FTSH-104-01-L-DV-A
FTSH-104-01-L-DV-A
    SAMTEC(申泰)
    .050'' X .050 TERMINAL STRIP
FTSH-104-01-L-DV-A 数据手册
SURFACE MOUNT MICRO HEADER 8 G b p s (1.27 mm) .050" PITCH • FTSH SERIES FTSH Board Mates: CLP, FLE Cable Mates: FFSD, FFTP FTSH -1 NO. PINS PER ROW 02 thru 50 SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (FTSH/CLP): 3.4 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C - LEAD STYLE - –01 PLATING OPTION –F = (3.05 mm) .120" Post (Mates with FFSD) = Gold flash on post, Matte Tin on tail –02 –L = (1.91 mm) .075" Post (Mates with FLE) –03 = (1.65 mm) .065" Post (Mates with CLP–D) - - TAIL OPTION –DV Leave Blank for -DH & -MT –DH –“XXX” = Double Vertical - = Polarized Position (Specify position of omitted pin) (Not available with -EX options) = Double Horizontal (Styles –01, –02 & –04 only) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail OPTION –MT = Mixed Technology (Styles –01, –02 & –04 only) –04 PROCESSING OPTION 1RRISRVLWLRQV[  =   Z –ES (2.57) .101 –EJ (15.77) .621 –EC (3.33) .131 –EP (5.87) .231 –EL (6.53) .257 1RRISRVLWLRQV[  = $   –EJ = Ejector Shroud (Style –01 only) –DH & –MT not available 10 pins/row minimum 25 pins/row maximum EXTENDED LIFE PRODUCT 1RRISRVLWLRQV[   HIGH MATING CYCLES   LEAD STYLE A –01 (3.05) .120 –02 (1.91) .075 –03 (1.65) .065 –04 (3.81) .150 –05 (4.32) .170   —EJ OPTION SHOWN 10 YEAR MFG WITH 30 µ" GOLD –EC = End Shroud with Locking Clip (Manual placement required) = End Shroud with Board Lock (Boards are positively locked and cannot be unmated) —EX OPTION SHOWN Molded Pick & Place pads Latches Other platings –ES = End Shroud –EL = (4.32 mm) .170" Post (Mates with CLP–BE) MOQ Required (Style –02 & –03 only, –DH & –MT not available) 9 pins/row minimum (Other positions available. Call Samtec.) = End Shroud with Guide Post –05 ALSO AVAILABLE - –EP = (3.81 mm) .150" Post (Mates with CLP-DH) Lead-Free Solderable: Yes SMT Lead Coplanarity: –MT & –DV Tail Option: (0.10 mm) .004" max (02-25) –MT & –DH Tail Option: (0.15 mm) .006" max (26-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) FLEX SHROUD OPTIONS $   —MT (Styles –01, —02 & —04 only)    64 $    —DV Notes: Severe Environment Testing qualified; aligns with MIL-DTL-55302. Visit samtec.com/set     OTHER OPTIONS –K = Keying Shroud for mating with FFSD (Style –01 only, 05 thru 25 pins/row only. 13, 17, 20 & 25 only with –EJ option) (-DV only) –A = Alignment Pin (–DV 3 positions minimum) (–DH 5 positions minimum) (Metal or plastic at Samtec discretion) –C = (5.00 mm) .197" DIA Polyimide film Pick & Place Pad (–DH only) –P = Pick & Place Pad (–DV 4 positions minimum) (–DH & –MT not available) –TR = Tape & Reel (Flex Shroud options not available except –ES & –EJ) –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) —DH (Styles —01, —02, —04 only) Some sizes, styles and options are non-standard, non-returnable. See SFM/TFM for positive alignment feature. F-224 —ES —EC —EP —EL —EJ —K —P samtec.com?FTSH Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. —A
FTSH-104-01-L-DV-A 价格&库存
很抱歉,暂时无法提供与“FTSH-104-01-L-DV-A”相匹配的价格&库存,您可以联系我们找货
