AW-16-03-G-D-122-100-P-TR
    SAMTEC(申泰)
    SMD,P=0.8mm
    排针 间距:0.8mm 2x16P SMT
AW-16-03-G-D-122-100-P-TR 数据手册
SMT MICRO BOARD STACKER (0.80 mm) .0315" PITCH • AW SERIES AW AW Mates: CLE SPECIFICATIONS Insulator Material: Top: Black LCP Bottom: Natural LCP Terminal Material: Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C - NO. PINS PER ROW 05 thru 90 - 03 - PLATING OPTION -D- –G STACKER HEIGHT –“XXX” = 10 µ" (0.25 µm) Gold = Stacker Height (in inches) (3.09 mm) .122" to (5.84 mm) .230" Example: –175 = (4.45 mm) .175" PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (05-40) (0.15 mm) .006" max (41-90)* *(.004" stencil solution may be available; contact ipg@samtec.com) - POST HEIGHT - –“XXX” = Post Height (in inches) (1.91 mm) .075" minimum Example: –075 = (1.91 mm) .075" OTHER OPTION –ES = End Shroud 11 pins/row min. (–075 Post Height only) –EP = End Shroud with Guide Post (–075 Post Height only) 11 pins/row min. –A = Alignment Pin (4 positions min.) (Available for board stacks between (4.06 mm) .160" to (5.84 mm) .230") (Metal or plastic at Samtec discretion.) No. of positions x (0.80) .0315 (3.05) .120 –P = Pick & Place Pad (8 positions min.) –TR = Tape & Reel (84 positions max.) OPTIONS –EP OPTION –P OPTION POST HEIGHT (7.75) .305 MAX OVERALL LENGTH STACKER HEIGHT (3.09) .122 to (5.84) .230 (1.91) .075 MIN (1.40) .055 –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (84 positions max.) (1.70) .067 (4.57) .180 –ES OPTION (4.17) .164 (3.56) .140 Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. Some lengths, styles and options are non-standard, non-returnable. –EP OPTION –ES OPTION –P OPTION samtec.com?AW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
AW-16-03-G-D-122-100-P-TR 价格&库存
很抱歉,暂时无法提供与“AW-16-03-G-D-122-100-P-TR”相匹配的价格&库存,您可以联系我们找货
