SEAF-30-06.0-S-05-1-A-K-TR 数据手册
HIGH-DENSITY
OPEN-PIN-FIELD ARRAYS
(1.27 mm) .050" PITCH
FEATURES & BENEFITS
• Maximum grounding & routing flexibility
• Up to 560 Edge Rate® contacts optimized for signal
integrity performance.
10 YEAR MFG
WITH 30 µ" GOLD
• 7 mm to 40 mm stack heights
• Variety of designs and options: Right-Angle, Guide Posts,
85 Ω Elevated Risers, 85 Ω Tuned, Press-Fit and Press-Fit
Right-Angle, Guide Post Field Termination Kits
• Cable mates (SEAC Series) and Jack Screw Standoffs
(JSO Series) also available
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
Solder Charges
MAXIMUM GROUNDING & ROUTING FLEXIBILITY
• Standards: VITA 47, VITA 57.1 FMC, VITA 57.4 FMC+,
VITA 74 VNX, PISMO™ 2
• Supports high-speed protocols such as Ethernet,
PCI Express®, Fibre Channel & InfiniBand™
• Severe Environment Testing qualified (SEAM/SEAF);
aligns with MIL-DTL-55302. Visit samtec.com/set
SERIES
INSULATOR
MATERIAL
CONTACT
MATERIAL
SEAM/SEAF
Black LCP
Copper Alloy
SEAM-RA/SEAF-RA
Black LCP
SEAM-GP
(1.12 mm) .044"
Nominal Wipe
Single-Ended
Power
CURRENT
RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
2.7 A
(10 pins powered)
240 VAC
Yes
Copper Alloy
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
1.9 A
(10 pins powered)
260 VAC
Yes
Black LCP
Copper Alloy
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
2.7 A
(10 pins powered)
240 VAC
Yes
SEAMP/SEAFP
Natural High
Temp Nylon
Copper Alloy
(SEAMP)
BeCu Alloy
(SEAFP)
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
1.9 A
(6 pins powered)
225 VAC
Not
Available
SEAR
Black LCP
Hard Gold
Plated
Contact Samtec
240 VAC
Not
Available
SEAMI
Black LCP
Copper Alloy
Not Available
Not
Available
Yes
PLATING
Au over 50 µ"
(1.27 µm) Ni
OPERATING
TEMP RANGE
Differential Pair
-55 °C to +125 °C
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
Note: Some lengths, styles and options
are non-standard, non-returnable
F-224
samtec.com/SEARAY
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(1.27 mm) .050" PITCH • SEAM/SEAF SERIES
SERIES
POSITIONS PER ROW
SEAM
–10, –15, –20, –30,
–40, –50
Terminal
SEAF
SEAM & SEAF: –10 only
available in -04 Row
Socket
LEAD
STYLE
PLATING
OPTION
NO. OF
ROWS
–L
Specify
LEAD
STYLE
from
chart
–04
= 10 µ" (0.25 µm)
Gold on contact area,
Matte Tin on solder tail
–05
–06
–S
SEAM: –15 only available in –04
Row with -02.0 Lead Style, and
–10 Row with any Lead Style
= 30 µ" (0.76 µm)
SEAF: –15 only available in –04
or –10 Row with –5.0 Lead Style
–STL
= 30 µ" (0.76 µm)
Tin/Lead on solder tail
–08
–10
- A - K - "X" R
SOLDER
TYPE
–1
–A
= Tin/Lead
Alloy Solder
Charge
= Alignment Pin
–K
–2
Polyimide Film Pick &
Place Pad
= Lead-Free
Solder
Charge
–TR
= Tape & Reel
(SEAM –04,
-05 & –06
Rows not
available
with –06.5
Lead Style)
SEAM
Board Mates:
SEAF, SEAFP
Standoffs:
JSO
B
No. of positions x (1.27) .050 + (4.98) .196
A
–FR
= Full Reel Tape & Reel
(must order max. quantity
per reel; contact Samtec
for quantity breaks)
LEAD
STYLE
A
–02.0
(5.61) .221
–03.0
(6.60) .260
NO. OF
ROWS
B
–04
(7.06) .278
–05, –06 (9.60) .378
–03.5
(7.11) .280
–08
(12.14) .478
–06.5
(10.16) .400
–10
(14.68) .578
–07.0
(10.59) .417
–09.0
(12.60) .496
–11.0
(14.61) .575
No. of positions x (1.27) .050 + (3.58) .141
View complete specifications at: samtec.com?SEAM
SEAF
Board Mates:
SEAM, SEAMP,
SEAR, SEAMI
Standoffs:
JSO
LEAD
STYLE
B
No. of positions x
(1.27) .050 + (5.82) .229
(1.27)
.050
A
NO. OF
ROWS
B
(5.66) .223
–05.0
(5.05) .199
–04
–06.0
(6.05) .238
–05, –06
(8.20) .323
–06.5
(6.55) .258
–08
(10.74) .423
–07.5
(7.54) .297
–10
(13.28) .523
A
STANDARDS
No. of positions x
View complete specifications at: samtec.com?SEAF
MATED HEIGHTS
SEAM LEAD STYLE
ALSO AVAILABLE
See website for 14 row option.
VITA 47
VITA 57.1 FMC
VITA 57.4 FMC+
VITA 74 VNX
SEAF LEAD STYLE
–05.0
–06.0
–06.5
–07.5
PISMOTM 2
–02.0
7 mm
8 mm
8.5 mm
9.5 mm
–03.0
8 mm
9 mm
9.5 mm
10.5 mm
Visit www.samtec.com/standards
for more information.
8.5 mm
9.5 mm
10 mm
11 mm
–06.5
11.5 mm
12.5 mm
13 mm
14 mm
12 mm
13 mm
13.5 mm
14.5 mm
14 mm
15 mm
15.5 mm
16.5 mm
16 mm
17 mm
17.5 mm
18.5 mm
–03.5
–07.0
–09.0
–11.0
Notes:
IPC-A-610F and
IPC J-STD-001F Class 3 solder joint.
Severe Environment Testing qualified; aligns
samtec.com/SEARAY
F-224
SEAF-30-06.0-S-05-1-A-K-TR 价格&库存
很抱歉,暂时无法提供与“SEAF-30-06.0-S-05-1-A-K-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 225+142.88079225+18.46886
