FHP-04-02-H-S-A-K-TR
    SAMTEC(申泰)
    .156 HI POWER SOCKET ASSEMBLY
FHP-04-02-H-S-A-K-TR 数据手册
MAX 13.1 POWER HEADERS, STACKERS & SOCKETS A m p s (3.96 mm) .156" PITCH • FWJ, HFWJ, JW, FHP SERIES FWJ, HFWJ, JW Board Mates: FHP - HFWJ - - S OTHER OPTIONS Leave blank for Through-hole = Matte Tin –RA = Right-angle (Style –02 & –04 only) –VS = Surface Mount Requires HFWJ (2 pins/row minimum) Style –05 not available. –P = Pick & Place Pad (3 Pos. min.) (6.98 mm) .275" min. post height (–VS only) (3.18) .125 No. of Positions x (3.96) .156 A E C (6.35) .250 LEAD STYLE A –01 (11.43) .450 –02 (12.70) .500 –04 (20.55) .809 –05* (3.81) .150 F (2.54) .100 B D B C D E (10.46) .412 – – – (11.73).462 (4.45) .175 (8.13) .320 (2.54) .100 (3.96) .156 (19.10) .752 (3.96) .156 (12.07) .475 – – (4.45) .175 F (13.56) .534 (4.95) .195 – – *FWJ Only JW - NO. OF PINS - 04 - 02 thru 24 PROCESSING POST HEIGHT (0.00) .000 MIN FHP - NO. OF PINS -S- PLATING OPTION –T STACK HEIGHT (27.43) 1.08 MAX (6.35) .250 MIN = Stacker Height (in inches) (0.13 mm) .005" increments LEAD STYLE - –01 PLATING OPTION –T = Through-hole = Matte Tin –02 = Surface Mount - POST HEIGHT –“XXX” = Post Height (in inches) -S- (8.89) .350 –01 Leave blank for Through-hole –VS –P = Pick & Place Pad (3 Pos. min.) (6.98 mm) .275" min. post height (–VS only) OTHER OPTIONS –LC = Locking Clip (Manual placement required) (–02 lead style only) = (6.50 mm) .256" DIA Polyimide film Pick & Place Pad (2-4 positions require –”X”R) (–02 lead style only) (5.08) .200 OTHER OPTIONS = Surface Mount (2 pins/row minimum) –K No. of Positions x (3.96) .156 - Example: –250 = (6.35 mm) .250" (31.75) 1.25 MAX (3.18) .125 (2.29) .090 - STACK HEIGHT –“XXX” = Matte Tin STACK HEIGHT (29.21) 1.15 MAX WITH (0.00) .000 POST (8.89) .350 MIN 02 thru 24 Note: Some lengths, styles and options are non-standard, non-returnable. PLATING OPTION –T Specifiy LEAD STYLE from chart below High Temp Header SPECIFICATIONS - LEAD STYLE 01 thru 24 Standard Header Board Mates: FWJ, HFWJ, JW Lead–Free Solderable: FWJ = No, Lead Wave only HFWJ, JW, FHP = Yes SMT Lead Coplanarity: HFWJ, FWJ, JW = (0.20 mm) .008" max (02-16)* (0.25 mm) .010" max (17-24)* FHP = (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com) NO. OF PINS FWJ FHP Insulator Material: FWJ = Black Glass Filled Polyester HFWJ, JW = Natural Liquid Crystal Polymer FHP = Black LCP Terminal Material (FWJ, HFWJ, JW): Phosphor Bronze Contact Material (FHP): BeCu Plating: Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C Voltage Rating: 600 VAC/845 VDC Insertion Depth (FHP): (3.57 mm) .140" to (8.76 mm) .345" or pass-through from top Wiping Distance (FHP): (0.38 mm) .015" - SERIES –02 samtec.com?FWJ, samtec.com?HFWJ, samtec.com?JW or samtec.com?FHP –TR = Tape & Reel Packaging (Available on positions 2-18) (–02 lead style only) -FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (Available on positions 2-18) (-02 lead style only) F-224 WEB Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FHP-04-02-H-S-A-K-TR 价格&库存
很抱歉,暂时无法提供与“FHP-04-02-H-S-A-K-TR”相匹配的价格&库存,您可以联系我们找货
  • 300+101.43580300+13.14801
