FTSH-115-04-F-D
FTSH-115-04-F-D
    SAMTEC(申泰)
    插件,P=1.27mm
    排针 间距:1.27mm 插件
FTSH-115-04-F-D 数据手册
F-219 (Rev 11MAY20) FTSH–150–02–L–D FTSH–115–03–L–D–RA 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES FTSH–125–01–F–D (1.27 mm) .050" FTSH SERIES THROUGH-HOLE MICRO HEADER Impedance matched for high-speed applications (Mated with CLP Series) Board Mates: CLP, FLE SPECIFICATIONS For complete specifications see www.samtec.com?FTSH Cable Mates: FFSD, FFTP Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (FTSH/CLP): 3.4 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C RoHS Compliant: Yes (1.27 mm) .050" micro pitch (2.51 mm) .099" Mates with socket strips or IDC cable Optional end shrouds and ejector shrouds PROCESSING HIGH-SPEED CHANNEL PERFORMANCE Lead-Free Solderable: Yes Rating based on Samtec reference channel. For full SI performance data visit Samtec.com or contact SIG@samtec.com RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality 1 FTSH 8 Through-hole, right-angle or surface mount G b p s NO. PINS PER ROW LEAD STYLE PLATING OPTION D TAIL OPTION OPTION OTHER OPTIONS FILE NO. E111594 LOCKING CLIP FFSD For single STRIP ASSEMBLY LOCKING mating CLIP cycle with the PC ġ FFSD. BOARD Specify -LC after tail option. Lead Style -01 and 10 pins/row minimum. 5-9 pins/row not available in combination with keying shroud (-K). Specify LEAD STYLE from chart 02 thru 50 02 (1.27) .050 01 02 ALSO AVAILABLE (0.40) .016 SQ 99 (3.43) .135 A (2.51) .099 –01 Notes: See SFM/TFM for positive alignment feature. –02 Some sizes, styles and options are non-standard, non-returnable. –04 –03 A MATES OPTION WITH (3.05) FFSD .120 (1.91) FLE .075 (1.65) CLP-D .065 (3.81) N/A .150 –ES –EJ –EP –EL Z (1.55) .061 (15.77) .621 (5.87) .231 (6.53) .257 = End Shroud with Board Lock (Style –02 & –03) 9 pins/row min. = Ejector Shroud (Style –01 only) 10 pins/row min. 25 pins/row max. –RA not available –EP (11.18) .440 –RA –K (1.27) .050 –EJ (3.20) .126 (2.29) .090 –K (2.29) .090 –ES –RA –ES Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM –EP = End Shroud with Guide Post (Style –02 & –03) 9 pins/row min. –EL (1.91) .075 DIA –EL (2.16) .085 (5.08) .200 –ES = End Shroud (Style –02 & –03) 9 pins/row min. –EJ (2.29) .090 (1.27) .050 (1.27) .050 LEAD STYLE = Rightangle 100 (MOQ Required) • Molded Pick & Place pads • Other platings –RA –“XXX” (3.05) .120 (2.29) .090 (3.43) .135 01 Leave blank for straight tail (1.17) .046 99 No. of positions x (1.27) .050 = Polarized Position (Specify position of omitted pin) (Not available with -EX options) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail 100 –EX OPTION SHOWN –L = Gold flash on post, Matte Tin on tail No. of positions x (1.27) .050 + Z (4.78) .188 –F Leave blank for RIght-angle All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. (1.27) .050 = Keying Shroud for mating with FFSD (Style –01 only, 05, 08, 10, 13, 15, 17, 20 & 25 pins/row only and 13, 17, 20 & 25 only with –EJ option)
FTSH-115-04-F-D 价格&库存
很抱歉,暂时无法提供与“FTSH-115-04-F-D”相匹配的价格&库存,您可以联系我们找货
FTSH-115-04-F-D
  • 30+28.12368
  • 60+26.40675
  • 120+24.26665
  • 510+19.63579
  • 1020+16.20195
  • 2520+12.68347
  • 5010+9.09244
库存:245
FTSH-115-04-F-D
  • 1+28.996461+3.76945
  • 25+27.7590225+3.60859
  • 50+26.0936250+3.39209
  • 100+24.01389100+3.12173
  • 500+22.15238500+2.87974
库存:415
