F-224 WEB
SEI–110–02–GF–S–E–TR
SEI–120–02–GF–S
SIBF–05–F–S–AD
(1.00 mm) .0394"(SEI) (1.27 mm) .050"(SIBF)
SIBF–25–F–S–AD
SIBF–10–F–S–AD
SEI, SIBF SERIES
ONE-PIECE INTERFACE
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?SEI or see
www.samtec.com?SIBF
Insulator Material:
SEI = Liquid Crystal Polymer
SIBF = Black Liquid
Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
SEI = Au over
50 µ" (1.27 µm) Ni
SIBF = Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
SEI = 2.3 A per pin
(1 pin powered)
SIBF = 2.5 A per pin
(1 pin powered)
Operating Temp Range:
-55 °C to +125 °C
Mating Force:
SEI = 50 g (0.49 N) per contact
Voltage Rating:
SEI = 250 VAC
SIBF = 155 VAC
Cycles:
SEI = 100 min
Contact Deflection:
SEI = (0.46 mm) .018" nominal
RoHS Compliant:
Yes
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity (SEI):
(0.10 mm) .004" max (05-25)
(0.15 mm) .006" max (30)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
SMT Lead Coplanarity (SIBF):
(0.10 mm) .004" max (05-20)
(0.15 mm) .006" max (25)*
ipg@samtec.com)
NO. OF
1 POSITIONS
SEI
S
–G
05, 10, 15,
20, 25, 30
= 10 µ" (0.25 µm) Gold
–GF
(Standard sizes)
= 3 µ" (0.08 µm) Gold flash
No. of positions x
(1.00) .03937 + (0.41) .016
INSERT
OPTION
ALIGNMENT
OPTION
Leave blank
for Short
Version
(No screw
down inserts
or holes)
Leave blank for
no Alignment Pin
OTHER
OPTION
–TR
= Tape &
Reel
–AT
–FR
= Alignment Pin
Top Side
= Full Reel
Tape &
Reel
= #2-56 x 1/16"
= Alignment Pin
(must
screw thread
Bottom Side
order max.
quantity
per reel;
(0.89)
= 2.00 mm
.035
Contact
x 0.40 mm
DIA
(1.27) Samtec
screw thread
.050
for
(4.32)
(1.27)
quantity
.170
.050
breaks)
–E
–AB
–M
(6.10) (4.95)
.240 .195
01
SHORT VERSION
(0.31) .012
(1.65)
.065
((No. of positions-1) x
(1.00) .03937) + (7.62) .300
(1.27)
.050
(0.15) .006 (0.46)
.018
–AT OPTION
(4.32)
.170
(0.89)
.035 DIA
–AB OPTION
(3.43)
.135
SIBF
Threaded
Insert (2)
INSERT OPTIONS
NO. OF
POSITIONS
PLATING
OPTION
–F
For complete scope of
recognitions see
www.samtec.com/quality
S
= Flash Gold,
Matte Tin on tail
–05, –10, –20, –25
RECOGNITIONS
FILE NO. E111594
PLATING
OPTION
02
OPTION
–AD
= Top & Bottom Alignment Pin
No. of positions x
(1.27) .050 + (0.43) .017
(6.25)
.246
(1.27)
.050
ALSO AVAILABLE
(7.50)
.295
(MOQ Required)
• Additional positions
• Top or bottom side only alignment pin
(0.70)
.028
(4.00)
.158
(3.00)
.118
No. of positions
x (1.27) .050
- (3.81) .150
(1.00)
.040
–AD OPTION
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“SEI-127-02-G-S-AB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 21+66.4153721+8.63379
