FFMD-08-T-03.00-01-N
    SAMTEC(申泰)
    .050 CABLE PLUG
FFMD-08-T-03.00-01-N 数据手册
TIGER ™ IDC EYE TIGER EYE™ FLAT IDC WIRE CABLES (1.27 mm) .050" PITCH • FFMD SERIES FFMD Mates: FLE*, SFMC* TRANSFER END Mates: FTS, FTSH, EHF, SHF, ESHF SERIES - NO. PINS PER ROW FFMD - –04, –05, –08, –10, –13, –17, –20, –25 = Terminal Strip –S = Single End –D - OVERALL LENGTH - 01 - –“XX.XX” –N = Notch Polarization on socket (-T end only) (Not available with -04 position) –T = Transfer End Insulator Material: PBT Terminal: Phosphor Bronze Contact: BeCu (-T) Plating: Sn over 50 µ" (1.27 µm) Ni Wire: 30 AWG Current Rating: 2.5 A per pin (2 pins powered) Operating Temp Range: -40 °C to +105 °C Voltage Rating: 215 VAC / 304 VDC - TRANSFER OPTION Leave blank for –S and –D End Options. = Assembled Length = Double End (Standard sizes) SPECIFICATIONS END OPTION OTHER OPTION –RW = Reverse Wiring (Red wire opposite position #1) –D “XX” = Daisy Chain –SR = Strain Relief (Mates only with ESHF Series) (Not available with –O, –M, –R or –DXX) –R 01 = Reversed (3.05) .120 –M = Middle Reversed (Requires –DXX) No. of positions x (1.27) .050 + (4.19) .165 –O = Outside Reversed (Requires –DXX) (5.08) .200 Assembled Length in INCHES (± .130") 2 inches minimum ALSO AVAILABLE MOQ Required Other sizes Assemble Length (–“XX.XX”) Single End (—S) Double End (—D) (50.8 mm) 2.00 min. Transfer End (—T) “XX” ± 1/8" No. of positions x (1.27) .050 + (8.00) .315 01 02 *Note: Standard FFMD callout will not mate with FLE, SFMC. Must use gold plated callouts. (See drawing on web.) When mated with a socket, Wire 1 mates with Pin 2; Wire 2 mates with Pin 1, etc. Note: This Series is non-standard, non-returnable. (101.60 mm) 4.00 min. Reverse Wiring (—RW) Reversed (—R) Daisy Chain (—D “XX”) Middle Reversed (—M) Strain Relief (—SR) Outside Reversed (—O) samtec.com?FFMD Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
FFMD-08-T-03.00-01-N 价格&库存
很抱歉,暂时无法提供与“FFMD-08-T-03.00-01-N”相匹配的价格&库存,您可以联系我们找货
