857-411, 857-412, 857-413, 857-414, 857-415, 857-416
74
JUMPFLEX® Transducers
Isolation amplifiers, fixed setting for voltage or current signals
Interface Modules
IN+ 1
GND 1 2
Us+ 3
OUT
5 OUT+
6 GND 2
7 Us+
POWER
8 GND 3
GND 3 4
IN
____________
_>
_>
3
6 mm/0.23 in
Short description:
The configurable isolation amplifiers convert, amplify, filter and electrically
isolate analog standard signals. The devices have a 3-way isolation with a
2.5kV test voltage. The 857-411 Isolation Amplifier provides electrical isolation
between the 0(4) - 20mA input and the 0(4) - 20mA output analog current
signals. The 857-412 Isolation Amplifier provides electrical isolation between
the 0(2) - 10V input and the 0(2) - 10V output analog voltage signals.
The device is supplied with 24VDC, which can be quickly and cost-effectively
commoned via lateral, push-in type jumper bars.
A green LED on the front panel indicates normal operation. The isolation
amplifiers meet the requirements for safe isolation of input, output and supply
circuits with 2.5kV test voltage according to EN 61140.
Description
Input signal
Output signal
Item No.
Pack.
Unit
Technical Data
Isolation amplifier
Isolation amplifier
Isolation amplifier
Isolation amplifier
Isolation amplifier
Isolation amplifier
0(4) ... 20 mA
0(2) ... 10 V
0 ... 10 V
0 ... 10 V
0 ... 20 mA
4 ... 20 mA
0(4) ... 20 mA
0(2) ... 10 V
0 ... 20 mA
4 ... 20 mA
0 ... 10 V
0 ... 10 V
857-411
857-412
857-413
857-414
857-415
857-416
1
1
1
1
1
1
Input signal
Input resistance
Output signal
Accessories
General accessories
see Full Line Catalog 2010/2011
Interface Modules
Approvals
Shipbuilding
4 r ANSI/ISA 12.12.01
Conformity marking
g
Class I, Div. 2, Grp. ABCD, T4
1
Load impedance
General Specifications
Dimensions (mm) W x H x L
Wire connection
Cross sections
Stripped lengths
WAGO Kontakttechnik GmbH & Co. KG
Subject to design changes
6 x 96 x 94
Height from upper-edge of DIN 35 rail
CAGE CLAMP®S
solid: 0.08 mm² ... 2.5 mm² /
AWG 28 ... 14
fine-stranded: 0.34 mm² ... 2.5 mm² /
AWG 22 ... 14
9 ... 10 mm / 0.37 in
6 x 96 x 94
18.04.2011
Max. operating frequency
Response time (T10-90)
Voltage supply VN
Supply voltage range
Current consumption at 24 V DC
Transmission error
Temperature coefficient
Test voltage (input/output/supply)
Ambient operating temperature
Storage temperature
Postfach 2880 - D-32385 Minden
Hansastr. 27 - D-32423 Minden
857-411: 0(4) ... 20 mA
857-412: 0(2) ... 10 V
857-413: 0 ... 10 V
857-414: 0 ... 10 V
857-415: 0 ... 20 mA
857-416: 4 ... 20 mA
≤ 50 Ω (I input)
≥ 100 kΩ (U input)
857-411: 0(2) ... 10 V
857-411: 0 ... 20 mA
857-411: 4 ... 20 mA
857-411: 0 ... 10 V
857-411: 0 ... 10 V
600 Ω (I output)
2 kΩ (U output)
100 Hz
< 3.5 ms
DC 24 V
16.8 V ... 31.2 V
< 25 mA
< 0.1 % of the full scale value
0.01 % /K
2.5 kV AC, 50 Hz, 1 min
-25 °C ... +70 °C
-40 °C ... +85 °C
Phone: +49(0)571/887-0
Fax: +49(0)571/887-169
E-Mail: info@wago.com
www.wago.com
很抱歉,暂时无法提供与“857-415”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2585.136971+334.08268
