NEW
0.3mm Pitch, 0.9mm Height, Top Contact One Action Lock, High FPC Retention Force Connector
FH72 Series
Dimension Diagram : 11pos.
6.7m
m
(11
p
os.)
0.9mm
Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3.5mm
0.7mm
(width)
0.4mm
(guide)
■Features
1. Space-saving design
Fig.1
One Action Lock
[Before mating]
· Space saving design with 0.3mm pitch, 3.5mm depth,
0.9mm height (Fig.1).
2. Automatic one action lock design
One action locking by simply inserting FPC after
mounting contributes to enhanced workability (Fig.2).
(Lock release by operating the lock lever when
removing.)
· Operation of the actuator is not required at the time of
FPC mating.
· Can be inserted with one hand.
· Contributes to assembly time reduction.
· Lock lever will not be damaged by operation.
· Eliminates failures due to FPC movement during
locking.
3. High FPC retention force
· The notches on both sides of FPC are held by the lock
lever, generating a high FPC retention force in spite of
the small size (Fig.3).
[After mating]
Insert only
Fig.2
High FPC retention force due to lock design
[FPC being inserted]
[FPC inserted]
4. Easy FPC insertion
· Wide guide for easy FPC insertion (Fig.1).
5. Compatible with 0.2mm thickness FPC
· 3mm pitch connector compatible with 0.2mm standard
thickness FPC (Appropriate rigidness of metal plates
prevents FPC deformation and issues during inserting
and fitting).
6. Detect FPC Mis-Mating with Original
Structure
Disengagement
prevention
Fig.3
FPC mis-mating detection
· Can detect mis-mating by checking the FPC insertion
status with FPC pattern (Fig.4).
7. Environmental
· Halogen free
*AS defined by IEC 61249-2-21.
Br : 900ppm max, Cl : 900ppm max, Br+Cl : 1,500ppm
max
OK
Fig.4
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2022.2
1
FH72 Series●0.3mm Pitch, 0.9mm Height, Top Contact One Action Lock, High FPC Retention Force Connector
■Product Specifications
Rating
Rated
current
0.3A
Operating
temperature range
-55 to +85°C (Note 1)
Rated
voltage
30V AC/DC
Operating
humidity range
Relative humidity 90%
max. (No condensation)
Adaptive FPC/FFC
contact specifications
Specification
50Mø min.
100V DC
2. Withstanding voltage
No flashover or insulation breakdown
100mø max.
* Including FPC conductor resistance
Contact resistance : 100mø max.
No damage, cracks, or parts dislocation
No electrical discontinuity of 1µs or more
Insulation resistance : 50Mø min.
90V AC rms / 1minute
4. Durability
(insertion/withdrawal)
5. Vibration
6. Shock
7. Humidity
(Steady state)
Conditions
1. Insulation resistance
3. Contact resistance
-10 to +50°C (Note 2)
Thickness : = 0.2±0.03mm Gold plated contact traces
Item
Storage
Temperature
range
Storage humidity
range
8. Temperature cycle
9. Resistance to soldiering
heat
No deformation of components affecting
performance
1mA (AC)
10 cycles
Frequency :
10 to 55Hz, single amplitude of 0.75mm,
10 cycles in each of the 3 directions
Acceleration of 981m/s2, duration of 6ms, sine
half-wave waveform, 3 cycles in each of the 3
axes
96 hours at temperature of 40°C and humidity
of 90% to 95%
Temperature :
-55°C→+15°C to +35°C→+85°C→
+15°C to +35°C
Time : 30→ 2∼3→ 30→ 2 to 3 (Minutes)
5 cycles
Reflow : See recommended temperature profile
(Page 8)
Manual soldering : 350 ± 10°C for 5 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature
Range and Humidity Range covers non-conducting condition of installed connectors in storage, shipment or during
transportation.
■Materials / Finish
Part
Insulator
Contact
Material
Color / Finish
UL standard
LCP
Beige
UL94V-0
Polyamide
Black
UL94V-0
Copper alloy
Gold plated
ーーー
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH 72 − 11S − 0.3 SHW (99)
❹
Series Name: FH
Series No.:72
No. of contacts:11
Connector pitch:0.3mm
2
❺
❻
Terminal type
SHW : SMT horizontal staggered array type
Specification
Blank : Standard 6,000pcs/reel
(99) : 500pcs/reel
■Connector Dimensions
A±0.15
B±0.15
0.6±0.1
HRS mark Cavity No.
(0.22)
Contact No.2
Number of contacts
(3.04)
(0.22)
(E)
80
(1
(1.62)
0.9±0.1
1.135±0.1
7
Fig.1
3.5±0.1
2.41±0.1
(2.33)
(1.11)
(0.67)
(0.59)
(0.25)
(FPC : t=0.2)
(0.54)
0.22±0.1
Lot No.
Polarity mark
Contact No.1
(0.22)
0.6±0.1
C±0.15
D±0.15
2.08±0.1 (Vacume pick up area)
3.34±0.1
0.16±0.1
(0.3)
0.31±0.1
Contact point position
2.83±0.15
0.36±0.1
Lock lever tab
Note
1 : Dimensions in parentheses are reference.
2 : Level of contact and retention tab lead shall be 0.1 max.
3 : Packaged in tape and reel. See the packaging specifications for details.
4 : Please note that the appearance may change slightly in order to improve sink marks.
5 : Quality of product remains good even when dark spots occur on molded plastic.
6 : This product satisfies halogen free requirements defined as 900ppm maximum chlorine, 900ppm maximum bromine,
and 1500ppm maximum total of chlorine and bromine.
7 Fig.1 indicates the lock lever in an open condition. FPC can be extracted by opening the lock lever more than 45°.
Unit : mm
FH72-7S-0.3SHW(**)
Under planning (Note 1)
No. of
Contacts
7
FH72-9S-0.3SHW(**)
9
Part No.
HRS No.
A
B
C
D
E
5.5
1.2
1.8
4.2
3.23
6.1
1.8
2.4
4.8
3.83
FH72-11S-0.3SHW(**)
580-5100-0 **
11
6.7
2.4
3.0
5.4
4.43
FH72-13S-0.3SHW(**)
13
7.3
3.0
3.6
6.0
5.03
FH72-15S-0.3SHW(**)
580-5104-0 **
15
7.9
3.6
4.2
6.6
5.63
FH72-17S-0.3SHW(**)
17
8.5
4.2
4.8
7.2
6.23
FH72-19S-0.3SHW(**)
19
9.1
4.8
5.4
7.8
6.83
FH72-21S-0.3SHW(**)
580-5101-0 **
21
9.7
5.4
6.0
8.4
7.43
FH72-23S-0.3SHW(**)
23
10.3
6.0
6.6
9.0
8.03
FH72-25S-0.3SHW(**)
25
10.9
6.6
7.2
9.6
8.63
FH72-27S-0.3SHW(**)
27
11.5
7.2
7.8
10.2
9.23
FH72-29S-0.3SHW(**)
29
12.1
7.8
8.4
10.8
9.83
FH72-31S-0.3SHW(**)
580-5102-0 **
31
12.7
8.4
9.0
11.4
10.43
Note 1 : Contact positions without HRS No. are currently under planning.
Please contact Hirose for detailed information about product variations.
3
Recommended PCB Mounting Pattern
0.68±0.02
0.6
0.35±0.02
(n-1)/2X
0.02 X
Contact No.1
2.58±0.02
(0.13)
(Connector Image)
0.64±0.02
Contact No.2
(n+1)/2X
0.35±0.02
0.64±0.02
2.58±0.03
B
(0.3)
0.02 X
0.6
C±0.02
X
0.4±0.02
2X
0.02 X
D
(Recommended stencil pattern thickness : t=0.1)
B
0.35±0.01
(n-1)/2X
0.02 Y
(0.3)
(Land pattern image)
3.11±0.01
0.6
0.54±0.01
(0.3)
0.44±0.01
3.11±0.01
0.55±0.01
Recommended Stencil Pattern
(n+1)/2X
0.35±0.01
0.02 Y
0.6
0.35±0.01
C±0.02
Y
2X
D
0.02 Y
Note 8 : 'n' shows the number of contacts.
Unit : mm
FH72-7S-0.3SHW(**)
No. of
contacts
7
FH72-9S-0.3SHW(**)
9
Part No.
HRS No.
B
C
D
1.2
1.8
4.2
1.8
2.4
4.8
FH72-11S-0.3SHW(**)
580-5100-0 **
11
2.4
3.0
5.4
FH72-13S-0.3SHW(**)
13
3.0
3.6
6.0
FH72-15S-0.3SHW(**)
580-5104-0 **
15
3.6
4.2
6.6
FH72-17S-0.3SHW(**)
17
4.2
4.8
7.2
FH72-19S-0.3SHW(**)
19
4.8
5.4
7.8
FH72-21S-0.3SHW(**)
580-5101-0 **
21
5.4
6.0
8.4
FH72-23S-0.3SHW(**)
23
6.0
6.6
9.0
FH72-25S-0.3SHW(**)
25
6.6
7.2
9.6
FH72-27S-0.3SHW(**)
27
7.2
7.8
10.2
FH72-29S-0.3SHW(**)
29
7.8
8.4
10.8
FH72-31S-0.3SHW(**)
580-5102-0 **
31
8.4
9.0
11.4
Please contact Hirose for detailed information about product variation.
4
Recommended FPC Dimensions Diagram
Contact No.1
F±0.05
C±0.02
B
0.3
0.45±0.05
9 R
.0 5
±0
.15
R0 0.05
.15
0.075±0.07
0.05
15±
R0.
0.07±0.07
Contact No.2
0.2±0.02
0.2±0.02
((N-1)/2)X
0.02 X
0.35±0.03
10 F±0.05
Note 9 When designing the FPC dimension R must be 0.5mm minimum.
10 Apply indicated tolerance to exposed part of conductor.
Part No.
3.04±0.3 (stiffener)
1.62±0.1
0.74±0.1
1.47±0.1
1±0.1
0.2±0.03
R0
.15
R0 0.05
.15
±0
.05
0±0.05
0.58±0.05
((N+1)/2)X
0.02 X
0.35±0.03
0.07±0.07
R
R0 0.15±0
.15
±0 05
.05
1.18±0.05
0.1±0.02
R0
2.04±0.3
(Exposed conductor part)
.05
±0 0.05
.15
R0 0.15
R
0.1±0.02
0.43±0.1
0.07±0.07
X
0.7±0.07
0.26±0.1
0.7±0.07
HRS No.
Unit : mm
No. of
contacts
7
B
C
F
1.2
1.8
3.2
FH72-7S-0.3SHW(**)
FH72-9S-0.3SHW(**)
9
1.8
2.4
3.8
FH72-11S-0.3SHW(**)
580-5100-0 **
11
2.4
3.0
4.4
FH72-13S-0.3SHW(**)
13
3.0
3.6
5.0
FH72-15S-0.3SHW(**)
580-5104-0 **
15
3.6
4.2
5.6
FH72-17S-0.3SHW(**)
17
4.2
4.8
6.2
FH72-19S-0.3SHW(**)
19
4.8
5.4
6.8
FH72-21S-0.3SHW(**)
580-5101-0 **
21
5.4
6.0
7.4
FH72-23S-0.3SHW(**)
23
6.0
6.6
8.0
FH72-25S-0.3SHW(**)
25
6.6
7.2
8.6
FH72-27S-0.3SHW(**)
27
7.2
7.8
9.2
FH72-29S-0.3SHW(**)
29
7.8
8.4
9.8
FH72-31S-0.3SHW(**)
580-5102-0 **
31
8.4
9.0
10.4
FPC Construction (Recommended Specifications)
Material Name
Covering film
Material
Thickness
(µm)
Polyimide 1mil
(25)
(25)
Cover adhesive
(4)
Surface treatment
1 to 6µm nickel underplated 0.2µm gold under plated
Conductor copper foil
Cu
Base adhesive
Heat-hardened adhesive
25
Base film
Polyimide 1mil
25
Reinforcement material
35
adhesiveStiffener
Polyimide 5mil
75
1oz
35
Note 1. Material composition of FPC is a reference example. Please adjust the thickness of the FPC mating section to
0.2±0.03mm in reference to the material composition.
2. For the details of the material composition, please contact each FPC manufacturer.
5
Packaging Specifications
Embossed Carrier Tape Dimensions
(2)
(0.3)
8±0.1
1.75±0.1
(1.15)
4±0.1
Ø1
0.1
G
+0.3
- 0.1
H±0.1
.5
Unreeling direction
Leader, Trailer Dimensions
Unreeling direction
(J : Reel inner width)
400mm min (Leader)
Unreeling
direction
(Ø380)
(Ø80)
(Ø
13
Reel Dimensions
160mm min
(Trailer, empty components)
Embossed
carrier tape
Top cover tape
100mm min
(empty components)
(K : Reel outer width)
Unit : mm
FH72-7S-0.3SHW(**)
No. of
contacts
7
FH72-9S-0.3SHW(**)
9
FH72-11S-0.3SHW(**)
580-5100-0 **
11
FH72-13S-0.3SHW(**)
13
FH72-15S-0.3SHW(**)
580-5104-0 **
15
FH72-17S-0.3SHW(**)
17
FH72-19S-0.3SHW(**)
19
Part No.
HRS No.
FH72-21S-0.3SHW(**)
580-5101-0 **
21
FH72-23S-0.3SHW(**)
23
FH72-25S-0.3SHW(**)
25
FH72-27S-0.3SHW(**)
27
FH72-29S-0.3SHW(**)
29
FH72-31S-0.3SHW(**)
580-5102-0 **
31
G
H
J
K
16
7.5
17.4
21.4
24
11.5
25.4
29.4
6
Temperature Profile
Temperature(°C)
MAX 250°C
Applicable Conditions
245
Reflow method
220°C
Solder
200
: IR/Hot air
Reflow environment : Room air
: Paste type Sn/3.0Ag/0.5Cu
(M705-GRN360-K2-V made by
180°C
Senju Metal Industry Co.)
Test PCB
150
150°C
: PCB material and size
Glass epoxy 32.85×18.3×1mm
Land size per recommendation on
page 4.
100
20 to 40
sec.
50
Metal mask
: Thickness and opening size per
recommendation on page 4.
(Peak temperature)
25°C
120±5 sec.
(Preheating time)
60 to 90 sec.
(Soldering time)
This temperature profile is based on the above conditions.
It may vastly depending on solder paste type,
manufacturer, PCB size and mounting materials. Please
Start
use only after checking the mounting conditions.
Time (sec.)
7
Connector operation and points to note
[Operation Method]
As this connector is a small-sized, thin product, care needs to be taken when handling.
Please check the following before use.
1. Initial Condition
①The product is delivered with the lock lever closed. The lock lever does not need to be operated other than
when removing the FPC.
2. FPC insertion method
①Insert FPC with the conductor surface facing upwards, horizontally to the board surface until fully inserted.
[Caution]
· During FPC insertion do not twist the FPC vertically, laterally or diagonally. Doing so may result in
deformation of the contacts and contact failure.
FPC
(horizontal)
Lock lever (closed)
Lock lever (closed)
FPC (horizontal)
Lock lever (open)
Lock lever (open)
FPC (diagonal)
FPC (diagonal)
3. Checking the FPC insertion status
After FPC is completely inserted visually inspect the FPC insertion status.
OK
FPC
The FPC lock lever part
is hidden in the connector
8
FPC (shallow)
FPC lock lever part can be
seen from the connector
FPC (diagonal)
[Operation Method]
4. FPC extraction method
①Push up the lock lever slowly and release the lock.
[Caution]
・The lock lever cannot be opened over 180°. Do not open it over this angle.
・After releasing the lock lever, do not touch the contact.
・Do not raise, pull, or twist the lock lever.
OK
Do not touch the contact.
180°
Rotational axis
Load is concentrated
on the rotational axis
leading to damage
Excessive force is applied to the lock lever.
②After releasing the lock lever, extract the FPC in the horizontal direction.
③After remove of the FPC, close the lock lever.
[Caution]
・Do not pull out FPC while the lock lever is not opened to 45° or more.
・Ensure both ends of the lock lever are closed.
Lock lever (open)
45° or more
45°
OK
FPC can be extracted without
the lock lever and FPC interfering.
OK
OK
Close both ends of
the lock lever.
FPC diagonal
FPC diagonal
9
[Operation Method]
5. FPC routing
①When routing the FPC please do not apply a load as it may cause FPC disconnection and
damage.
It also may cause additional load to the connector resulting in poor connection and other issues.
[Caution]
・Make sure the FPC's stiffener does not touch the chassis.
・When designing and assembling the FPC avoid applying stress by pulling, pushing and loosening
on the connector. Additionally, avoid pulling up and down on the FPC
・When designing and assembling the FBC after cabling avoid pulling the FPC and route the wire
with slack. In this case the stiffener should be parallel to the PCB.
・Do not mount other components under the FPC's stiffener.
OK
Reinforcing film
Load applied to FPC
Mounting parts
that interfere with FPC
Reinforcing film
Load applied to FPC
[Cautions for mounting PCB]
◆PCB Warping
Minimize PCB warping as much as possible.
Lead co-planarity including reinforced metals is 0.1mm or less.
Too much PCB warping may result in a soldering failure.
◆FPC Mounting
When mounted on FPC, be sure to provide a reinforcing plate to ease handling.
We recommend a reinforcing plate of 0.3mm or thicker made of glass epoxy material.
◆Load to Connector
Do not apply an external for to the connector greater than 1.0N prior to mounting.
Additionally do not insert the FPC or operate the connector before mounting.
◆Load to PCB
• Splitting a large PCB into several pieces
• Screwing the PCB
Avoid the handling described above so that no force is
exerted on the PCB during the assembly process.
Otherwise, the connector may become defective.
Connector
FPC
(for mounting
connector)
◆Instructions on manual soldering
Follow the instructions shown below when soldering the connector manually during repair etc.
1. Do not perform any reflow or hand soldering operation while FPC is inserted in the connector.
2. Do not apply extreme heat, or allow the soldering iron to touch anything other than the connector
lead.
This could cause the connector to be deformed or melted.
3. Do not supply excessive solder (flux).
If excessive solder (flux) is applied to the contact, the solder or flux could adhere on the contact
point andcause contact failure.
10
MEMO:
11
MEMO:
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
12
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 02/2022. Contents are subject to change without notice for the purpose of improvements.
