HT803/IXG-8/10S-63-72
    HRS(广濑)
    HIROSE(HRS) - HT803/IXG-8/10S-63-72 - Crimp Tool, Hand, Hirose IX Series The Next-Generation Etherne...
HT803/IXG-8/10S-63-72 数据手册
Conforming to IEC Standard The Next-Generation Ethernet Connector for Industrial Equipment IX Series Contribution to size reduction 75% reduced size compared to RJ-45 Compact size ix Industrial TM Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RJ-45 Parallel-mounting at P=10mm is possible Overview Multi-purpose small-sized I/O connector for industrial machinery. Conforming to IEC Standard IEC 61076-3-124 Compact size, robust and high speeds. High EMC resistance. Features 1. Contribution to size reduction The ix Industrial offers a reduced size of 75% compared to conventional RJ-45 modular solutions. This size reduction allows for reduced installation space. Parallel-mounting at P=10mm is possible. Lock design Audible Click ! 2. Single action lock design The connector locks by simply inserting the plug into the receptacle. An audible click insures locking. The lock can be released by pushing a button on the plug leading to smooth removal. 3. Robust design resistant to prying forces The PCB-mounted receptacle shell is designed to minimize the influence of prying force from the plug on the mated surface. Additionally, the PCB-mounted shape is designed to protect the contacts.Unique metal hold down placement prevents peeling of contacts. Stainless steel material is used for metal parts to enhance the mechanical strength. Single action lock allows for easy operation Clear tactile click prevents insufficient mating 4. High EMC Resistance Optimized shielding design guarantees high EMC resistance to secure safe data transmission. 5. High Data Rate Transmission Cat.5e (1Gbps) and Cat.6A (10Gbps) high-speed Ethernet performance. 6. PIP (Pin-In-Paste) mounting possible The receptacle shell is mounted at the through hole section of the PCB to enhance the mounting strength of the PCB. Both signal contact SMT and PIP mounting allows for reflow-mounting and reduction of man-hours required for board processing. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2020.4③ 1 IX Series●Conforming to IEC Standard The Next-Generation Ethernet Connector for Industrial Equipment Product Specifications Voltage Ratings Electric current 50V AC / 60V DC 1.5A 3.0A Operating temperature range All-pin signal Storage 4 pins of contacts No.1, 2, 6 and 7 temperature range Specifications Signal : 30mΩ or less (Note 2) 1. Contact resistance Shield : 100mΩ or less (Note 2) 2. Insulation 500MΩ or more resistance 3. Withstanding No flashover or breakdown voltage Signal : 80mΩ or less (Note 2) 4. Mechanical operation Shield : 100mΩ or less (Note 2) 5. Vibration resistance ①No electrical discontinuity of 1μs or more ②No damage, crack or loosened parts 6. Shock resistance Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items 7. Fretting corrosion ①No electrical discontinuity of 1μs or more resistance ②No damage, crack or loosened parts Note 1 : Includes temperature rise due to current flow. Note 2 : Conductor resistance of the cable isn't included.   -40 to +85℃ (Note 1) -30℃ to +60℃ Conditions Measured at 100mA Measured at 500V DC Apply a voltage of 500V DC for 1 minute. 5000 times 10 to 500Hz, half amplitude 0.35mm, Acceleration of 50m/s². 300m/s², 11ms duration, 3 axis both directions, 3 times each. 490m/s², 30 times/min, 1000 times Materials / Finish ●Receptacle Component Materials Color/Finish Remarks Insulator Contact Liquid crystal polymer Gray UL94V-0 Copper alloy Partially gold plated ̶̶̶ Shielding plate Stainless steel ̶̶̶ ̶̶̶ Shell Stainless steel Tin plated ̶̶̶ Suction cap Polyamide resin Black UL94V-0 Component Materials Color/Finish Remarks ●Plug 2 Contact Copper alloy Partially gold plated ̶̶̶ Insulator Polyamide resin Black, Dark gray UL94V-0 Shielding plate Stainless steel ̶̶̶ ̶̶̶ Insulated case Polyamide resin UL94V-0 Guide Polycarbonate resin UL94V-0 Shield case Stainless steel Black Transparent, Clear yellow, Clear blue Nickel plated Shield shell Stainless steel Nickel plated ̶̶̶ Cover case Polycarbonate resin Dark gray UL94V-0 ̶̶̶ IX Series●Conforming to IEC Standard The Next-Generation Ethernet Connector for Industrial Equipment ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacle IX 61 G − A − 10 P (**) ❹ ❺ ❻ ❾ ●Plug IX 40 G − A − 10 S − CV 7.0 (**) Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❹ ❺ ❻ ❼ ❽ ❾ Series name : IX   IX Series Maximum number of usable contacts : 10 10 contacts Mounting/connection method : 8(Note) 8 contacts 40 Hand soldering Contact polarity : P Male contact 30 IDC (26 to 28 AWG, Cable outer dia meter Ø0.95 to1.05) S   Female contact 31 IDC (24 to 25 AWG, Cable outer dia meter Ø1.1 to 1.25) ❼ Plug cover 32 IDC (22 AWG, Cable outer dia meter Ø1.4 to 1.6) CV Cable outlet direction : Straight 61 Upright right angle SMT ❽ Applicable cable diameter : (7.0) 80  Vertical SMT Sheath outside diameter : Ø6.3 to 7.2 Correspond to Gigabit Ethernet: G ❾ Plating specifications : Mating key : Type A Blank Gold plated Type B (01) Palladium-Nickel plated + Gold plated Note : Contacts No.3 and 8 do not have a hole to pass the cable through the IDC guide. Diagram of Connector Mating Combinations ●Receptacle ●Plug (7.0) (**) IX40G-*-10S-CV IX61G-*-10P (**) IX30G-*-10S-CV (7.0) (**) (7.0) (**) IX31G-*-10S-CV (**) IX80G-*-10P ※Mating key (Type A, B) of Plug & Receptacle must be the same for mating. (7.0) (**) IX32G-*-8S-CV 3 IX Series●Conforming to IEC Standard The Next-Generation Ethernet Connector for Industrial Equipment Receptacle ●Upright right angle type Contact No.1 Contact No.10 Contact No.5 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 9.4 0.4 1 1.5 2.75 5.75 1.9 3.75 9.75 3.05 4.75 5.75 6.75 0.4 0.4 Contact No.10 1.5 5.8 (6.2) 8.4 (8.8) HRS No. 251-0021-0 251-0021-0 01 251-0026-0 251-0026-0 01 (10) Contact No.6 Contact No.1 Part No. IX61G-A-10P IX61G-A-10P(01) IX61G-B-10P IX61G-B-10P(01) Receptacle mating key shape Type A Type B 10∞0.25 1.5 Plating of the contact area Gold plated 0.2μm Palladium-Nickel plated 0.75μm + Gold plated 0.05μm Gold plated 0.2μm Palladium-Nickel plated 0.75μm + Gold plated 0.05μm ●Receptacle (Vertical type) Receptacle mating key shape Type A Type B 4(Lead) 0.4 3.5 1.75 Contact No.5 Contact No.10 0.25 2 Contact No.6 4 5.5 (R0.2) 2.1 3) 0. (C 2×1.4 1.2 Ø1.2 Contact No.6 3.075 2(Lead) 4(Lead) 2(Lead) 0.25(Lead) Contact No.1 Contact No.10 10×0.25(Lead width) 0.25(Lead) 10 Note : This product is delivered with a cap to accommodate pick & place equipment. Please take the cap off before use. Part No. IX80G-A-10P IX80G-A-10P(01) IX80G-B-10P IX80G-B-10P(01) 4 HRS No. 251-0018-0 251-0018-0 01 251-0019-0 251-0019-0 01 9 0.4 Plating of the contact area Gold plated 0.2μm Palladium-Nickel plated 0.75μm + Gold plated 0.05μm Gold plated 0.2μm Palladium-Nickel plated 0.75μm + Gold plated 0.05μm Product appearance (7.1) (5.7) 1.5 7.8(Lead) 9 1.5 0.25 Contact No.5 3×R0.5 7.8 2×0.6 (R0.2) Contact No.1 C1 6.6 5 11 4.8 4 2 Vacuum area Suction cap IX Series●Conforming to IEC Standard The Next-Generation Ethernet Connector for Industrial Equipment Contact No.10 9.2 Contact No.6 (Ø 7. 2) Plug Contact No.1 Contact No.5 Plug mating key shape Type A Type B 22.9 5.7 17.5 16.3 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 16.3 Part No. HRS No. Plating of the contact area IX40G-A-10S-CV(7.0) 251-0022-0 Gold plated 0.2μm IX40G-A-10S-CV(7.0)(01) 251-0022-0 01 Palladium-Nickel plated 0.75μm + Gold plated 0.05μm IX40G-B-10S-CV(7.0) 251-0032-0 Gold plated 0.2μm IX40G-B-10S-CV(7.0)(01) 251-0032-0 01 Palladium-Nickel plated 0.75μm + Gold plated 0.05μm IX30G-A-10S-CV(7.0) 251-0020-0 Gold plated 0.2μm IX30G-A-10S-CV(7.0)(01) 251-0020-0 01 Palladium-Nickel plated 0.75μm + Gold plated 0.05μm IX30G-B-10S-CV(7.0) 251-0025-0 Gold plated 0.2μm IX30G-B-10S-CV(7.0)(01) 251-0025-0 01 Palladium-Nickel plated 0.75μm + Gold plated 0.05μm IX31G-A-10S-CV(7.0) 251-0023-0 Gold plated 0.2μm IX31G-A-10S-CV(7.0)(01) 251-0023-0 01 Palladium-Nickel plated 0.75μm + Gold plated 0.05μm IX31G-B-10S-CV(7.0) 251-0024-0 Gold plated 0.2μm IX31G-B-10S-CV(7.0)(01) 251-0024-0 01 Palladium-Nickel plated 0.75μm + Gold plated 0.05μm IX32G-A-8S-CV(7.0)(Note) 251-0042-0 Gold plated 0.2μm IX32G-A-8S-CV(7.0)(01)(Note) 251-0042-0 01 Palladium-Nickel plated 0.75μm + Gold plated 0.05μm IX32G-B-8S-CV(7.0)(Note) 251-0043-0 Gold plated 0.2μm IX32G-B-8S-CV(7.0)(01)(Note) 251-0043-0 01 Palladium-Nickel plated 0.75μm + Gold plated 0.05μm Note : Cable assembly is possible up to 8pos. Contacts No.3 and 8 do not have a hole to pass the cable through the IDC guide. 5 IX Series●Conforming to IEC Standard The Next-Generation Ethernet Connector for Industrial Equipment Recommended Land Pattern Dimensions(Board thickness:t=1.6mm) ●IX61G-*-10P Recommended Metal Mask Pattern(t=0.15) Recommended Land Pattern(Mounting side) (t=1.6) 6.75 6 5.75 4.75 3.75 2.75 1.6 0.8 +0.1 0(TH) 0.6 +0.1 0(TH) 2 (LAND) 4∞2.1+0.1 0(TH) 4∞2.7 (LAND) 1.9 10∞0.3 (LAND) Contact No.10 1.95 3.35 4 4.5 5 10∞0.19 2.5 0 5.45 - 0.1 3.35 2.95 1.95 1 16∞R0.6 2.5 16∞R0.3 5.75 7.5 5.75 7.5 7.05 +0.1 0 (9.75) Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. +0.1 Contact 1.4 0(TH) 4∞R0.6 No.1 4∞R0.3 6.75 5.75 4.75 3.75 2.75 2(LAND) 4∞R0.5 Board end Board end 4∞0.8+0.1 0(TH) 4∞1.4 (LAND) +0.1 0 1.2 (HOLE) 5.8 7.2 8.4 9.8 Mating position 4.4 7 11.4 14 Pattern forbidden area General tolerance unless specified ±0.05. General tolerance unless specified ±0.02. ●IX80G-*-10P Recommended Metal Mask Pattern(t=0.15) Recommended Land Pattern(Mounting side) (t=1.6) 9 4 11 2 4 0.25 4 10×0.6(LAND) Contact No.1 2 0.25 Contact No.5 2×1.4(LAND) Pattern forbidden area 10×0.5 2×0.8(TH) Contact No.10 Contact No.6 3.075±0.05 2.5 4.37 2.69 2.69 4.37 2.1±0.05 Ø1.35(HOLE) 2×1.9(TH) Mounting area 2×2.5(LAND) 4.8 7.8 8×R0.3(TH) 2.45 2.45 4.4 4.4 8×R0.6(LAND) 0.25 2 4 0.25 2 4 7.5 11 General tolerance unless specified ±0.05. 6 General tolerance unless specified ±0.02. IX Series●Conforming to IEC Standard The Next-Generation Ethernet Connector for Industrial Equipment Recommended Panel Thickness ●IX61G-*-10P Mated Condition Diagram Housing panel Reference Housing Panel cut-out Dimension IX※※G-※-※S-CV (7.0) 7 4∞R1 10.2 IX61G-※-10P Mounting surface 0.8 PCB Reference dimensions. (0.55) ●IX80G-*-10P Mated Condition Diagram Reference Housing Panel cut-out Dimension IX※※G-※-※S-CV(7.0) 11 6 8×R0.3 7.8 6.2 4×R1 (0.55) Reference dimensions. Housing panel IX80G-※-10P PCB (2) (9) Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (2) (9.75) Cable Clamp Jig Tools Part No. HT803/IXG-8/10S-63-72 HRS No. 902-2218-0 Remark IX**G-*-**S-CV(7.0) 7 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. IX Series●Conforming to IEC Standard The Next-Generation Ethernet Connector for Industrial Equipment USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 04/2020. Contents are subject to change without notice for the purpose of improvements.
HT803/IXG-8/10S-63-72 价格&库存
很抱歉,暂时无法提供与“HT803/IXG-8/10S-63-72”相匹配的价格&库存,您可以联系我们找货
  • 1+4354.286701+564.39846
