FH63S-10S-0.5SH(99)
FH63S-10S-0.5SH(99)
    HRS(广濑)
    HIROSE(HRS) - FH63S-10S-0.5SH(99) - FFC / FPC Board Connector, R/A, 0.5 mm, 10 Contacts, Receptacle,...
FH63S-10S-0.5SH(99) 数据手册
0.5mm Pitch FLYER FH63S Series One Action Lock, Horizontal Type FPC, FFC, Shielded FFC Connectors Nov.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Features 1 One Action Lock improves workability and is ideal for robot assembly 2 Independent spring with two-point contact design for high contact reliability - Wiping effect reduces contact failure due to foreign matter Supports Embedded Display Port 1.3 HDMI 1.4a USB 3.0 V-by-One HS 3 125℃ heat resistance - Passed various strict tests for automotive 4 Easy FPC insertion and high retention force 5 Shielded FFC is available for EMI prevention One Action Lock ◆FPC/FFC Insertion ◆FPC/FFC Removal ① Insert FPC ①Unlock Lift lock lever For Automotive Applications Patented Specifications (Inserting) ②Lock Click ③Close the lock lever* ②Removal FPC Lock lever stays open without being hold back by hand. Rated Current 0.5A Rated Voltage 50V AC/DC Withstanding Voltage 150V AC for 1 min. Insulation Resistance 500MΩ or more (DC 100V) Operating Temperature -55 to +125C Mating Durability 10 times - RoHS compliant, Halogen free* *This product satisfies halogen free requirements defined as 900ppm maximum chlorine, 900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine. *The lock lever close automatically when the FPC is removed, but this is not a defect of the product. MKT-J-19121F Issued: Jan.28,2020 © 2019 HIROSE ELECTRIC CO., LTD. All rights reserved. 予告なく、仕様を変更する場合がございますので、詳細の仕様につきましては弊社窓口へお問い合わせ頂きますようお願い申し上げます。
FH63S-10S-0.5SH(99) 价格&库存
很抱歉,暂时无法提供与“FH63S-10S-0.5SH(99)”相匹配的价格&库存,您可以联系我们找货
