MTLW-103-23-G-D-285
MTLW-103-23-G-D-285
    SAMTEC(申泰)
    针座连接器 通孔 6 位置 0.100"(2.54mm)
MTLW-103-23-G-D-285 数据手册
LOW PROFILE .025" SQ POST HEADERS (2.54 mm) .100" PITCH • TLW/MTLW SERIES TLW/MTLW Board Mates: BSW, CES, SLW, HLE TLW -1 01 thru 40 FEATURES These headers provide the ultimate low profile (0.64 mm) .025" square post board stacking system. The high quality Phosphor Bronze terminals are available with a standard short post height (TLW Series) for mating with low profile sockets, or the post height can be Modified (MTLW Series) to accommodate IDC assemblies and other applications. - NO. PINS PER ROW - LEAD STYLE 01 thru 36 = Double Row PROCESSING Lead–Free Solderable: Yes –G = 10 µ" (0.25 µm) Gold on post, Gold flash on tail (2.48) .098 F-224 –S –RA = Single Row = Right-angle (–01 Lead Style only) –D –“XX” = Double Row (5.03) .198 (3.05) .120 (1.52) .060 B = Polarized Position Specify position for omitted pin. —01 —05 & —06 MTLW -1 - NO. PINS PER ROW 01 thru 40 - LEAD STYLE Specify LEAD STYLE from chart = Single Row 01 thru 36 = Double Row PLATING OPTION –F = Gold flash on post, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –G = 10 µ" (0.25 µm) Gold on post, Gold flash on tail (2.48) .098 –T = Matte Tin (5.03) .198 POST (0.00) .000 MIN (OAL) LEAD STYLE A B –01 N/A (5.84) .230 –05 (4.32) .170 –06 (3.43) .135 ROW OPTION - B (1.52) .060 A (1.52) .060 Note: Some lengths, styles and options are non-standard, non-returnable. MTLW Series is non-standard, nonreturnable. OTHER OPTION –T MOQ Required Other platings Notch option - ROW OPTION = Matte Tin (2.54) .100 x No. of Positions ALSO AVAILABLE = Gold flash on post, Matte Tin on tail (2.54) .100 x No. of Positions SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (TLW/SLW): 5.2 A per pin (2 pins powered) Operating Temp Range: -55 °C to +105 °C with Tin -55 °C to +125 °C with Gold - –F Specify LEAD STYLE from chart = Single Row PLATING OPTION TAIL (0.00) .000 MIN - –S = Single Row –D (2.67) .105 POST HEIGHT –“XXX” = Post Height Dimension (In inches) = Double Row LEAD STYLE OAL –05 (8.51) .335 –06 (7.62) .300 –07 (10.92) .430 –08 (13.46) .530 –09 (18.54) .730 –10 (21.08) .830 –22 (16.00) .630 –23 (11.30) .445 –24 (12.19) .480 samtec.com?TLW or samtec.com?MTLW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MTLW-103-23-G-D-285 价格&库存
很抱歉,暂时无法提供与“MTLW-103-23-G-D-285”相匹配的价格&库存,您可以联系我们找货
MTLW-103-23-G-D-285
  • 16+18.16735
  • 50+14.00501
库存:66
MTLW-103-23-G-D-285
  • 1+13.355091+1.72995
  • 50+10.3010150+1.33434
  • 100+8.39335100+1.08724
  • 500+7.47544500+0.96833
库存:101
