange: Status system,
program, internal data bus, CANopen, status programmable by user
(can be used via CODESYS library); LED (A, B) green: System power
supply status, field supply
System supply voltage
DC 24 V (−25 … +30 %); via wiring level (CAGE CLAMP® connection)
Input current typ. at rated load (24 V)
550 mA
Total current for system supply
1700 mA
Field supply voltage
DC 24 V (-25 … 30 %); via power jumper contacts
Current carrying capacity of the power jumper contacts
10 A
Number of outgoing power jumper contacts
3
Isolation
500 V system/supply
Connection data
Connection technology: communication/fieldbus
CANopen: 1 x D-Sub 9 connector; Modbus TCP/UDP: 2 x RJ-45;
Modbus RTU: 1 x D-Sub 9 socket; RS-232 serial interface: 1 x D-Sub
9 socket; RS-485 interface: 1 x D-sub 9 socket
Connection technology: system supply
2 x CAGE CLAMP®
Connection technology: field supply
6 x CAGE CLAMP®
Connection type (1)
System-/Feldversorgung
Solid conductor
0.08 … 2.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 Inch
Connection technology: device configuration
1 x 4-pole male connector
30.10.2018 Page 3/11
Geometrical Data
Width
112 mm / 4.409 inch
Height
71.9 mm / 2.831 inch
Height from upper-edge of DIN-35 rail
64.7 mm / 2.547 inch
Depth
100 mm / 3.937 inch
Mechanical data
Weight
256.858 g
Color
light gray
Housing material
Polycarbonate, polyamide 6.6
Conformity marking
CE
Environmental Requirements
Surrounding air (operating) temperature
0 … 55 °C
Surrounding air (storage) temperature
-25 … 85 °C
Degree of protection
IP20
Degree of pollution (5)
2 per IEC 61131-2
Operating altitude
without temperature derating: 0 … 2000 m; with temperature
derating: 2000 … 5000 m (0.5 K/100 m); max.: 5000 m
Relative air humidity (no condensation)
95 %
Mounting position
any
Type of mounting
DIN-35 rail
Vibration resistance
4g per IEC 60068-2-6
Shock resistance
15g per IEC 60068-2-27
EMC immunity to interference
acc. to EN 61000-6-2, marine applications
EMC emission of interference
acc. to EN 61000-6-3, marine applications
Exposure to pollutants
Per IEC 60068-2-42 and IEC 60068-2-43
Permissible H2S contaminant concentration at a relative humidity <
10 ppm
75 %
Permissible SO2 contaminant concentration at a relative humidity <
25 ppm
75 %
Commercial data
Packaging type
BOX
Country of rigin
DE
GTIN
4055143759762
30.10.2018 Page 4/11
Compatible products
General accessories
Item no.: 750-921
Bluetooth® Adapter
www.wago.com/750-921
Item no.: 750-923
Configuration cable; USB connector
www.wago.com/750-923
Item no.: 750-923/000-001
/000-001
Carrier rail
Item no.: 210-112
www.wago.com/210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
www.wago.com/210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-196
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Item no.: 2759-101/1110-2002
e!COCKPIT software; license (single workstation)
www.wago.com/2759-101
/1110-2002
Item no.: 2759-101/1110-2005
software
30.10.2018 Page 5/11
e!COCKPIT software; license (5 users)
/1110-2005
Item no.: 2759-101/1110-2010
e!COCKPIT software; license (10 users)
/1110-2010
Item no.: 2759-101/1110-2015
e!COCKPIT software; license (15 users)
/1110-2015
Item no.: 2759-101/1110-2020
e!COCKPIT software; license (20 users)
/1110-2020
Item no.: 2759-101/1110-3000
e!COCKPIT software; license (site)
/1110-3000
Item no.: 2759-101/1110-4000
e!COCKPIT software; license (buy-out)
/1110-4000
Item no.: 759-333
WAGO-I/O-PRO
www.wago.com/759-333
Item no.: 759-333/000-923
WAGO-I/O-PRO; USB-Set
/000-923
Item no.: 759-911
WAGO-I/O-PRO; CD
www.wago.com/759-911
Item no.: 850-804
IP65 enclosure; Stainless steel; WxHxD (400x123x200 mm); 4 x M20, 16 x M16, 28 x M12 cable grip
www.wago.com/850-804
Item no.: 850-804/000-001
IP65 enclosure; Stainless steel; WxHxD (400x123x200 mm); 2 x M20, 13 x M16, 32 x M12 cable grip
/000-001
Item no.: 850-805
IP65 enclosure; Stainless steel; WxHxD (600x123x200 mm); 4 x M20, 19 x M16, 67 x M12 cable grip
www.wago.com/850-805
Item no.: 850-814/002-000
IP65 enclosure; Sheet steel (RAL 7035); WxHxD (200x120x200 mm); without flange plate
www.wago.com/850-814
/002-000
Item no.: 850-815/002-000
IP65 enclosure; Sheet steel (RAL 7035); WxHxD (300x120x200 mm); without flange plate
www.wago.com/850-815
/002-000
Item no.: 850-816/002-000
IP65 enclosure; Sheet steel (RAL 7035); WxHxD (400x120x200 mm); without flange plate
www.wago.com/850-816
/002-000
Item no.: 850-817/002-000
www.wago.com/850-817
system box
30.10.2018 Page 6/11
IP65 enclosure; Sheet steel (RAL 7035); WxHxD (600x120x200 mm); without flange plate
/002-000
Item no.: 850-825
IP65 enclosure; Aluminium (RAL 7032); WxHxD (160x100x160 mm); 9 x M12, 4 x M20
www.wago.com/850-825
Item no.: 850-826
IP65 enclosure; Aluminium (RAL 7032); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable
grip
www.wago.com/850-826
Item no.: 850-826/002-000
IP65 enclosure; Aluminium (RAL 7035); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable
grip
/002-000
Item no.: 850-827
IP65 enclosure; Aluminium (RAL 7032); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable
grip
www.wago.com/850-827
Item no.: 850-827/002-000
IP65 enclosure; Aluminium (RAL 7035); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable
grip
/002-000
Item no.: 850-828
IP65 enclosure; Aluminium (RAL 7032); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable
grip
www.wago.com/850-828
Item no.: 850-828/002-000
IP65 enclosure; Aluminium (RAL 7035); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable
grip
/002-000
Item no.: 850-834
IP65 enclosure; Polyester (RAL 7032); WxHxD (164x100x164 mm); 9 x M12, 4 x M20
www.wago.com/850-834
Item no.: 850-835
IP65 enclosure; Polyester (RAL 7032); WxHxD (244x100x164 mm); 4 x M20, 4 x M16, 14 x M12 cable
grip
www.wago.com/850-835
Item no.: 850-836
IP65 enclosure; Polyester (RAL 7032); WxHxD (324x100x164 mm); 4 x M20, 8 x M16, 17 x M12 cable
grip
www.wago.com/850-836
Item no.: 758-879/000-001
Memory Card SD; SLC-NAND; 2 GByte; Temperature from -40 to 90 °C
www.wago.com/758-879
/000-001
memory card
shield connection
Item no.: 790-108
Shield clamping saddle; 11 mm wide; 0-8 mm diameter conductors
www.wago.com/790-108
Item no.: 790-116
Shield clamping saddle; 19 mm wide; 7-16 mm diameter conductors
www.wago.com/790-116
Item no.: 790-124
Shield clamping saddle; 27 mm wide; 6-24 mm diameter conductors
www.wago.com/790-124
Item no.: 790-140
Shield clamping saddle; 43 mm wide; 22-40 mm diameter conductors
www.wago.com/790-140
Item no.: 790-208
30.10.2018 Page 7/11
Item no.: 790-208
Shield clamping saddle; 12.4 mm wide; 3-8 mm diameter conductors
www.wago.com/790-208
Item no.: 790-216
Shield clamping saddle; 21.8 mm wide; 6-16 mm diameter conductors
www.wago.com/790-216
Item no.: 790-220
Shield clamping saddle; 30 mm wide; 6–20 mm diameter
www.wago.com/790-220
wiring and connectors
Item no.: 750-963
Fieldbus Connector CANopen; with D-sub female connector; 9-pole
www.wago.com/750-963
Item no.: 750-975
RJ-45 connector; IP20; ETHERNET 10/100 Mbit/s
www.wago.com/750-975
Item no.: 750-977/000-011
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22
www.wago.com/750-977
/000-011
Item no.: 750-977/000-012
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22
/000-012
Item no.: 750-977/000-021
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24
/000-021
Item no.: 750-977/000-022
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24
/000-022
Item no.: 750-978/000-011
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22; Strain relief
www.wago.com/750-978
/000-011
Item no.: 750-978/000-012
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22; Strain relief
/000-012
Item no.: 750-978/000-021
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24; Strain relief
/000-021
Item no.: 750-978/000-022
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24; Strain relief
/000-022
Item no.: 750-979/000-011
Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 22; Strain relief
www.wago.com/750-979
/000-011
Item no.: 750-979/000-012
Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 22; Strain relief
/000-012
Item no.: 750-979/000-021
30.10.2018 Page 8/11
Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 24; Strain relief
Item no.: 750-979/000-022
Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 24; Strain relief
/000-021
/000-022
Marking accessories
Item no.: 2009-145
Mini-WSB Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type
www.wago.com/2009-145
Item no.: 2009-145/000-002
/000-002
Item no.: 2009-145/000-005
/000-005
Item no.: 2009-145/000-006
/000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; plain; 1,700 Mini-WSB markers (5 mm) on roll; stretchable 5 - 5.2 mm
/000-007
Item no.: 2009-145/000-012
/000-012
Item no.: 2009-145/000-023
Mini-WSB Inline; on reel; stretchable 5 - 5.2 mm; plain; snap-on type
/000-023
Item no.: 2009-145/000-024
/000-024
Item no.: 248-501
Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type
/000-002
Item no.: 248-501/000-005
Mini-WSB marking card; as card; plain; snap-on type
/000-005
Item no.: 248-501/000-006
/000-006
Item no.: 248-501/000-007
30.10.2018 Page 9/11
/000-007
Item no.: 248-501/000-012
/000-012
Item no.: 248-501/000-017
/000-017
Item no.: 248-501/000-023
/000-023
Item no.: 248-501/000-024
/000-024
Item no.: 750-103
Group marker carrier
www.wago.com/750-103
Item no.: 750-107
www.wago.com/750-107
Downloads
Documentation
Manual
Cyber Security for Controller PFC100 / PFC200
07-Aug-2018
Download
9.5 MB
PFC200 G2 2ETH RS CAN
25-Sep-2018
2 x ETHERNET, RS-232 / RS-485, CAN, CANopen
WAGO MODBUS Master Configurator
Download
5.6 MB
22-Sep-2014
Download
1.3 MB
for configuration of MODBUS networks in WAGO-I/O-PRO (CODESYS)
System Description
Controller PFC100/200, General Product Information
06-Jun-2017
Download
524.3 kB
Design Notes
03-May-2011
Basic conditions and recommendations for higher operational safety
Overview on WAGO-I/O-SYSTEM 750 approvals
Download
1.5 MB
06-Jun-2017
Download
314.9 kB
Additional Information
15-Oct-2018
Download
30.10.2018 Page 10/11
Disposal; Electrical and electronic equipment, Packaging
15-Oct-2018
Download
265.8 kB
CAD files
CAD data
3D Download 750-8214
Download
Product family
Controllers:
Show all products from the family.
Subject to changes.
WAGO Corporation
Germantown, WI 53022
32423 Minden
Phone: +49571 887-0 | Fax: (262) 255-6222
Email: info.us@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at {0}.
30.10.2018 Page 11/11
