BM08B-CPTK-1A-TB
BM08B-CPTK-1A-TB
    JST
    SMD,P=2mm
    线对板针座
BM08B-CPTK-1A-TB 数据手册
CPTCONNECTOR Board-to-wire Features ●Compact design 2.0 mm pitch is realized miniaturization and low profile as the connector for automobile. ●Terminal construction Female terminal is designed for simple box structure by having spring structure on male terminal. Developed in pursuit of miniaturization and low profile as PC board connector for automobile. This connector is surface mounting type connector having the spring structure on male terminal disproving the conventional concept. Specifications ¡Current rating: 3 A AC, DC (0.3 mm2, Single circuit) ¡Voltage rating: 50 V AC, DC ¡Temperature range: -40°C to +100°C (including temperature rise in applying electrical current) ¡Contact resistance: Initial value/ 8 mΩ max. After environmental tests/ 16 mΩ max. ¡Insulation resistance: 100 MΩ min. ¡Withstanding voltage: 1,000 VAC/minute ¡Applicable wire: AESSX-f/ AVSS 0.3 mm2 ∗ Compliant with ELV/RoHS. ∗ Contact JST for details. 1 CPTCONNECTOR Female terminal Applicable wire range Conductor (mm2) Insulation O.D. (mm) Q’ty/reel SCPT-A021GF-0.5 0.3 1.4 15,000 Material and Finish Brass, nickel-undercoated, Contact area; gold-plated Barrel area; tin-plated 5.5 1.4 5.5 Model No. Female connector Single row 12.5 ¡2 circuits 0.8 6.6 Housing 2 Retainer 6 ¡4 circuits 04CPT-B1-2A 13.5 13.5 04CPT-B1-2B Housing 2 Retainer 2 2 X3=6 2×3=6 10 10 0.8 0.8 6.6 6.6 Housing Retainer 13.5 ¡8 circuits 0.8 6.6 Housing 2 Retainer 2X7=14 18 2 CPT CONNECTOR Female connector Double row ¡20 circuits 12.5 13.5 ¡8 circuits Housing 2 Retainer 0.8 0.8 9.1 9.1 Housing 2 2×3=6 2×9=18 10 22 ¡24 circuits 13.5 13.5 ¡12 circuits Retainer Housing 2 Retainer 0.8 0.8 9.1 9.1 Housing 2 2×5=10 2×11=22 14 26 Retainer ¡16 circuits 12.5 Type Circuits 2 Single row 4 9.1 Housing 0.8 Double row 2 2×7=14 18 3 Retainer Model No. 02CPT-B-2A 04CPT-B1-2A 04CPT-B1-2B Q’ty/box 500 600 8 08CPT-B1-2A 400 8 08CPT-B-2A 500 12 12CPT-B-2A 300 16 16CPT-B-2A 250 20 20CPT-B-2A 250 24 24CPT-B-2A 200 Material and Finish Housing: Glass-filled PBT, Black Retainer: Glass-filled PBT, Blue CPT CONNECTOR Male connector Top entry type Double row ¡8 circuits Single row ¡2 circuits 15.6 10.5 12.7 1 4 1 8 5 9.2 2 Circuit No. 2.5 6.8 2 Circuit No. 2 11.7 Side entry type Single row ¡2 circuits 2 14.1 15.2 11.6 10.6 6.8 Circuit No. 2 1 ¡4 circuits SM04B1-CPTK-1A-TB SM04B1-CPTK-1B-TB 6 6 15.2 18.1 15.6 15.2 18.1 15.6 10.6 10.6 Circuit No. 4 1 6.8 6.8 Circuit No. 4 1 4 CPT CONNECTOR Male connector Side entry type Single row ¡12 circuits ¡8 circuits 14 11 26.1 15.2 23.6 22.1 10.6 15.2 Circuit No. 8 Circuit No. ¡20 circuits 19 30.1 15.2 Circuit No. 2.5 27.6 10 1 20 11 9.3 5 6 1 12 7 1 10.6 9.3 6.8 2.5 19.6 10.6 CPT CONNECTOR Male connector Side entry type Double row ¡16 circuits ¡8 circuits 7 15 15.2 Circuit No. 1 8 1 16 9 10.6 9.3 8 Circuit No. 23.6 9.3 4 15.2 26.1 10.6 2.5 15.6 2.5 18.1 5 ¡24 circuits 23 Type Circuits Top type 34.1 15.2 31.6 10.6 9.3 1 2.5 12 24 Side type 13 Q’ty/reel 2 (Single) BM02B-CPTK-1A-TB 370 8 (Double) BM08B-CPTK-1A-TB 240 2 (Single) SM02B-CPTK-1A-TB 500 4 (Single) Circuit No. Model No. SM04B1-CPTK-1A-TB SM04B1-CPTK-1B-TB 500 8 (Single) SM08B1-CPTK-1A-TB 500 8 (Double) SM08B-CPTK-1A-TB 390 12 (Double) SM12B-CPTK-1A-TB 390 16 (Double) SM16B-CPTK-1A-TB 390 20 (Double) SM20B-CPTK-1A-TB 390 24 (Double) SM24B-CPTK-1A-TB 390 Material and Finish Terminal: Copper alloy, nickel-undercoated, Contact area; gold-plated Solder tail; tin-plated (reflow treatment) Housing: Glass-filled LCP, Black Peg: Brass, nickel-undercoated, tin-plated (reflow treatment) 6 CPT CONNECTOR Taping Specifications Top entry type ¡2 circuits 1.5+0.1 0 Cover tape 28.4 φ380±2 14.2±0.1 2 Feeding direction 32±0.3 ±0.1 1.75±0.1 4±0.1 Feeding direction ±0.1 ¡2, 8 circuits Carrier tape (φ13) 33.5+2.5 -1 2±0.5 16 ±0.1 ¡8 circuits 1.5+0.1 0 2 Connector mounting part 28.4 Leader part 100min. The end part 160min. Cover tape 400min. 32 ±0.3 Cover tape leader 14.2±0.1 Carrier tape ±0.1 1.75±0.1 Feeding direction 4±0.1 ±0.1 Feeding direction Carrier tape 24±0.1 Side entry type ¡2, 4, 8, 12, 16, 20, 24 circuits 1.75±0.1 Feeding direction 4±0.1 1.5+0.1 0 Cover tape C ±0.1 φ380±2 B±0.1 2±0.1 D±0.3 Feeding direction Carrier tape (φ13) A+2.5 -1 2±0.5 20±0.1 Feeding direction Carrier tape Cover tape leader Type The end part 160min. Leader part 100min. Connector mounting part Single 400min. Double 7 Circuits A B C D 2 33.5 14.2 28.4 32 4 33.5 14.2 28.4 32 8 45.5 20.2 40.4 44 8 45.5 20.2 40.4 44 12 45.5 20.2 40.4 44 16 45.5 20.2 40.4 44 20 45.5 20.2 40.4 44 24 57.5 26.2 52.4 56 CPT CONNECTOR PC board layout, Assembly layout Top entry type ¡8 circuits ¡2 circuits 15.7±0.1 6.8 ±0.05 16.1 6.2±0.05 16 11.8±0.1 ±0.1 5.8 3±0.05 4.9±0.05 Circuit No.1 1 9.2 1.6±0.05 Circuit No.1 5.5±0.05 1.85 13.5 4.95±0.05 14.5 Circuit No.2 3±0.05 4.35±0.05 1.35±0.05 8.2 10.9±0.1 2±0.05 Circuit No.8 4.75±0.05 2±0.05 1±0.05 6±0.1 Side entry type ¡2, 4, 8 (Single) circuits ¡4 circuits ¡2 circuits a 1 19.6 Circuit No.a Circuit No.1 16 1 6.8 6.8 Circuit No. a 20.6 15 A±0.05 3.3±0.05 0.75±0.03 2±0.05 20.6 Circuits A B 2 2 15.8 4 6 19.8 8 (Single) 14 27.8 3.85±0.05 7.4±0.05 B±0.1 16 6.8 5±0.05 8.8±0.05 ¡8 (Single) circuits ¡8 (Double), 12, 16, 20, 24 circuits Circuit No.a Circuit No.1 a ¡8 (Double) circuits ¡12 circuits 20.6 19.6 1 16 15 b Circuit No.c Circuit No. a c 9.3 Circuit No.b 9.3 c 1b 0.75±0.03 ¡20, 24 circuits ¡16 circuits 1±0.05 20.6 19.6 A B 8 (Double) 7 19.8 12 11 23.8 16 15 27.8 20 19 31.8 24 23 35.8 3.85±0.05 6.4±0.05 B±0.1 16 9.3 5±0.05 8.8±0.05 Circuits 15 9.3 3.3±0.05 A±0.05 Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers. 2. The dimensions above should serve as guideline. Contact JST for details. Crimping machine, Applicator Crimp applicator MKS-L Strip terminal Crimping machine Dies Crimp applicator with dies SCPT-A021GF-0.5 AP-K2N MK/SCPT-A021-05 APLMK SCPT-A021-05 Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal. 8
BM08B-CPTK-1A-TB 价格&库存
很抱歉,暂时无法提供与“BM08B-CPTK-1A-TB”相匹配的价格&库存,您可以联系我们找货
BM08B-CPTK-1A-TB
库存:460
