RUGGED HIGH-SPEED STRIPS
FEATURES & BENEFITS
Edge Rate® rugged high-speed connector strips are designed for high-speed, high cycle applications,
and enabled by Samtec's signal integrity-optimized Edge Rate® contact system.
• Up to 1.5 mm contact wipe for a reliable connection
• 20 to 200 positions
• Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch
• 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch
• 0.635 mm pitch system with extremely slim 2.5 mm body width
• Rugged latching, extended guide posts and 360° shielding
Signal integrity-optimized
Edge Rate® contact
system reduces
broadside coupling
• Severe Environment Testing qualified (ERM8/ERF8); aligns with MIL-DTL-55302.
Visit samtec.com/set
EDGE RATE® STACK HEIGHT FLEXIBILITY
(shown in mm)
5
7
8
ERM6/
ERF6
10
9
12
11
ERM5/ERF5
13
14
15
16
18
17
ERM8/ERF8
Rugged 360º shielding
reduces EMI
KEY SPECIFICATIONS
SERIES
PITCH
ERM5 / ERF5
0.50 mm
ERM6 / ERF6
0.635 mm
ERM8 / ERF8
0.80 mm
F-224
INSULATOR
MATERIAL
TERMINAL MATERIAL
Phosphor Bronze or BeCu (ERM5),
BeCu (ERF5)
Black LCP
Copper Alloy
Phosphor Bronze or BeCu (ERM8),
BeCu (ERF8)
PLATING
Au or Sn
over 50 µ"
(1.27 µm)
Ni
OPERATING
TEMP RANGE
-55 °C to +125 °C
CURRENT
RATING
VOLTAGE
RATING
1.5 A
190 VAC
1.4 A
155 VAC
1.4 A
225 VAC
LEAD-FREE
SOLDERABLE
Yes
samtec.com/EdgeRate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.80 mm) .0315" PITCH • SHIELDED HIGH-SPEED HEADERS & SOCKETS
TYPE
ERM8
= Shielded
Terminal
ERF8
= Shielded
Socket
POSITIONS
PER ROW
–010,
–020,
–025,
–030
LEAD STYLE
–02.0
= 2 mm (ERM8 with
–S only)
–05.0
= 5 mm (ERF8 with
–S & ERM8 with
–EGPS & –DSS only)
–07.0
= 7 mm (ERF8 with
–EGPS only)
–09.0
PLATING
OPTION
DV
–L
OPTIONS
"X"R
–S
= 10 µ"
(0.25 µm) Gold
on contact,
Matte Tin on
tail
–TR
= Shield
(Lead Styles: ERM8 –02.0 only; ERF8 –05.0 only)
= Tape & Reel
–FR
–EGPS
= Full Reel
Tape & Reel
(must order
maximum
quantity per reel;
contact Samtec
for quantity
breaks)
= Extended Guide Post Shield
(Lead Styles: ERM8 –05.0 & -09.0 only; ERF8 –07.0 only)
–S
–DSS
= 30 µ"
(0.76 µm) Gold
on contact,
Matte Tin on
tail
= Differential Pair with Extended Guide Post Shield
(ERM8 only, with –05.0 & -09.0
Lead Styles, –10 & –025 Positions only)
–K
= 9 mm (ERM8 with
–EGPS & –DSS only)
= Polyimide Film Pick & Place Pad
(–02.0 Lead Style N/A)
–P
= Pick & Place Pad
(ERM8 –02.0 & -05.0 Lead Styles only)
ERM8-S
Board Mates:
See "Mated Height" Chart
01
LEAD
STYLE
No. of Positions x
(0.80) .0315 + (6.00) .236
A
B
–05.0
(9.87) .389
(10.81) .425
-09.0
(13.87) .546 (14.81) .583
(7.20)
.283
(Note: ERF8-S does not
mate with ERM8-EGPS)
02
(7.18)
.283
A
B
(5.97)
.235
–S OPTION
–EGPS OR –DSS OPTION
View complete specifications at: samtec.com?ERM8
MATED HEIGHTS
7 mm
ERF8-S
ERM8-02.0-S
to
ERF8-05.0-S
Board Mates:
(Note: ERM8-EGPS does
not mate with ERF8-S)
9 mm
12 mm
16 mm
ERM8-05.0-EGPS ERM8-09.0-EGPS
ERM8-02.0-S
to
to
to
ERF8-07.0-EGPS ERF8-07.0-EGPS ERF8-07.0-EGPS
A
01
(6.80)
.268
02
LEAD
STYLE
–05.0
Notes:
Severe Environment
Testing qualified; aligns
with MIL-DTL-55302.
Some lengths, styles and
options are non-standard,
non-returnable.
–07.0
B
B
(-S)
(-EGPS)
(5.90)
.232
N/A
N/A
(7.42)
.292
(7.20)
.283
B
POSITIONS
PER ROW
A
–010
(18.00) .71
–020
(26.00) 1.02
–025
(30.00) 1.18
–030
(34.00) 1.34
–S OPTION
View complete specifications at: samtec.com?ERF8
samtec.com/EdgeRate
F-224
很抱歉,暂时无法提供与“ERF8-100-05.0-L-DV”相匹配的价格&库存,您可以联系我们找货
