SEAM-50-01-S-06-2-RA-GP-TR 数据手册
HIGH-DENSITY
OPEN-PIN-FIELD ARRAYS
(1.27 mm) .050" PITCH
FEATURES & BENEFITS
• Maximum grounding & routing flexibility
• Up to 560 Edge Rate® contacts optimized for signal
integrity performance.
10 YEAR MFG
WITH 30 µ" GOLD
• 7 mm to 40 mm stack heights
• Variety of designs and options: Right-Angle, Guide Posts,
85 Ω Elevated Risers, 85 Ω Tuned, Press-Fit and Press-Fit
Right-Angle, Guide Post Field Termination Kits
• Cable mates (SEAC Series) and Jack Screw Standoffs
(JSO Series) also available
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
Solder Charges
MAXIMUM GROUNDING & ROUTING FLEXIBILITY
• Standards: VITA 47, VITA 57.1 FMC, VITA 57.4 FMC+,
VITA 74 VNX, PISMO™ 2
• Supports high-speed protocols such as Ethernet,
PCI Express®, Fibre Channel & InfiniBand™
• Severe Environment Testing qualified (SEAM/SEAF);
aligns with MIL-DTL-55302. Visit samtec.com/set
SERIES
INSULATOR
MATERIAL
CONTACT
MATERIAL
SEAM/SEAF
Black LCP
Copper Alloy
SEAM-RA/SEAF-RA
Black LCP
SEAM-GP
(1.12 mm) .044"
Nominal Wipe
Single-Ended
Power
CURRENT
RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
2.7 A
(10 pins powered)
240 VAC
Yes
Copper Alloy
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
1.9 A
(10 pins powered)
260 VAC
Yes
Black LCP
Copper Alloy
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
2.7 A
(10 pins powered)
240 VAC
Yes
SEAMP/SEAFP
Natural High
Temp Nylon
Copper Alloy
(SEAMP)
BeCu Alloy
(SEAFP)
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
1.9 A
(6 pins powered)
225 VAC
Not
Available
SEAR
Black LCP
Hard Gold
Plated
Contact Samtec
240 VAC
Not
Available
SEAMI
Black LCP
Copper Alloy
Not Available
Not
Available
Yes
PLATING
Au over 50 µ"
(1.27 µm) Ni
OPERATING
TEMP RANGE
Differential Pair
-55 °C to +125 °C
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
Note: Some lengths, styles and options
are non-standard, non-returnable
F-224
samtec.com/SEARAY
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(1.27 mm) .050" PITCH • RIGHT-ANGLE & GUIDE POST
SERIES
POSITIONS
PER ROW
SEAM
- 01 -
–20
Right-Angle
Terminal
SEAF
–L
–40
= 30 µ" (0.76 µm)
Gold on contact
area, Matte Tin on
solder tail
SEAM-RA
- RA -
SOLDER
TYPE
–04
–1
–08
-08 & -10
Row options
require
fixturing to
process
–K
–LP
:LWKRXW²*3 1RRISRVLWLRQV[
SEAF-RA
Board Mates:
SEAM, SEAMP
–FR
= Full Reel
Tape &
Reel (must
order max.
quantity per
reel; contact
Samtec for
quantity
breaks)
Latch Post
(Available with
SEAF in -06 Row
with 30 positions
only; Required for
mating to SEAC)
²*3 1RRISRVLWLRQV[
Board Mates:
SEAF, SEAF-RA,
SEAFP
= Tape &
Reel
= Polyimide Film
Pick & Place Pad
= Lead-Free
Solder Charge
"X"R
–TR
= Guide Post/Hole
–2
–10
OPTIONS
–GP
= Tin/Lead
Alloy Solder
Charge
–06
–S
–50
NO. OF
ROWS
= 10 µ" (0.25 µm)
Gold on contact
area, Matte Tin on
solder tail
–30
Right-Angle
Socket
PLATING
OPTION
B
A
–GP = No. of positions x (1.27) .050 + (19.56) 0.77
Without –GP = No. of positions x (1.27) .050 + (9.40) 0.37
NO.PINS
PER ROW
A
–04
(13.77) .542
(7.91) .311
–06
(16.31) .642
(10.45) .411
B
–08
(18.85) .742
(12.99) .511
–10
(21.39) .842
(15.53) .611
View complete specifications at: samtec.com?SEAM-RA & samtec.com?SEAF-RA
SERIES
SEAM
Terminal
with Guide
post
SEAM-GP
Board Mates:
SEAF-RA-GP
POSITIONS
PER ROW
–20, –30,
–40, –50
02.0
PLATING
OPTION
NO. OF
ROWS
–L
–04
–S
–08
= 10 µ" (0.25 µm)
Gold on contact area,
Matte Tin on solder tail
= 30 µ" (0.76 µm)
SOLDER
TYPE
–1
–06
= Tin/Lead
Alloy Solder
Charge
–10
= Lead-Free
Solder Charge
–2
No. of positions x (1.27) .050 + (19.46) .766
(12.65)
.498
- A - GP -
K
"X"R
–TR
= Tape &
Reel
–FR
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact
Samtec for
quantity
breaks)
(5.54)
.218
Note: Some lengths,
styles and options
are non-standard,
non-returnable
samtec.com/SEARAY
F-224
SEAM-50-01-S-06-2-RA-GP-TR 价格&库存
很抱歉,暂时无法提供与“SEAM-50-01-S-06-2-RA-GP-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 125+317.02840125+41.03603
