Relay Sockets with Miniature Switching Relay
Switching current (A)
Relay with 1 changeover contact (1u)
for normal switching power
Nominal input voltage
VN 12 V, 24 V, 48 V, 60 V, 110 V, 220 V DC
VN 24 V, 115 V, 230 V AC/DC
10
resistive load
1
0.1
1
10
100
400
Switching voltage (V)
DC load limit curve
A1
Note: Inductive loads have to be attenuated by an
appropriate protective circuit in order to protect relay coils
and contacts.
A2
Description
VN
IN
Item No.
Pack.
Unit
Relay socket with miniature switching relay,
for DIN 35 rail
12 V DC
24 V DC
48 V DC
60 V DC
17 mA
10 mA
6.5 mA
5.2 mA
857-303
857-304
857-305
857-306
1
1
1
1
Technical Data
Coil:
Input voltage range
Contacts:
Contact material
Max. continuous current
Max. switching voltage
Max. switching power (resistive)
Recommended minimum load
Pull-in/drop-out/bounce time typ.
Mechanical life
General specifications:
Nominal voltage to EN 60664-1
Dielectric strength, contact-coil (AC, 1 min)
Dielectric strength open contact (AC, 1 min)
Dielectric strength contact-contact (AC, 1 min)
Ambient operating temperature at VN
Storage temperature
Dimensions (mm) W x H x L
Wire connection
Cross sections
Strip length
Standards/specifications
WAGO Kontakttechnik GmbH & Co. KG
Subject to design changes
14.01.2015
VN
IN
Item No.
Pack.
Unit
24 V AC/DC
115 V AC/DC
230 V AC/DC
8.5 mA
4 mA
3.5 mA
857-354
857-357
857-358
1
1
1
Accessories see pages 33 … 35
VN -15 % ... +20 %
VN -15 % ... +20 % (857-354/857-357)
VN -15 % ... +10 % (857-358)
AgNi
6A
250 VAC
1500 VA AC; DC see load limit curve
10 VDC / 10 mA, 24 VDC / 1 mA
8ms / 4ms / 5 x 106 switching operations
AgNi
6A
250 VAC
250 V / 4 kV / 2
4 kVrms
1 kVrms
-40 °C ... +60 °C
-40 °C ... +70 °C
6 x 81 x 94
Height from upper-edge of DIN 35 rail
CAGE CLAMP® S
0.34 … 2.5 mm² / AWG 22 … 14
9 … 10 mm / 0.35 … 0.39 in
EN 60664-1; EN 61810-1; EN 61140; r
(857-304: g)
250 V / 4 kV / 2
4 kVrms
1 kVrms
-25 °C ... +60 °C
-40 °C ... +70 °C
6 x 81 x 94
CAGE CLAMP® S
EN 60664-1; EN 61810-1; r
(857-358: g)
Postfach 2880 - D-32385 Minden
Hansastr. 27 - D-32423 Minden
Tel.: +49(0)571/887-0
E-Mail: info@wago.com
Fax: +49(0)571/887-169
www.wago.com
很抱歉,暂时无法提供与“857-354”相匹配的价格&库存,您可以联系我们找货
