QTS-075-02-H-D-RA-WT-LS2 数据手册
F-219
QTS–025–01–F–D–RA
QTS–050–01–F–D–RA–WT
(0.635 mm) .025"
QTS-RA SERIES
RIGHT-ANGLE GROUND PLANE HEADER
Integral metal plane
for power or ground
Board Mates:
QSS
SPECIFICATIONS
Rightangle
For complete specifications and
recommended PCB layouts see
www.samtec.com?QTS-RA
Selectively
plated
Insulator Material:
Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Contact:
2 A per pin
(2 pins powered)
Ground Plane:
15.7 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
275 VAC mated with QSS-RA
RoHS Compliant:
Yes
• Guide posts
APPLICATIONS
• Weld tabs
• PCB mounting
holes
• Solder pin
option
HORIZONTAL
HIGH-SPEED CHANNEL PERFORMANCE
QTS-RA/QSS-RA or QTS-RA/QSS-D
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (025-075)
14
G b p s
NO. OF POSITIONS
PER ROW
QTS
Guide
post
01
PLATING
OPTION
RA
D
PERPENDICULAR
OTHER
OPTION
WT
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–F
–025, –050, –075
= Gold Flash on Signal Pins
and Ground Plane,
Matte Tin on tails
(50 total positions per bank)
FILE NO. E111594
–SP
–WT
= Solder
Pin
= Weld Tab
(Not available on
25 positions)
–L
= 10 µ" (0.25 µm) Gold on
Signal Pins and Ground Plane,
Matte Tin on tails
ALSO AVAILABLE
(MOQ Required)
• 30 µ" (0.76 µm) Gold
• Differential Pair
• “Partitionable” (combine
differential & single-ended
banks in same connector)
• Lead Style for (2.36 mm)
.093" thick board
• –LS1 Locking Screw (Mates
with QSS-RA-LS1)
• –LS2 Locking Screw (Mates
with QSS-LS2)
• 100 positions per row
(No. of Positions per Row/25)
x (20.00) .7875 + (14.73) .580
x (20.00) .7875 + (8.38) .330
(3.18) .125 DIA
(6.35) .250 DIA
(10.29) (3.05)
(7.11) .405 .120
.280
(3.18)
.125
DIA
01
x (20.00) .7875 + (5.72) .225
02
(0.38) .015
(2.03) .080
(0.635)
.025 SQ
(0.635)
.025
(0.89)
.035 DIA
–SP OPTION
(5.08) .200
(5.97) (9.42)
.235 .371
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(1.40)
.055
(0.20) .008
(1.50)
.059
(0.10)
.004
(0.30)
.012
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
(1.73)
.068
QTS-075-02-H-D-RA-WT-LS2 价格&库存
很抱歉,暂时无法提供与“QTS-075-02-H-D-RA-WT-LS2”相匹配的价格&库存,您可以联系我们找货
