SFC-125-T2-L-D-A-TR
SFC-125-T2-L-D-A-TR
    SAMTEC(申泰)
    .050'' X .050
SFC-125-T2-L-D-A-TR 数据手册
RUGGED TIGER EYE™ SYSTEMS (1.27 mm) .050" PITCH MAX 8 3.7 A m p G b p s s FEATURES & BENEFITS • S crew down, locking clip, friction latching and weld tab ruggedizing options • Shrouded, polarized and keyed • Surface mount or through-hole tails • High-density, four row design (FOLC/MOLC Series) • Discrete wire assemblies available in single or double row, 28 and 30 AWG PVC or *Teflon™ Fluoropolymer (See pages 238-239). Contact asp@samtec.com for custom solutions. • Cable components (ISDF/CC03) and tooling available: samtec.com/tooling • Severe Environment Testing qualified (SFM/TFM); aligns with MIL-DTL-55302. Visit samtec.com/set *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. KEY SPECIFICATIONS SERIES STACK INSULATOR HEIGHTS MATERIAL CONTACT MATERIAL BeCu (SFM) SFM/TFM 6 to 12 mm Black LCP SFC/TFC Black LCP 6 to 12 mm F-224 (Rev 04APR24) Phosphor Bronze (TFM) Phosphor Bronze IDC cable assemblies with rugged strain relief (FFSD/FFMD, FFTP/FMTP) Locking for increased unmating force (SFML/TFML) PLATING OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING MAX. CYCLES LEAD-FREE SOLDERABLE Au or Sn over 50 µ" (1.27 µm) Ni -55 °C to +125 °C 3.7A per pin (2 pins powered) 275 VAC 10,000 with 30 µ" (0.76 µm) Au Yes Au or Sn over 50 µ" (1.27 µm) Ni -55 °C to +125 °C 3.1 A per pin (2 pins powered) 350 VAC (Call Samtec for E.L.P.™ plating option) Yes samtec.com/127mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 8 MAX 3.1 A (1.27 mm) .050" PITCH • COST-EFFECTIVE HEADER/SOCKET SFC - NO. PINS PER ROW 1 - LEAD STYLE 04, 05, 10, 15, 20, 25, 30, 35, 40, 45, 50 - –T1 D p - OPTIONS –A = Gold flash on contact, Matte Tin on tail –T2 = Alignment Pin –K –L = Surface Mount Tiger Eye™ LITE G b p s s –F = Through-hole Tiger Eye™ LITE (Standard sizes) - PLATING OPTION m = (4.00 mm) .157" DIA Polyimide film Pick & Place Pad = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –TR = Tape & Reel (–T2 only) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (-T2 only) SFC Board Mates: TFC Cable Mates: TFSD, TFSDT  [1RRI3RVLWLRQV   H[FHSWIRUDOLJQPHQWSLQRSWLRQ  [1RRI3RVLWLRQV             - - NO. PINS PER ROW 1 03, 04, 06, 08 - LEAD STYLE –X1 (Lead Style –01 & –02 only) = Through-hole 05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 = Surface Mount –X2 (Standard sizes) - PLATING OPTION D   –F - –T2 OPTIONS –RA = Gold flash on post, Matte Tin on tail = Right-angle (–01 only) –L = Alignment Pin –A = 15 µ" (0.38 µm) Gold on post, Matte Tin on tail –LC = Locking Clip (Manual Placement required) (not available with –RA) (1.27) .050 x No. of Positions + (3.18) .125 –K = (6.75 mm) .266" DIA Polyimide film Pick & Place Pad (not available with –RA) (5.72) .225 TFC Board Mates: SFC Cable Mates: SFSD, SFSDT –P B A SMT LEAD STYLE Note: Some lengths, styles and options are non-standard, non-returnable.   –T1 View complete specifications at: samtec.com?SFC TFC –A OPTION A B TH LEAD STYLE = Plastic Pick & Place Pad (5 positions min.) (not available with –RA) A –TR = Tape & Reel (–X2 only) (not available with –RA) A B –02 (5.72) .225 (3.38) .133 –01 (5.59) .220 (3.38) .133 –12 (7.49) .295 –11 (7.37) .290 –22 (9.27) .365 (3.30) .130 –21 (9.14) .360 (3.30) .130 –32 (11.18) .440 –31 (11.05) .435 –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (-X2 only) (not available with –RA) View complete specifications at: samtec.com?TFC samtec.com/127mm-TigerEye F-224 (Rev 04APR24) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SFC-125-T2-L-D-A-TR 价格&库存
很抱歉,暂时无法提供与“SFC-125-T2-L-D-A-TR”相匹配的价格&库存,您可以联系我们找货
