FX27-120S-0.8SV
FX27-120S-0.8SV
    HRS(广濑)
    SMD,P=0.8mm
    120 位置 母头 连接器 PCI Express™ 镀金 0.031"(0.80mm) 黑色
FX27-120S-0.8SV 数据手册
0.8mm Pitch Floating Card Edge Connector Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 22mmMIN FX27 Series Stacking height:22mmMIN ■Features 1. Contact pitch : 0.8mm 2. Stacking Height : 22mm Min. Y Adjustable height by selecting different PCB interposer heights. Double floating ±0.6mm Single floating Floating range by using two FX27 connectors is ±1.2mm max. 6. Customizable interposer PCB 7. Current capacity : 0.5A/pin 8. Pick & Place Mounting (suction tape attached as standard) ±0.6mm Max. Single floating ±1.2mm 3. Pin Varieties : 40/60/80/100/120 4. Floating Range : 0.6mm Max. in X and Y directions 5. High-speed Transmission : 2.5Gbps (PCle-Gen.1) X Single floating : ±0.6mm Double floating : ±1.2mm (Ex.) Equipping with Electrical chips 9. Large guide post for excellent mating performance Easy mating operation due to large self-alignment range. (Ex.) Power Source Board Use Customizable PCB interposer Taper : 0.7mm Large self-alignment In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2019.8 1 FX27 Series●0.8mm Pitch Floating Card Edge Connector ■Product Specifications Rated Current : 0.5A Ratings Rated Voltage : 100V AC Items Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Contact resistance Operating Temperature : -55 to 105℃ (Note 1) Storage temperature : -10 to 60℃ (Note 2) Operating/storage humidity range : 85% or less relative humidity (No dew condensation is allowed) Specifications 30mΩ Max. (Note 3) Conditions Measured at 100mA 2. Insulation Resistance 1,000MΩ or more 3. Withstanding Voltage No flashover or breakdown Measured at 250V DC Energized at 300V AC for 1 minute 4. Mating durability Contact Resistance 40mΩ Max. (Note 3) 100 Insertion/Extraction cycles 5. Vibration proof No electrical discontinuity of 1µ or more. 6. Shock resistance No electrical discontinuity of 1µ or more. 7. Moisture resistance Contact Resistance 40mΩ max. (Note 3) Left for 96 hours at 40℃ and a humidity of 90 to 95% Insulation Resistance 1,000MΩ max. 8. Temperature cycle Contact Resistance 40mΩ max. (Note 3) Temperature -55 → 85℃ Insulation Resistance 1,000MΩ max. Time 30 → 30min. for 5 cycles Frequency 10-55Hz, half amplitude 0.75mm, 10 cycles in each of the 3-axis directions each for 5 minutes per cycle Acceleration of 490m/s2 ; duration 11ms, sine half-wave, 3 cycles in each of the 3 axes each in both directions. Note 1 : Includes the temperature rise caused by current flow. Note 2 : The term storage refers to the long-term storage condition of unused products prior to mounting on PCB. Note 3 : Contact resistance for 1 connector. Does not include the conductor resistance of the PCB interposer when mated. ■Materials / Finish 2 Part Materials Finish/Remarks Standard Insulator Polyamide resin Black UL94V-0 Contact Copper alloy Contact part : gold plating Mounting part : gold plating − Solder tab Brass Reflow tin plating − FX27 Series●0.8mm Pitch Floating Card Edge Connector ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Straight receptacle ❶Series Name FX27 - 120 S - 0.8 SV ❶ ❷ ❸ ❹ ❺ :FX27 ❷No. of pos. ❸Connector type S : Receptacle type ❹Contact pitch ❺Product type :0.8mm SV : Straight type ■High-speed transmission property ●Pin assignment Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The following pin arrangement is recommended to match the 100Ω differential impedance and to contain cross-talk. Signal pin Diff pair Ground pin ●Insertion Loss ●Intra-pair skew 3 FX27 Series●0.8mm Pitch Floating Card Edge Connector ●Return loss Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Connector 1 Connector 2 ●Near End Cross-Talk (NEXT) Connector 1 Connector 2 FX27-**S-0.8SV(②) ※ Simulation Tool : HFSS Ver.2016.1.0 Standard Impedance : 100Ω FX27-**S-0.8SV(①) ※ *Simulation performed using the same FX27 connector for connector 1 and connector 2 4 FX27 Series●0.8mm Pitch Floating Card Edge Connector ■Floating Range X Direction: ±0.6mm Max. Fastened portion Y Direction : ±0.6mm Max. Floating part Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ±1.2mm Max. Double floating Can have a floating range up to ±1.2mm Max. when using 2 FX27 connectors Floating portion Floating portion Fastened portion Fastened portion ■Number of contacts variations 40pos. 60pos. 80pos. 100pos. 120pos. 5 FX27 Series●0.8mm Pitch Floating Card Edge Connector ■Product Dimensions Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Straight Receptacle 30.9±0.3 29.5±0.3 (17.4) 10.6±0.3 7.3±0.2 8.4±0.2 7.9±0.2 2.7±0.2 0.1±0.15 15.2±0.2 P=0.8±0.15 27.1±0.05 1.5±0.05 P=0.8±0.03 Pin No.1 0.5±0.05 Pin No.40 2-Ø Pin No.20 ) 5(穴 0.0 7± 1.2 4.6±0.05 15.2±0.05 Pin No.21 2.45±0.05 1.2±0.05 18.2±0.05 3.2±0.05 Pin No.20 Pin No.40 Pin No.21 2.45±0.05 1.5±0.1 1.2±0.05 1.32±0.25 Pin No.1 6 (2-Ø1.12) t=0.2±0.03×w=0.22±0.05 18.2±0.1 Part No. HRS No. No. of contacts Packaging Quantity FX27-40S-0.8SV 577-1002-0 00 40 300/RL Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX27 Series●0.8mm Pitch Floating Card Edge Connector 0.1±0.15 10.6±0.3 7.3±0.2 8.4±0.2 7.9±0.2 2.7±0.2 38.9±0.3 37.5±0.3 (25.4) (2-Ø1.12) 1.32±0.25 t=0.2±0.03×w=0.22±0.05 26.2±0.1 Pin No.1 23.2±0.2 P=0.8±0.15 Pin No.30 Pin No.31 2.45±0.05 1.5±0.1 Pin No.60 35.1±0.05 2.45±0.05 26.2±0.05 Pin No.60 0.5±0.05 Pin No.30 1.2±0.05 Pin No.1 1 2-Ø 1.2±0.05 1.5±0.05 3.2±0.05 P=0.6±0.03 (穴) .05 ±0 .27 4.6±0.05 23.2±0.05 Pin No.31 Part No. HRS No. No. of contacts Packaging Quantity FX27-60S-0.8SV 577-1003-0 00 60 300/RL 7 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX27 Series●0.8mm Pitch Floating Card Edge Connector (19) 0.1±0.15 2.7±0.2 50.1±0.3 48.7±0.3 (36.6) (15.8) 8.4±0.2 7.9±0.2 A 10.6±0.3 7.3±0.2 A (2-Ø1.12) 1.32±0.25 t=0.2±0.03×w=0.22±0.05 37.4±0.1 Pin No.1 1.5±0.1 34.4±0.2 20.8±0.2 16.8±0.2 P=0.8±0.15 Pin No.40 Pin No.41 Pin No.80 2.45±0.05 46.3±0.05 37.4±0.05 34.4±0.05 2.45±0.05 20.8±0.05 Pin No.80 Pin No.40 1.2±0.05 0.5±0.05 Pin No.1 1.2±0.05 1.5±0.05 3.2±0.05 8 2- 05( ±0. 27 Ø1. P=0.8±0.03 穴) 4.6±0.05 16.8±0.05 Pin No.41 Part No. HRS No. No. of contacts Packaging Quantity FX27-80S-0.8SV 577-1004-0 00 80 300/RL 0.1±0.15 58.1±0.3 56.7±0.3 (44.6) (19.8) 2.7±0.2 (23) 8.4±0.2 7.9±0.2 A 10.6±0.3 7.3±0.2 A (2-Ø1.12) 1.34±0.25 t=0.2±0.03×w=0.22±0.05 45.4±0.1 1.5±0.1 42.4±0.2 Pin No.1 24.8±0.2 20.8±0.2 P=0.8±0.15 Pin No.50 Pin No.51 Pin No.100 2.45±0.05 54.3±0.05 45.4±0.05 42.4±0.05 2.45±0.05 24.8±0.05 20.8±0.05 1.2±0.05 1.5±0.05 0.5±0.05 Pin No.1 Pin No.50 4.6±0.05 Pin No.100 (穴 ) 0.05 27± . 1 Ø 2- P=0.8±0.03 1.2±0.05 Pin No.51 3.2±0.05 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX27 Series●0.8mm Pitch Floating Card Edge Connector Part No. HRS No. No. of contacts Packaging Quantity FX27-100S-0.8SV 577-1005-0 00 100 150/RL 9 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX27 Series●0.8mm Pitch Floating Card Edge Connector 66.1±0.3 64.7±0.3 0.1±0.15 2.7±0.2 (52.6) (23.8) (2-Ø1.12) t=0.2±0.03×w=0.22±0.05 1.32±0.25 10.6±0.3 7.3±0.2 8.4±0.2 7.9±0.2 (27) 53.4±0.1 1.5±0.1 50.4±0.2 28.8±0.2 24.8±0.2 Pin No.1 P=0.8±0.15 Pin No.60 Pin No.120 Pin No.61 2.45±0.05 62.3±0.05 53.4±0.05 50.4±0.05 2.45±0.05 28.8±0.05 24.8±0.05 Pin No.60 4.6±0.05 1.5±0.05 3.2±0.05 10 0.5±0.05 Pin No.1 1.2±0.05 Pin No.120 ( 穴) 0.05 27± . 1 Ø 2- P=0.8±0.03 1.2±0.05 Pin No.61 Part No. HRS No. No. of contacts Packaging Quantity FX27-120S-0.8SV 577-1001-0 00 120 150/RL FX27 Series●0.8mm Pitch Floating Card Edge Connector 1.75±0.1 ■Embossed Packaging Diagram 1 0. + 0 5 2±0.2 . Ø1 12 1.7+00.15 A A A A (6.5) Suction Tape A A A A Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A±0.3 B±0.1 C±0.3 Suction Tape P=20±0.15 P=4±0.1 F 0.8 Ø1 1± 3± Ø2 0.2 (0.5) (13.57) 1.5+00.1 ØD MAX ØE MAX G+02 (H) End section Connector Mounting Area Empty Portion (No connectors inserted) (8 or more pockets) Embossed Carrier Lead Section (400mm Min.) Empty Portion (No connectors inserted) (5 or more pockets) Embossed Cover Tape Unit : mm A B C D E F G H FX27-40S-0.8SV Part No. 56 52.4 26.2 382 102 55.9~59.4 56.4 62.4 FX27-60S-0.8SV 72 68.4 34.2 382 102 71.9~75.4 72.4 78.4 FX27-80S-0.8SV 72 68.4 34.2 382 102 71.9~75.4 72.4 78.4 FX27-100S-0.8SV 88 84.4 42.2 332 152 87.9~91.4 88.4 94.4 FX27-120S-0.8SV 88 84.4 42.2 332 152 87.9~91.4 88.4 94.4 11 FX27 Series●0.8mm Pitch Floating Card Edge Connector ■Recommended PCB Interposer Dimensions 40S 1.6±0.16 0.45 P=0.8±0.03 1.6±0.16 0.45 CL CL indicates the center of 44.45 80S 45° 1.6±0.16 0.45 45° 44.45±0.1 42.4±0.05 24.8±0.05 20.8±0.05 1.6±0.1 2.4±0.1 1±0.2 3.8±0.2 100S 0.55±0.05 1.6±0.16 0.45 45° CL CLindicates the center of 52.45 1.6±0.1 21.2±0.13 120S 0.55±0.05 1.6±0.16 0.45 45° CL 25.2±0.13 1.6±0.1 25.2±0.13 1±0.2 3.8±0.2 Z−10±0.1 52.45±0.1 50.4±0.05 28.8±0.05 24.8±0.05 1.6±0.1 2.4±0.1 CL 21.2±0.13 1±0.2 3.8±0.2 1.6±0.1 17.2±0.13 1±0.2 3.8±0.2 6.4±0.1 CL 17.2±0.13 1±0.2 3.8±0.2 Z−10±0.1 P=0.8±0.03 Z−10±0.1 36.45±0.1 34.4±0.05 20.8±0.05 16.8±0.05 1.6±0.1 0.55±0.05 2.4±0.1 CL 11.6±0.13 11.6±0.13 1±0.2 3.8±0.2 6.4±0.1 CL CL indicates the center of 36.45 P=0.8±0.03 60S Z−10±0.1 7.6±0.13 1±0.2 3.8±0.2 CL 1±0.2 3.8±0.2 6.4±0.1 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7.6±0.13 P=0.8±0.03 25.25±0.1 23.2±0.05 0.55±0.05 1±0.2 3.8±0.2 CL CL indicates the center of 25.25 45° Z−10±0.1 P=0.8±0.03 17.25±0.1 15.2±0.05 0.55±0.05 1±0.2 3.8±0.2 CL CL indicates the center of 17.25 Z±0.5 FX27-**S-0.8SV Mated Board FX27-**S-0.8SV Customer supplied PCB interposer. 12 FX27 Series●0.8mm Pitch Floating Card Edge Connector Recommended Temperature Profile (Peak Temperature : 250℃ Max.) 260 Test PCB Dimensions : 110×60×1.6mm 240 220℃ 220 200℃ 200 Temperature (℃) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Material : Glass epoxy Solder composition : Sn-3Ag-0.5Cu Flux content : 11wt% Metal mask thickness : 0.12mm, 0.15mm 180 Number of reflow times : 2 times max. 160 140 150℃ *The temperature profile is a reference under the condition of the above settings : Temperature profile may change depending on the conditions such as solder paste types, manufacturers, PCB size, and other 0 (90 to 120 sec.) Preheating time (150 to 200℃) soldering materials. We confirmed there is no issue on (Within 60 sec.) Soldering time (220℃ or more) the 2nd reverse mounting, but please use after thoroughly confirming the mounting state. Cleaning Conditions ●Cleaning with organic solvent Solvent Normal Temperature Cleaning Heated cleaning IPA (Isopropyl alcohol) ○ ○ ●Cleaning with water When water-type cleaning agents (terpene, alkaline saponification agents) are used, select cleaning agents based on the 'table of influence' on metals and resins issued by the cleaning agent manufacturer. Caution : Do not leave with any water content left. ●Cleaning Precautions When cleaning the parts with organic solvents and water-type agents, if flux or cleaning agents remain in the connector, it could cause the deterioration of electric performance. Please be sure to check if adequate cleaning has been completed. Usage Precautions ●Pin Assignment FX27-**S-0. 8SV:① No(* . */2) Ex. For 60pos : No.60/2=No.30 Polarity Mark : No.1 No. ** FX27-**S-0. 8SV:① Polarity Mark PCB Interposer FX27-**S-0. 8SV:② No(* . */2+1) Ex. For 60pos. : No.60/2+1=No.31 No. ** No(* . */2+1) Ex. For 60pos. : No.60/2+1=No.31 Polarity Mark : No.1 Polarity Mark No(* . */2) Ex. For 60pos : No.60/2=No.30 FX27-**S-0. 8SV:② When the connector is connected as shown in the figure on the left, polarity marks 1 and 2 of the FX27-**S-0.8SV are inverted. Please pay attention to board circuit pin assignment. 13 FX27 Series●0.8mm Pitch Floating Card Edge Connector ●Securing Boards Using only connectors is not recommended. The board is designed to be secured with a spacer. If the board is supported only by the connector, an excessive load may be applied to the connector which may result in damage or contact failure. Take measures to secure the board other than using the connector. ●Mating Precautions ・The self-alignment range is ±0.7mm in the X and Y directions. Insert the connector straight in without applying excessive load during mating. Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Taper : 0.7mm ・It is recommended that the connector be inserted and removed straight without tilting the connector. X direction (Longitudinal) Y direction (transverse direction) ●Misalignment allowance in Mated Condition (Floating Amount) Since this connector has a floating structure, the maximum allowable PCB misalignment amount is ±0.6mm in the X and Y directions when mated. When two FX27 connectors are used for stacking connections, they have a double floating capability, allowing for a maximum PCB misalignment of ±0.12mm in the X and Y directions. However, this product cannot be used to absorb misalignment when there are constant changes due to vibration, etc. Be sure to secure the boards after mating. The floating operation can be repeated 100 times max. based on the connector durability (insertion/extraction times). Supplementary ●Friction Lock during Initial Insertion/Extraction Ex. FX27-60S-0.8SV A-A Cross Section PCB Interposer Removal Direction ↓A A↓ 0.8±0.1 .5 R0 2- 4.15±0.1 1.5±0.1 Notch Dimensions (Reference) Notch The notched sides of the PCB interposer remain when removed. 14 Connector Lock-hooking design in the notches of the interposer. Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX27 Series●0.8mm Pitch Floating Card Edge Connector MEMO: 15 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX27 Series●0.8mm Pitch Floating Card Edge Connector USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 16 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2019. Contents are subject to change without notice for the purpose of improvements.
FX27-120S-0.8SV 价格&库存
很抱歉,暂时无法提供与“FX27-120S-0.8SV”相匹配的价格&库存,您可以联系我们找货
FX27-120S-0.8SV
  • 1+109.015531+14.17167
  • 10+92.6648010+12.04613
  • 25+86.8570425+11.29114
  • 50+82.7099550+10.75203
FX27-120S-0.8SV
  • 150+76.54232150+9.95026
  • 300+72.89106300+9.47560
  • 450+70.83783450+9.20869
  • 750+68.33287750+8.88306
  • 1050+66.731791050+8.67492
