SSR CONNECTOR
Emboss
Emboss Tape
Tape
1.0mm pitch/Disconnectable Insulation displacement connectors
SSR CONNECTOR
Specifications
• Current rating: 0.5A AC, DC
• Voltage rating: 50V AC, DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/20mΩ max.
After environmental testing/40mΩ max.
• Insulation resistance: 100MΩ min.
• Withstanding voltage: 500V AC/minute
• Applicable wire: Conductor size/AWG #32
Conductor/7 strands,
tin-coated annealed copper
Insulation O.D./0.52 to 0.56mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
This connector is for wire-to-board
connection with 1.0 mm pitch insulation
displacement connection, which achieved
miniaturization with mounting height 2.0 mm
and depth 4.5 mm.
The twin U-slots and the 3-point grip
construction provides excellent connection
performance.
Compact
T
win U-slot insulation displacement section
3-point grip construction
Header designed for vacuum pick and place
robotics
● Mating structure withstanding "pry"
Standards
Recognized E60389
Certified LR20812
PC board layout (viewed from component side) and Assembly layout
1.0 ±0.05
Header outline
1.0 ±0.1
1.2 ±0.1
Note: 1
. Tolerances are non-cumulative: ± 0.05mm for all centers.
2. The dimensions above should serve as a guideline. Contact JST for details.
1
2.0
4.5 ±0.1
4.5
0.2±0.1
1.8±0.1
2.95±0.1
0.6 ±0.05
SSR CONNECTOR
Socket
1.85
1.55
3.5
Circuit No.1
1.0
A
B
2.2
1.0
No. of
circuits
Model No.
2
3
4
04SSR-32H
5
05SSR-32H
6
Dimensions (mm)
Q'ty / box
A
B
02SSR-32H
1.0
3.0
2,000
03SSR-32H
2.0
4.0
2,000
3.0
5.0
2,000
4.0
6.0
2,000
06SSR-32H
5.0
7.0
2,000
8
08SSR-32H
7.0
9.0
2,000
9
09SSR-32H
8.0
10.0
2,000
10
10SSR-32H
9.0
11.0
2,000
11
11SSR-32H
10.0
12.0
2,000
12
12SSR-32H
11.0
13.0
2,000
13
13SSR-32H
12.0
14.0
2,000
14
14SSR-32H
13.0
15.0
2,000
SSR CONNECTOR
Material and Finish
Contact: Phosphor bronze, tin-plated (reflow treatment)
Housing: PA 46, UL94V-0, gray
RoHS compliance
Header
3.2
0.7
1.95
1.0
B
A
Circuit No.1
1.3 0.2
1.5
No. of
circuits
Model No.
2
SM02B-SSR-H-TB
3
SM03B-SSR-H-TB
4
Dimensions (mm)
A
B
Q'ty / reel
1.0
4.6
4,500
2.0
5.6
4,500
SM04B-SSR-H-TB
3.0
6.6
4,500
5
SM05B-SSR-H-TB
4.0
7.6
4,500
6
SM06B-SSR-H-TB
5.0
8.6
4,500
8
SM08B-SSR-H-TB
7.0
10.6
4,500
9
SM09B-SSR-H-TB
8.0
11.6
4,500
10
SM10B-SSR-H-TB
9.0
12.6
4,500
11
SM11B-SSR-H-TB
10.0
13.6
4,500
12
SM12B-SSR-H-TB
11.0
14.6
4,500
13
SM13B-SSR-H-TB
12.0
15.6
4,500
14
SM14B-SSR-H-TB
13.0
16.6
4,500
Material and Finish
Contact: Copper-alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA, UL94V-0, gray
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
RoHS compliance This product displays (LF)(SN) on a label.
Note: The products listed above are supplied on embossed-tape.
Model number allocation
Socket
Header
SM 02 B - SSR - H - TB
02 SSR - 32 H
Shape of assembled product:
SM…SMT side entry type
No. of circuits: 2 to 6, 8 to 14
Indication of assembly
Series name
Series name
Applicable wire range: 32…AWG #32
Color: H…Gray
Color: H…Gray
Packaging style: TB…Embossed-taping
2
很抱歉,暂时无法提供与“04SSR-32H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.277731+0.68365
- 10+3.5940910+0.46556
- 50+3.0532350+0.39550
- 100+2.69557100+0.34917
- 500+2.62578500+0.34013
- 1000+2.564721000+0.33222
- 2000+2.538552000+0.32883
- 国内价格 香港价格
- 1+3.977931+0.51528
- 50+3.4806950+0.45087
- 100+2.95858100+0.38324
- 300+2.61052300+0.33816
- 500+2.54422500+0.32957
- 1000+2.486211000+0.32205
- 4000+2.453064000+0.31776
- 国内价格 香港价格
- 2000+3.423702000+0.44349
- 国内价格 香港价格
- 1+4.187291+0.54240
- 50+3.6638850+0.47460
- 100+3.11430100+0.40341
- 300+2.74791300+0.35595
- 500+2.67812500+0.34691
- 1000+2.617061000+0.33900
