SFM-105-L1-S-D-LC
SFM-105-L1-S-D-LC
    SAMTEC(申泰)
    插件,P=1.27mm
    排母 间距:1.27mm 插件
SFM-105-L1-S-D-LC 数据手册
SFM–110–02–L–D–A F-219 (Rev 23JAN19) SFML–125–T2–L–D–LC SFML–115–T2–L–D–LC SFM–125–02–L–SH (1.27 mm) .050" SMT & THROUGH-HOLE TIGER EYE SOCKET ™ SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SFM or www.samtec.com?SFML Insulator Material: Black Liquid Crystal Polymer Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (SFM/TFM): 3.2 A per pin (2 pins powered) Voltage Rating: 250 VAC mated with TFM Operating Temp Range: -55 °C to +125 °C Insertion Depth: (3.05 mm) .120" to (4.06 mm) .160" Wiping Distance: (0.38 mm) .015" Normal Force: Standard= 132 g (1.29 N) avg.; LIF= 90 g (0.88 N) avg. Max Cycles: 10,000 with 30 µ" (0.76 µm) Au (Call Samtec for E.L.P.™ plating option) RoHS Compliant: Yes PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (05-25) (0.15 mm) .006" max (30-50)* *(.004" stencil solution may be available; contact IPG@samtec.com) RECOGNITIONS Low insertion force Tiger Eye™ contacts available SFM Board Mates: TFM SFM Cable Mates: TFSD, TFSS SFML Board Mates: TFML (1.27 mm x 1.27 mm) .050" x .050" micro pitch • Passes 10 Year MFG 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT (Surface Mount) 05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 = Tiger Eye™ Contact (BeCu) (1.27) .050 x No. of Positions + (0.38) .015 02 (2.41) .095 –01, –03 = Tiger Eye™ Contact (BeCu) –L2 –L1, –L3 = Low Insertion Force Tiger Eye™ Contact (BeCu) (1.78) .070 = Low Insertion Force Tiger Eye™ Contact (BeCu) –T2 = Tiger Eye™ LITE Contact (Phosphor Bronze) 01 (1.27) .050 TYP SINGLE ROW (1.27) .050 x No. of Positions + (3.94) .155 except for alignment pin option: (1.27) .050 x No. of Positions + (3.17) .125 (2.03) .080 02 (3.68) .145 01 DOUBLE ROW (2.41) .095 (4.70) .185 (3.37) .133 (0.58) .023 (2.26) .089 –SH (–02 only) (3.68) .145 (9.78) .385 (0.13) .005 TYP (3.05) .120 (4.19) .165 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM (9.78) .385 (1.27) .050 (2.79) .110 (0.51) .020 –T1 = Tiger Eye™ LITE Contact (Phosphor Bronze) (1.78) .070 (3.05) .120 (1.27) .050 TYP (3.18) .125 (Through-hole) –02 (Standard sizes) = Locking 8 G b p s LEAD STYLE (SFM only) SFML HIGH-SPEED CHANNEL PERFORMANCE Rating based on Samtec reference channel. For full SI performance data visit Samtec.com or contact SIG@samtec.com 03, 04, 06, 08 SFM For complete scope of recognitions see www.samtec.com/quality Note: Some sizes, styles and options are non-standard, non-returnable. • Screw Down option NO. PINS PER ROW 1 = Standard FILE NO. E111594 • Locking clip option Choice of SMT or through-hole tails HIGH MATING CYCLES TYPE STRIP • Locking option Locking feature increases unmating force (SFML) All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. (4.64) .183 (2.26) .089 –DH (–02 only) SFM–120–L3–L–D SFM–110–01–L–D–A SFM–110–02–L–D–DS SFM–105–L3–L–D SFML–115–T1–L–D–LC SFM–115–02–L–DH SFM, SFML SERIES Mates with TFM for coplanar and perpendicular mating Screw down option High-reliability Tiger Eye™ contacts Surface mount or Through-hole tails (1.27 mm x 1.27 mm) .050" x .050" micro pitch ALSO AVAILABLE (MOQ Required) OTHER SOLUTIONS • Solder nail option • Other sizes • Other platings • Lower cost plating options. See SFC Series. ROW OPTION PLATING OPTION –S –L –D 02 (3.68) .145 = Dual Screw Down for (1.60 mm) .062" PCB (05 thru 40 positions only) (Lead styles –01, –02 & –03 only) (Requires –D row option) (Not available with SFML) (Mates with TFM-DS option) (Not available with –A, –LC, –K, –P, –TR) = Double Horizontal (05 thru 30 positions only) (SFM only) (Lead style –02 only) (1.27) .050 (3.68) .145 (3.05) .120 01 (8.50) .335 Specify only –K or –P (Lead styles –02, –L2, –T2 only) –K = Polyimide film Pick & Place Pad (Not available with –DH, –SH) –P = Plastic Pick & Place Pad (Not available with –DH, –SH) Specify –TR last (Lead styles –02, –L2, –T2 only) –TR = Tape & Reel (Required callout for –DH, –SH) (1.78) .070 DOUBLE ROW (2.41) .095 (0.13) .005 TYP –DS –DH (1.27) .050 TYP (3.68) .145 (4.57) .180 = Locking Clip (Available with all lead styles) (Manual placement required) = Single Horizontal (05 thru 30 positions only) (SFM only) (Lead style –02 only) (1.78) .070 (1.27) .050 x No. of Positions + (3.94) .155 except for alignment pin option: (1.27) .050 x No. of Positions + (3.17) .125 (2.03) .080 (1.27) .050 TYP –LC –SH (1.27) .050 x No. of Positions + (0.38) .015 SINGLE ROW –A = Alignment Pin (Available with all lead styles) = Double Row LEAD STYLE A B –01, –L1, –T1 (3.05) .120 (0.51) .020 (1.91) .075 (0.41) .016 –03, –L3 01 Specify only –A, –LC or –DS (Not available with –DH, –SH) = Single Row (SFM only) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (Call Samtec for E.L.P.™ plating option) (2.41) .095 OPTION –DS (–D, –01 –02 & –03) (1.65) .065 (1.27) .050 (2.79) .110 A B (1.27) .050 DIA (1.59) .063 –A (1.41) x (0.25) .056 .010 –LC Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
SFM-105-L1-S-D-LC 价格&库存
很抱歉,暂时无法提供与“SFM-105-L1-S-D-LC”相匹配的价格&库存,您可以联系我们找货
SFM-105-L1-S-D-LC
  • 1+23.390461+3.03020
  • 25+20.5721325+2.66509
  • 50+18.2498750+2.36424
  • 100+16.30024100+2.11167
  • 500+16.20283500+2.09905
库存:39
