811-411
    WAGO(万可电子)
    端子块连接器 2 位置 断连 灰色 6-14 AWG
811-411 数据手册
Printview: Fuse terminal block; for class CC fuses; with blown fuse indication; 90 … 600 VAC, 115 … 600 VDC; suitable for DIN 35 rail acc. to EN 60715; 1-pole - Item No.: 811-411 . Fuse terminal block; for class CC fuses; with blown fuse indication; 90 … 600 VAC, 115 … 600 VDC; suitable for DIN 35 rail acc. to EN 60715; 1-pole Item No.: 811-411 . Fuse terminal block; for class CC fuses; with blown fuse indication; 90 … 600 VAC, 115 … 600 VDC; suitable for DIN 35 rail acc. to EN 60715; 1-pole . Marking . Business data Supplier WAGO Item no. 811-411 GTIN / EAN 4050821508205 Content 1 Order amount 1 Customer item number . Notes Safety information 1: Electrical ratings are given by the fuse and blown fuse indication. Technical data Miscellaneous No. of poles 1 Total number of connection points 2 Total number of potentials 1 Color light gray Ratings according to 1 IEC/EN 60947-7-3 Nominal current [A] 32 [A] Connection technology (1) CAGE CLAMP® Solid sizes 1 2.5 … 16 mm² / 16 … 6 AWG WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Fuse terminal block; for class CC fuses; with blown fuse indication; 90 … 600 VAC, 115 … 600 VDC; suitable for DIN 35 rail acc. to EN 60715; 1-pole - Item No.: 811-411 Technical data Fine-stranded wires 1 2.5 … 16 mm² / 16 … 6 AWG Strip length 1 12 … 13 mm / 0.47 … 0.51 in Type of wiring Front-entry wiring Design horizontal Insulating material Polyamide 66 (PA 66) Weight [g] 1.111 [g] Width 17.5 mm / 0.689 in Height from upper-edge of DIN-rail [mm] 55 [mm] Height from upper-edge of DIN-rail 55 mm / 2.165 in Length 105 mm / 4.134 in Type of mounting DIN 35 rail Safety information 2 Temperature scale handling from -35°C … +85°C WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Fuse terminal block; for class CC fuses; with blown fuse indication; 90 … 600 VAC, 115 … 600 VDC; suitable for DIN 35 rail acc. to EN 60715; 1-pole - Item No.: 811-411 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Fuse terminal block; for class CC fuses; with blown fuse indication; 90 … 600 VAC, 115 … 600 VDC; suitable for DIN 35 rail acc. to EN 60715; 1-pole - Item No.: 811-411 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
811-411 价格&库存
很抱歉,暂时无法提供与“811-411”相匹配的价格&库存,您可以联系我们找货
    • 1+145.901081+17.44920
    • 4+144.044834+17.22720
    • 15+142.2814015+17.01630
    • 40+140.9820240+16.86090
    • 100+138.94015100+16.61670
    库存:25
