FLAT FLEXIBLE CABLE
(FCC) JUMPER & SOCKET
(1.00 mm) .0394" PITCH • FJ/ZF1/FC1 SERIES
FJ
Mates:
FC1, ZF1
FJ
ZF1/FC1
NO. OF
POSITIONS
–05, –10, –15,
–20, –25, –30
Mates:
FJ
SPECIFICATIONS
FJ
Conductor:
Tin Plated Copper
Conductor Resistance:
300 Ω/km max
Operating Temp Range:
-30 °C to +80 °C
Voltage Rating:
300 VAC
Length in inches
–R
= (76.2 mm) 3.00"
= Reversed End
–06.00
–12.00
= (304.8 mm) 12.00"
–24.00
= (609.6 mm) 24.00"
(Standard Lengths)
NO. OF
POSITIONS
–05, –10, –15,
–16, –20, –25, –30
(No. of pins x (1.00) .03937)
+ (5.85) .230
–R STYLE
LEAD
STYLE
PLATING
OPTION
–01
–T
= Contact
Bottom
WT
OPTION
–TR
= Weld Tab
= Tape & Reel
–FR
–02
= Full Reel Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(5.30) .209
PROCESSING
FC1
NO. OF
POSITIONS
(3.00)
.118
–05, –10, –15, –20, –25
LEAD
STYLE
–01
= Vertical
PLATING
OPTION
–T
= Tin
–02
= Horizontal
(2.77)
.109
(No. of pins x (1.00) .03937)+ (2.33) .092
Some sizes, styles and
options are non-standard,
non-returnable.
–WT
= Matte Tin
= Contact
Top
(10 positions
only)
(No. of pins x (1.00) .03937) + (7.00) .276
Notes:
FJ Stiffener color will be
blue or black at Samtec’s
discretion.
–4
= (4.00 mm) .157"
(Required for mating
with FC1 & ZF1)
= (152.4 mm) 6.00"
–D STYLE
ZF1
STRIP
LENGTH
–03.00
(4.00)
.157
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Sn over 50 µ" (1.27 µm) Ni
-55 °C to +105 °C
Max Cycles:
25 with FJ
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
LENGTH
–D
(No. of
positions
x (1.00)
.03937)
+ (1.00)
.03937
FC1
ZF1/FC1
STYLE
= Double End
LENGTH
ZF1
Insulator Material:
Contact Material:
Phosphor Bronze
Plating:
Sn over 40 µ" (1.02 µm) Ni
Weld Tab: Phosphor Bronze
-55 °C to +105 °C
(5.18)
.204
(6.35)
.250
(4.09)
.161
—01
OPTION
–LC
= (4.00 mm)
.158" DIA
Polyimide film
Pick & Place Pad
(–01 only)
–WT
= Tape & Reel
= Weld
Tab
(–02 only)
—LC
—02
samtec.com?FJ, samtec.com?ZF1 or samtec.com?FC1
–K
= Locking
Clip
(Manual
placement
required)
(–01 only)
–TR
–FR
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact Samtec
for quantity
breaks)
F-224 WEB
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“FJ-30-D-29.50-4”相匹配的价格&库存,您可以联系我们找货
