09332006221
09332006221
    HARTING(浩亭)
    CONTACTH.D.CRIMPSOCKET12AWG
09332006221 数据手册
Contacts Technical characteristics Contact resistance Material (contacts) Material (accessories) Details ≤1 mΩ Copper alloy Thermoplastic Crimping tools see chapter 90 Remarks on the crimp technique The wire gauges mentioned in the catalogue refer to geometric wire gauges of cables. Specifications and approvals Coding pin Use of the coding pin prevents incorrect mating to other connectors of the same type. The male pin should be omitted from the opposing cavity in the male insert. EN 60664-1 IEC 61984 Identification Han E® HMC, Crimp contact, Contact surface: HMC gold plated Han HMC Conductor cross-section (mm²) Male 0,14 ... 0,37 0,5 0,75 1 1,5 2,5 4 09 33 200 6117 09 33 200 6122 09 33 200 6115 09 33 200 6118 09 33 200 6116 09 33 200 6123 09 33 200 6119 Part number Female Drawing (dimensions in mm) 09 33 200 6217 09 33 200 6222 09 33 200 6215 09 33 200 6218 09 33 200 6216 09 33 200 6223 09 33 200 6221 Stripping length 7.5 mm Han E® Han® EE Han® EEE , Coding pin for crimp inserts only 16 · 22 09 33 000 9954
09332006221 价格&库存
很抱歉,暂时无法提供与“09332006221”相匹配的价格&库存,您可以联系我们找货
    • 10+48.90234
    • 30+48.14838
    库存:40
