FH63-30S-0.5SH
FH63-30S-0.5SH
    HRS(广濑)
    HIROSE(HRS) - FH63-30S-0.5SH - FFC / FPC Board Connector, 0.5 mm, 30 Contacts, Receptacle, FH63, Sur...
FH63-30S-0.5SH 数据手册
0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector FH63 Series Single action lock (Dimension diagram : 30pos.) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.8mm 21.9 4mm Insert FPC/FFC without opening the lock lever before insertion! 5.15mm Fig.1 Two-point contact design for dust prevention ■Features 1. Automatic single action locking design · Single action locking by simply inserting FPC after mounting contributes to enhanced workability. (Fig.1) (Lock release by operating the lock lever when removing.) · Operation of the lock lever is not required at the time of mating FPC. Can be inserted with one hand. Contributes to reduced assembly time. The lock lever will not be damaged by operation. Mating failure is reduced by eliminating the need to operate a lever while mating. 2. Two-points of contact prevents contact failure by dust Fig.2 Supports FPC/FFC/Shield FFC · High contact reliability by independent spring two-point contact design, preventing contact failure by dust. (Fig.2) 3. Supports FPC/FFC/Shield FFC · FH63 allows you to choose from FPC/FFC/Shield FFC. · Shielded FFC is acceptable for EMI prevention. (Fig.3) 4. High FPC retention force · The circuit is automatically locked after FPC/FFC is inserted by a single action. The notches on both sides of FPC are held by the lock lever, generating a high FPC retention force in spite of the small contact. (Fig.4) FPC FFC Shield FFC Shielded FFC is acceptable for EMI prevention. 5. Visual inspection on the mated status of FPC/FFC is possible. GND contact · As the notches on both sides of FPC can be checked from the top surface after inserting FPC/FFC, insufficient insertion during assembly is prevented. (Fig.5) 6. Environmental · Halogen free *AS defined by IEC 61249-2-21. Br : 900ppm max, Cl : 900ppm max, Br+Cl : 1,500ppm max FPC/FFC can be checked from the top surface after mating. OK Mated condition (correct position) Shield FFC GND contact and FFC GND plate contact at multiple points. Fig.3 High FPC retention force NG Insufficient insertion condition (incorrect position) Fig.5 Robust lock firmly retains FPC/FFC. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2017.8② Fig.4 1 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector ■Product Specifications Rated current 0.5A Rated voltage 50V AC/DC rms Rating Adaptive FPC contact specifications Storage temperature range : -10ç to +60°C (Note 2) Storage humidity range : Relative humidity 90% max. (No condensation) Thickness : = 0.33 ± 0.03mm Signal layout : Gold plated, GND plate : Tin plated Item Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating temperature range : -55ç to +105°C (Note 1) Operating humidity range : Relative humidity 90% max. (No condensation) Specification Conditions 1. Insulation resistance 500Mø min. 100V DC 2. Withstanding voltage No flashover or insulation breakdown 150V AC rms / 1 minute 3. Contact resistance 100mø max. * Including FPC/FFC conductor resistance 1mA AC 4. Durability (insertion / withdrawal) Contact resistance : 100mø max. No damage, cracks, or parts dislocation 10 cycles 5. Vibration No electrical discontinuity of 1µs or more Contact resistance : 100mø max. No damage, cracks, or parts dislocation Frequency : 10 to 55Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 directions 6. Shock No electrical discontinuity of 1µs or more Contact resistance : 100mø max. No damage, cracks, or parts dislocation Acceleration of 981m/s2, duration of 6 ms, sine half-wave waveform, 3 cycles in each of the 3 axes 7. Damp heat (Steady state) Contact resistance : 100mø max. Insulation resistance : 50Mø min. No damage, cracks, or parts dislocation 96 hours at temperature of 60ç and humidity of 90% to 95% 8. Temperature cycle Contact resistance : 100mø max. Insulation resistance : 50Mø min. No damage, cracks, or parts dislocation Temperature : -55°C / +15ç to +35ç / +105ç / +15ç to +35ç Time : 30 / 2 to 3 / 30 / 2 to 3 (Minutes) 5 cycles 9. Resistance to soldering heat No deformation of components affecting performance Reflow : Recommended Temperature Profile Manual soldering: 350 ± 10°C for 5 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity Range covers non-conducting condition of installed connectors in storage, shipment or during transportation. ■Materials / Finish Part Materials LCP LCP Copper alloy Copper alloy SUS Insulator Signal contact Grounding contact Reinforcing metal tabs Finish Grey Black Nickel barrier gold plated Pure tin reflow plated Pure tin reflow plated ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH 63 − 30S − 0.5 SH (99) ❹ Series name : FH Series No. : 63 No. of contacts : 30 Contact pitch : 0.5mm 2 ❺ ❻ Terminal type SH … SMT horizontal mounting type Specification Blank : Standard 3,500pcs/reel (99) : 500pcs/reel UL standard UL94V-0 UL94V-0 ------------------------------------------- FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector ■Connector Dimensions A±0.15 3 B±0.15 (C) (0.1) Signal contact No.1 Cavity No. 2 4.5±0.1 4.9±0.1 (3.3) (Pickup area) 1 Polarity mark Grounding contact No.1 2±0.1 E±0.1 Grounding contact No.2 E±0.1 (0.1) 5 D±0.15 4 a 2.8±0.2 0.5±0.1 (0.25) (F) (0.65) (5.15) (4) (2.85) (2.4) (2.2) 0.25±0.2 (0.87) (0.89) (0.42) (5.3) Ground contact point °) FPC/FFC/Shield FFC t=0.33 G±0.15 (45 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS mark 0.25±0.2 Reinforcing metal tabs Grounding contact 0.75±0.1 (Grounding contact lead) 4.25±0.2 0.55±0.1 Signal Signal (Lead of reinforcing metal tabs) contact point contact 3.9±0.2 0.35±0.1 (Signal contact lead) Note 1 : The dimension in parentheses are for reference. 2 : Lead co-planarity including reinforced chucking metals shall be 0.1 max. 3 : To be delivered with tape and reel packages. See the packaging specifications for details. 4 : Note that preventive hole for sink mark or slit could be added for improvement. 5 : The quality remains good, even with the dark spots, which could occasionally occur on molded plastic. 6 : This product satisfies halogen free requirements defined as 900ppm maximum chlorine, 900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine. Unit : mm Part No. HRS No. No. of Contacts FH63-10S-0.5SH Under planning (Note 1) 10 12.7 FH63-20S-0.5SH Under planning (Note 1) 20 17.7 9.5 6.55 9 1.5 12.15 14.9 FH63-30S-0.5SH 580-4400-0 ** 30 22.7 14.5 5.55 14 2 17.15 19.9 A B C D E F G 4.5 5.55 4 2 7.15 9.9 FH63-40S-0.5SH 580-4403-0 ** 40 27.7 19.5 10.55 19 1.5 22.15 24.9 FH63-50S-0.5SH Under planning (Note 1) 50 32.7 24.5 15.55 24 2 27.15 29.9 FH63-60S-0.5SH Under planning (Note 1) 60 37.7 29.5 20.55 29 1.5 32.15 34.9 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 3 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BRecommended PCB Mounting Pattern HX 0.02 Z 0.95±0.02 E 3.95±0.03 3.6±0.03 0.7±0.02 0.9±0.02 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (0.25) 2X 0.02 Z Z nX 0.02 Z 0.3±0.02 1.1±0.02 (0.15) B±0.02 0.5 0.3±0.02 E 2 D (±0.02) G (±0.02) BRecommended Stencil Pattern 2X 0.02 Y HX 0.02 Y 0.8±0.01 E 4.1±0.01 0.9±0.01 0.95±0.01 (0.25) 0.65±0.01 Y nX 0.02 Y 0.28±0.01 0.5 3.8±0.01 (0.05) B±0.02 0.28±0.01 E 2 D (±0.02) G(±0.02) Note 7 : 'n' shows the number of contacts. BRecommended Dimensions of PCB Mounting Pattern and Stencil Pattern Part No. HRS No. FH63-10S-0.5SH Under planning (Note 1) 10 4.5 4 FH63-20S-0.5SH Under planning (Note 1) 20 9.5 9 FH63-30S-0.5SH 580-4400-0 ** 30 14.5 14 2 19.9 8 FH63-40S-0.5SH 580-4403-0 ** 40 19.5 19 1.5 24.9 11 FH63-50S-0.5SH Under planning (Note 1) 50 24.5 24 2 29.9 13 FH63-60S-0.5SH Under planning (Note 1) 60 29.5 29 1.5 34.9 16 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 4 Units:mm No. of Contacts B D E G H 2 9.9 3 1.5 14.9 6 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BRecommended FPC/FFC Dimensions 0.4±0.03 nX 0.02 X 2.9±0.1 R0.2 R0.2 R0.1±0.1 1.3±0.07 1.3±0.07 J±0.05 L±0.1 BRecommended Shield FFC Dimensions 0.8±0.05 1.3±0.08 0.32±0.03 0.5 0.33±0.03 W nX 0.05 W R0.1±0.1 R0.1±0.1 R0.2 R0.2 1.3±0.08 1.3±0.08 (M) 1.1±0.3 1.1±0.3 0.5±0.3 R0.2 R0.2 R0.2 1.3±0.08 J±0.05 (K) B±0.05 6 MIN (Reinforcing film) 0.8±0.05 1.25±0.1 2.9±0.1 4.15±0.1 4.75±0.1 1 MIN (overlapping amount) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. R0.1±0.1 R0.2 R0.2 6 MIN (Reinforcing film) 1.3±0.07 1 MIN (overlapping amount) 1.3±0.07 0.5 4.15±0.1 X 1.25±0.1 R0.2 0.33±0.03 0.8±0.05 4.75±0.3 J±0.05 (K) B±0.02 0.8±0.05 Grounding plate Shield J±0.05 L±0.1 Note 7 : The value 'n' indicates the number of pos. 8 Overlap the shield on the grounding plate. BRecommended Dimensions of FPC/FFC/Shield FFC Part No. HRS No. No. of Contacts FH63-10S-0.5SH Under planning (Note 1) 10 4.5 7.1 FH63-20S-0.5SH Under planning (Note 1) 20 9.5 12.1 FH63-30S-0.5SH 580-4400-0 ** 30 14.5 17.1 FH63-40S-0.5SH 580-4403-0 ** 40 19.5 22.1 FH63-50S-0.5SH Under planning (Note 1) 50 24.5 FH63-60S-0.5SH Under planning (Note 1) 60 29.5 B J Units:mm K L M 5.5 9.1 4.9 10.5 14.1 9.9 15.5 19.1 14.9 20.5 24.1 19.9 27.1 25.5 29.1 24.9 32.1 30.5 34.1 29.9 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 5 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BMaterial composition of FPC/FFC/Shield FFC (Recommended specifications) ② Cover lay film ① Shield ④ Surface treatment ③ Cover lay adhesive ⑥ Base adhesive ⑤ Pattern copper foil ⑦ Base material ⑧ Reinforcing film adhesive ⑨ Reinforcing film ⑩ Grounding plate adhesive ⑬ Shield ⑪ Grounding plate ⑫ Surface treatment FPC Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Material name FFC Shield FFC FFC Thickness (μm) Materials Thickness (μm) Materials Polyimide 1mil Thermosetting adhesive 25 28 Polyester Adhesive 25 25 25 25 Nickel foundation 1 to 6μm +Gold plated 0.2μm (3.7) Nickel foundation 0.5 to 5μm +Gold plated 0.05 to 1μm (3.275) (3.275) Rolled copper 1oz ⑤ Pattern copper foil ⑥ Thermosetting adhesive Base adhesive ⑦ Polyimide 1mil Base material ⑧ Reinforcing film adhesive Thermosetting adhesive ⑨ Polyimide 8mil Reinforcing film ⑩ Grounding plate adhesive ⑪ Grounding plate ⑫ Surface treatment ⑬ Shield tape 35 8 25 55 200 Annealed copper foil Adhesive Polyester Adhesive Polyester Adhesive 35 25 25 30 150 30 35 25 50 30 188 Conductive tape Tin plated 1 to 5μm 37 ① ② ③ Shield tape Cover lay film Cover lay adhesive ④ Surface treatment 3. Caution 1. This specification is recommendation for the construction of the FH63 series FPC/FFC/Shield FFC (t=0.33±0.03mm) 2. For details about the construction, please contact FPC/FFC/Shield FFC manufactures. 6 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BPackaging Specifications ●Embossed Carrier Tape Dimensions R±0.1 1.75±0.1 R±0.1 7 P±0.3 9 6 9 Unreeling direction Unreeling direction ●Reel Dimensions ●Leader, Trailer Dimensions S±1 (Reel outer width) Unreeling direction Unreeling direction 400mm MIN(Leader) Ø380±2 Ø80±1 8 (Ø 13 ) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6 4±0.1 (2) 1 0. + 0 7 8±0.1 (3) (0.3) .5 Ø1 1 0. + 0 4±0.1 (2) Q±0.1 P±0.3 8±0.1 .5 Ø1 (3) (0.3) tape width 32mm or less 1.75±0.1 tape width 24mm or less 160mm MIN (Trailer, empty components) Embossed carrier tape Top cover tape 100mm MIN (empty components) U±1 (Reel inner width) Note 9 : 3500 pieces shall be packaged in one reel. (For standard products) Note 10 : The package complies with JIS C 0806 and IEC 60286-3 (Packaging of automotive mounting parts). Unit : mm Part No. HRS No. No. of Contacts P Q R S U FH63-10S-0.5SH Under planning (Note 1) 10 24 ---- 11.5 29.4 25.4 FH63-20S-0.5SH Under planning (Note 1) 20 32 28.4 14.2 37.4 33.4 FH63-30S-0.5SH 580-4400-0 ** 30 44 40.4 20.2 49.4 45.4 FH63-40S-0.5SH 580-4403-0 ** 40 44 40.4 20.2 49.4 45.4 FH63-50S-0.5SH Under planning (Note 1) 50 56 52.4 26.2 61.4 57.4 FH63-60S-0.5SH Under planning (Note 1) 60 56 52.4 26.2 61.4 57.4 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 7 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BTemperature Profile Applicable Conditions Temperature(℃) MAX 250℃ 245 Reflow method 220℃ Solder 200 : IR/Hot air Reflow environment : Room air : Paste type Sn/3.0Ag/0.5Cu (M705-GRN360-K2-V made by Senju 180℃ Metal Industry Co.) 150 Test PCB 150℃ : PCB material and size Glass epoxy 45×25×1mm Land size, per recommended on page 4. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 Metal mask : Thickness and opening size Per recommended on page 4. 50 25℃ 120±5 sec. Preheating time 0 20 to 40 sec. Peak temperature 60 to 90 sec. Soldering time start It may vastly depending on solder paste type, manufacturer, PCB size and mounting materials. Please use only after checking the mounting conditions. Time(sec.) 8 This temperature profile is based on the above conditions. FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BConnector operation and points to note [Operation method] Care needs to be taken when handling this connector. In order to prevent the damage and contact failure etc. (incorrect mating, disconnection of FPC pattern) of connectors and FPC, please use after confirming the following contents. This connector supports FPC/FFC/Shield FFC, however, for convenience, the description is made only for FPC. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Signal contact Grounding contact Lock lever Insulation case Connector's top surface (absorbing surface) Connector's bottom surface (mounting surface) (FPC insertion port) Reinforcing metal tabs (Diagram of the connector's top surface) (Diagram of the connector's front surface) 1. Delivered state This product is delivered with the lock lever closed. The lock lever does not need to be operated before inserting FPC. [Caution] · Do not open the lock lever when FPC is not inserted. Additionally, the lock lever does not need to be opened except to remove the FPC. (Example 1) · Do not operate the connector until it is mounted on the board. (Example 1) (Example 1) NG – Delivered state – Lock lever (open) Lock lever (closed) FPC not inserted Unmounted 9 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BConnector operation and points to note [Operation method] 2. How to insert FPC Insert FPC to the end correctly (Ex.2) horizontal to the board surface. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Caution] · Please confirm that the lock lever is closed when you insert FPC. Do not insert FPC while the lock lever is open. (Example 3) · Do not FPC while at the same time pressing the lock lever. (Example 4) · Insert FPC straight after positioning its tip end in a horizontal plane in reference to the guides on both ends of the connector mating port. · Insert in a manner that it won't be diagonal to the insertion direction. (Example 5) · When inserting, do not move the FPC in a vertical, lateral or diagonal direction. (Example 6) (Example 2) (Example 3) OK OK NG Lock lever (closed) Lock lever (open) Lock lever (closed) FPC (horizontal) FPC (horizontal) Insert FPC straight after positioning both its ends in a horizontal plane in reference to the guides on both ends of the connector mating port. (Example 4) (Example 5) NG Lock lever (closed) (Example 6) NG Lock lever (closed) FPC (horizontal) FPC (diagonal) FPC (diagonal) 10 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BConnector operation and points to note [Operation method] 3. Confirming the mated state of FPC When FPC is completely inserted, visually inspect the inserted status of FPC. (Example 7) (This connector uses the lock protrusion of the lock lever for positioning FPC.) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Caution] · FPC is not inserted deep enough or in a diagonal direction. (Example 8)(Example 9) · Because of the single action lock, The lever does not need to be operated after inserting FPC. (Example 7) OK The FPC tab inserted to the back of the mating port can be visually confirmed. Case butting position (Example 8) NG FPC is not inserted deep enough down to the back of the mating port. Case butting position (Example 9) NG FPC is inserted diagonally, and is not inserted to the back of the mating port. Case butting position FPC Outer shape of FPC is parallel to the outer shape of the housing. – Cross section of the lock section – FPC (shallow) FPC is not inserted deep enough, leaving a large gap between FPC and the housing. – Cross section of the lock section – The protrusion of the lock lever runs over the FPC tab. FPC (diagonal) FPC is inserted diagonally, and leaves a large gap between FPC and the housing. – Cross section of the lock section – The protrusion of the lock lever runs over the FPC tab. 11 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BConnector operation and points to note [Operation method] 4. How to unlock the lock lever Push up the lock lever slowly, and release the lock. (Example 10) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Caution] · When releasing the lock, operate the lock lever around the center. (Example 11) · When releasing the lock, do not operate only one side of the lock lever. (Example 12) · As the lock lever cannot be opened to over 45°, do not open it over this angle. (Example 13) · Do not pick and raise the lock lever off, or pull it. (Example 14) · Be sure to operate the lock lever by hand, and do not operate it with sharp-edged tools such as tweezers etc. (Example 15) · Don't apply an excessive force to the housing during operation. (Example 16) · The FPC insertion direction for this connector is different from the direction of the lock lever operation section. Do not try to open FPC from its insertion side. (Example 17) (Example 10) OK Lock lever Lock lever (Example 11) (Example 12) OK Operate the lock lever around the center. 12 NG Lock lever Operate the lock lever on one side. FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BConnector operation and points to note [Operation method] (Example 13) NG 45° Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Lock lever A load is applied to the lock lever in the opposite direction. (Example 14) (Example 15) NG NG Sharp-edged tools Lock lever Lock lever Rotation axis Load is concentrated on the rotation axis, and leads to breakage. (Example 16) (Example 17) NG Apply an excessive force to the lock lever. NG Lock lever Lock lever 13 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BConnector operation and points to note [Operation method] 5. How to remove FPC After releasing the lock lever, remove the FPC in the horizontal direction. (Example 18) When removing the FPC, do not press the lock lever. (Example 19) As the released lock lever automatically closes when removing the FPC, the lever does not need to be operated after removal. (Example 20) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Caution] · Do not pull out FPC while the lever is locked. (Example 21) · This connector is equipped with the FPC retention mechanism by means of the lock lever. When pulling out FPC, do not apply load in the upward or lateral direction. (Example 22) (Example 18) OK (Example 19) OK NG Lock lever (open) Lock lever (open) (Example 20) (Example 21) – Condition after FPC is pulled out – Lock lever (closed) NG Lock lever (closed) (Example 22) (Example 23) NG NG Lock lever (closed) FPC (diagonal) FPC (diagonal) 14 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BConnector operation and points to note [Operation method] [Cautions for PCB layout] Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Depending on the routing of FPC to mate, a load may be applied to the connector, which could lead to failure. In order to prevent failure, please consider the following concerning the mechanism design. [Caution] · When routing the FPC, please be careful that FPC is not pulled and routing is carried out with a margin. · Please check that the reinforcing film is placed horizontal to the board surface. (Example 23) · Please insure there is no load applied to the connector in the pulling, inserting or lateral direction. A bent FPC, it could cause contact failure or damage/disconnection of FPC. Therefore, please take some measure to fix FPC etc. (Example 24)(Example 25) · Don't place any parts under the FPC that will interfere with FPC. (Example 26) · As for the flexibility of FPC, please make adjustments with the FPC manufacturer. · Please ensure the FPC has adequate insertion space when designing the layout so that it is not inserted diagonally. Additionally, ensure the insertion space is not too short for FPC. Please adopt adequate parts layout and length for FPC. · When you design the board/layout, please secure a space required for operations. (Example 23) (Example 24) OK Reinforcing film NG Lock lever Reinforcing film Lock lever The state where a load is applied to FPC (Example 25) (Example 26) NG NG Lock lever Lock lever Reinforcing film The state where a load is applied to FPC Mounting parts interfering with FPC 15 FH63 Series●0.5mm Pitch, 2.8mm high, Single Action Lock at bottom contact point, FPC/FFC/Shield FFC connector BConnector operation and points to note [Notes for mounting on the board/after mounting on the board] [Notes for mounting on the board] Please be careful of the following at the time of board mounting. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Caution] · Please confirm recommendations for mount board land shape, metal mask opening shape, and FPC shape. · If the land is narrower than recommend, or if the metal mask opening is wider than recommend, solder (flux) wicking is more likely to occur. If there is difference from the recommendation, please use check the mounted state. · The level difference between the bottom surfaces of contact lead and the mold is designed to be small. When there is silk print etc. on the bottom surface of the connector, it could push up the connector bottom surface, and cause non-sticking solder or defective fillet formation. When there is silk print etc. on the bottom surface of the connector, please use it after checking the mounted state. · Use the reflow conditions within the specifications of our company. The mounted status may vary due to external conditions such as the type of cream solder, manufacturer, and board size. Please use it after checking the mounted state. · Please control the board warpage as much as possible. While the coplanarity of this connector is 0.1mm or less, defective soldering could occur if the board warpage is considerable. · When mounted on FPC, be sure to provide a reinforcing plate to ease handling. We recommend a reinforcing plate of 0.3mm or thicker made of glass epoxy material. · When pulling out the emboss from the reel, or when the connector is absorbed from the emboss and so on, do not apply any excessive external force (of 1N or more) to the connector before mounting. Powered by TCPDF (www.tcpdf.org) [Cautions when handling the board after mounting] Please be careful of the following when handling the board after mounting operation. [Caution] · Do not apply any load to the board in the assembly process, such as "dividing a multi-piece board" or "securing the board to the frame". Such action could apply a load to the connector and damage it. · Use the board with the deflection being 1mm or less when the board width is 100mm. (Example 27) If the board has some deflection, it could apply a load to the connector and damage it. (Example 27) 1 MAX 100 Connector 1 MAX Connector PCB 100 [Cautions for hand-soldering] Please be careful of the following when hand-soldering for repair work etc. [Caution] · Do not hand-solder while FPC is inserted. · Please be careful not to apply excessive heat, or allow the solder iron to touch any place other than the connector contact lead. Such action could cause the connector to be deformed or melted. · Do not supply an excessive amount of solder (flux). If too much solder (flux) is supplied to the contact, the solder or flux could adhere on the contact point and cause contact failure. Additionally, if you supply too much solder to the reinforcing metal tabs the rotational action of the lock lever could be defective and the connector could be damaged. ® 16 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2017. Contents are subject to change without notice for the purpose of improvements.
FH63-30S-0.5SH 价格&库存
很抱歉,暂时无法提供与“FH63-30S-0.5SH”相匹配的价格&库存,您可以联系我们找货
FH63-30S-0.5SH
  • 3500+11.501773500+1.48673
