S04B-JWPS-KES-ZR (LF)(SN) 数据手册
JWPS CONNECTOR
4.0mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
This JWPS connector can be used for the
place of which especially waterproof is
required.
This is the wire-to-board connector that is
grade 7 ingress protection of JIS C 0920
(IPX7 of IEC 60529).
• Waterproof performance
• Contained seal ring
• Solid rubber seal
• Double-spring construction
• Housing-to-terminal locks
• Mis-mating prevention key
• Current rating: 4 A AC, DC (AWG #22)
: 5 A AC, DC (AWG #20)
: 6 A AC, DC (AWG #18)
• Voltage rating: 300 V AC, DC
• Temperature range: -55˚C to +85˚C
(including temperature rise in applying
electrical current)
• Applicable wire: Conductor size/ AWG #22 to #18
Insulation O.D./ 1.75 to 2.5 mm
• Applicable PC board thickness: 1.6 mm
• Waterproof grade: Grade 7 ingress protection of JIS C 0920
(IPX7 of IEC 60529 )
(*Since the waterproof performance is not
available at the opposite side of mating
entrance, waterproof treatment is required,
if necessary.)
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Standards–––––––––––––––––––––––
Recognized E60389
Certified LR20812
2-φ1.8 ±0.05
φ2.1
±0.05
±0.05
±0.05
4.7
(17.6)
2
4
±0.05
9.4
±0.05
(33.7)
±0.05
(11.4)
4-φ1.1
4.5
±0.05
4
±0.05
(1.3)
(26.6)
Note: 1. The above figure is the figure viewed from the connector mounting side.
Note: 2. Hole dimensions differ according to the type of PC board and piercing method.
The dimensions above should serve as a guideline. Contact JST for details
1
4
4
2
2
JWPS CONNECTOR
Receptacle contact
Model No.
Applicable wire
AWG#
Insulation O.D.
(mm)
Q’ty /
reel
SJWPSR-21T-P1.0
22∼18
1.75∼2.5
4,500
Material and Finish
Copper alloy, tin-plated
RoHS compliance
14.8
(7.5)
(5.8)
JST 5
Crimping
machine Crimp applicator
Contact
SJWPSR-21T-P1.0 AP-K2N
MKS-L
Applicator
Dies
Crimp applicator with dies
MK/SJWPSR/T-21-10 APLMK SJWPSR/T21-10
Receptacle housing assembly
Circuits Keying
X
23.2
4
16.4
Y
Z
Model No.
04R-JWPS-VKLE-DX-A
04R-JWPS-VSLE-DY-A
04R-JWPS-VELE-DZ-A
Q’ty / box
400
400
400
7.4
X
11
Material
Receptacle housing: Glass-filled PBT, UL94V-0, X keying (black), Y keying (natural), Z keying (blue)
Retainer: PBT, UL94V-0, purple
Seal rubber plate: Silicone rubber, light blue
RoHS compliance
Note: Seal rubber plate and retainer are preassembled in receptacle housing
assembly.
0.8
4
6.2
16.7
11.6
3
2.5
1
Header housing assembly
Circuits Keying
X
4
Y
x
Z
Model No.
S04B-JWPS-KKS-XR
S04B-JWPS-KSS-YR
S04B-JWPS-KES-ZR
Q’ty / box
160
160
160
Material and Finish
Header housing: Glass-filled PBT, UL94V-0, black
Seal ring holder: Glass-filled PBT, UL94V-0, X keying (black), Y keying (natural), Z keying (blue)
Seal ring: Silicone rubber, brown
Tab contact: Copper alloy, tin-plated
26.6
11.4
RoHS compliance This product displays (LF)(SN) on a label.
Note: Seal ring and seal ring holder are preassembled in header housing
assembly.
16.8
6.2
16.4
3
1.4
3.3
1.5
1
4
4.5
4
(1.3)
12.8
2
S04B-JWPS-KES-ZR (LF)(SN) 价格&库存
很抱歉,暂时无法提供与“S04B-JWPS-KES-ZR (LF)(SN)”相匹配的价格&库存,您可以联系我们找货
