09454521509
09454521509
    HARTING(浩亭)
    CONN RJ45 COUPLER CAT6 W/CBL 1M
09454521509 数据手册
har-port coupler har-port USB coupler Advantages Technical characteristics • Compact and well-shaped service interface in a timeless attractive design • Easy mounting • Compact and robust design • Practical accessories Number of ports 2x USB Typ A Mounting Screwable in cover plates Degree of protection IP 20 Mating cycles min. 1500 Temperature range -25 °C ... +70 °C Housing material Polyamide Identification Drawing Part No. har-port USB 2.0 A-A coupler 09 45 452 1901 har-port USB 3.0 A-A coupler 09 45 452 1902 har-port USB 2.0 A-A coupler with cable Length: 0.5 m 1.0 m 1.5 m 2.0 m 3.0 m 5.0 m 09 45 452 1920 09 45 452 1921 09 45 452 1922 09 45 452 1923 09 45 452 1924 09 45 452 1925 har-port USB 2.0 B-B coupler with cable 154 Length: 0.5 m 1.5 m 2.0 m 3.0 m 09 45 452 1910 09 45 452 1912 09 45 452 1913 09 45 452 1914 Dimensions in mm har-port coupler har-port RJ45 coupler Advantages Technical characteristics • Compact and well-shaped service interface in a timeless attractive design • Easy mounting • Transmission category 6, performance class EA, suitable for 1/10 Gigabit Ethernet • Compact and robust design • Practical accessories Number of ports Identification Part No. har-port RJ45 Cat. 6 coupler 2x RJ45 Transmission performance Category 6 / class EA acc. to ISO/IEC 11 801:2002, EN 50 173-1 Transmission rate 10/100 Mbit/s and 1/10 Gbit/s Shielding Fully shielded, 360° shielding contact Mounting Screwable in cover plates Degree of protection IP 20 Mating cycles min. 750 Temperature range -25 °C ... +70 °C Housing material Polyamide Drawing Dimensions in mm 09 45 452 1560 har-port RJ45 Cat. 6 coupler with cable Length:   0.2 m   0.5 m   1.0 m   1.5 m   2.0 m   3.0 m   5.0 m har-port HIFF coupler housing (for all HIFF compatible modules) 09 45 452 1501 09 45 452 1504 09 45 452 1509 09 45 452 1510 09 45 452 1511 09 45 452 1513 09 45 452 1516 09 45 452 0000 155 har-port coupler har-port accessories Advantages Technical characteristics • Compact and well-shaped service interface in a timeless attractive design • Easy mounting • Compact and robust design • Practical accessories Temperature range -25 °C ... +70 °C Housing material Polyamide Identification Drawing Part No. Accessories 156 har-port protection cover IP 65 / IP 67 black 09 45 502 0000 har-port sealing cover 09 45 502 0001 har-port label holder 09 45 502 0002 har-port label for label holder 09 45 502 0002 09 45 502 0003 har-port blind cover IP 65 / 67 09 45 502 0004 Dimensions in mm
09454521509 价格&库存
很抱歉,暂时无法提供与“09454521509”相匹配的价格&库存,您可以联系我们找货
  • 1+397.035811+51.52800
  • 5+373.614185+48.48830
  • 10+351.4985910+45.61810
  • 25+316.4967425+41.07550
  • 50+291.5949450+37.84370
  • 100+281.32077100+36.51030
库存:10
09454521509
  • 1+368.51515
  • 5+346.81101
  • 10+326.23281
  • 25+293.72452
  • 50+270.63093
  • 100+261.13238
库存:10
09454521509
    • 1+336.62729
    • 5+302.95935
    库存:7
