09380052702
09380052702
    HARTING(浩亭)
    INSERT FEMALE 3+2POS+1GND SCREW
09380052702 数据手册
Product data sheet 09 38 005 2702 Han K 3/2 Pos. Female Insert Screw Term. Han K 3/2 Pos. Female Insert Screw Term. Part number 09 38 005 2702 Specification Han K 3/2 Pos. Female Insert Screw Term. HARTING eCatalogue https://b2b.harting.com/09380052702 Image is for illustration purposes only. Please refer to product description. Identification Category Inserts Series Han-Com® Identification Han® K 3/2 Specification Angled Version Termination method Axial screw termination / screw termination Gender Female Size 24 B Number of contacts 3 further contacts + 2 additional signal contacts PE contact Yes Technical characteristics Conductor cross-section 35 ... 70 mm² 0.5 ... 2.5 mm² Signal 16 ... 35 mm² PE Rated current 200 A Rated voltage conductor-earth 1,150 V Rated voltage conductor-conductor 2,000 V Rated impulse voltage 8 kV Pollution degree 3 Rated current (signal) 16 A Page 1 / 3 | Creation date 2021-05-15 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | 32339 Espelkamp | Germany Phone +49 5772 47-97100 | electric@HARTING.com | www.HARTING.com Product data sheet 09 38 005 2702 Han K 3/2 Pos. Female Insert Screw Term. Technical characteristics Rated voltage (signal) 400 V Rated impulse voltage (signal) 6 kV Pollution degree (signal) 3 Rated current acc. to UL 200 A Rated voltage acc. to UL 600 V Rated current acc. to UL (signal) 16 A Rated voltage acc. to UL (signal) 600 V Rated current acc. to CSA 160 A Rated voltage acc. to CSA 600 V Rated current acc. to CSA (signal) 16 A Rated voltage acc. to CSA (signal) 600 V Insulation resistance >1010 Ω Contact resistance ≤0.2 mΩ Contact resistance, signal area ≤1 mΩ Stripping length 22 mm 7 mm Signal contacts 14 mm PE contact Tightening torque 8 Nm @ 35 mm² 9 Nm @ 50 mm² 10 Nm @ 70 mm² 0.5 Nm Signal contacts 6 Nm PE contact Limiting temperature -40 ... +125 °C Mating cycles ≥500 Material properties Material (insert) Polycarbonate (PC) Colour (insert) RAL 7032 (pebble grey) Material (contacts) Copper alloy Surface (contacts) Silver plated Material flammability class acc. to UL 94 V-0 RoHS compliant with exemption RoHS exemptions 6(a) / 6(a)-I: Lead as an alloying element in steel for machining purposes and in galvanised steel containing up to 0,35 % lead by weight / Lead as an alloying element in steel for machining purposes containing up to 0,35 % lead by weight and in batch hot dip galvanised steel components containing up to 0,2 % lead by weight 6(c): Copper alloy containing up to 4 % lead by weight Page 2 / 3 | Creation date 2021-05-15 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | 32339 Espelkamp | Germany Phone +49 5772 47-97100 | electric@HARTING.com | www.HARTING.com Product data sheet 09 38 005 2702 Han K 3/2 Pos. Female Insert Screw Term. Material properties ELV status compliant with exemption China RoHS 50 REACH Annex XVII substances No REACH ANNEX XIV substances No REACH SVHC substances Yes REACH SVHC substances Lead ECHA SCIP number 5dbb3851-b94e-4e88-97a1-571845975242 Specifications and approvals Specifications EN 60664-1 IEC 61984 Approvals DNV GL UL / CSA UL 1977 ECBT2.E235076 CSA-C22.2 No. 182.3 ECBT8.E235076 Commercial data Packaging size 1 Net weight 411 g Country of origin Germany European customs tariff number 85366990 eCl@ss 27440205 Contact insert for industrial connectors Page 3 / 3 | Creation date 2021-05-15 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | 32339 Espelkamp | Germany Phone +49 5772 47-97100 | electric@HARTING.com | www.HARTING.com
09380052702 价格&库存
很抱歉,暂时无法提供与“09380052702”相匹配的价格&库存,您可以联系我们找货
  • 1+2512.951941+315.12900
  • 2+2476.306562+310.53360
  • 3+2455.151393+307.88070
  • 4+2440.192284+306.00480
  • 5+2393.279135+300.12180
