B03B-PASK-1-GU
B03B-PASK-1-GU
    JST
    B03B-PASK-1-GU
B03B-PASK-1-GU 数据手册
PA ラジアル FAMILY SERIES/PA•PAF•PAL CONNECTOR 2.0mm pitch/Wire-to-board (Crimp style/IDC) / Wire-to-wire (Crimp style/IDC) Standards –––––––––––––––––––––– 0 Retainer PA Receptacle (Crimp style Standard type) Retainer Retainer PAF Receptacle (IDC style) PA Shorouded header (Top entry type) PAF Receptacle (IDC style) PAL (Crimp style Wire-to-wire) PA Receptacle (Crimp style   Retainer    mountable type) PA Shorouded header (Side entry type) PA Shorouded header (Top entry type) Retainer Based upon wire-to-board crimp style PA connectors, the PA series family of connector have been expanded to meet the requirement of complex wire harness of 2.0mm pitch connectors with secure locking mechanism thanks to the additional line up of wire-to-board IDC style PAF connectors and wire-to-wire crimp style PAL connectors. • Secure locking device • Interchangeable between crimp and IDC socket • Secondary retainers • Harness variation PA connector (Standard type, Retainer mountable type) • Highly reliable contact • Insertion guide mechanism • Flanged press pin Recognized E60389 1 Certified LR20812 Specifications ––––––––––––––––––– PA Connector (Standard type) • Current rating: 3A AC, DC (AWG #22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: Initial/1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #28 to #22 • Applicable PC board thickness: 1.6mm PA Connector (Retainer mountable type) • Current rating: 3A AC, DC (AWG #22) • Voltage rating: 100V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/15m Ω max. After environmental testing/25m Ω max. • Insulation resistance: Initial/1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #28 to #22 PAF Connector • Current rating: 1.0A AC, DC (AWG #26) • Voltage rating: 100V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/15m Ω max. After environmental testing/25m Ω max. • Insulation resistance: Initial/1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: UL1061(Contact JST for details regarding other UL wires.) AWG #26 Conductor/7 strands, tin-coated annealed copper Insulation O.D./0.9 to 1.0mm PAL Connector PAF connector • The industry’s first secure lock ID connectors • Metallic strain relief • Retainer with four locking points PAL connector • The industry’s first wire to wire 2.0mm pitch retainer mountable type connector. • Either with or without panel lock can be selected according to application. 406 • Current rating: 3A AC, DC (AWG #22) • Voltage rating: 100V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/15m Ω max. After environmental testing/25m Ω max. • Insulation resistance: Initial/1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #28 to #22 • Applicable panel thickness : 0.5 to 2.0mm * RoHS compliant products are published. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. PA FAMILY SERIES /PA•PAF•PAL CONNECTOR List of combinations Crimp style Standard type Top entry type Shrouded header Contact Side entry type B( )B-PASK SPHD-001T-P0.5 B( )B-PASK-1 SPHD-002T-P0.5 S( )B-PASK-2 Housing PAP-( )V-S High box type Shrouded header BH( )B-PASK BH( )B-PASK-1 Crimp style Retainer mountable type Contact Shrouded header SPA-001T-P0.5 BM( )B-PASS Housing BM( )B-PASS-1 PARP-( )V SM( )B-PASS Retainer SM( )B-PASS-1 SMT type Top entry type Side entry type PMS-( )V-S Insulation displacement type Wire to wire Connectors Receptacle Contact ( )PAF-6S SPAL-001T-P0.5 Retainer SPAL-002T-P0.5 PAFS-( )V-S Receptacle housing PALR-( )V(F) Retainer PMS-( )V-S PC board layout (viewed from component side) and Assembly layout Through-hole type Top entry type (5.8) 7.2 1.5 ±0.05 9.8 φ1.1+0.1  0 2.0 ±0.05 1.7±0.05 φ0.7 +0.1  0 PA Receptacle + PA Header (Standard type) (14.9) A±0.05 (14.7)retainer included 5.8 PA Receptacle + PA Header (Retainer mountable type) PAF Receptacle + PA Header Side entry type (18.8)retainer included φ0.7+0.1  0 (8.4) 2.0±0.05 2.1±0.05 φ1.1 1.5±0.05 7.0 A±0.05 +0.1  0 8.2 PA Receptacle + PA side entry type header (Standard type) (18.9) 8.2 PA Receptacle + PA side entry type header (Retainer mountable type) (7.0) 13.8 8.2 PAF Receptacle + PA side entry type header Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 407 PA FAMILY SERIES /PA•PAF•PAL CONNECTOR PC board layout (viewed from component side) and Assembly layout SMT type Top entry type (7.6) 2.2±0.05 φ0.8+0.1  0 MIN 1.0 3.6±0.1 4.9±0.1 MIN R0.4 +0.1 0 Connector outline 2.0±0.05 (16.2) A±0.1 11.1 1.7±0.1 5.0±0.1 2.9 1.0±0.1 (1.4) (1.4) (16.0)retainer included (6.2) (6.2) (1.4) 1.8±0.1 1.45±0.1 PA Receptacle + PA Header (Standard type) PA Receptacle + PA Header (Retainer mountable type) PAF Receptacle + PA Header Side entry type 1.45±0.1 1.8±0.1 (1.1) (16)retainer included 8.9 1.0±0.1 PA Receptacle + PA side entry type header (SMT) (Standard type) 5.7 (7.6) PA Receptacle + PA side entry type header (SMT) (Retainer mountable type) (16.2) 8.9 (6.2) φ0.8+0.1  0 2.2±0.05 1.7±0.1 (1.1) 5.7 (6.2) 11.1 8.9 5.7 R0.4 +0.1 0 (1.1) 7.95±0.1 3.8±0.1 2.8 Connector outline 2.7 MIN 7.8±0.1 A±0.1 2.0±0.05 MIN 1.0 PAF Receptacle + PA side entry type header (SMT) Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. High box type 7.1 7.2 A ±0.05 1.5 ±0.05 φ1.1 +0.1  0 15.9 2.0 ±0.05 1.7 ±0.05 φ0.7 +0.1  0 PA Receptacle + PA high box type header (Standard type) 20.9 (20.7)retainer included 7.1 PA Receptacle + PA high box type header (Retainer mountable type) PAF Receptacle + PA high box type header Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Wire-to-wire PA Receptacle + PAL Receptacle (Standard type) 408 PA Receptacle + PAL Receptacle (Retainer mountable type) PAF Receptacle + PAL Receptacle retainer included (8.9) (26)retainer included retainer included retainer included (8.4) (25.8)retainer included (7.6) (21.5)retainer included PA FAMILY SERIES /PA CONNECTOR (Crimp style Standard type) Contact Applicable wire mm2 AWG # Insulation O.D. (mm) Q'ty / reel SPHD-001T-P0.5 0.13∼0.33 26∼22 1.0∼1.5 8,000 SPHD-002T-P0.5 0.08∼0.21 28∼24 0.9∼1.5 8,000 1.5 Model No. Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS compliance 6.5 2.85 1.3 Contact Applicator Crimping machine Crimp applicator Dies Crimp applicator with dies MKS-LS-10・MKS-L-10 MK/SPHD-002-05 SPHD-002T-P0.5 AP-K2N SPHD-001T-P0.5 *MKS-SC-10 APLMK SPHD002-05 SC/SPHD-002-05 APLSC SPHD002-05 MKS-LS-10・MKS-L-10 MK/SPHD-001-05 APLMK SPHD001-05 *MKS-SC-10 SC/SPHD-001-05 APLSC SPHD001-05 Note:*Strip-crimp applicator Housing (2 to 9 circuits) Circuits B (2.0) 2.0 (2.0) 2.0 8.0 5.8 4.6 7.3 A Q'ty / bag PAP-02V-S 2.0 6.0 1,000 PAP-03V-S 4.0 8.0 1,000 4 PAP-04V-S 6.0 10.0 1,000 5 PAP-05V-S 8.0 12.0 1,000 6 PAP-06V-S 10.0 14.0 1,000 7 PAP-07V-S 12.0 16.0 1,000 8 PAP-08V-S 14.0 18.0 1,000 9 PAP-09V-S 16.0 20.0 1,000 10 PAP-10V-S 18.0 22.0 1,000 11 PAP-11V-S 20.0 24.0 1,000 12 PAP-12V-S 22.0 26.0 1,000 13 PAP-13V-S 24.0 28.0 1,000 14 PAP-14V-S 26.0 30.0 1,000 15 PAP-15V-S 28.0 32.0 1,000 16 PAP-16V-S 30.0 34.0 1,000 8.0 B B 3 Circuit No.1 (10 to 15 circuits) A 2 5.8 4.6 7.3 A Dimensions (mm) Model No. Circuit No.1 Material (16 circuits) PA 66, UL94V-0, natural (white) B (2.0) 2.0 Circuit No.1 5.8 4.6 8.0 7.3 A RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PAP-02V-SS…natural (white) K…black R…red E…blue M…green O…orange N…brown P…purple PK…pink Y…yellow L…lemon yellow FY…vivid yellow LE…light blue H…gray TR…tomato red 409 PA FAMILY SERIES Through-hole type shrouded header Side entry type (2 to 9 circuits) (2 to 9 circuits) A Circuit No.1 B A 5.3 6.5 (3.4) 6.5 (3.4) 6.1 (3.4) 5.9 7.7 7.7 6.5 3.0 1.2 5.9 2.0 φ0.8 (10 to 15 circuits) 1.7 Circuit No.1 1.5 (10 to 15 circuits) B 2.0 5.3 5.9 3.0 1.2 7.7 Circuit No.1 7.7 A B A Circuit No.1 φ0.8 0.5 (16 circuits) 2.0 1.7 (16 circuits) 1.5 B A B A 2.0 Circuit No.1 φ0.8 2.0 6.1 8.2 11.7 5.9 7.7 5.9 Circuit No.1 3.0 1.2 7.7 5.3 0.5 1.7 1.5 Top entry type Circuits 6.1 2.0 5.9 0.5 8.2 11.7 B 8.2 11.7 Top entry type Side entry type Model No. Without a boss 2(Note1) B02B-PAFYK-A With a boss Dimensions (mm) A B Q'ty / box Circuits B02B-PAFYK-1A 2.0 6.0 1,000 2 2 B02B-PASK B02B-PASK-1 2.0 6.0 1,000 3 3 B03B-PASK B03B-PASK-1 4.0 8.0 1,000 4 4 B04B-PASK B04B-PASK-1 6.0 10.0 1,000 5 5 B05B-PASK B05B-PASK-1 8.0 12.0 500 6 6 B06B-PASK B06B-PASK-1 10.0 14.0 500 7 7 B07B-PASK B07B-PASK-1 12.0 16.0 500 8 8 B08B-PASK B08B-PASK-1 14.0 18.0 500 9 9 B09B-PASK B09B-PASK-1 16.0 20.0 500 10 10 B10B-PASK B10B-PASK-1 18.0 22.0 500 11 11 B11B-PASK B11B-PASK-1 20.0 24.0 250 12 12 B12B-PASK B12B-PASK-1 22.0 26.0 250 13 13 B13B-PASK B13B-PASK-1 24.0 28.0 250 14 14 B14B-PASK B14B-PASK-1 26.0 30.0 250 15 15 B15B-PASK B15B-PASK-1 28.0 32.0 250 16 16 B16B-PASK B16B-PASK-1 30.0 34.0 250 Model No. S02B-PASK-2 S03B-PASK-2 S04B-PASK-2 S05B-PASK-2 S06B-PASK-2 S07B-PASK-2 S08B-PASK-2 S09B-PASK-2 S10B-PASK-2 S11B-PASK-2 S12B-PASK-2 S13B-PASK-2 S14B-PASK-2 S15B-PASK-2 S16B-PASK-2 Dimensions (mm) A B Q'ty / box 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 500 8.0 12.0 500 10.0 14.0 500 12.0 16.0 250 14.0 18.0 250 16.0 20.0 250 18.0 22.0 250 20.0 24.0 250 22.0 26.0 250 24.0 28.0 200 26.0 30.0 200 28.0 32.0 200 30.0 34.0 200 Material and Finish Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) (Note1) PA 66, UL94V-0, vivid yellow RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 410 B02B-PASKS…natural (white) K…black R…red E…blue M…green O…orange N…brown P…purple PK…pink Y…yellow L…lemon yellow FY…vivid yellow LE…light blue H…gray TR…tomato red Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. S03B-PASK-2S…natural (white) K…black R…red E…blue M…green O…orange N…brown P…purple PK…pink Y…yellow L…lemon yellow LE…light blue H…gray TR…tomato red PA FAMILY SERIES SMT type shrouded header Side entry type Top entry type (2 to 3 circuits) (2 to 3 circuits) B B A A 2.0 5.7 2.0 7.1 7.1 1.8 1.8 5.7 Circuit No.1 Circuit No.1 (4 to 9 circuits) (4 to 9 circuits) B B A A 2.0 5.7 2.0 7.1 7.1 1.8 1.8 5.7 Circuit No.1 Circuit No.1 (10 to 12 circuits) (10 to 13 circuits) B B A A 2.0 2.0 5.7 7.1 7.1 1.8 1.8 5.7 Circuit No.1 Circuit No.1 Side entry type Top entry type Model No. Dimensions(mm) Q'ty / reel Circuits 8.0 500 10.0 500 12.0 8.0 BM06B-PASS-1-(*) BM07B-PASS-(*) 8 Circuits Without a boss With a boss A 2 BM02B-PASS-(*) BM02B-PASS-1-(*) 2.0 3 BM03B-PASS-(*) BM03B-PASS-1-(*) 4.0 4 BM04B-PASS-(*) BM04B-PASS-1-(*) 6.0 5 BM05B-PASS-(*) BM05B-PASS-1-(*) 6 BM06B-PASS-(*) 7 B Model No. Dimensions(mm) With a boss 2 SM02B-PASS-(*) SM02B-PASS-1-(*) 2.0 8.0 1,000 3 SM03B-PASS-(*) SM03B-PASS-1-(*) 4.0 10.0 1,000 500 4 SM04B-PASS-(*) SM04B-PASS-1-(*) 6.0 12.0 1,000 14.0 500 5 SM05B-PASS-(*) SM05B-PASS-1-(*) 8.0 14.0 1,000 10.0 16.0 500 6 SM06B-PASS-(*) SM06B-PASS-1-(*) 10.0 16.0 1,000 BM07B-PASS-1-(*) 12.0 18.0 500 7 SM07B-PASS-(*) SM07B-PASS-1-(*) 12.0 18.0 1,000 BM08B-PASS-(*) BM08B-PASS-1-(*) 14.0 20.0 500 8 SM08B-PASS-(*) SM08B-PASS-1-(*) 14.0 20.0 1,000 9 BM09B-PASS-(*) BM09B-PASS-1-(*) 16.0 22.0 500 9 SM09B-PASS-(*) SM09B-PASS-1-(*) 16.0 22.0 1,000 10 BM10B-PASS-(*) BM10B-PASS-1-(*) 18.0 24.0 500 10 SM10B-PASS-(*) SM10B-PASS-1-(*) 18.0 24.0 1,000 11 BM11B-PASS-(*) BM11B-PASS-1-(*) 20.0 26.0 500 11 SM11B-PASS-(*) SM11B-PASS-1-(*) 20.0 26.0 1,000 12 BM12B-PASS-(*) BM12B-PASS-1-(*) 22.0 28.0 500 12 SM12B-PASS-(*) SM12B-PASS-1-(*) 22.0 28.0 1,000 13 BM13B-PASS-(*) BM13B-PASS-1-(*) 24.0 30.0 500 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Note: (*): TF…taping product TFT…taping product with suction tape. A B Q'ty / reel Without a boss Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Note: (*): TB…taping product TBT…taping product with suction tape. 411 PA FAMILY SERIES Shrouded header (2 circuits) (5, 6 circuits) B A 7.1 5.3 7.1 5.3 2.0 3.0 3.0 13.9 13.9 B A Circuit No.1 Circuit No.1 (3 circuits) (7 to 9 circuits) B A 2.0 B A 7.1 5.3 7.1 5.3 3.0 3.0 13.9 13.9 2.0 Circuit No.1 Circuit No.1 (4 circuits) (10 to 12, 15 circuits) B A B A 7.1 5.3 7.1 5.3 2.0 3.0 3.0 13.9 13.9 2.0 Circuit No.1 Circuit No.1 Circuits 2 3 4 5 6 7 8 9 10 11 12 15 Model No. Without a boss BH02B-PASK BH03B-PASK BH04B-PASK BH05B-PASK BH06B-PASK BH07B-PASK BH08B-PASK BH09B-PASK BH10B-PASK BH11B-PASK BH12B-PASK BH15B-PASK With a boss BH02B-PASK-1 BH03B-PASK-1 BH04B-PASK-1 BH05B-PASK-1 BH06B-PASK-1 BH07B-PASK-1 BH08B-PASK-1 BH09B-PASK-1 BH10B-PASK-1 BH11B-PASK-1 BH12B-PASK-1 BH15B-PASK-1 Dimensions(mm) B 2.0 6.0 900 4.0 8.0 675 6.0 10.0 525 8.0 12.0 450 10.0 14.0 375 12.0 16.0 325 14.0 18.0 300 16.0 20.0 250 18.0 22.0 225 20.0 24.0 225 22.0 26.0 200 28.0 32.0 150 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) RoHS compliance This product displays (LF)(SN) on a label. 412 Q'ty / box A PA FAMILY SERIES /PA CONNECTOR (Crimp style Retainer mountable type) Contact Applicable wire mm2 AWG # Insulation O.D. (mm) Q'ty / reel 0.13∼0.33 26∼22 0.9∼1.5 10,000 Model No. 1.5 SPA-001T-P0.5 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 8.4 2.85 1.3 2.2 RoHS compliance Contact SPA-001T-P0.5 Applicator Crimping machine Crimp applicator AP-K2N Dies Crimp applicator with dies MKS-L MK/SPA-001-05 APLMK SPA001-05 ― ― ― Housing (2 circuits) (3 circuits) B A B A 2.0 11.4 Circuit No.1 Circuit No.1 (4 circuits) (5 circuits) B A B A 7.2 7.2 2.0 Q'ty / bag PARP-02V 2.0 5.4 1,000 PARP-03V 4.0 7.4 1,000 4 PARP-04V 6.0 9.4 1,000 5 PARP-05V 8.0 11.4 1,000 6 PARP-06V 10.0 14.0 1,000 7 PARP-07V 12.0 16.0 1,000 8 PARP-08V 14.0 18.0 1,000 9 PARP-09V 16.0 20.0 1,000 10 PARP-10V 18.0 22.0 1,000 *15 PARP-15V 28.0 32.0 500 2 3 11.4 11.4 2.0 B Model No. 7.2 11.4 7.2 Material PA 66, UL94V-0, natural (white) Circuit No.1 Circuit No.1 (6 to 9 circuits) B A Dimensions(mm) A Circuits RoHS compliance Note: *Marked product is not CSA approved. (10, 15 circuits) B A 7.2 7.2 2.0 2.0 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. PARP-02V-oo(blank)…natural (white) R…red E…blue Y…yellow M…green 11.4 11.4 ex. Circuit No.1 Circuit No.1 Retainer (2 to 5 circuits) Circuits B A A B 2.0 2.0 (6 to 15 circuits) 1.5 2.4 2.4 3.1 7.0 2.85 7.0 1.5 Model No. Dimensions(mm) A B Q'ty / bag 2 PMS-02V-S 2.0 7.3 1,000 3 PMS-03V-S 4.0 9.3 1,000 4 PMS-04V-S 6.0 11.3 1,000 5 PMS-05V-S 8.0 13.3 1,000 6 PMS-06V-S 10.0 11.55 1,000 7 PMS-07V-S 12.0 13.55 1,000 8 PMS-08V-S 14.0 15.55 1,000 * 9 PMS-09V-S 16.0 17.55 1,000 *10 PMS-10V-S 18.0 19.55 1,000 *15 PMS-15V-S 28.0 29.55 1,000 Material Glass-filled PA 66, UL94V-0, natural (ivory) RoHS compliance Note: *Marked products are not CSA approved. 413 PA FAMILY SERIES /PAF CONNECTOR (Insulation displacement type) Receptacle Circuits A Q'ty / box 02PAF-6S 2.0 6.0 1,000 03PAF-6S 4.0 8.0 1,000 4 04PAF-6S 6.0 10.0 500 5 05PAF-6S 8.0 12.0 500 6 06PAF-6S 10.0 14.0 500 7 07PAF-6S 12.0 16.0 500 8 08PAF-6S 14.0 18.0 250 9 09PAF-6S 16.0 20.0 250 10 10PAF-6S 18.0 22.0 250 11 11PAF-6S 20.0 24.0 250 12 12PAF-6S 22.0 26.0 250 13 13PAF-6S 24.0 28.0 250 14 14PAF-6S 26.0 30.0 250 15 15PAF-6S 28.0 32.0 250 *16 16PAF-6S 30.0 34.0 250 3.1 2.0 5.1 B 3 13.0 8.0 Circuit No.1 A 2 B 2.0 Dimensions(mm) Model No. Material and Finish Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: PA 66, UL94V-0, natural (white) RoHS compliance Note: *Marked product is not UL/CSA approved. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 02PAF-6SS…natural (white) R…red E…blue M…green Y…yellow Retainer A B 2.0 Circuits 4.1 8.9 Model No. Dimensions(mm) A B Q'ty / bag 2 PAFS-02V-S 2.0 7.4 1,000 3 PAFS-03V-S 4.0 9.4 1,000 4 PAFS-04V-S 6.0 11.4 1,000 5 PAFS-05V-S 8.0 13.4 1,000 6 PAFS-06V-S 10.0 15.4 1,000 7 PAFS-07V-S 12.0 17.4 1,000 8 PAFS-08V-S 14.0 19.4 1,000 * 9 PAFS-09V-S 16.0 21.4 1,000 *10 PAFS-10V-S 18.0 23.4 1,000 *11 PAFS-11V-S 20.0 25.4 1,000 *12 PAFS-12V-S 22.0 27.4 1,000 *13 PAFS-13V-S 24.0 29.4 1,000 *14 PAFS-14V-S 26.0 31.4 1,000 *15 PAFS-15V-S 28.0 33.4 1,000 Material Glass-filled PA 66, UL94V-0, natural (ivory) RoHS compliance Note: *Marked products are not UL/CSA approved. 414 PA FAMILY SERIES /PAL CONNECTOR (Wire-to-wire type) Contact Applicable wire Model No. 0.5 1.6 SPAL-001T-P0.5 SPAL-002T-P0.5 Insulation O.D. (mm) Q'ty / reel mm2 AWG # 0.13∼0.33 26∼22 1.0∼1.5 10,000 0.08∼0.21 28∼24 0.9∼1.5 10,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 12.8 RoHS compliance 2.85 1.3 0.5 Dies ― AP-K2N ― ― MKS-L SPAL-002T-P0.5 Crimp applicator with dies MK/SPAL-001-05 APLMK SPAL001-05 MKS-L SPAL-001T-P0.5 2.4 Applicator Crimping machine Crimp applicator Contact MK/SPAL-002-05 APLMK SPAL002-05 ― ― ― Housing Circuits Without panel locks (2 to 5 circuits) B A 2.0 (6 to 8 circuits) 6.3 3.4 3.7 B A 2.0 3.7 3 4 5 6 7 11.2 20 20 8 4.7 Circuit No.1 B Q'ty / bag 2.0 9.4 1,000 4.0 11.4 1,000 6.0 13.4 1,000 8.0 15.4 1,000 10.0 17.4 1,000 12.0 19.4 1,000 14.0 21.4 1,000 A PALR-02VF PALR-03VF PALR-04VF PALR-05VF PALR-06VF PALR-07VF PALR-08VF 2 6.3 3.4 Dimensions(mm) Model No. Material PA 66, UL94V-0, natural (white) 4.4 Circuit No.1 RoHS compliance With panel locks Circuits Model No. (2 to 4 circuits) B A 2.0 3.2 PALR-02V PALR-03V PALR-04V PALR-06V PALR-07V PALR-08V 2 6.3 1.0 3.4 3.7 3 4 6 4.6±0.05 4 3.25 8 6.5+0.1 0 20 7 C D±0.1 D Q'ty / bag 2.0 9.4 9.8 13.4 1,000 4.0 11.4 11.8 15.4 1,000 6.0 13.4 13.8 17.4 1,000 10.0 17.4 19.8 21.4 1,000 12.0 19.4 21.8 23.4 1,000 14.0 21.4 23.8 25.4 1,000 RoHS compliance 3.2 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 6.3 3.4 3.7 1.6 4.4 PALR-02V(F)-oo(blank)…natural (white) R…red E…blue M…green Y…yellow 6.5+0.1 0 5.8 5.1±0.05 20 ex. 5.15 Circuit No.1 C PA 66, UL94V-0, natural (white) (6 to 8 circuits) B A 2.0 B Material +0.1 0 Circuit No.1 Dimensions(mm) A C+0.1 0 D±0.1 Retainer Retainers are interchangeable with those of the PA crimp style retainer mountable type. 415 PA FAMILY SERIES Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– Feeding direction Feeding direction Cover tape leader φ380±2.0 Carrier tape The end part Connector mounting part 160min. Leader part 100min. 400min. (φ13) 2.0±0.5 W1+2.5 –1.0 Top entry type (2 to 5 circuits) (6 to 13 circuits) 4.0±0.1φ1.55±0.05 2.9±0.1 1.75±0.1 4.0±0.1φ1.55±0.05 2.9±0.1 Carrier tape S±0.1 W±0.3 F±0.1 Cover tape F±0.1 Carrier tape Cover tape W±0.3 Feeding direction 1.75±0.1 Feeding direction 16.0±0.1 16.0±0.1 Side entry type (2 to 5 circuits) Feeding direction Cover tape Cover tape Carrier tape S±0.1 W±0.3 F±0.1 Carrier tape W±0.3 2.0±0.1 φ1.55±0.05 F±0.1 4.0±0.1 2.0±0.1 φ1.55±0.05 1.75±0.1 4.0±0.1 Feeding direction 1.75±0.1 (6 to 12 circuits) 12.0±0.1 12.0±0.1 Circuits Taping dimensions (mm) Reel dimensions (mm) Q'ty / reel Top entry type Side entry type F S W W1 2 to 5 11.5 – 24.0 25.5 500 1,000 6, 7 14.2 28.4 32.0 33.5 500 1,000 8 to 13 20.2 40.4 44.0 45.5 500 1,000 Note: 1. Specifications conform to JIS C 0806. The tape width, connector loading recess square hole dimensions, etc. are determined by the number of circuits and external shape of the connector to be loaded. 2. Specifications are subject to change without prior notice.
B03B-PASK-1-GU 价格&库存
很抱歉,暂时无法提供与“B03B-PASK-1-GU”相匹配的价格&库存,您可以联系我们找货
B03B-PASK-1-GU
    B03B-PASK-1-GU
      库存:10
      B03B-PASK-1-GU
      • 51+2.4488251+0.31823
      • 100+1.92317100+0.24992
      • 500+1.90370500+0.24739
      • 1000+1.246841000+0.16203
      库存:676
      B03B-PASK-1-GU
      • 1+4.485411+0.58289
      • 10+3.7955410+0.49324
      • 25+3.2961325+0.42834
      • 100+2.58933100+0.33649
      • 500+2.56140500+0.33286
      • 1000+1.677691000+0.21802
      库存:690
