Data sheet | Item number: 870-687
3-conductor ground terminal block; 2.5 mm²; lateral marker slots; for DIN-rail 35 x
15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; green-yellow
https://www.wago.com/870-687
Color:
green-yellow
Notes
Safety information 1
Notice: This ground conductor terminal block cannot be commoned with push-in type
jumper bars!
Safety information 2
Max. insulation diameter: 4.4 mm
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60947-7-2
Connection data
Total number of connection points
3
Connection 1
Total number of potentials
1
Connection technology
CAGE CLAMP®
Number of levels
1
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor; with insulated
ferrule
0.08 … 1.5 mm² / 28 … 14 AWG
Strip length
6 … 7 mm / 0.24 … 0.28 inch
Page 1/7
Version 04.05.2022
Continued on next page
Connection 1
Wiring direction
Front-entry wiring
Physical data
Width
5 mm / 0.197 inch
Height
49 mm / 1.929 inch
Depth from upper-edge of DIN-rail
27.5 mm / 1.083 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Side marking
Material data
Note (material data)
Information on material data can be found here
Color
green-yellow
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.093 MJ
Weight
7.3 g
Commercial data
eCl@ss 10.0
27-14-11-41
eCl@ss 9.0
27-14-11-41
ETIM 7.0
EC000901
ETIM 6.0
EC000901
PU (SPU)
100 Stück
Packaging type
Box
Country of origin VKOrg Germany
DE
GTIN
4045454094607
Customs tariff number VKOrg Germany
85369010000
Approvals and certificates
Country specific Approvals
Ship Approvals
Approval
Standard
Certificate name
Approval
Standard
Certificate name
CCA
DEKRA Certification B.V.
EN 60947
NTR NL 7468
20-HG1941090-PDA
CCA
EN 60947
2189801.01
ABS
American Bureau of Ship
ping
LR
Lloyds Register
EN 60947
91/20112 (E9)
Page 2/7
Version 04.05.2022
UL-Approvals
Approval
Standard
Certificate name
cURus
UL International Germany
GmbH
UL 1059
E45172
Downloads
Environmental Product Compliance
Compliance Search
Compliance 870-687
Documentation
Additional Information
Technical Section
Bid Text
pdf
2142.18 KB
870-687
19.02.2019
xml
3.20 KB
31.05.2017
doc
24.50 KB
870-687
CAD/CAE-Data
CAD data
CAE data
2D/3D Models 870-687
EPLAN Data Portal
870-687
WSCAD Universe
870-687
ZUKEN Portal 870-687
Page 3/7
Version 04.05.2022
1 Compatible products
1.1 Required accessories
1.1.1 End plate
1.1.1.1 End plate
Item no.: 870-933
End and intermediate plate; 1 mm thick;
gray
Item no.: 870-934
orange
1.2 Optional accessories
1.2.1 DIN-rail
1.2.1.1 Mounting accessories
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm
thick; 2 m long; unslotted; similar to EN
60715; silver-colored
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm
thick; 2 m long; unslotted; according to
EN 60715; copper-colored
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm
thick; 2 m long; slotted; galvanized; simi
lar to EN 60715; silver-colored
Item no.: 210-197
thick; 2 m long; slotted; similar to EN
Item no.: 210-506
thick; 2 m long; unslotted; galvanized; si
milar to EN 60715; silver-colored
Item no.: 210-114
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick;
2 m long; slotted; according to EN 60715;
"Hole width 18 mm; silver-colored
Item no.: 210-112
"Hole width 25 mm; silver-colored
Item no.: 210-504
2 m long; slotted; galvanized; according
Item no.: 210-113
2 m long; unslotted; according to EN
Item no.: 210-505
2 m long; unslotted; galvanized; according
1.2.2 End plate
1.2.2.1 End plate
Item no.: 870-946
Separator plate; 1 mm thick; gray
Item no.: 870-947
Separator plate; 1 mm thick; orange
Page 4/7
Version 04.05.2022
1.2.5 Ferrule
1.2.3
Insulation stop
1.2.3.1 Ferrule
Item no.: 216-321
Ferrule; Sleeve for 0.25 mm² / AWG 24; in
sulated; electro-tin plated; yellow
Item no.: 216-131
uninsulated; electro-tin plated; silver-co
lored
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; in
sulated; electro-tin plated; light turquoise
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24;
Item no.: 216-221
Ferrule; Sleeve for 0.5 mm² / 20 AWG; in
sulated; electro-tin plated; white
Item no.: 216-121
Ferrule; Sleeve for 0.5 mm² / AWG 22; un
insulated; electro-tin plated; silver-colo
red
Item no.: 216-222
Ferrule; Sleeve for 0.75 mm² / 18 AWG; in
sulated; electro-tin plated; gray
Item no.: 216-122
Ferrule; Sleeve for 0.75 mm² / AWG 20;
lored
Item no.: 216-123
Ferrule;
for 1 mm² / AWG 18; unin
Item no.:Sleeve
280-471
sulated;
electro-tin
silver-colored
Insulation
stop; 0.25plated;
- 0.5 mm²;
5 pieces/
strip; light gray
Item no.: 216-224
Ferrule;
for 1.5 mm² / AWG 16; in
Item no.:Sleeve
280-472
sulated;
electro-tin
black
Insulation
stop; 0.75plated;
- 1 mm²;
5 pieces/
strip; black
Item no.: 216-124
Ferrule; Sleeve for 1.5 mm² / AWG 16; un
Mounting carrier; for isolated mounting on
DIN 35 rails; gray
Item no.: 249-117
Screwless end stop; 10 mm wide; for DINrail 35 x 15 and 35 x 7.5; gray
Item no.: 249-116
Screwless end stop; 6 mm wide; for DINrail 35 x 15 and 35 x 7.5; gray
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; 1700
pieces on roll; stretchable 5 - 5.2 mm;
plain; snap-on type; blue
Item no.: 2009-145/000-007
plain; snap-on type; gray
Item no.: 2009-145/000-023
plain; snap-on type; green
Item no.: 2009-145/000-012
plain; snap-on type; orange
Item no.: 2009-145/000-005
plain; snap-on type; red
Item no.: 2009-145/000-024
plain; snap-on type; violet
Item no.: 2009-145
plain; snap-on type; white
Item no.: 2009-145/000-002
plain; snap-on type; yellow
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stret
chable; plain; snap-on type; blue
Item no.: 248-501/000-007
stretchable; plain; snap-on type; gray
Item no.: 248-501/000-023
stretchable; plain; snap-on type; green
Item no.: 248-501/000-017
chable; plain; snap-on type; light green
Item no.: 248-501/000-012
chable; plain; snap-on type; orange
Item no.: 248-501/000-005
stretchable; plain; snap-on type; red
Item no.: 248-501/000-024
stretchable; plain; snap-on type; violet
Item no.: 248-501
chable; plain; snap-on type; white
Item no.: 248-501/000-002
chable; plain; snap-on type; yellow
Item no.: 793-5501/000-006
WMB marking card; as card; for terminal
block width 5 - 17.5 mm; stretchable 5 5.2 mm; plain; snap-on type; blue
Item no.: 793-5501/000-007
block width 5 - 17.5 mm; stretchable 5 5.2 mm; plain; snap-on type; gray
Item no.: 793-5501/000-017
block width 5 - 17.5 mm; stretchable 5 5.2 mm; plain; snap-on type; green
Item no.: 793-5501/000-023
block width 5 - 17.5 mm; stretchable 5 5.2 mm; plain; snap-on type; light green
Item no.: 793-5501/000-012
block width 5 - 17.5 mm; stretchable 5 5.2 mm; plain; snap-on type; orange
Item no.: 793-5501/000-005
block width 5 - 17.5 mm; stretchable 5 5.2 mm; plain; snap-on type; red
Item no.: 793-5501/000-024
block width 5 - 17.5 mm; stretchable 5 5.2 mm; plain; snap-on type; violet
1.2.5.1 Insulation stop
Item no.: 216-223
Ferrule;
for 1 mm² / AWG 18; insu
Item no.:Sleeve
280-470
lated;
electro-tin
plated;
Insulation
stop; 0.08
- 0.2red
mm² "s" (0.14
mm² "f-st"); 5 pieces/strip; white
1.2.4 Marking
1.2.6
Installation
1.2.4.1 Mounting accessories
1.2.6.1
Item no.:Marker
209-106
Page 5/7
Version 04.05.2022
1.2.6.1 Marker
Item no.: 793-5501
block width 5 - 17.5 mm; stretchable 5 5.2 mm; plain; snap-on type; white
Item no.: 793-5501/000-002
block width 5 - 17.5 mm; stretchable 5 5.2 mm; plain; snap-on type; yellow
Item no.: 793-501/000-006
WMB marking card; as card; not stretcha
Item no.: 793-501/000-007
Item no.: 793-501/000-023
Item no.: 793-501/000-017
Item no.: 793-501/000-012
Item no.: 793-501/000-005
Item no.: 793-501/000-024
Item no.: 793-501
Item no.: 793-501/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pie
ces on roll; stretchable 5 - 5.2 mm; plain;
snap-on type; blue
Item no.: 2009-115/000-007
snap-on type; gray
Item no.: 2009-115/000-023
snap-on type; green
Item no.: 2009-115/000-017
Item no.: 2009-115/000-012
Item no.: 709-177
Marking strips; on reel; 7.5 mm wide; not
stretchable; plain; snap-on type; translu
cent
Item no.: 709-178
stretchable; plain; snap-on type; white
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a
partially insulated shaft; multicoloured
Item no.: 210-657
partially insulated shaft; short; multicolou
red
1.2.6.2 Marking strip
Item no.: 709-196
Marking strips; for laser printer; translu
cent
1.2.7 Protective warning marker
1.2.7.1 Cover
Item no.: 280-405
Protective warning marker; for 5 terminal
blocks; with high-voltage symbol, black;
yellow
1.2.8 Tool
1.2.8.1 Operating tool
Item no.: 210-658
partially insulated shaft; angled; short;
multicoloured
Page 6/7
Version 04.05.2022
Installation notes
Installation
Snapping a rail-mount terminal block onto
DIN-35 rail.
Conductor termination
CAGE CLAMP® connection
Inserting a conductor via operating tool
(0.08 … 4 mm² “f-st”).
With ferruled conductors, it is necessary
to use a terminal block one size smaller
than the conductor's nominal cross-secti
on.
Inserting insulation stops into conductor
entry holes of terminal strip.
Marking
WMB markers in Mini-WSB marker slots
Translucent marking strip
Mini-WSB markers
Translucent marking strip (709-196) –
jumpers below may be visible.
Subject to changes. Please also observe the further product documentation!
Current addresses can be found at: w w w.wago.com
Page 7/7
Version 04.05.2022
很抱歉,暂时无法提供与“870-687”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+89.879231+11.64251
- 10+63.7348710+8.25590
- 25+56.3028625+7.29319
- 50+51.7879150+6.70835
- 100+48.12412100+6.23376
- 250+44.38651250+5.74961
- 500+42.24335500+5.47199
- 1000+40.568941000+5.25510
