F-217
FTS–110–02–F–DV
FTS–111–02–L–DV–SA
FTS–122–01–F–DV
FTS–116–02–L–D
(1.27 mm) .050"
FTS SERIES
MICRO LOW PROFILE TERMINAL STRIPS
SPECIFICATIONS
Board Mates:
CLP, FLE
For complete specifications and
recommended PCB layouts see
www.samtec.com?FTS
Cable Mates:
FFSD
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Operating Temp Range:
-55 °C to +125 °C
Plating:
Sn or Au over 50 µ"
(1.27 µm) Ni
Current Rating:
3.3 A per pin
(1 pin powered per row)
RoHS Compliant:
Yes
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
.004" (0.10 mm) max
Mates with
socket strips
or IDC cable
Low profile
(1.27 mm) .050"
OPTIONS
–S OPTION
–SA OPTION
Surface
mount or
through-hole
–P OPTION
Shrouded and
alignment pin
options available
Micro pitch
.050" x .050"
(1.27 mm x 1.27 mm)
–TR OPTION
Impedance matched for
high speed applications
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
FTS
1
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
ROW
OPTION
OTHER
OPTION
–D
(–D & –DV only)
FILE NO. E111594
(MOQ Required)
= .120"
(3.05 mm)
Post
(Mates with
FFSD)
02 thru 50
• Alignment pin
Contact Samtec.
(except –S & –SA
option = 05 thru 46)
(5.84)
.230
–02
No. of positions x .050 (1.27)
02
50
(1.27)
.050
(3.42)
.135
49
01
(2.16)
.085
50
01
No of positions x .050 (1.27)
+ .325 (8.25) = –SA
+ .200 (5.08) = – S
02
46
(4.70)
.185
(0.86)
.034
(3.48)
.137
01
45
= Double
Through-hole
–L
= Double
Vertical SMT
–S
–S
= Single
Through-hole
= End Shroud
(05 thru 46
positions. Style
-02 & -03 only)
–SV
= Single
Vertical SMT
= .065"
(1.65 mm)
Post
(Mates with
CLP)
–P
= Pick &
Place Pad
(04 positions
minimum)
(3.56)
.140
(1.40)
.055
–SA OPTION
LEAD
A
STYLE
– 01 (3.05) .120
– 02 (1.91) .075
– 03 (1.65) .065
(1.59)
.0625
(1.27)
.050
DIA
(3.30)
.130
X
(5.08)
.200
(4.06)
.160
–P OPTION
(1.27)
.050
A
(2.29)
.090
–S
–SA
= End Shroud with
Alignment Pin
(05 thru 46
positions. Style
-02 & -03 only)
–DV
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin
on tail
= .075"
(1.91 mm)
Post
(Mates with
FLE)
(0.41)
.016
SQ
(Shrouded options removed for clarity)
= Gold flash
on post,
Matte Tin
on tail
–03
(1.27) .050
(4.57)
.180
Note: Some lengths,
styles and options are
non-standard, non-returnable.
–F
–01
ALSO AVAILABLE
–SV
(3.56)
.140
A
–DV
–D
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
–TR
= Tape & Reel
(-DV only)
(Required callout
for positions
2 thru 4)
–S OPTION
很抱歉,暂时无法提供与“FTS-104-01-L-DV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+14.315241+1.85272
- 10+12.1914610+1.57785
- 100+10.36274100+1.34117
- 500+9.24946500+1.19709
- 1000+8.807911000+1.13994
- 5000+8.741485000+1.13135
