DF63SF-1618SCFA(05)
DF63SF-1618SCFA(05)
    HRS(广濑)
    CONN CRIMP SKT 16-18AWG
DF63SF-1618SCFA(05) 数据手册
12A 3.96mm pitch Wire-to-Board Connectors DF63SF Series (UL, C-UL, Listed) Power circular connector (Ex:HR41A) Small & Vertical Mating Possible to pass through a narrow opening ■Features Ø14.8 1. Rated for up to 12A 2. The small vertical-mating design allows for easy assembly Vertical mating and holizontal wiring (Side Feed) enables a high flexibility in the arrangement of components. (Fig.1) Hole for installation Minimized keep-out space Other components can be mounted under the cables (5) DF63SF has the capacity to handle a max of 12A when using 16 AWG wire. (Please refer to the chart for the rated current in each pin counts.) (9.5) 3. Secure Mating with a Clear Tactile Click A large area to press down the socket at the center. Secure mating with a clear tactile click with sharp sound. (Fig.2) 4. Molded lance design The lance is actually part of the housing instead of being a part of the terminal. This prevents tangled wires during assembly. (3.2) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Easy Mating Comparison with general right-angle type General product DF63SF Excess cable Perfect fit 5. THR mounting Contribute to the improvement of productivity by corresponding to the automatic mounting machine. 6. Glow Wire compliance (Compliant with IEC 60695-2-11) Fig.1 * Supports 7.92mm pitch Also supports 7.92mm pitch with 2 pos. by skipped pin. Secure mating g Click ! Easy-to-push with one finger Fig.2 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.4② 1 DF63SF Series●12A 3.96mm pitch Wire-to-Board Connectors ■Product Specifications No. of Contacts 16 AWG 18 AWG 3 12A 10A 15A 13A Current Rating (Note 1) 2 (7.92mm pitch) Specification Voltage Rating UL,C-UL TÜV Ratings Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item 1. Insulation Resistance 2. Withstand Voltage 3. Contact Resistance 4. Vibration Resistance 5. Shock Resistance 6. Moistureresistance 7. Temperature cycles 8. Durability 9. Solder heat resistance AC/DC 630V AC/DC 600V AC/DC 300V Operating temperature range -55 to 105ç (Note 2) Operating humidity range 20 to 80% (Note 3) Storage temperature range -10 to 60ç (Note 4) Storage humidity range 40 to 70% (Note 4) UL/TÜV File No. and Recognition No. UL   :E52653 C-UL   : E52653 TÜV   :R50372836 Specifications Conditions No less than 1,000Mø Measured at DC 500V No flashover or breakdown AC 2,200V is applied for one minute. No more than 10mø Measured at 1mA (DC or 1000Hz) and no higher than 20mV Frequency 10-55Hz, half amplitude 0.75 mm, 10 times in each of the three directions Accelerated velocity : 490 m/s2 for 11ms, half-sine wave in 3 directions, 3 times for each direction Temperature : 40±2ç ; humidity : 90 to 95%, left as it is for 96 hours -55ç : 30 minutes → 85ç : 30 minutes 5 cycles 50 mating cycles Reflow : according to the Recommended Temperature Profile Hand soldering : temperature of soldering iron at 350ç±10ç for 5 seconds No electrical discontinuity of 1µs or greater No electrical discontinuity of 1µs or greater Contact resistance : no more than 20mø Insulation resistance : no less than 500Mø Contact resistance : no more than 20mø Insulation resistance : no less than 1,000Mø Contact resistance : no more than 20mø The resin parts should withstand the temperature and resist melting. Note 1:This is the maximum current rating while all pins are powered or used as all power lines. Note 2:Includes temperature rise caused by current flow. Note 3:Use without condensation on parts. Note 4:The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating temperature for temporary storage such as pre-assembly and during shipping. ■Materials / Finish Component Header Crimp socket Crimp contact Part Insulator Contact Insulator Contact Material LCP Copper alloy PBT (glass-reinforced) Copper alloy Finish Black Gold plated Black Gold plated UL Specification UL94V-0 − UL94V-0 − ■Product Number Structure Refer to the chart below when datermining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Header ❶ Series name:DF DF 63SF - * P - 3.96 TV ❶ ❷ ❸ ❹ ❺ ❻ ❷ Series No. :63SF ❺ Contact Pitch:3. 96mm 7.92mm ❸ Number of contacts:2, 3 ❻ Termination style TV:THR vertical type ❹ Connector type P:Header ●Crimp socket DF 63SF - * S - 3.96 C ❶ ❷ ❸ ❹ ❺ ❻ ●Crimp contact DF 63SF - 1618 SCFA ❶ 2 ❷ ❶ Series name:DF ❺ Contact Pitch:3. 96mm ❷ Series No. :63SF ❻ Termination style C:Crimp housing ❸ Number of contacts:3 ❹ Connector type S:Crimp socket ❶ Applicable Conductor 1618 16 to 18 AWG ❷ Packaging  SCFA:Socket contacts・Reel・Gold plated DF63SF Series●12A 3.96mm pitch Wire-to-Board Connectors ■Straight Header (THR) 15.8 11.82 7.92 P=3.96 Cav. No. HRS mark 8.5 96 9.6 8.2 Recommended PCB Layout (t=1.6mm) Lot No. 6BC1 1.4 7.92±0.05 5( Outline DF63SF-3P-3.96TV ±0 .5± 0.0 [Specification number]** (51) :Gold plated(0.2µm) , embossed packaging (52) :Gold plated(0.76µm) , embossed packaging R1 R0 1.65 0.8 (5) (9.6) ro 1.95±0.05 .05 (La ugh nd) ho le) 1.1±0.05 2.1±0.05 (15.8) Th 2.95±0.05 P=3.96±0.05 Part No. HRS No. No. of Contacts DF63SF-3P-3.96TV (**) 680-0701-0 ** 3 DF63SF-2P-7.92TV (**) 680-0704-0 ** 2 Note : Please place orders for embossed packaged products in multiples 450 (450 pcs/reel). A .1 +0 0 .5 1.5+0.1 0 5) .7 (0 1.7 +0.15 0 5±0.2 Ø1 B A-A (16.2) 12.4±0.2 Vacuum cap 14.2±0.1 28.4±0.1 32±0.3 16±0.1 4±0.1 2±0.1 1.75±0.1 BPackaging Specification R A Unreeling direction B (10.9) B-B (8.5) ●Style of reel Product Label Ø1.5 sprocket hole far side Ø1 3± 0.2 38.4MAX 32.4 +20 Ø80±1 0.5 2± Ø380±2 Unreeling direction 8 0. 1± Ø2 R1 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No.1 3 DF63SF Series●12A 3.96mm pitch Wire-to-Board Connectors ■Crimp Socket 18.4 HRS mark Contact No.1 7.92 Part No. HRS No. No. of Contacts DF63SF-3S-3.96C 680-0702-0 3 8.25 P=3.96 Note : Please specify the number of packs (100 pcs/pack) when placing orders. ■Crimp Contact 3.8 2 2 1.3 0.85 2 16.65 11.85 2.72 Ø2 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 13.3 5.75 P=11.5 Part No. t=0.25 HRS No. Type Quantity Finish 680-0703-0 Reel contact(Note 1) 3,000 pcs/reel DF63SF-1618SCA Under planning Pack contact(Note 2) 100 pcs/pack Gold plated 0.2µm DF63SF-1618SCFA (05) 680-0703-0 05 Reel contact(Note 1) 3,000 pcs/reel DF63SF-1618SCA (05) Under planning Pack contact(Note 2) 100 pcs/pack DF63SF-1618SCFA Gold plated 0.76µm Note 1 : The package style is 3,000 pcs/reels. Please place orders in multiples of reels. Note 2 : The package style is 100 pcs/packs. Please place orders in multiples of packs. ●Applicable wire (Tinned Annealed Copper Wire) Conductor size (Core structure) Jacket outer diameter Recommended wire (Note 1) Strip length (Note 2) 16 AWG 26pieces/0.254mm in diameter Ø2.40mm UL1007 16 AWG 54pieces/0.18mm in diameter Ø2.53mm UL1430 18 AWG 34pieces/0.18mm in diameter Ø2.10mm UL1007 3.1 to 3.8mm Note 1 : Please contact our Sales representative when using wires other than applicable wires. Note 2 : The strip length is a reference value. Please adjust the strip length accordingly for specifications and requirements. Refer to the crimping quality standard (ATAD-H0891-00) for details. BApplicable Crimping Tool Type Applicator Press body Hand tool Contact extraction tool Part No. HRS No. AP105-DF63SF-1618S 901-4651-0 00 CHX022400H-UP(Note 3) − CM-105C 901-0001-0 00 HT802/DF63SF-1618SCFA(Note 2) 550-0440-0 00 DF-C-PO (B) 550-0179-2 00 Applicable contact DF63SF-1618SCFA(**) − DF63SF-1618SCA(**) − Note 1 : Any problems that occur from using tools other than those specified by Hirose, are not covered by warranty. Note 2 : Hand tool dies cannot be switched. The compatible wire is Limted to UL1007 (16 to 18 AWG). Note 3 : Applicator manufactured by JAPAN AUTOMATIC MACHINE (J.A.M.). Please access to web of J.A.M., if you make inquiries about the applicator or crimp defect. (URL : http://www.jam-net.co.jp) 4 DF63SF Series●12A 3.96mm pitch Wire-to-Board Connectors BPrecautions 1. Recommended Temperature Profile (Compatible with leadfree soldering) 10sec MAX MAX 250℃ 250 220℃ TEMPERATURE (℃) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 200 180℃ 150 100 0 TIME (sec) 90 to 120sec 60sec MAX PRE-HEATING TIME SOLDERING TIME [Applicable Conditions] 1. Peak temperature : 250℃ max. 2. Soldering area : 220℃ min. for less than 60 seconds 3. Preheating area : 150℃ to 180℃ for 90 to 120 seconds 4. Number of times : no more than 2 times * Measurement is conducted at the contact lead part Soldering results may change depending on conditions such as solder paste type, manufacturer, PCB size, and other soldering materials. Please determine all mounting conditions before use. Note 1 : This temperature profile is a recommended value. Note 2 : Prohibited backside-surface mounting. 2. Recommended manual soldering conditions Temperature of soldering iron : 350±10℃, soldering time : within 5 seconds 3. Recommended screen thickness and board thickness Screen thickness : 0.15mm Board thickness : 1.6mm 4. Warpage of the Board A maximum of 0.02mm at the center of connector, as measured from either end of the connector 5. Cleaning Conditions IPA cleaning is allowed. (Cleaning is not recommended due to potential changes in mating action and other variables. Please contact us if you use other cleaning agents.) 6. Noteworthy Points 1. Please note that any mating operation of the connector when not mounted on the board may cause damage or deformation of the contacts. 2. During hand soldering, do not apply flux, as it will flow over the connector. 3. This housing color may have slight variations depending on the production lot. This color variation does not affect performance. 4. The connector could be damaged if it is pulled out forcibly. When it is hard to pull out, push it in slightly first and then depress the lock and un-mate. 5. When thick, short sections of wire are used, the connector could be deformed due to the force of the wires’ position. Route cables in such a way that they do not twist when being installed. 6. Make sure to turn off the power when mating or un-mating the connector. 7. Please do not touch any area around the contact part with your hand when the power is on; it could be very dangerous. 8. Please refer to “DF63SF Series mating and unmating Procedure Document (ETAD-H0901-00)” for points in handling regarding mating operations. 9. Please refer to “Harness procedure manual (ETAD-H0897-00)” for points in harness operations. 5 DF63SF Series●12A 3.96mm pitch Wire-to-Board Connectors BRemoving Contacts ●Contact extraction tool : DF-C-PO (B) ●For Crimp contacts : DF63SF-1618SC (F) A (**) ●Procedure When pulling out an inserted crimp terminal, please lift mold lance with using, DF-C-PO (B) or pinted needle and then pulling the cable. Due to any previous repairs, the strength of the lance could have been compromised. Hirose recommends the use of a new crimp housing to assure proper performance. Sectioned drawing of the housing 1 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact extraction tool Powered by TCPDF (www.tcpdf.org) 2 Caution Please be very careful when removing the contact work so that you don’t become injured by the protruding part of the crimp contact. BMated dimensions ●Wire-to-Board Connection using the straight pin header (15.8) DF63SF-3S-3.96C (18.4) (3.2) (9.5) DF63SF-3P-3.96TV BRated values Please avoid using the device above the rated values. Also, do not insert or pull out energized or “ live” wires. BOperating environment Please contact us if you are designing this connector into environmental conditions where high and low temperatures are repeated. ® 6 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 04/2018. Contents are subject to change without notice for the purpose of improvements.
DF63SF-1618SCFA(05) 价格&库存
很抱歉,暂时无法提供与“DF63SF-1618SCFA(05)”相匹配的价格&库存,您可以联系我们找货
DF63SF-1618SCFA(05)
  • 3000+3.644513000+0.46954
  • 6000+3.470606000+0.44714
  • 9000+3.372799000+0.43453
  • 15000+3.2534615000+0.41916
  • 21000+3.1772221000+0.40934
库存:4765
DF63SF-1618SCFA(05)
  • 1+5.397611+0.69540
  • 10+4.5879610+0.59109
  • 25+4.3005225+0.55406
  • 50+4.0951150+0.52759
  • 100+3.89945100+0.50239
  • 250+3.65521250+0.47092
  • 500+3.48036500+0.44839
  • 1000+3.314231000+0.42699
库存:4765
