FH26-21S-0.3SHW(05)
FH26-21S-0.3SHW(05)
    HRS(广濑)
    SMD
    FH26-21S-0.3SHW(05)
FH26-21S-0.3SHW(05) 数据手册
0.3 mm Pitch, 1.0 mm Height FPC Connector FH26 Series 1.0mm ●Space saving(51 pos. shown) 3.2mm 16.8mm Metal fittings do no protrude outside of the connector body ■Features ●Can be mounted over conductive traces. 1. Low-profile 0.3 mm pitch FPC connector Ultra-thin design, 1.0 mm height, 3.2 mm width all add up to a compact, space saving form factor. *30% reduction in PCB footprint *40% reduction in weight (Compared to our 0.3 mm pitch FH23 Series 51 position connector.) 2. Easy PCB Mounting The leads are double sided and have a 0.6 mm mounting lead pitch to simplify mounting. No exposed contacts on the bottom of the connector 3. Fully molded structure aids PCB layout The bottom of this connector is enclosed by a fully molded structure that protects the contacts and removes any restrictions from PCB patterning and design. 4. Rotating one-touch ZIF mechanism ●Operation (1) (1) Actuator Actuator open open (2) (2) Insert Insert FPC FPC The one-touch rotating ZIF mechanism is easier to operate and works with a light force, and a clear tactile click is delivered upon the successful completion of the mating process Actuator q 5. Easy FPC insertion The metal FPC insertion guides helps to make this the FPC insertion process easier. w 6. FPC. Accepts standard 0.2 mm thick FPC This connector accepts standard 0.2 mm thick FPC. (The proper FPC stiffener thickness will prevent FPC deformation and ease insertion and mating.) FPC 7. Supports automatic pick-n-place mounting Offered in tape and reel packaging that is compatible with automatic machine mounting. (5,000 pieces per reel) (3) (3) Close Close the the actuator actuator (4) (4) FPC FPC connected connected 8. Halogen-free If you need a Halogen free connector, please use the FH26W type. All materials and substances used to produce the FH26W Series product complies with Halogen-free standards. * Defined according to IEC61249-2-21 Br: 900ppm max, Cl: 900ppm max, Br+Cl: 1,500ppm max. 9. Multiple packing options e r The standard packaging is 5,000 pieces per reel, but it is also offered in a 500 piece reel. (The outer diameter of the reel will be Ø180 mm in this case.) 2013.11w 1 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors ■Specifications Rating Recommended FPC : Current rating Voltage rating Operating temperature range -55 ç to +85ç (Note 1) Operating humidity range Relative humidity 90% max. (No condensation) 0.2A DC 30V AC Storage temperature range -10ç to +50ç (Note 2) Storage humidity range Relative humidity 90% max. Thickness: = 0.2±0.03mm gold plated Item Specification Conditions 1. Insulation resistance 50 M ohms min. 100 V DC 2. Withstanding voltage No flashover or insulation breakdown. 90 V AC /one minute 3. Contact resistance 100 m ohms max. * Including FPC conductor resistance 1 mA 4. Durability (Insertion/ withdrawal) Contact resistance: 100 m ohms max. No damage, cracks, or parts dislocation. 10 cycles 5. Vibration No electrical discontinuity of 1μs or more. Contact resistance: 100 m ohms max. No damage, cracks, or parts dislocation. Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 10 cycles, 3 directions. 6. Shock No electrical discontinuity of 1μs. min. Contact resistance: 100 m ohms max. No damage, cracks, or parts dislocation. Acceleration of 981 m/s2, 6 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 7. Humidity (Steady state) Contact resistance: 100 m ohms max. Insulation resistance: 50 M ohms min. No affect on appearance or performance. 96 hours at temperature of 40±2ç and humidity of 90% to 95%. 8. Temperature cycle Contact resistance: 100 m ohms max. Insulation resistance: 50 M ohms min. No damage, cracks, or parts looseness. Temperature: -55 ç/+15ç to +35ç/+85ç/+15ç to +35ç Time: 30 / 2 to 3 / 30 / 2 to 3 (Minutes) 5 cycles 9. Resistance to soldering heat No deformation of components affecting performance. Reflow: At the recommended temperature profile Manual soldering: 350ç +/-10ç for 5±1 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation. ■Materials Part Material Finish LCP Insulator Contacts Metalfittings Remarks Color: Black UL94V-0 FH26 series: Deep brown PA Phosphor bronze FH26W series: Light brown UL94HB Gold plating --------------- Pure tin reflow plating --------------- ■Ordering information FH 26 W - 51S - 0.3 SHW (05) 1 3 4 5 6 7 1 Series name: FH 6 Termination type SHW: SMT horizontal staggered mounting type 2 Series No.: 26 7 Specifications 3 Blank: Standard W: Satisfies halogen-free requirements (Flame retardance UL94HB). 4 Number of positions: 13 to 71 5 Contact pitch: 0.3mm 2 2 (10)…Gold plating with nickel barrier, 5,000 pieces / reel (99)…Gold plating with nickel barrier, 500 pieces / reel FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors ■Connector Dimensions 0.3 A B 0.6 (0.3) 3.2 (1.25) (0.12) 0.6 Number of contacts indicator (0.12) 1 C 0.5 0.3 3.2 (D: FPC insertion slot dimension) 1 0.1 1 0.1 E Notes 1 The coplanarity of each terminal lead within specified dimension is 0.1 mm Max. 2 Packaged on tape and reel only. Check packaging specification. 3 Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. 4 After reflow, the terminal plating may change color, however this does not represent a quality issue. All dimensions: mm Part Number FH26-13S-0.3SHW(**) FH26-15S-0.3SHW(**) FH26-17S-0.3SHW(**) FH26-21S-0.3SHW(**) FH26-23S-0.3SHW(**) FH26-25S-0.3SHW(**) FH26-27S-0.3SHW(**) FH26-29S-0.3SHW(**) FH26-31S-0.3SHW(**) FH26-33S-0.3SHW(**) FH26-35S-0.3SHW(**) FH26-37S-0.3SHW(**) FH26-39S-0.3SHW(**) FH26-41S-0.3SHW(**) FH26-45S-0.3SHW(**) FH26-51S-0.3SHW(**) FH26-55S-0.3SHW(**) FH26-57S-0.3SHW(**) FH26-61S-0.3SHW(**) FH26-71S-0.3SHW(**) CL No. 580-0209-3-** 580-0218-4-** 580-0217-1-** 580-0207-8-** 580-0203-7-** 580-0208-0-** 580-0204-0-** 580-0216-9-** 580-0214-3-** 580-0210-2-** 580-0205-2-** 580-0224-7-** 580-0201-1-** 580-0206-5-** 580-0211-5-** 580-0200-9-** 580-0221-9-** 580-0212-8-** 580-0213-0-** 580-0202-4-** Number of Contacts 13 15 17 21 23 25 27 29 31 33 35 37 39 41 45 51 55 57 61 71 A 5.4 6.0 6.6 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 12.6 13.2 13.8 15.0 16.8 18.0 18.6 19.8 22.8 B 3.0 3.6 4.2 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.6 14.4 15.6 16.2 17.4 20.4 C 3.6 4.2 4.8 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 13.2 15.0 16.2 16.8 18.0 21.0 D 4.23 4.83 5.43 6.63 7.23 7.83 8.43 9.03 9.63 10.23 10.83 11.43 12.03 12.63 13.83 15.63 16.83 17.43 18.63 21.63 E 4.9 5.5 6.1 7.3 7.9 8.5 9.1 9.7 10.3 10.9 11.5 12.1 12.7 13.3 14.5 16.3 17.5 18.1 19.3 22.3 Part Number FH26W-13S-0.3SHW(**) FH26W-15S-0.3SHW(**) FH26W-17S-0.3SHW(**) FH26W-19S-0.3SHW(**) FH26W-21S-0.3SHW(**) FH26W-23S-0.3SHW(**) FH26W-25S-0.3SHW(**) FH26W-27S-0.3SHW(**) FH26W-29S-0.3SHW(**) FH26W-31S-0.3SHW(**) FH26W-33S-0.3SHW(**) FH26W-35S-0.3SHW(**) FH26W-37S-0.3SHW(**) FH26W-39S-0.3SHW(**) FH26W-41S-0.3SHW(**) FH26W-45S-0.3SHW(**) FH26W-51S-0.3SHW(**) FH26W-57S-0.3SHW(**) FH26W-61S-0.3SHW(**) FH26W-71S-0.3SHW(**) CL No. 580-2401-1-** 580-2402-4-** 580-2403-7-** 580-2437-9-** 580-2404-0-** 580-2405-2-** 580-2406-5-** 580-2400-9-** 580-2407-8-** 580-2408-0-** 580-2409-3-** 580-2410-2-** 580-2411-5-** 580-2412-8-** 580-2413-0-** 580-2414-3-** 580-2415-6-** 580-2417-1-** 580-2418-4-** 580-2419-7-** Number of Contacts 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 45 51 57 61 71 A 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 12.6 13.2 13.8 15.0 16.8 18.6 19.8 22.8 B 3 3.6 4.2 4.8 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.6 14.4 16.2 17.4 20.4 C 3.6 4.2 4.8 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 13.2 15.0 16.8 18.0 21.0 D 4.23 4.83 5.43 6.03 6.63 7.23 7.83 8.43 9.03 9.63 10.23 10.83 11.43 12.03 12.63 13.83 15.63 17.43 18.63 21.63 E 4.9 5.5 6.1 6.7 7.3 7.9 8.5 9.1 9.7 10.3 10.9 11.5 12.1 12.7 13.3 14.5 16.3 18.1 19.3 22.3 Note1 : Embossed tape reel packaging(5,000pieces/reel, 500pieces/reel). Order by number of reels. 3 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors (0.55:Metal mask) Recommended metal mask thickness: t=0.1 (0.3:Metal mask) 0.4±0.05 C±0.05 0.5±0.05 ■Recommended FPC Dimensions Detail H (Lead plated 0.1 MAX) F±0.05 0.3±0.07 0.2±0.03 1 M (0.5) 2.25±0.1 2.1±0.1 B A 2.5±0.3 0.3+0.04 -0.03 0.3±0.02 H 1.1±0.1 0.3±0.1 0.6±0.02 M AX (2.5) R0 .2 1±0.1 (0.15) 0±0.03 1.1±0.1 1±0.1 C±0.03 3.5 MIN.(Stiffener) 0.3±0.07 πRELATIVE POSITIONS OF POINT-A dnd B (0.65:Metal mask) 0.6±0.05 0.3±0.03 (0.23:Metal mask) 0.95±0.05 Outline of the connector 0.3±0.05 (0.7:Metal mask) (0.2) 0.6±0.05 0.2±0.05 0.3±0.03 (0.23:Metal mask) (0.45) B±0.05 2.15±0.05 0.8±0.05 (3.6) 0.65±0.05 ■Recommended PCB mounting pattern and metal mask dimensions 0.3+0.04 -0.03 0.1±0.02 (0.2) (0.2) (0.07) 0.6±0.07 (0.05) B±0.03 1 (0.15) 0.6±0.07 Dimention M must be 0.5mm minimum when the stiffener is shorter than 3.5 min. All dimensions: mm 4 Part Number CL No. FH26-13S-0.3SHW(**) FH26-15S-0.3SHW(**) FH26-17S-0.3SHW(**) FH26-21S-0.3SHW(**) FH26-23S-0.3SHW(**) FH26-25S-0.3SHW(**) FH26-27S-0.3SHW(**) FH26-29S-0.3SHW(**) FH26-31S-0.3SHW(**) FH26-33S-0.3SHW(**) FH26-35S-0.3SHW(**) FH26-37S-0.3SHW(**) FH26-39S-0.3SHW(**) FH26-41S-0.3SHW(**) FH26-45S-0.3SHW(**) FH26-51S-0.3SHW(**) FH26-55S-0.3SHW(**) FH26-57S-0.3SHW(**) FH26-61S-0.3SHW(**) FH26-71S-0.3SHW(**) 580-0209-3-** 580-0218-4-** 580-0217-1-** 580-0207-8-** 580-0203-7-** 580-0208-0-** 580-0204-0-** 580-0216-9-** 580-0214-3-** 580-0210-2-** 580-0205-2-** 580-0224-7-** 580-0201-1-** 580-0206-5-** 580-0211-5-** 580-0200-9-** 580-0221-9-** 580-0212-8-** 580-0213-0-** 580-0202-4-** Number of Contacts 13 15 17 21 23 25 27 29 31 33 35 37 39 41 45 51 55 57 61 71 B C F Part Number CL No. 3.0 3.6 4.2 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.6 14.4 15.6 16.2 17.4 20.4 3.6 4.2 4.8 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 13.2 15.0 16.2 16.8 18.0 21.0 4.2 4.8 5.4 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 12.6 13.8 15.6 16.8 17.4 18.6 21.6 FH26W-13S-0.3SHW(**) FH26W-15S-0.3SHW(**) FH26W-17S-0.3SHW(**) FH26W-19S-0.3SHW(**) FH26W-21S-0.3SHW(**) FH26W-23S-0.3SHW(**) FH26W-25S-0.3SHW(**) FH26W-27S-0.3SHW(**) FH26W-29S-0.3SHW(**) FH26W-31S-0.3SHW(**) FH26W-33S-0.3SHW(**) FH26W-35S-0.3SHW(**) FH26W-37S-0.3SHW(**) FH26W-39S-0.3SHW(**) FH26W-41S-0.3SHW(**) FH26W-45S-0.3SHW(**) FH26W-51S-0.3SHW(**) FH26W-57S-0.3SHW(**) FH26W-61S-0.3SHW(**) FH26W-71S-0.3SHW(**) 580-2401-1-** 580-2402-4-** 580-2403-7-** 580-2437-9-** 580-2404-0-** 580-2405-2-** 580-2406-5-** 580-2400-9-** 580-2407-8-** 580-2408-0-** 580-2409-3-** 580-2410-2-** 580-2411-5-** 580-2412-8-** 580-2413-0-** 580-2414-3-** 580-2415-6-** 580-2417-1-** 580-2418-4-** 580-2419-7-** Number of Contacts 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 45 51 57 61 71 B C F 3.0 3.6 4.2 4.8 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.6 14.4 16.2 17.4 20.4 3.6 4.2 4.8 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 13.2 15.0 16.8 18.0 21.0 4.2 4.8 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 12.6 13.8 15.6 17.4 18.6 21.6 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors ■Recommended FPC Construction ●Contact FPC manufacturer for specific details. 1. Using Single-sided FPC Connecting side Material Name Covering film layer. Material Polyimide 1 mil thick. Cover adhesive Thickness (μm) 25 25 Surface treatment 1μm to 5μm Nickel underplated 0.2μm Gold plated Copper foil Cu Base adhesive Thermosetting adhesive 25 Base film Polyimide 1 mil thick 25 Reinforcement material adhesive Thermosetting adhesive 40 Stiffener Polyimide 75 1oz 3 mil thick 3 35 203 Total Back side 2. Using Double-sided FPC Connecting side Material Material Name Covering layer film Polyimide 1 mil thick 25 25 Cover adhesive Surface treatment 1μm to 5μm Nickel underplated 0.2μm Gold plated Through-hole copper Cu Copper foil Cu Base adhesive Thermosetting adhesive 18 Base film Polyimide 1 mil thick 25 Base adhesive Thermosetting adhesive 18 Copper foil Cu 18 Cover adhesive Thermosetting adhesive 25 Covering layer film Polyimide 1 mil thick 25 Reinforcement material adhesive Thermosetting adhesive 25 Stiffener Back side Thickness (μm) Polyimide 3 15 1/2oz 1/2oz 1 mil thick Total 18 25 197 ●To prevent release of the FPC due to it's bending, use of double sided FPC with copper foil on the back side is NOT RECOMMENDED. 3. Precautions 1. This specification is a recommendation for the construction of the FH26 Series FPC (t=0.2 ± 0.03). 2. For details about the construction, please contact the FPC manufacturers. 5 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors ■Packaging Specification ●Embossed Carrier Tape Dimensions ●Embossed Carrier Tape Dimensions (3.05) (4.55) + 0 0 .1 G±0.3 (K) J±0.1 H±0.1 Ø1 (0.3) Flat surface, for placement with automatic equipment (1.25) Unreeling direction (3.05) (4.55) 1.5+0.1 0 1.7 +0.15 0 Unreeling direction .5 (1.6) (K) J±0.1 (0.3) 1.75±0.1 .5 8±0.1 Ø1 4±0.1 2±0.15 (1.6) (1.25) (Ø1 3) ●Reel Dimensions Unreeling direction (Ø80) (Ø380) (L : INSIDE) (M : OUTSIDE) End section Mounting section Lead section (400mm min.) Connectors Blank section (10 pockets min.) 6 Embossed carrier tape Blank section (10 pockets min.) Top cover tape G±0.3 1.75±0.1 (Tape width of 32mm min.) + 0 0 .1 (Tape width of 24mm max.) Flat surface, for placement with automatic equipment FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors All dimensions: mm Part Number FH26-13S-0.3SHW(**) FH26-15S-0.3SHW(**) FH26-17S-0.3SHW(**) FH26-21S-0.3SHW(**) FH26-23S-0.3SHW(**) FH26-25S-0.3SHW(**) FH26-27S-0.3SHW(**) FH26-29S-0.3SHW(**) FH26-31S-0.3SHW(**) FH26-33S-0.3SHW(**) FH26-35S-0.3SHW(**) FH26-37S-0.3SHW(**) FH26-39S-0.3SHW(**) FH26-41S-0.3SHW(**) FH26-45S-0.3SHW(**) FH26-51S-0.3SHW(**) FH26-55S-0.3SHW(**) FH26-57S-0.3SHW(**) FH26-61S-0.3SHW(**) FH26-71S-0.3SHW(**) CL No. 580-0209-3-** 580-0218-4-** 580-0217-1-** 580-0207-8-** 580-0203-7-** 580-0208-0-** 580-0204-0-** 580-0216-9-** 580-0214-3-** 580-0210-2-** 580-0205-2-** 580-0224-7-** 580-0201-1-** 580-0206-5-** 580-0211-5-** 580-0200-9-** 580-0221-9-** 580-0212-8-** 580-0213-0-** 580-0202-4-** Number of Contacts 13 15 17 21 23 25 27 29 31 33 35 37 39 41 45 51 55 57 61 71 G 16 16 16 16 16 16 16 24 24 24 24 24 24 24 24 24 32 32 32 44 H ------------------------------------------------28.4 28.4 28.4 40.4 J 7.5 7.5 7.5 7.5 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 14.2 20.2 K 5.6 6.2 6.8 8.0 8.6 9.2 9.8 10.4 11.0 11.6 12.2 12.8 13.4 14.0 15.2 17.0 18.2 18.8 20.0 23.0 L 17.4 17.4 17.4 17.4 17.4 17.4 17.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 33.4 45.4 M 21.4 21.4 21.4 21.4 21.4 21.4 21.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 37.4 49.4 Part Number FH26W-13S-0.3SHW(**) FH26W-15S-0.3SHW(**) FH26W-17S-0.3SHW(**) FH26W-19S-0.3SHW(**) FH26W-21S-0.3SHW(**) FH26W-23S-0.3SHW(**) FH26W-25S-0.3SHW(**) FH26W-27S-0.3SHW(**) FH26W-29S-0.3SHW(**) FH26W-31S-0.3SHW(**) FH26W-33S-0.3SHW(**) FH26W-35S-0.3SHW(**) FH26W-37S-0.3SHW(**) FH26W-39S-0.3SHW(**) FH26W-41S-0.3SHW(**) FH26W-45S-0.3SHW(**) FH26W-51S-0.3SHW(**) FH26W-57S-0.3SHW(**) FH26W-61S-0.3SHW(**) FH26W-71S-0.3SHW(**) CL No. 580-2401-1-** 580-2402-4-** 580-2403-7-** 580-2437-9-** 580-2404-0-** 580-2405-2-** 580-2406-5-** 580-2400-9-** 580-2407-8-** 580-2408-0-** 580-2409-3-** 580-2410-2-** 580-2411-5-** 580-2412-8-** 580-2413-0-** 580-2414-3-** 580-2415-6-** 580-2417-1-** 580-2418-4-** 580-2419-7-** Number of Contacts 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 45 51 57 61 71 G 16 16 16 16 16 16 16 16 24 24 24 24 24 24 24 24 24 32 32 44 H ---------------------------------------------------28.4 28.4 40.4 J 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 20.2 K 5.6 6.2 6.8 7.4 8.0 8.6 9.2 9.8 10.4 11.0 11.6 12.2 12.8 13.4 14.0 15.2 17.0 18.8 20.0 23.0 L 17.4 17.4 17.4 17.4 17.4 17.4 17.4 17.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 45.4 M 21.4 21.4 21.4 21.4 21.4 21.4 21.4 21.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 49.4 ■Recommended Temperature Profile MAX 250ç 250 Temperature 230ç 200 200ç 150 150ç (ç) 100 50 25ç (60sec.) 90 sec. to 120 sec. 0 Start 60 Preheating 120 Time (Seconds) (60sec.) Soldering HRS test conditions Solder method :Reflow, IR/hot air Environment :Room air Solder composition :Paste, 96.5%Sn/3.0%Ag/0.5%Cu (Senju Metal Industry, Co., Ltd.'s Part Number: M705221CM5-32-10.5) Test board :Glass epoxy 25mm∞50mm∞0.8mm thick Land dimensions :0.3mm∞0.65mm, 0.3mm∞0.8mm Metal mask :0.23∞0.55∞0.1mm thick, 0.23∞0.65∞0.1mm thick The temperature profiles are based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. 7 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors ■Operation and Precautions Operation 1.FPC insertion procedure. Connector installed on the board. 1 Lift up the actuator. Use thumb or index finger. 2 Fully insert the FPC in the connector par- allel to mounting surface, with the exposed conductive traces facing down. FPC conductor surface (Bottom side) 3 Rotate down the actuator until firmly closed. It is critical that the inserted FPC is not moved and remains fully inserted. 2.FPC removal 1 Lift up the actuator. Carefully withdraw the FPC. 8 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors Precautions This connector needs to be handled with care due to its thin design and miniature stature. [ Precautions when mounting to PCB ] SAcceptable amount of PCB distortion The PCB distortion should be kept to a minimum. The maximum coplanarity of this connector is 0.1 mm, but excessive distortion can create solder failure. SFPC specifications Stiffeners can be used to improve the rigidity of the FPC. We recommend using a glass epoxy with the thickness of 0.3 mm or more. SLoad to the connector Do not apply any excessive force or mate/unmate these connectors until they are mounted, failure to follow this precaution can lead to deformation or damage to these connectors. Inserting the FPC prior to mounting is not recommended either. [ Precautions in handling PCB after mounting ] SApplied force to the PCB Do not place any excessive force on the PCB after the connector has been mounted, this type of action may damage the connectors. (e.g., When separating the PCB into multiple boards or installing fastening screws onto the PCB) SPCB bending For PCB with a width of 100 mm, it should not be bent more than a maximum of 0.5 mm. (Please refer to the diagrams below.) PCB bending places an extra load onto the connector and will lead to damage or malfunction. Connector PCB 0.5MAX 100 0.5MAX Connector 100 PCB Precautions When Inserting or Coupling FPC Pay attention to the following points when inserting FPC. SActuator operation 1 Do not apply excessive force when opening the actuator prior to FPC insertion. When opening make sure that the force is applied only to the actuator itself, avoiding touching of the contacts. Actuator Damage to the contacts Damage Axis of rotation 2 Axis of rotation Assure free rotation of the actuator 9 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors Precautions 3 The actuator will rotate 135 degrees 135˚ maximum. Do not apply force to rotate further. (1N max.) 4 When operating the actuator, do so at the center portion. 5 As illustrated, do not attempt removal or re- positioning of the actuator. SFPC Insertionq The FPC should be aligned parallel with the board surface and perpendicular with the connector (as shown), then completely inserted. Perpendicular with the connector To assure correct electrical and mechanical connection do not insert FPC at angle. It must be fully inserted. Make sure that the FPC is NOT MOVED during the closing of the actuator. 10 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors Precautions SFPC Insertionw Do not insert the FPC at any angle from above. As illustrated, angle insertion may cause electrical discontinuity when the FPC is deflected in use. *To avert insertion of the FPC on an angle, consideration should be given to securing FPC insertion space at the time of board layout. Insertion will be difficult when the FPC is too short. *Contact the FPC manufacturer for information about the bending specifications. SVerification of the fully closed actuator. The actuator should be fully closed (as illustrated) and the FPC held firmly in the connector. Do not press against the actuator when is fully closed. Max force applied to the fully closed actuator should not exceed 1 N. Routing the FPC (FPC fully inserted/ actuator closed) SFPC Load Do not apply force in excess of 0.05N/pin max. in the upward direction (as illustrated). Do not bend the FPC too close to the actuator. Load: 0.05N/pin max. 11 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors Precautions Removing the FPC Rotate the actuator to the open position (maximum open angle of 135). Carefully withdraw the FPC. 135˚ Other Precautions SHand Soldering Precautions When hand soldering: 1 Do not perform reflow or hand soldering with the FPC inserted in the connector. 2 Do not apply excessive heat or touch the soldering iron anywhere other than the connector leads. 3 Do not use excessive amount of solder or flux compounds. Operation of the actuator and contacts may be affected by excessive amounts of solder or flux compounds. ® 12 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The contents of this catalog are current as of date of 11/2013. Contents are subject to change without notice for the purpose of improvements.
FH26-21S-0.3SHW(05) 价格&库存
很抱歉,暂时无法提供与“FH26-21S-0.3SHW(05)”相匹配的价格&库存,您可以联系我们找货
FH26-21S-0.3SHW(05)
  • 5000+7.676415000+0.99295
