FH52 Series
May.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact,
Front Flip, FPC/FFC Connector
Product Page
https://www.hirose.com/en/product/series/FH52
Sep. 2023
FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip, FPC/FFC Connector
Features
1. Highly reliable connection
and robust design
Solder tabs prevent actuator
disengagement
Higher connector body strength and FPC/ FFC
connection reliability are required even more than
before as connectors continue to be produced
with higher pin counts. Compared with existing
products ( HRS 0. 5mm pitch standard connector
FH12 Series horizontal mounting type) , FH52
Series has higher connection reliability due to the
FPC/ FFC positioning mechanism and provides a
secure connection that prevents unlocking due to
the original, robust design.
Each contact prevents actuator
disengagement
Secure Actuator Retention
2. Product variations that meet
a variety of needs
・ FH52E : Long solder tabs type
Solder tabs extending from the connector
body enable visual inspection of the soldering
conditions.
・ FH52K : Long solder tabs and 125℃ ( Note)
heat resistance type
125℃ heat resistant connector meets severe
automotive requirements.
・ FH52T : Long solder tabs and 2- point
contact type
The 2 independent spring design connects with
the FPC/ FFC at 2 points, preventing contact
failure due to dust adhesion.
The solder tabs extend out from the connector body,
enabling visual inspection of soldering.
Long Solder Tabs Type ( FH52E/ FH52K/ FH52T)
Note : The heat resistant when using FFC is 105℃. When the heat
resistant temperature is less than 125℃ for FPC and 105℃
for FFC, the heat resistant temperature of the FPC/ FFC is
applied.
2-point contact design with independent springs
enhances reliability.
2- Point Contact ( FH52T)
2
3. Flip lock simplifies operations
The flip lock ( one- touch rotation) design enables
easier FPC/ FFC connection operation with less
force. The clear tactile click upon locking is
enhanced compared to existing products ( FH12
horizontal mounting type) for a secure
connection.
4. High FPC/ FFC retention force
Tabbed FPC/ FFCs enhanced retention force in
the horizontal direction.
FPC/FFC with tabs increase the retention
force in the horizontal direction.
Connection Utilizing FPC/ FFC Position Alignment
Design
5. Accepts standard 0. 3mm
thick FPC/ FFC
Compatible 0. 3mm thickness FPC/ FFC, which are
easy to manufacture and have superb insertion
performance
6. No pattern prohibited area on
the bottom of the connector
( Overmolding design)
The bottom surface of the connector is fully
enclosed to eliminate contact exposure, removing
PCB pattern restrictions and enhancing board
design flexibility.
7. Halogen- free
All materials and substances used to produce this
product comply with Halogen- free standards.
As defined in IEC 61249- 2- 21.
Br : 900ppm or less, Cl : 900ppm or less,
Br+ Cl : 1, 500ppm or less
3
8. Supports automatic pick &
place mounting
Offered in tape and reel packaging that is
compatible with automatic machine mounting.
( 3, 000pcs per reel)
9. 500pcs per reel packing
option available
The standard packaging is 3, 000pcs per reel, but
FH52 is also offered in 500pcs per reel. ( The
reel outer diameter is φ180mm for the 500pcs
per reel option)
4
Product Specifications
Rated Current (Note 1)
0.5A
Operating Temperature (Note 2)(Note 3)
-40 to +105℃
Rated Voltage
50V AC
Operating Humidity Range
RH 90% Max. (No Condensation)
Storage Temperature Range (Note 4)
-10 to +50℃
Storage Humidity Range (Note 4)
Adaptive FPC/FFC Contact Specifications
Items
Thickness : = 0.3 ± 0.05mm Gold Plated
Specifications
Conditions
Insulation Resistance
500M Ω Min.
100V DC
Withstanding Voltage
No flashover or insulation breakdown
150Vms AC for 1 min.
Contact
Resistance
50m Ω Max.
Includes FPC/FFC conductor resistance
1mA (DC or 1000Hz)
Mating Durability
(Insertion /
Withdrawal)
Contact Resistance : 50m Ω Max.
No damage, cracks, or parts dislocation
20 cycles
Vibration
No electrical discontinuity of 1μ s or more
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
10 cycles in each of the 3 directions
Shock
Acceleration of 981m/s2, duration of 6 ms,
sine half-wave waveform, 3 cycles in each of the 3 axes
Humidity
(Steady State)
Insulation Resistance : 50M Ω Min.
96 hours at temperature of 40℃ and humidity of 90% to 95%
Temperature
Cycle
Temperature : -40 → +15 to +35 → +105 (Note 3) → +15
to +35℃
Time : 30 → 2 to 3 → 30 → 2 to 3 (Minutes)
5 cycles
Resistance to
Soldering Heat
No deformation of components affecting
performance
Reflow : Peak temperature 250℃ Max.,
230℃ or more, 60 seconds or less
Manual soldering : 350 ± 10℃ for 5 seconds
Note 1 : When passing the current through all of the contacts, use 70% of the current rating.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : FH52K withstands up to 125℃ . The heat resistant when using FFC is 105℃ . When the heat resistant temperature is less than 125℃ for
FPC and 105℃ for FFC, the heat resistant temperature of the FPC/FFC is applied.
Note 4 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity Range covers non-conducting condition of installed connectors in storage, shipment or during transportation.
Materials / Finish
Part
Materials
Color/Finish
Grey
Insulator
LCP
Contacts
Copper Alloy
Partially Gold Plated
Solder Tabs
Brass
Tin Plated
Black
5
Remarks
UL94V-0
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH52 E - 50 (25) S B - 0.5 SH (##)
❶
❷
❸
❹
❺ ❻
❼
❽
❾
❶
Series Name
FH52
❺
Contact
Arrangement
Single (pole piece array)
❷
Connector Type
Blank : Standard Type
E : Long Solder Tabs Type
K : Long Solder Tabs, 125℃ Heat
Resistant Type
T : Long Solder Tabs, 2-Point
Contact Type
❻
Alternating
Direction
No Symbol : Standard Type
(All Contacts Loaded)
A : Alternating Contact Type
(Alternating on the Polarity Side)
B : Alternating Contact Type
(Alternating on Opposite the Polarity Side)
❼
Contact Pitch
0.5mm, 1mm
❸
No. of Pos.
Standard Type : No. of Pos.
Alternating Contact Type : Mold Size
❽
Termination Type
SH : SMT Horizontal Mounting Type
❹
No. of Pos.
Standard Type : No Symbol
Alternating Contact Type : No. of Pos.
❾
Specification
Blank : Standard, Partially Gold Plated,
3,000pcs per reel
(99) : Partially Gold Plated, 500pcs per reel
6
Connector Dimensional Drawing
■FH52 (Standard Type) 0.5mm Pitch Product
A±0.15
B±0.08
(0.12)
(5.0)
0.5±0.08
A ##
(0.15)
(C)
D±0.1
No. of Pos. Indicator
c
b
1.75±0.2
Detailed Drawing a
(Note 6) c
(3.9)
10
(1
2.0±0.2
Cav No.
a
(Note 1)(Note 2) 0.15 Max.
1.4±0.1
3.0±0.1
(4.3)
5.7±0.2
Note 1 : The coplanarity of the contact and solder tab lead is 0.1 Max.
Note 2 : The contact lead position indicates the dimension from b, the bottom surface of the
insulator body.
Note 3 : Packaged in tape and reel only. Check the "Packaging Specification" for details.
Note 4 : Sink mark reliefs may be added due to improvements.
Note 5 : Sight variations in color of the plastic compounds do not affect form, fit or function.
After reflow, the contact plating may change color, however this does not represent a
quality issue.
Note 6 : The actuator design of the 60pos. type are shown in the figure.
7
0.15 Max. (Note 1)(Note 2)
0.45±0.1
0.7±0.2
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
FH52-6S-0.5SH(##)
CL0580-3304-0-##
6
7.3
2.5
3.57
5.7
FH52-8S-0.5SH(##)
CL0580-3305-3-##
8
8.3
3.5
4.57
6.7
FH52-10S-0.5SH(##)
CL0580-3306-6-##
10
9.3
4.5
5.57
7.7
FH52-11S-0.5SH(##)
CL0580-3320-7-##
11
9.8
5.0
6.07
8.2
FH52-12S-0.5SH(##)
CL0580-3307-9-##
12
10.3
5.5
6.57
8.7
FH52-15S-0.5SH(##)
CL0580-3302-5-##
15
11.8
7.0
8.07
10.2
FH52-18S-0.5SH(##)
CL0580-3321-0-##
18
13.3
8.5
9.57
11.7
FH52-20S-0.5SH(##)
CL0580-3309-4-##
9.5
10.57
12.7
FH52-22S-0.5SH(##)
CL0580-3317-2-##
22
15.3
10.5
11.57
13.7
FH52-24S-0.5SH(##)
CL0580-3318-5-##
24
16.3
11.5
12.57
14.7
FH52-25S-0.5SH(##)
CL0580-3316-0-##
25
16.8
12.0
13.07
15.2
FH52-26S-0.5SH(##)
CL0580-3319-8-##
26
17.3
12.5
13.57
15.7
FH52-28S-0.5SH(##)
CL0580-3324-8-##
28
18.3
13.5
14.57
16.7
FH52-30S-0.5SH(##)
CL0580-3310-3-##
30
19.3
14.5
15.57
17.7
FH52-32S-0.5SH(##)
CL0580-3325-0-##
32
20.3
15.5
16.57
18.7
FH52-40S-0.5SH(##)
CL0580-3300-0-##
40
24.3
19.5
20.57
22.7
FH52-42S-0.5SH(##)
CL0580-3329-1-##
42
25.3
20.5
21.57
23.7
FH52-45S-0.5SH(##)
CL0580-3311-6-##
45
26.8
22.0
23.07
25.2
FH52-50S-0.5SH(##)
CL0580-3303-8-##
50
29.3
24.5
25.57
27.7
FH52-60S-0.5SH(##)
CL0580-3301-2-##
60
34.3
29.5
30.57
32.7
8
Purchase Unit Purchase Unit
(##) : (00)
(##) : (99)
3,000pcs per reel
500pcs per reel
■FH52 (Standard Type) 1.0mm Pitch Product
A±0.15
(Q)
(R)
B±0.08
(0.12)
(5.0)
1±0.08
A ##
b
(C)
D±0.1
2.0±0.2
Detailed Drawing a
(Note 6) c
10
(1
1.75±0.2
(0.15)
a
c
(3.9)
Cav No.
(1.3) 0.15 Max. (Note 1)(Note 2)
0.45±0.1
1.4±0.1
3.0±0.1
0.7±0.2
(4.3)
5.7±0.2
insulator body.
quality issue.
Note 6 : The actuator design of the 30pos. type are shown in the figure.
Unit : mm
HRS No.
No. of
Pos.
A
B
C
D
Q
R
FH52-10(4)SA-1SH(##)
CL0580-3330-0-##
4
9.3
3
5.57
7.7
2.9
3.4
FH52-5S-1SH(##) (Note)
CL0580-3336-7-##
5
9.8
4.0
6.07
8.2
2.9
2.9
FH52-12S-1SH(##)
CL0580-3323-5-##
12
16.8
11
13.07
15.2
2.9
2.9
FH52-32(16)SB-1SH(##) (Note)
CL0580-3338-2-##
16
20.3
15
16.57
18.7
2.4
2.9
FH52-60(30)SB-1SH(##)
CL0580-3315-7-##
30
34.3
29
30.57
32.7
2.4
2.9
Part No.
Note : The (99) specification is only available for 4, 12 and 30pos.
9
(##) : (00)
(##) : (99)
3,000pcs
per reel
500pcs
per reel
■FH52E (Long Solder Tabs Type) 0.5mm Pitch
Product
(0.12)
(5.0)
0.5±0.08
A±0.15
B±0.08
A ##
Cav No.
a
c
b
E±0.2
(Note 6) c
1.75±0.2
Detailed Drawing a
0°
(3.9)
2.0±0.2
(C)
D±0.1
11
1.2±0.2 (1.3)
1.55±0.2
0.45±0.1
0.7±0.2
(4.3)
5.7±0.2
insulator body.
quality issue.
Unit : mm
HRS No.
No. of
Pos.
A
B
C
D
E
FH52E-6S-0.5SH(##)
CL0580-3365-0-##
6
7.3
2.5
3.57
5.55
8.1
FH52E-8S-0.5SH(##)
CL0580-3349-0-##
8
8.3
3.5
4.57
6.55
9.1
FH52E-10S-0.5SH(##)
CL0580-3346-0-##
10
9.3
4.5
5.57
7.55
10.1
FH52E-15S-0.5SH(##)
CL0580-3337-0-##
15
11.8
7.0
8.07
10.05
12.6
FH52E-18S-0.5SH(##)
CL0580-3331-3-##
18
13.3
8.5
9.57
11.55
14.1
FH52E-20S-0.5SH(##)
CL0580-3357-0-##
9.5
10.57
12.55
15.1
FH52E-22S-0.5SH(##)
CL0580-3343-2-##
22
15.3
10.5
11.57
13.55
16.1
FH52E-24S-0.5SH(##)
CL0580-3340-4-##
24
16.3
11.5
12.57
14.55
17.1
FH52E-26S-0.5SH(##) (Note)
CL0580-3366-0-##
26
17.3
12.5
13.57
15.55
18.1
FH52E-30S-0.5SH(##)
CL0580-3347-3-##
30
19.3
14.5
15.57
17.55
20.1
FH52E-40S-0.5SH(##)
CL0580-3334-1-##
40
24.3
19.5
20.57
22.55
25.1
FH52E-45S-0.5SH(##)
CL0580-3368-0-##
45
26.8
22.0
23.07
25.05
27.6
FH52E-50S-0.5SH(##)
CL0580-3335-4-##
50
29.3
24.5
25.57
27.55
30.1
FH52E-60S-0.5SH(##)
CL0580-3339-5-##
60
34.3
29.5
30.57
32.55
35.1
FH52E-64S-0.5SH(##)
CL0580-3333-9-##
64
36.3
31.5
32.57
34.55
37.1
FH52E-68S-0.5SH(##)
CL0580-3332-6-##
68
38.3
33.5
34.57
36.55
39.1
Part No.
Note : The (99) specification is available for all positions except 26pos.
10
(##) : (00)
(##) : (99)
3,000pcs
per reel
500pcs
per reel
■FH52E (Long Solder Tabs Type) 1.0mm Pitch
Product
A±0.15
(Q)
(R)
B±0.08
(0.12)
(5.0)
1.0±0.08
A ##
a
c
(C)
b
D±0.1
Detailed Drawing a
(Note 6) c
10
(1
1.75±0.2
2.0±0.2
E±0.2
(3.9)
Cav No.
1.2±0.2
0.45±0.1
1.55±0.2
0.7±0.2
(4.3)
5.7±0.2
Note
Note
Note
Note
Note
insulator body.
quality issue.
Unit : mm
HRS No.
No. of
Pos.
A
B
C
D
E
Q
R
FH52E-8(4)SB-1SH(##)
CL0580-3351-0-##
4
8.3
3.0
4.57
6.55
9.1
2.4
2.9
FH52E-20(10)SA-1SH(##)
CL0580-3352-0-##
10
14.3
9.0
10.57
12.55
15.1
2.9
2.4
FH52E-20(10)SB-1SH(##)
CL0580-3353-0-##
10
14.3
9.0
10.57
12.55
15.1
2.4
2.9
FH52E-50(25)SA-1SH(##)
CL0580-3354-0-##
25
29.3
24.0
25.57
27.55
30.1
2.9
2.4
FH52E-50(25)SB-1SH(##)
CL0580-3355-0-##
25
29.3
24.0
25.57
27.55
30.1
2.4
2.9
FH52E-60(30)SB-1SH(##) (Note)
CL0580-3358-0-##
30
34.3
29.0
30.57
32.55
35.1
2.4
2.9
Part No.
Note : The (99) specification is available for all positions except 30pos.
11
(##) : (00)
(##) : (99)
3,000pcs
per reel
500pcs
per reel
■FH52K (Long Solder Tabs, 125℃ Heat
Resistant Type) 0.5mm Pitch Product
A±0.15
B±0.08
(0.12)
(5.0)
0.5±0.08
A ##
a
c
(C)
b
D±0.1
Detailed Drawing a
(Note 6) c
10
(1
1.75±0.2
2.0±0.2
E±0.2
(3.9)
Cav No.
1.2±0.2
0.45±0.1
0.7±0.2
1.55±0.2
(4.3)
5.7±0.2
Note
Note
Note
Note
Note
2 : The contact terminal lead position indicates the dimension from b, the bottom surface of the
insulator body.
quality issue.
12
Unit : mm
HRS No.
No. of
Pos.
A
B
C
D
E
FH52K-6S-0.5SH(##)
CL0580-4613-0-##
6
7.3
2.5
3.57
5.55
8.1
FH52K-8S-0.5SH(##)
CL0580-4611-0-##
8
8.3
3.5
4.57
6.55
9.1
FH52K-10S-0.5SH(##)
CL0580-4606-0-##
10
9.3
4.5
5.57
7.55
10.1
FH52K-12S-0.5SH(##)
CL0580-4629-0-##
12
10.3
5.5
6.57
8.55
11.1
FH52K-15S-0.5SH(##)
CL0580-4617-0-##
15
11.8
7.0
8.07
10.05
12.6
FH52K-18S-0.5SH(##)
CL0580-4636-0-##
18
13.3
8.5
9.57
11.55
14.1
FH52K-20S-0.5SH(##)
CL0580-4604-0-##
9.5
10.57
12.55
15.1
FH52K-22S-0.5SH(##)
CL0580-4632-0-##
22
15.3
10.5
11.57
13.55
16.1
FH52K-24S-0.5SH(##)
CL0580-4633-0-##
24
16.3
11.5
12.57
14.55
17.1
FH52K-25S-0.5SH(##)
CL0580-4634-0-##
25
16.8
12.0
13.07
15.05
17.6
FH52K-26S-0.5SH(##)
CL0580-4635-0-##
26
17.3
12.5
13.57
15.55
18.1
FH52K-30S-0.5SH(##)
CL0580-4631-0-##
30
19.3
14.5
15.57
17.55
20.1
FH52K-32S-0.5SH(##)
CL0580-4600-9-##
32
20.3
15.5
16.57
18.55
21.1
FH52K-34S-0.5SH(##)
CL0580-4601-0-##
34
21.3
16.5
17.57
19.55
22.1
FH52K-40S-0.5SH(##)
CL0580-4620-0-##
40
24.3
19.5
20.57
22.55
25.1
FH52K-45S-0.5SH(##)
CL0580-4637-0-##
45
26.8
22.0
23.07
25.05
27.6
FH52K-50S-0.5SH(##)
CL0580-4609-0-##
50
29.3
24.5
25.57
27.55
30.1
FH52K-60S-0.5SH(##)
CL0580-4607-0-##
60
34.3
29.5
30.57
32.55
35.1
FH52K-68S-0.5SH(##)
CL0580-4614-0-##
68
38.3
33.5
34.57
36.55
39.1
FH52K-80S-0.5SH(05) (Note)
CL0580-4641-0-05
80
44.3
39.5
40.57
42.55
45.1
Part No.
(##) : (00)
(##) : (99)
3,000pcs
per reel
500pcs
per reel
Note : The (05) specification is available for 80pos. only. The purchase unit is 2,000pcs per reel for specification (05) of FH52K-80S-0.5SH.
13
Resistant Type) 1.0mm Pitch Product
A±0.15
(R)
B±0.08
1±0.08
Detailed Drawing A
(0.12)
(5.0)
(Q)
A ##
a
Cav No.
b
Detailed Drawing a
(C)
0°
1.75±0.2
11
2±0.2
D±0.1
E±0.2
(3.9)
c
(Note 1)(Note 2)0.15 Max.
(1.3)
0.45±0.1
1.2±0.2
1.55±0.2
0.7±0.2
(4.3)
5.7±0.2
Note
Note
Note
Note
Note
insulator body.
quality issue.
Unit : mm
Part No.
HRS No.
No. of
Pos.
FH52K-12(6)SA-1SH(##)
CL0580-4638-0-##
6
10.3
5.0
6.57
8.55
11.1
2.9
2.4
FH52K-20(10)SB-1SH(##)
CL0580-4630-0-##
10
14.3
9.0
10.57
12.55
15.1
2.4
2.9
A
B
C
D
E
Q
R
14
(##) : (00)
(##) : (99)
3,000pcs
per reel
500pcs
per reel
■FH52T (Long Solder Tabs, 2-Point Contact
A±0.15
B±0.08
(2.35)
(2.45)
(0.08)
(5.0)
0.5±0.08
A ##
Cav No.
a
c
(C)
b
D±0.1
Detailed Drawing a
10
(1
1.75±0.2
2.0±0.2
E±0.2
(3.9)
(1.6)
0.45±0.1
1.2±0.2
1.55±0.2
0.7±0.2
(4.2)
5.7±0.2
Note
Note
Note
Note
Note
insulator body.
quality issue.
Unit : mm
HRS No.
No. of
Pos.
A
B
C
D
E
FH52T-10S-0.5SH(##)
CL0580-4503-0-##
10
9.3
4.5
5.57
7.55
10.1
FH52T-24S-0.5SH(##)
CL0580-4500-0-##
24
16.3
11.5
12.57
14.55
17.1
FH52T-32S-0.5SH(##)
CL0580-4502-0-##
32
20.3
15.5
16.57
18.55
21.1
FH52T-50S-0.5SH(##)
CL0580-4501-7-##
50
29.3
24.5
25.57
27.55
30.1
Part No.
15
(##) : (00)
(##) : (99)
3,000pcs
per reel
500pcs
per reel
● Recommended
Dimensions
PCB Mounting Pattern and Metal Mask
Connector image
0.3±0.03(Land pattern)
0.25±0.03(Metal mask)
2±0.05
0.5±0.05
E±0.05
0.8±0.03
The recommended PCB mounting pattern for the FH12 Series (horizontal
mounting type) can be used as well.
● Recommended
FPC/FFC Dimensions
F±0.1 (Note)
G±0.05
B±0.03
0.5±0.03
0.35±0.03
(FPC)
0.3±0.03
(FFC)
0.3±0.05
2-R0.2±0.1 (Note)
2-R0.2±0.1 (Note)
(1.0 Min.)
1.35±0.1 (Note)
3.5 Min.
2-R0.2±0.05
0.5±0.07
2-R0.2±0.1 (Note)
2-R0.2±0.05 (Note)
Note : FPC/FFC without tabs can also be used.
When using FPC/FFC without tabs the specified dimensions are not necessary.
16
4.5 Min.
0.5±0.07
3.1±0.1 (Note)
4.6±0.05
0.85±0.05
Recommended metal mask thickness : 0.12mm
B±0.05
Unit : mm
Part No.
HRS No.
No. of Pos.
B
E
F
G
FH52-6S-0.5SH(##)
CL0580-3304-0-##
6
2.5
5.1
5.1
3.5
FH52-8S-0.5SH(##)
CL0580-3305-3-##
8
3.5
6.1
6.1
4.5
FH52-10S-0.5SH(##)
CL0580-3306-6-##
10
4.5
7.1
7.1
5.5
FH52-11S-0.5SH(##)
CL0580-3320-7-##
11
5.0
7.6
7.6
6.0
FH52-12S-0.5SH(##)
CL0580-3307-9-##
12
5.5
8.1
8.1
6.5
FH52-15S-0.5SH(##)
CL0580-3302-5-##
15
7.0
9.6
9.6
8.0
FH52-18S-0.5SH(##)
CL0580-3321-0-##
18
8.5
11.1
11.1
9.5
FH52-20S-0.5SH(##)
CL0580-3309-4-##
12.1
12.1
10.5
FH52-22S-0.5SH(##)
CL0580-3317-2-##
22
10.5
13.1
13.1
11.5
FH52-24S-0.5SH(##)
CL0580-3318-5-##
24
11.5
14.1
14.1
12.5
FH52-25S-0.5SH(##)
CL0580-3316-0-##
25
12.0
14.6
14.6
13.0
FH52-26S-0.5SH(##)
CL0580-3319-8-##
26
12.5
15.1
15.1
13.5
FH52-28S-0.5SH(##)
CL0580-3324-8-##
28
13.5
16.1
16.1
14.5
FH52-30S-0.5SH(##)
CL0580-3310-3-##
30
14.5
17.1
17.1
15.5
FH52-32S-0.5SH(##)
CL0580-3325-0-##
32
15.5
18.1
18.1
16.5
FH52-40S-0.5SH(##)
CL0580-3300-0-##
40
19.5
22.1
22.1
20.5
FH52-42S-0.5SH(##)
CL0580-3329-1-##
42
20.5
23.1
23.1
21.5
FH52-45S-0.5SH(##)
CL0580-3311-6-##
45
22.0
24.6
24.6
23.0
FH52-50S-0.5SH(##)
CL0580-3303-8-##
50
24.5
27.1
27.1
25.5
FH52-60S-0.5SH(##)
CL0580-3301-2-##
60
29.5
32.1
32.1
30.5
17
● Recommended
Dimensions
0.85±0.05
B±0.05
0.3±0.03
(Land pattern)
1.0±0.05
2.0±0.05
(Connector image)
S±0.05
● Recommended
T±0.05
E±0.05
0.8±0.03
FPC/FFC Dimensions
F±0.1 (Note)
G±0.07
2-R0.2±0.05
V±0.1
B±0.05
U±0.1
0.3±0.05
0.6±0.03
1.0±0.05
2-R0.2±0.1 (Note)
1.35±0.1 (Note)
3.1±0.1(Note)
(1.0 Min.)
4.5 Min.
2-R0.2±0.1 (Note)
3.5 Min.
4.6±0.05
0.25±0.03
(Metal mask)
2-R0.2±0.1 (Note)
2-R0.2±0.05 (Note)
Unit : mm
Part No.
HRS No.
No. of
Pos.
B
E
F
G
S
T
U
V
CL0580-3330-0-##
4
3.0
7.1
7.1
5.5
1.8
2.3
1.5
1.0
CL0580-3336-7-##
5
4.0
7.6
7.6
6.0
1.8
1.8
1.0
1.0
FH52-12S-1SH(##)
CL0580-3323-5-##
12
11.0
14.6
14.6
13.0
1.8
1.8
1.0
1.0
CL0580-3338-2-##
16
15.0
18.1
18.1
16.5
1.3
1.8
1.0
0.5
CL0580-3315-7-##
30
29.0
32.1
32.1
30.5
1.3
1.8
1.0
0.5
18
Product
● Recommended
Dimensions
(0.2)
0.5±0.05
(0.3)
(0.3)
1.8±0.05
5.85±0.05
(0.2)
Connector image
B±0.05
F±0.05
FPC/FFC Dimensions
G±0.1 (Note)
H±0.05
2-R0.2±0.05
0.5±0.03
B±0.03
0.35±0.03
(FPC)
0.3±0.03
(FFC)
2-R0.2±0.1 (Note)
2-R0.2±0.1 (Note)
2-R0.2±0.1 (Note)
1.35±0.1 (Note)
3.1±0.1 (Note)
0.3±0.05
0.5±0.07
2-R0.2±0.05 (Note)
19
(1.0 Min.)
0.5±0.07
4.5 Min.
● Recommended
(0.225)
(0.5)
2.0±0.03
3.5 Min.
0.85±0.05
Unit : mm
Part No.
HRS No.
No. of Pos.
B
F
G
H
FH52E-6S-0.5SH(##)
CL0580-3365-0-##
6
2.5
5.1
5.1
3.5
FH52E-8S-0.5SH(##)
CL0580-3349-0-##
8
3.5
6.1
6.1
4.5
FH52E-10S-0.5SH(##)
CL0580-3346-0-##
10
4.5
7.1
7.1
5.5
FH52E-15S-0.5SH(##)
CL0580-3337-0-##
15
7.0
9.6
9.6
8.0
FH52E-18S-0.5SH(##)
CL0580-3331-3-##
18
8.5
11.1
11.1
9.5
FH52E-20S-0.5SH(##)
CL0580-3357-0-##
12.1
12.1
10.5
FH52E-22S-0.5SH(##)
CL0580-3343-2-##
22
10.5
13.1
13.1
11.5
FH52E-24S-0.5SH(##)
CL0580-3340-4-##
24
11.5
14.1
14.1
12.5
CL0580-3366-0-##
26
12.5
15.1
15.1
13.5
FH52E-30S-0.5SH(##)
CL0580-3347-3-##
30
14.5
17.1
17.1
15.5
FH52E-40S-0.5SH(##)
CL0580-3334-1-##
40
19.5
22.1
22.1
20.5
FH52E-45S-0.5SH(##)
CL0580-3368-0-##
45
22.0
24.6
24.6
23.0
FH52E-50S-0.5SH(##)
CL0580-3335-4-##
50
24.5
27.1
27.1
25.5
FH52E-60S-0.5SH(##)
CL0580-3339-5-##
60
29.5
32.1
32.1
30.5
FH52E-64S-0.5SH(##)
CL0580-3333-9-##
64
31.5
34.1
34.1
32.5
FH52E-68S-0.5SH(##)
CL0580-3332-6-##
68
33.5
36.1
36.1
34.5
Product
● Recommended
Dimensions
B±0.05
1.0±0.05
0.3±0.03
(Land pattern)
5.85±0.05
0.25±0.03
(Metal mask)
(Connector image)
1.8±0.05
S±0.05
T±0.05
F±0.05
● Recommended
2.0±0.03
FPC/FFC Dimensions
G±0.1 (Note)
H±0.07
B±0.05
U±0.1
V±0.1
0.6±0.03
1.0±0.05
2-R0.2±0.05
0.3±0.05
4.5 Min.
2-R0.2±0.1 (Note)
1.35±0.1 (Note)
3.1±0.1(Note)
(1.0 Min.)
2-R0.2±0.1 (Note)
2-R0.2±0.1 (Note)
3.5 Min.
0.85±0.05
2-R0.2±0.05 (Note)
Unit : mm
HRS No.
No. of
Pos.
B
F
G
H
S
T
U
V
CL0580-3351-0-##
4
3.0
6.1
6.1
4.5
1.3
1.8
1.0
0.5
CL0580-3352-0-##
10
9.0
12.1
12.1
10.5
1.8
1.3
0.5
1.0
CL0580-3353-0-##
10
9.0
12.1
12.1
10.5
1.3
1.8
1.0
0.5
CL0580-3354-0-##
25
24.0
27.1
27.1
25.5
1.8
1.3
0.5
1.0
CL0580-3355-0-##
25
24.0
27.1
27.1
25.5
1.3
1.8
1.0
0.5
CL0580-3358-0-##
30
34.3
32.1
32.1
30.5
1.3
1.8
1.0
0.5
Part No.
21
● Recommended
Dimensions
(0.2)
F±0.05
(0.225)
(0.5)
2.0±0.03
FPC/FFC Dimensions
G±0.1 (Note)
H±0.05
2-R0.2±0.05
0.5±0.03
B±0.03
0.35±0.03
(FPC)
0.3±0.03
(FFC)
2-R0.2±0.1 (Note)
2-R0.2±0.1 (Note)
2-R0.2±0.1 (Note)
1.35±0.1(Note)
3.1±0.1 (Note)
0.3±0.05
0.5±0.07
2-R0.2±0.05 (Note)
22
(1.0 Min.)
0.5±0.07
4.5 Min.
● Recommended
(0.3)
(0.3)
1.8±0.05
5.85±0.05
0.5±0.05
3.5 Min.
(0.2)
0.85±0.05
Connector image
B±0.05
Unit : mm
Part No.
HRS No.
No. of Pos.
B
F
G
H
FH52K-6S-0.5SH(##)
CL0580-4613-0-##
6
2.5
5.1
5.1
3.5
FH52K-8S-0.5SH(##)
CL0580-4611-0-##
8
3.5
6.1
6.1
4.5
FH52K-10S-0.5SH(##)
CL0580-4606-0-##
10
4.5
7.1
7.1
5.5
FH52K-12S-0.5SH(##)
CL0580-4629-0-##
12
5.5
8.1
8.1
6.5
FH52K-15S-0.5SH(##)
CL0580-4617-0-##
15
7.0
9.6
9.6
8.0
FH52K-18S-0.5SH(##)
CL0580-4636-0-##
18
8.5
11.1
11.1
9.5
FH52K-20S-0.5SH(##)
CL0580-4604-0-##
12.1
12.1
10.5
FH52K-22S-0.5SH(##)
CL0580-4632-0-##
22
10.5
13.1
13.1
11.5
FH52K-24S-0.5SH(##)
CL0580-4633-0-##
24
11.5
14.1
14.1
12.5
FH52K-25S-0.5SH(##)
CL0580-4634-0-##
25
12.0
14.6
14.6
13.0
FH52K-26S-0.5SH(##)
CL0580-4635-0-##
26
12.5
15.1
15.1
13.5
FH52K-30S-0.5SH(##)
CL0580-4631-0-##
30
14.5
17.1
17.1
15.5
FH52K-32S-0.5SH(##)
CL0580-4600-9-##
32
15.5
18.1
18.1
16.5
FH52K-34S-0.5SH(##)
CL0580-4601-0-##
34
16.5
19.1
19.1
17.5
FH52K-40S-0.5SH(##)
CL0580-4620-0-##
40
19.5
22.1
22.1
20.5
FH52K-45S-0.5SH(##)
CL0580-4637-0-##
45
22.0
24.6
24.6
23.0
FH52K-50S-0.5SH(##)
CL0580-4609-0-##
50
24.5
27.1
27.1
25.5
FH52K-60S-0.5SH(##)
CL0580-4607-0-##
60
29.5
32.1
32.1
30.5
FH52K-68S-0.5SH(##)
CL0580-4614-0-##
68
33.5
36.1
36.1
34.5
CL0580-4641-0-05
80
39.5
42.1
42.1
40.5
23
● Recommended
Dimensions
B±0.05
1.0±0.05
0.3±0.03
(Land pattern)
5.85±0.05
0.25±0.03
(Metal mask)
(Connector image)
1.8±0.05
S±0.05
T±0.05
F±0.05
● Recommended
2.0±0.03
FPC/FFC Dimensions
G±0.1 (Note)
H±0.07
B±0.05
U±0.1
2-R0.2±0.05
V±0.1
0.6±0.03
1.0±0.05
0.3±0.05
4.5 Min.
2-R0.2±0.1 (Note)
1.35±0.1 (Note)
3.1±0.1(Note)
(1.0 Min.)
2-R0.2±0.1 (Note)
2-R0.2±0.1 (Note)
3.5 Min.
0.85±0.05
2-R0.2±0.05 (Note)
Unit : mm
Part No.
HRS No.
No. of
Pos.
B
F
G
H
S
T
U
V
CL0580-4638-0-##
6
5.0
8.1
8.1
6.5
1.8
1.3
0.5
1.0
CL0580-4630-0-##
10
9.0
12.1
12.1
10.5
1.3
1.8
1.0
0.5
24
● Recommended
Dimensions
0.85±0.05
B±0.05
0.3±0.03
(Land pattern)
0.5±0.05
5.85±0.05
0.25±0.03
(Metal mask)
1.8±0.05
(Connector image)
● Recommended
F±0.05
2.0±0.03
FPC/FFC Dimensions
G±0.1 (Note)
H±0.05
2-R0.2±0.05
0.5±0.03
B±0.03
0.35±0.03
(FPC)
0.3±0.03
(FFC)
0.3±0.05
0.5±0.07
2-R0.2±0.1 (Note)
3.5 Min.
(1.0 Min.)
2-R0.2±0.1 (Note)
4.5 Min.
0.5±0.07
2-R0.2±0.1 (Note)
1.35±0.1 (Note)
3.1±0.1 (Note)
2-R0.2±0.05 (Note)
Unit : mm
Part No.
HRS No.
No. of Pos.
B
F
G
H
FH52T-10S-0.5SH(##)
CL0580-4503-0-##
10
4.5
7.1
7.1
5.5
FH52T-24S-0.5SH(##)
CL0580-4500-0-##
24
11.5
14.1
14.1
12.5
FH52T-32S-0.5SH(##)
CL0580-4502-0-##
32
15.5
18.1
18.1
16.5
FH52T-50S-0.5SH(##)
CL0580-4501-7-##
50
24.5
27.1
27.1
25.5
25
FPC/FFC Construction (Recommended Specifications)
1. Single-Sided FPC (FPC : Flexible Printed Circuit)
Material Name
Covering Film Layer
Material
Polyimide
1mil
Copper Foil
Base Adhesive
Base Film
Reinforcement Material Adhesive
Stiffener
(25)
(25)
Cover Adhesive
Surface Treatment
Thickness ( µm)
0.2 μm Thick Gold Plated over 1 to 5 μm
Thick Nickel Underplating
Cu
1oz
Thermosetting Adhesive
Polyimide
1mil thick
Polyimide
7mil thick
Total
3
35
25
25
30
175
293
2. Double-Sided FPC (FPC : Flexible Printed Circuit)
Material Name
Covering Film Layer
Cover Adhesive
Surface Treatment
Material
Polyimide
1mil
Thickness ( µm)
(25)
(25)
3
Through-hole Copper
Cu
Copper Foil
Cu
Base Adhesive
18
Base Film
Polyimide
1mil thick
25
Base Adhesive
18
Copper Foil
Cu
Cover Adhesive
25
Covering Layer Film
Polyimide
1mil thick
25
Reinforcement Material Adhesive Thermosetting Adhesive
50
Stiffener
1/2oz
1/2oz
Polyimide
4mil thick
Total
15
18
(18)
100
297
Note : Use of double-sided FPC with copper foil is not recommended in order to prevent release of the FPC due to bending.
3. FFC (FFC : Flexible Flat Cable)
Material Name
Material
Polyester Film
Adhesive
Gold Plated Annealed Copper Foil
with Nickel Underplating
Adhesive
Thermoplastic Polyester
Thickness ( µm)
(12)
(30)
35
Polyester
Polyester
30
12
Adhesive
Polyester
30
Stiffener
Polyester
188
Total
295
Note : Typical thickness tolerance is about ± 20μ m
4. Precautions
1. This is a reference FPC/ FFC construction. Make the thickness of the FPC/ FFC mated portion 0. 30 ± 0. 05mm in
reference to the FPC/ FFC construction.
2. Contact an FPC/ FFC maker for details on component construction.
26
Carrier Tape Dimensions
(Tape Width 24mm Max.)
0 .1
5 +0
(2.4)
(0.3)
(J)
φ
1.
2.0±0.1
12.0±0.1
4.0±0.1
K±0.1 1.75±0.1
L±0.3
● Embossed
5 +0
(2.4)
(0.3)
1.7 +0.15
(J)
K±0.1
M±0.1
L±0.3
2.0±0.1
4.0±0.1
12.0±0.1
1.75±0.1
(Tape Width 32mm Min.)
0 .1
● Embossed
φ
1.
Unreeling Direction
● Reel
1.5+0.1
(6.4)
Dimensions
φ80±1
0.2
φ13±
P±1: Reel Inside Width
R1
a
End Section Mounting Section
Blank Section
(15 Pockets Min.)
φ
21
0.
2±0.5
N±1: Reel Outside Width
8
Detailed Drawing a
φ380±2
Unreeling Direction
(4.65)
(6.4)
Embossed Carrier
Tape
Lead Section (400mm Min.)
Blank Section
(10 Pockets Min.)
27
Top Cover Tape
Part No.
HRS No.
Unit : mm
No. of Pos.
J
FH52-6S-0.5SH(##)
CL0580-3304-0-##
6
7.6
FH52-8S-0.5SH(##)
CL0580-3305-3-##
8
8.6
FH52-10S-0.5SH(##)
CL0580-3306-6-##
10
9.6
FH52-11S-0.5SH(##)
CL0580-3320-7-##
11
10.1
FH52-12S-0.5SH(##)
CL0580-3307-9-##
12
10.6
FH52-15S-0.5SH(##)
CL0580-3302-5-##
15
12.1
FH52-18S-0.5SH(##)
CL0580-3321-0-##
18
13.6
FH52-20S-0.5SH(##)
CL0580-3309-4-##
FH52-22S-0.5SH(##)
CL0580-3317-2-##
22
15.6
FH52-24S-0.5SH(##)
CL0580-3318-5-##
24
16.6
FH52-25S-0.5SH(##)
CL0580-3316-0-##
25
17.1
FH52-26S-0.5SH(##)
CL0580-3319-8-##
26
17.6
FH52-28S-0.5SH(##)
CL0580-3324-8-##
28
18.6
FH52-30S-0.5SH(##)
CL0580-3310-3-##
30
19.6
FH52-32S-0.5SH(##)
CL0580-3325-0-##
32
20.6
FH52-40S-0.5SH(##)
CL0580-3300-0-##
40
24.6
FH52-42S-0.5SH(##)
CL0580-3329-1-##
42
25.6
FH52-45S-0.5SH(##)
CL0580-3311-6-##
45
27.1
FH52-50S-0.5SH(##)
CL0580-3303-8-##
50
29.6
FH52-60S-0.5SH(##)
CL0580-3301-2-##
60
34.6
K
L
M
N
P
11.5
24.0
29.4
25.4
14.2
32.0
28.4
37.4
33.4
20.2
44.0
40.4
49.4
45.4
26.2
56.0
52.4
61.4
57.4
Part No.
HRS No.
Unit : mm
No. of Pos.
J
K
L
M
N
P
29.4
25.4
29.4
25.4
CL0580-3330-0-##
4
9.6
11.5
24.0
CL0580-3336-7-##
5
10.1
11.5
24.0
FH52-12S-1SH(##)
CL0580-3323-5-##
12
17.1
14.2
32.0
28.4
37.4
33.4
CL0580-3338-2-##
16
20.6
20.2
44.0
40.4
49.4
45.4
CL0580-3315-7-##
30
34.6
26.2
56.0
52.4
61.4
57.4
28
FH52E (Long Solder Tabs Type) 0.5mm Pitch Product
Part No.
HRS No.
No. of Pos.
J
FH52E-6S-0.5SH(##)
CL0580-3365-0-##
6
7.6
FH52E-8S-0.5SH(##)
CL0580-3349-0-##
8
8.6
FH52E-10S-0.5SH(##)
CL0580-3346-0-##
10
9.6
FH52E-15S-0.5SH(##)
CL0580-3337-0-##
15
12.1
FH52E-18S-0.5SH(##)
CL0580-3331-3-##
18
13.6
FH52E-20S-0.5SH(##)
CL0580-3357-0-##
FH52E-22S-0.5SH(##)
CL0580-3343-2-##
22
15.6
FH52E-24S-0.5SH(##)
CL0580-3340-4-##
24
16.6
CL0580-3366-0-##
26
17.6
FH52E-30S-0.5SH(##)
CL0580-3347-3-##
30
19.6
FH52E-40S-0.5SH(##)
CL0580-3334-1-##
40
24.6
FH52E-45S-0.5SH(##)
CL0580-3368-0-##
45
27.1
FH52E-50S-0.5SH(##)
CL0580-3335-4-##
50
29.6
FH52E-60S-0.5SH(##)
CL0580-3339-5-##
60
34.6
FH52E-64S-0.5SH(##)
CL0580-3333-9-##
64
36.6
FH52E-68S-0.5SH(##)
CL0580-3332-6-##
68
38.6
Unit : mm
K
L
M
N
P
11.5
24.0
29.4
25.4
14.2
32.0
28.4
37.4
33.4
20.2
44.0
40.4
49.4
45.4
26.2
56.0
52.4
61.4
57.4
FH52E (Long Solder Tabs Type) 1.0mm Pitch Product
Part No.
HRS No.
No. of Pos.
J
CL0580-3351-0-##
4
8.6
CL0580-3352-0-##
10
14.6
CL0580-3353-0-##
10
14.6
CL0580-3354-0-##
25
29.6
CL0580-3355-0-##
25
29.6
CL0580-3358-0-##
30
34.6
29
Unit : mm
K
L
M
N
P
11.5
24.0
29.4
25.4
20.2
44.0
40.4
49.4
45.4
26.2
56.0
52.4
61.4
57.4
FH52K (Long Solder Tabs, 125℃ Heat Resistant Type) 0.5mm Pitch
Product
Part No.
HRS No.
No. of Pos.
J
FH52K-6S-0.5SH(##)
CL0580-4613-0-##
6
7.6
FH52K-8S-0.5SH(##)
CL0580-4611-0-##
8
8.6
FH52K-10S-0.5SH(##)
CL0580-4606-0-##
10
9.6
FH52K-12S-0.5SH(##)
CL0580-4629-0-##
12
10.6
FH52K-15S-0.5SH(##)
CL0580-4617-0-##
15
12.1
FH52K-18S-0.5SH(##)
CL0580-4636-0-##
18
13.6
FH52K-20S-0.5SH(##)
CL0580-4604-0-##
FH52K-22S-0.5SH(##)
CL0580-4632-0-##
22
15.6
FH52K-24S-0.5SH(##)
CL0580-4633-0-##
24
16.6
FH52K-25S-0.5SH(##)
CL0580-4634-0-##
25
17.1
FH52K-26S-0.5SH(##)
CL0580-4635-0-##
26
17.6
FH52K-30S-0.5SH(##)
CL0580-4631-0-##
30
19.6
FH52K-32S-0.5SH(##)
CL0580-4600-9-##
32
20.6
FH52K-34S-0.5SH(##)
CL0580-4601-0-##
34
21.6
FH52K-40S-0.5SH(##)
CL0580-4620-0-##
40
24.6
FH52K-45S-0.5SH(##)
CL0580-4637-0-##
45
27.1
FH52K-50S-0.5SH(##)
CL0580-4609-0-##
50
29.6
FH52K-60S-0.5SH(##)
CL0580-4607-0-##
60
34.6
FH52K-68S-0.5SH(##)
CL0580-4614-0-##
68
38.6
CL0580-4641-0-05
80
44.6
Unit : mm
K
L
M
N
P
11.5
24.0
29.4
25.4
14.2
32.0
28.4
37.4
33.4
20.2
44.0
40.4
49.4
45.4
26.2
56.0
52.4
61.4
57.4
34.2 ± 0.3
72.0+0.4/-0.3
68.4
77.4
73.4
FH52K (Long Solder Tabs, 125℃ Heat Resistant Type) 1.0mm Pitch
Product
Part No.
HRS No.
No. of Pos.
J
CL0580-4638-0-##
6
10.6
CL0580-4630-0-##
10
14.6
K
L
11.5
24.0
M
P
29.4
25.4
FH52T (Long Solder Tabs, 2-Point Contact Type) 0.5mm Pitch Product
Part No.
HRS No.
Unit : mm
N
Unit : mm
No. of Pos.
J
K
L
M
N
P
FH52T-10S-0.5SH(##)
CL0580-4503-0-##
10
9.6
11.5
24.0
29.4
25.4
FH52T-24S-0.5SH(##)
CL0580-4500-0-##
24
16.6
14.2
32.0
28.4
37.4
33.4
FH52T-32S-0.5SH(##)
CL0580-4502-0-##
32
20.6
20.2
44.0
40.4
49.4
45.4
FH52T-50S-0.5SH(##)
CL0580-4501-7-##
50
29.6
26.2
56.0
52.4
61.4
57.4
30
Recommended Temperature Profile
Applicable Conditions
250℃ Max.
Temperature
250
230℃
200
200℃
150
Solder Method :
Reflow, IR
Environment :
Room air
Solder Composition :
Paste, 96.5%Sn/3.0%Ag/0.5%Cu
(Senju Metal Industry's Part Number : M705221CM5-32-10.5)
Test Board :
Material and Size
150℃
100
Glass epoxy 80mm × 100mm × 1.6mm thick
50
25℃(60sec.) 90sec. to 120sec.
Preheating Time
(60sec.)
Soldering Time
Start
180
Time (Seconds)
Land Dimensions 0.3 × 0.85mm
Metal Mask Dimensions :
0.12mm thick
Opening dimensions 0.25 × 0.85mm
This temperature profile is for the above applicable conditions.
The temperature profile may vary depending on the type of cream solder, the
manufacturer, the board size, and other conditions such as mounting materials.
Please check the mounting status before use.
31
Operation and Precautions
[ Operation]
1. FPC/ FFC Insertion
① Lift the actuator upward. ( Lock release)
You can easily pop it up with the thumbnail or index- finger nail.
② Insert the FPC or FFC with the exposed conductive traces facing down.
When connecting a tabbed FPC/ FFC, ensure that the FPC/ FFC is inserted at an angle of approximately
10°with respect to the board surface and perpendicular to the connector.
FPC/FFC Positioning Guide
③ Rotate down the actuator until firmly closed.
2. FPC/ FFC removal
① Lift the actuator upward. After the lock has been released slightly lift up the FPC/ FFC and pull it out.
32
[ Precautions]
① The FH52 Series actuator does not rotate open beyond 110°. Do not apply a force to open it beyond
this point. The actuator may come off or be permanently damaged.
② Insert the FPC or FFC properly to the opening of the connector.
Improper insertion may lead to a break or poor continuity of the FPC or FFC.
③ The connector does not have a strong upward tensile strength due to its design.
Secure the FPC or FFC when it is subjected to a tensile force.
④ When inserting an FPC or FFC, do not rub it vigorously against the bottom side of the connector opening.
Excessive contact between the contacts and the FPC or FFC may result in the deformation of contacts,
peeling of conductive traces, or other faults.
33
Precautions when Mating/Unmating FPC/FFC with Tabs for Positioning Guidance
[ How to insert]
Insert the cable so that the tabs align in the interspace (
) between the mold walls on both ends of the cable
insertion port and the guide walls (
) on the insides of both sides of the connector.
[ Precautions when mating/ un- mating]
① Avoid insertion in diagonal direction.
Do not insert the cable in diagonal direction.
The corner of the cable may touch the contact, resulting in contact deformation.
Be sure to insert the FPC or FFC straight into the connector opening.
Perpendicular to the Connector
34
② Avoid Overlap
Avoid inserting the cables in way that it overlaps the guides on either side. Do not close the actuator
with the cables overlapped on the guides as it may result in conduction failure.
Overlap on Both Guides
Overlap on Right Guide
Correct Insertion
FPC/FFC Positioning Tab
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please review the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, the warranty of the product may be
affected.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
HIROSE
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
※ The contents of this catalog are current as of date of 9/ 2023. Contents are subject to change without notice for the purpose of improvements.
※ The HRS logo and "HIROSE" are trademarks of HIROSE ELECTRIC CO., LTD.
35
