The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
CTF SERIES PLASTIC D SUBMINIATURE SHELL (ACCESSORIES)
General
May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
HIROSE CTF series plastic D subminiature shells offer
the highest quality of mechanical design and
appearance. Available to fit 9, 15, 25, and 37 position
connectors and most competitors products. LN
mounts allow for design flexibility.
Features
(1) Standard screw type locking mechanism provides
a strong and secure lock.
(2) ABS resin molding material offers light weight,
sturdy construction.
(3) Easy to assemble and service because the case is
split at the center of the cable inlet and few screws
are used.
(4) Two types of locking devices are available, rectangular and hexagonal, to meet different panel
mounting complies.
(5) The 25-contact model complies with the the modem plug case specified in JIS-C-6361.
(6) Can easily incorporate solderling (HD) and crimping.
Application
Modems in communications equipment such as computers, peripherals and terminal eqipment, control
equipment, measuring instruments, and export equipment.
79
04/2009
Materials
Part
Material
Finish
Plug case
ABS resin
2.5PB 6/2(color)
Locking device
Steel or zinc
alloy die casting
Nickel plating
Ordering Informations
Plug case
Locking device
HD
B − CT
(1)
(2)
F
※1
※2
(3) (4) (5)
(8)
HD − LN
A
(1)
(7) (8)
(6)
※2
(1) Connector series
(2) Connector size: E (9 contacts), A (15 contacts), B (25 contacts), C (37 contacts)
Note: Not available for 50pos. cover.
(3) Type of plug case
CT: Plug case with a vertical cable inlet opening
(4) Serial sign for series
F: Plug case made of plastic
(5) Locking screws
No sign: To be locked with a screwdriver
1: To be locked by hand
(6) Locking device
LN: screw type locking device
(7) Type of locking device
Provided with a sequence of upper-case alphabe-tic charactors.
No sign: Rectangular
A: Hexagonal
(8) Type of screw
Provided with a sequence of Arabic numerls.
No sign: M2.6
(4-40): inch
80
04/2009
Dataphone shell (To be locked with a screwdriver)
Unit: mm
HDB-CTF(50)
HRS No
No.of pin
Part No.
A
B
C
D
E
F
G
H
CL211-0159-8-50
CL211-0160-7-50
CL211-0139-0-50
9
15
25
HDE-CTF(50)
HDA-CTF(50)
HDB-CTF(50)
24.99
33.32
47.04
33.2
41.2
55
18
18
27.2
40
19.2
27.2
40
40.2
43.2
46
19.6
19.6
20.8
7
9
10
CL211-0161-0-50
37
HDC-CTF(50)
63.5
72.2
57
51.2
24
12
RoHS
YES
Dataphone Shell (To be locked by hand)
Unit: mm
HDB-CTF1(50)
HRS No
No.of pin
Part No.
A
B
C
D
E
F
G
H
CL211-0168-9-50
9
HDE-CTF1(50)
24.99
33.2
18
19.2
19.2
40.2
19.6
7
CL211-0350-2-50
CL211-0166-3-50
15
25
HDA-CTF1(50)
HDB-CTF1(50)
33.32
47.04
41.2
55
18
40
27.2
40
43.2
46
19.6
20.8
9
10
CL211-0328-3-50
37
HDC-CTF1(50)
63.5
72.2
57
51.2
24
12
RoHS
YES
81
04/2009
SM Series (D SUB) Accessory
Spring lock
Material
Body:
Screws:
Finish
Screws:
Stainless steel
Steel
Treated with
dichromate over
zinc plating
HRS No
Part No.
RoHS
HRS No
Part No.
RoHS
CL211-0122-8-50
DA-L(50)
YES
CL211-0123-0-50
DA-LP(50)
YES
Spring lock
Material
Body:
Screws:
Finish
Screws:
D※−PLA(50)
(1)
Stainless steel
Steel
Nickel plating
Unit: mm
(1)Connector size: E(9contacts)
A(15contacts)
B(25contacts)
C(37contacts)
HRS No
Part No.
A
B
No.of pin RoHS
CL211-0679-8-50
DE-PLA(50)
35.37 28.51
9
CL211-0680-7-50
CL211-0681-0-50
CL211-0682-2-50
DA-PLA(50)
DB-PLA(50)
DC-PLA(50)
43.7 36.84
57.42 50.56
73.88 67.02
15
25
37
YES
D−PLA(05)
Material: Steel
Body
Finish:
Nickel plating
Screws
Setup View
Notes(1)Minimum ordering quantity is one
package, which contains two units.
(2)Applicable for any size of our
connectors.
82
HRS No
Part No.
RoHS
CL211-0732-9-05
D-PLB(05)
YES
04/2009
Screw lock (for HD-LNA)
Note: Minimum ordering quantity is one package, which contains two units.
Material
Body: Steel
Finish
Nickel plating
D-SLA(50)
HD-LNA(05)
Setup View
HRS No
Part No.
RoHS
CL211-0307-3-50
D-SLA(50)
YES
Before mounting the D-SLA, loosen the screw slightly
Note(1)Applicable for 9 to 37 contacts.
(2)Minimum ordering quantity is one package which contains two units.
Locking device
No. of washers
Applicable panel
thickness
1.6-2.0mm
1
2
0.8-1.2mm
0-0.4mm
washer
CL211-0140-0 05
HD-LN(05)
CL211-0171-3-05
HD-LN(4-40)
(05)
CL211-0172-6-05
HD-LN(05)
CL211-0196-4-05
HD-LN(4-40)
(05)
Unit: mm
HRS No
Part No.
CL211-0140-0 05
HD-LN(05)
CL211-0171-3 05
CL211-0140-0 08
HD-LN(4-40)
(05)
HD-LN(08)
RoHS
CL211-0171-3 08 HD-LN(4-40)
(08) YES
CL211-0172-6 05
HD-LNA(05)
CL211-0196-4 05 HD-LNA(4-40)
(05)
Applicable panel
thickness
No. of washers
Finish
1.2mm or less
Nickel plating
1.2-1.6mm
1.6-2.0mm
0.8-1.2mm
0-0.4mm
2
Material
Steel or zinc alloy
Finish
Nickel plating
Adjust no. of washer
83
04/2009
Clamp
Material
Steel
Finish
Nickel plating
Unit: mm
HRS No
Part No.
L1
L2
L3
P
W1
W2
H(abt.)RoHS
CL211-0018-6-50
CL211-0005-4-50
CL211-0011-7-50
HDE-C(50)
HDA-C(50)
HDB-C(50)
7.3
8.0
20.2
30.6
38.9
52.8
24.99
33.32
47.04
7.5
7.5
7.5
12.7
12.7
12.7
16.3
16.3
16.3
CL211-0059-3-50
CL211-0006-7-50
HDC-C(50)
HDD-C(50)
37.0
37.0
69.1
66.7
17.5
17.5
63.5
61.11
7.5
9.9
12.7
15.5
16.3
17.6
Dust cap
For male
connector
YES
Material
Vinyl chloride (UL94V-2)
Finish
Color: Light blue
HRS No
No.of pin
Part No.
A
B
CL211-0777-7
CL211-0778-0
9
15
25
37
50
DE-9P-DC1
DA-15P-DC1
18.7
27.0
10.2
10.2
DB-25P-DC1
DC-37P-DC1
41.0
57.7
10.4
10.6
DD-50P-DC1
55.0
13.3
CL211-0779-2
CL211-0780-1
CL211-0781-4
RoHS
YES
For female
connector
HRS No
No.of pin
Part No.
A
B
CL211-0782-7
CL211-0783-0
9
15
25
37
50
DE-9S-DC1
DA-15S-DC1
17.4
25.6
8.8
8.8
DB-25S-DC1
DC-37S-DC1
39.3
55.8
8.8
8.8
DD-50S-DC1
53.4
11.6
CL211-0784-2
CL211-0785-5
CL211-0786-8
RoHS
YES
Note: Dust cap for male connector cannot be used for the connector with locking device (LN)
Material
Polyethylene resin
Finish
Color: Natural
84
HRS No
Part No.
RoHS
HRS No
Part No.
RoHS
CL211-0162-2
DB-25S-DC
YES
CL211-0130-6
HDE-9S-DC
YES
04/2009
很抱歉,暂时无法提供与“HDE-CTF(50)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+51.76876
- 10+46.04602
