09452812800333
09452812800333
    HARTING(浩亭)
09452812800333 数据手册
Product data sheet 09 45 281 2800 333 T1 Industrial jack AH IP20 This product is available upon request. Please contact your local HARTING subsidiary. T1 Industrial jack AH IP20 Part number 09 45 281 2800 333 Specification T1 Industrial jack AH IP20 HARTING eCatalogue https://b2b.harting.com/09452812800333 Image is for illustration purposes only. Please refer to product description. Identification Category Connectors Series HARTING T1 Industrial Element PCB connector Version Termination method THR connection Shielding Fully shielded, 360° shielding contact Number of contacts 2 Additional contacts + shielding Pack contents Sample Technical characteristics Rated current 4 A Rated voltage 60 V DC Contact resistance ≤20 mΩ Shielding resistance ≤100 mΩ Limiting temperature -40 ... +85 °C Mating cycles ≥1,000 Degree of protection acc. to IEC 60529 IP20 Test voltage UDC 1 kV (contact-contact) 2.25 kV (contact-ground) Transmission characteristics 600 MHz Bandwidth Page 1 / 2 | Creation date 2020-02-21 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Stiftung & Co. KG | Marienwerderstr. 3 | 32339 Espelkamp | Germany Product data sheet 09 45 281 2800 333 T1 Industrial jack AH IP20 This product is available upon request. Please contact your local HARTING subsidiary. Technical characteristics Data rate 10 Mbit/s 100 Mbit/s 1 Gbit/s Moisture Sensitivity Level (MSL) 1 acc. to ECA/IPC/JEDEC J-STD-020D Process Sensitivity Level (PSL) R0 acc. to ECA/IPC/JEDEC J-STD-020D Specifications and approvals Specifications IEC 63171-6 IEEE 802.3bu (remote power supply over PoDL = Power over Data Line) IEEE 802.3cg (10BASE-T1) IEEE 802.3bw (100BASE-T1) IEEE 802.3bp (1000BASE-T1) Commercial data Packaging size 1 eCl@ss 27440402 PCB connector Page 2 / 2 | Creation date 2020-02-21 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Stiftung & Co. KG | Marienwerderstr. 3 | 32339 Espelkamp | Germany
09452812800333 价格&库存
很抱歉,暂时无法提供与“09452812800333”相匹配的价格&库存,您可以联系我们找货
  • 1+48.38269
  • 50+46.45613
  • 100+44.51916
库存:4
