09 46 800 0000
09 46 800 0000
    HARTING(浩亭)
    HARTING - 09 46 800 0000 - Crimp Tool, Hand, Harting 28-12AWG PushPull Power Contacts
09 46 800 0000 数据手册
PushPull HARTING PushPull Power HARTING PushPull Power 2/0, type acc. to IEC 61 076-3-106 variant 4 panel feed-through and connector, 3-poles, 250 V / 16 A Advantages l l Technical characteristics Power connectors for devices Locking PushPull Technology acc. to IEC 61 076-3-106 variant 4  asyInstall panel feed-through for simple device E integration Degree of protection IP 65 / IP 67 Number of contacts 2 + PE Electrical data acc. to EN 61 984 16 A 250 V 4 kV 3 Cable diameter 4.9 ... 8.6 mm l Compact, space-saving design l Touch-proof according to IEC DIN EN 60 529 Termination Crimp l Polarisation with nose Termination cross section 0.75 - 2.5 mm² (AWG 20 - 12) stranded l Cable side: Male with crimp termination Mating cycles min. 750 l Device side: female with crimp termination Temperature range -40 °C … +70 °C Housing material Plastic, black l 4 different coding variants without loss of contact Identification Part No. Flammability acc. to UL 94 V0 Drawing Dimensions in mm HARTING PushPull Power 2/0 Panel feed-through set incl. 3 turned crimp contacts (female) for 1.5 mm², ­insulation body (black), housing bulkhead mounting EasyInstall 09 46 245 3430 Panel feed-through set incl. 3 turned contacts (female) for 1.5 mm², ­­insulation body (black), housing bulkhead mounting, with crimp termination 09 46 245 3410 Power-female with solder termination angled 09 46 500 3400 Power-female with crimp termination without contacts 09 46 500 3401 Connector set incl. 3 turned crimp contacts (male) for 1.5 mm², ­insulation body (black), housing, cable gland 09 46 145 3410 Connector set without contacts 09 46 145 3411 Coding pin set  to avoid accidental incorrect mating a coding system is required. This coding pins are inserted without loss of contact. Crimp contacts see page 02.26 Panel cut outs see page 02.04 09 46 840 0000 02 27 PushPull HARTING PushPull Power HARTING PushPull Power 4/0, type acc. to IEC 61 076-3-106 variant 4 connector 4-poles 48 V / 12 A Advantages l l l l l l l Technical characteristics Power connectors for devices Locking PushPull Technology acc. to IEC 61 076-3-106 variant 4  asyInstall panel feed-through for simple device E integration Degree of protection IP 65 / IP 67 Number of contacts 4 Electrical data acc. to EN 61 984 12 A 48 V 1.5 kV 3 Cable diameter 4.9 ... 8.6 mm Termination Crimp Termination cross section 0.75 - 2.5 mm² (AWG 20 - 12) stranded Mating cycles min. 750 Temperature range -40 °C … +70 °C Housing material Plastic, black Compact, space-saving design Touch-proof according to IEC DIN EN 60 529 Polarisation with nose Cable side: Male with crimp termination 4 different coding variants without loss of contact Identification Part No. Connector set  incl. 4 turned crimp contacts (male) for 1.5 mm², insulation body, housing, cable gland Connector set  without contacts 09 46 145 4401 Accessories – crimp contacts male 0.75 mm² (AWG 20 - 18) 09 46 500 0403 1.0  mm² (AWG 18) 09 46 500 0407 1.5  mm² (AWG 16 - 14) 09 46 500 0401 2.5  mm² (AWG 12) 09 46 500 0405 Accessories – crimp contacts female 0.75 mm² (AWG 20 - 18) 09 46 500 0404 1.0  mm² (AWG 18) 09 46 500 0408 1.5  mm² (AWG 16 - 14) 09 46 500 0402 2.5  mm² (AWG 12) 09 46 500 0406 Accessories – Coding pin set  to avoid accidental incorrect mating 09 46 840 0000 a coding system is required. This coding pins are inserted without loss of contact. 02 26 1) 09 46 145 4400 09 46 195 44001) Metal version (without contacts) Flammability acc. to UL 94 V0 Drawing Dimensions in mm HARTING PushPull Power PushPull Identification Tooling Part No. HARTING PushPull Power 8-indent crimping tool incl. positioner 09 46 800 0000 Locator HARTING PushPull Power contacts for Buchanan crimping tool (09 99 000 0001) 09 46 800 0010 Insertion tool 09 46 800 0099 Extraction tool 09 46 800 0098 Crimp connection A perfect crimp connection is gastight, therefore corrosion free and amounts to a cold weld of the parts being connected. For reason, major features in achieving high quality crimp this ­ connections are the design of the contact crimping parts and of course the crimping tool itself. Wires to be connected must ­ atched with the correct size of crimp contacts. If be carefully m requirements are met, users will be assured of these basic ­ highly reliable ­connections with low contact resistance and high resistance to corrosive attack. The economic and technical advantages are: ● Constant contact resistance as a result of precisely repeated crimp connection quality ● Corrosion free connections as a result of cold weld action ● Pre-preparation of cable forms with crimp contacts fitted ● Optimum cost cable connection Requirements for crimp connectors are laid down in DIN IEC 60 352-2, Amend. 2, as illustrated in the table. Pull out force of stranded wire The main criterion to judge the quality of a crimp ­connection is the retention force achieved by the wire conductor in the ­terminal section of the contact. DIN IEC 60 352, part 2, defines the ­ ­extraction force in relation to the cross-section of the c­ onductor. When fitted using HARTING crimping tools and subject to their ­utilization in an approved manner, our crimp connectors comply with the required extraction forces. For wire gauges 0.08 … 4.0 mm² (AWG 28 … 12). For an easy insertion and extraction of the male and female crimp contacts into / out of the insulator body. Tensile strength of crimped connections Conductor cross-section mm² AWG 0.08 28 0.12 26 0.14 0.22 24 0.25 0.32 22 0.50 20 0.75 0.82 18 1.00 1.30 16 1.50 2.10 14 2.50 3.30 12 4.00 Extract from DIN IEC 60 352-2, Amend. 2, Table IV Crimping tools Crimping tools (hand operated or automatic) are carefully designed to produce with high pressure forming parts a ­ symmetrical connection of the crimping part of the contact and the wire being connected with the minimum increase in size at the ­ connection point. The positioner automatically locates the crimp and wire at the correct point in the tool. A ratchet in the tool performs 2 functions: ➀ It prevents insertion of the crimp into the tool for crimping ­before the jaws are fully open ➁ It prevents the tool being opened before the crimping action is completed 02 28 Identical, perfectly formed, connections can be produced using this crimping system. Tensile strength Crimp-cross section HARTING crimp profile N 11 15 18 28 32 40 60 85 90 108 135 150 200 230 275 310
09 46 800 0000 价格&库存
很抱歉,暂时无法提供与“09 46 800 0000”相匹配的价格&库存,您可以联系我们找货
