24024050020
24024050020
    HARTING(浩亭)
    HARTING - 24024050020 - ENET SWITCH, UNMANAGED, 5PORT, DIN RAIL
24024050020 数据手册
Ha-VIS eCon 2000 Full Gigabit Ethernet Basic PoE / PoE+ 4 to 7 Ethernet ports RJ45, FOC, and PoE / PoE+ English Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0 °C ... +55 °C / Industrial temp.: -40 °C ... +70 °C Energy Efficient Ethernet ■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in ac- cordance with IEEE 802.3at ■ Full Gigabit Ethernet non-blocking switch architecture according to IEEE 802.3 ■ Support of jumbo frames (10 kB) ■ Variants with industrial temperature range of -40 °C ... +70 ° C ■ Wide range power supply 24/48 VDC ■ Surge protection and reverse polarity protection ■ Minimum energy consumption due to energy-efficient Ethernet Target markets Machinery & Robotics Automation Industrial network infrastructures Wind Energy, Solar Energy Transportation Shipbuilding General description The Ha-VIS eCon 2000 Full Gigabit family of unmanaged Ethernet switches is equipped with up to 7 gigabit Ethernet ports and allow for cost-efficient and quick expansion and/or reconstruction of network infrastructures with high bandwidth requirements. In this, all variants support extra-long Ethernet frames (jumbo frames). The switches work as power sourcing equipment (PSE) and are capable of simultaneously providing the full PoE output of 34.2 watts on up to four ports. Due to the extremely flat design, these switches can be accommodated in installations where space is restricted towards the cable connection at the front. The selection includes various combinations of variants with RJ45 and fibre optic ports. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for simple plug and play. All variants are available with the temperature ranges "Industrial" and "Commercial". Technical characteristics Switch features Ethernet ports 10BASE-T / 100BASE-TX EEE / 1000BASE-TX EEE Enclosure width 120 mm Type of connection RJ45 Auto-negotiation Yes Store and Forward Auto-polarity Yes Supported standards IEEE 802.3 Frame size Auto-MDI(X) 10 kBytes MAC table size Transfer conditions 8k entries Transfer speed 10 / 100 / 1000 Mbit/s Transfer length 100 m (Twisted Pair, Cat 5) Number of interfaces 5, 7 Switching technology Packet buffer size 1 Mbit Non-blocking Yes Quality of Service Yes Energy-efficient Ethernet Yes PROFINET-compatible Yes EthernetIP-compatible Yes Ethernet ports 1000BASE-SX / 1000BASE-LX Type of fibre 24 VDC 48 VDC Surge protection Yes Reverse polarity proof Yes Starting current 3.2 A Overcurrent protection at input 54 VDC 9 VDC ... 60 VDC 6.40 A Yes (4 A) Max. power consumption @ 24 VDC 3.60 W ... 4.80 W Conductor cross-section 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) Type of connection Pinout 3-pole, pluggable screw type terminal block +/-/ Supply circuit (according to 60950) Transfer length Input sensitivity 7.20 A SELV (circuit breaker 10 A) HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany ICPN-Service@harting.com | Service hotline: +49 5772 47-9479 Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches FOC 850 nm Transfer speed Output power Single-mode (SM) SC Duplex Transfer conditions Wavelength Permissible voltage range Multi-mode (MM) Type of connection Power supply Nominal voltage Yes Twisted pair 1310 nm 1000 Mbit/s 0.55 km 10 km -9.5 dBm ... -4 dBm -9.5 dBm ... -3 dBm ≤ -17 dBm ≤ -21 dBm Environmental conditions Commercial temperature range Industrial temperature range Storage temperature range 0 °C ... +55 °C -40 °C ... +70 °C -40 °C ... +85 °C Relative humidity (operation) 0% ... 95 % (non-condensing) Relative humidity (storage and transport) 0% ... 95 % (non-condensing) Air pressure 2000 m (795 hPa) Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. PoE Enclosures Number of PoE ports 4 Standard IEEE 802.3af / IEEE 802.3at PoE type PSE Supported mode Alternative A Power supply PSE 48 VDC Maximum Power consumption Maximum output power PSE 54 VDC 375 mA 638 mA 15.4 W per port 61.6 W total 34.2 W per port 136.8 W total Supported cabling See 802.3at, section 33.1.4 PoE pinout Alternative A, MDI-X (1/2 = V-, 3/6 = V+) Status and diagnostic displays Power ("Pwr") illuminated green Supply voltage is applied Link/Activity ("L/A") off No link Link/Activity ("L/A") illuminated green Link/Activity ("L/A") flashes green Link is active Link is active and data is transferred Link speed ("Spd") off 10 Mbit/s Link speed ("Spd") illuminated yellow 100 Mbit/s Link speed ("Spd") illuminated green PoE status off Enclosure width Dimensions H x W x D (without pluggable screw type terminal block and holding bracket) 120 mm 113.5 mm x 120 mm x 27.3 mm Weight 410 g ... 442 g Type of installation 35 mm DIN rail acc. to EN 60 715 Material enclosures Anodised aluminium Protection class (with pluggable screw type terminal block) IP30 Protection class III Approvals CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) 1000 Mbit/s PoE is inactive / low voltage PoE status illuminated green Voltage in PoE range PoE status illuminated blue Voltage in PoE+ range PoE status illuminated red Fault Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Resonance search IEC 60068-2-27 Shock test Included in delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions Drawings Technical characteristics / order information Ports / order information Enclosure width Power consumption @ 24 VDC without PoE Commercial temp.: 0 °C ... +55 °C MTBF in million h RJ45 SFP SC 4 - 3x MM (0.55 km) 120 mm 0.19 A 0.98 Ha-VIS eCon 2043GB-AD-P 24 02 404 3130 Ha-VIS eCon 2043GBT-AD-P 24 02 404 3120 4 - 3x SM (10 km) 120 mm 0.20 A 0.98 Ha-VIS eCon 2043GB-AF-P 24 02 404 3230 Ha-VIS eCon 2043GBT-AF-P 24 02 404 3220 5 - - 120 mm 0.15 A 1.01 Ha-VIS eCon 2050GB-A-P 24 02 405 0030 Ha-VIS eCon 2050GBT-A-P 24 02 405 0020 5 - 2x MM (0.55 km) 120 mm 0.19 A 0.98 Ha-VIS eCon 2052GB-AD-P 24 02 405 2130 Ha-VIS eCon 2052GBT-AD-P 24 02 405 2120 5 - 2x SM (10 km) 120 mm 0.20 A 0.98 Ha-VIS eCon 2052GB-AF-P 24 02 405 2230 Ha-VIS eCon 2052GBT-AF-P 24 02 405 2220 6 - 1x MM (0.55 km) 120 mm 0.19 A 0.98 Ha-VIS eCon 2061GB-AD-P 24 02 406 1130 Ha-VIS eCon 2061GBT-AD-P 24 02 406 1120 6 - 1x SM (10 km) 120 mm 0.20 A 0.98 Ha-VIS eCon 2061GB-AF-P 24 02 406 1230 Ha-VIS eCon 2061GBT-AF-P 24 02 406 1220 7 - - 120 mm 0.19 A 0.98 Ha-VIS eCon 2070GB-A-P 24 02 407 0030 Ha-VIS eCon 2070GBT-A-P 24 02 407 0020 Copyright© 2014 HARTING Technology Group All rights reserved Date of issue 02.2015 ICPN Datasheet 0840/01 Switch Part no. Industrial temp.: -40 °C ... +70 °C Switch Part no.
24024050020 价格&库存
很抱歉,暂时无法提供与“24024050020”相匹配的价格&库存,您可以联系我们找货
