RUGGED TIGER EYE™ SYSTEMS
(1.27 mm) .050" PITCH
MAX
8
3.7
A
m
p
G b p s
s
FEATURES & BENEFITS
• S
crew down, locking clip, friction latching and
weld tab ruggedizing options
• Shrouded, polarized and keyed
• Surface mount or through-hole tails
• High-density, four row design (FOLC/MOLC Series)
• Discrete wire assemblies available in single or double row,
28 and 30 AWG PVC or *Teflon™ Fluoropolymer (See pages 238-239).
Contact asp@samtec.com for custom solutions.
• Cable components (ISDF/CC03) and tooling available: samtec.com/tooling
• Severe Environment Testing qualified (SFM/TFM); aligns with MIL-DTL-55302.
Visit samtec.com/set
*Teflon™ is a trademark of The Chemours Company FC, LLC
used under license by Samtec.
KEY SPECIFICATIONS
SERIES
STACK
INSULATOR
HEIGHTS MATERIAL
CONTACT
MATERIAL
BeCu (SFM)
SFM/TFM 6 to 12 mm
Black LCP
SFC/TFC
Black LCP
6 to 12 mm
F-224 (Rev 04APR24)
Phosphor
Bronze (TFM)
Phosphor
Bronze
IDC cable
assemblies with
rugged strain relief
(FFSD/FFMD, FFTP/FMTP)
Locking for
increased
unmating force
(SFML/TFML)
PLATING
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
MAX.
CYCLES
LEAD-FREE
SOLDERABLE
Au or Sn
over 50 µ"
(1.27 µm) Ni
-55 °C to +125 °C
3.7A per pin
(2 pins powered)
275 VAC
10,000
with 30 µ"
(0.76 µm) Au
Yes
Au or Sn
over 50 µ"
(1.27 µm) Ni
-55 °C to +125 °C
3.1 A per pin
(2 pins powered)
350 VAC
(Call Samtec for
E.L.P.™ plating
option)
Yes
samtec.com/127mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MAX
3.7
A
(1.27 mm) .050" PITCH • SMT/THROUGH-HOLE SOCKET
SERIES
NO. PINS
PER ROW
1
SFM
03, 04, 06, 08
SFML
05, 07, 10, 15,
20, 25, 30, 35,
40, 45, 50
= Standard
= Locking
(SFM only)
(Surface Mount) (Through-hole)
–02
= Tiger Eye™
Contact
(BeCu)
–L2
–L1, –L3
= Low
Insertion
Force
Tiger Eye™
Contact
(BeCu)
–T2
= Low
Insertion
Force
Tiger Eye™
Contact
(BeCu)
= Tiger Eye™
LITE Contact
(Phosphor
Bronze)
Board Mates:
TFM
Cable Mates:
TFSD, TFSS
–01, –03
= Tiger Eye™
Contact
(BeCu)
(Standard sizes)
SFM
LEAD STYLE
PLATING
OPTION
–L
m
p
ROW
OPTION
s
–S
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
(Call Samtec
for E.L.P.™
plating option)
= Single Row
(SFM only)
–D
= Double Row
–SH
= Single
Horizontal
(05 thru 30
positions only)
(SFM only)
(Lead style
–02 only)
–T1
–DH
= Tiger Eye™
LITE Contact
(Phosphor
Bronze)
= Double
Horizontal
(05 thru 30
positions only)
(SFM only)
(Lead style
–02 only)
SFML
Board Mates:
TFML
Cable Mates:
TFSD
[1RRI3RVLWLRQV
8
G b p s
OPTIONS
Specify only
–A, –LC or –DS
(Not available
with –DH, –SH)
Specify only
–K or –P
(Lead styles –02,
–L2, –T2 only)
–A
–K
= Alignment Pin
–LC
= Polyimide film
Pick & Place Pad
(Not available
with –DH, –SH)
–DS
= Plastic Pick
& Place Pad
(Not available
with –DH, –SH)
= Locking Clip
(Manual
placement
required)
–P
= Dual Screw
Down for
Specify –TR or
(1.60 mm) .062"
PCB (05 thru 40 –FR last; Required
for
–DH & –SH.
positions only)
(Lead styles –02,
(Lead styles –01,
–L2 & –T2 only)
–02 & –03 only)
(Requires –D
row option)
–TR
(Not available with
= Tape & Reel
SFML) (Mates with
TFM-DS option)
–FR
(Not available
= Full Reel
with –A, –LC,
Tape & Reel
–K, –P, –XR)
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
SINGLE ROW
[1RRI3RVLWLRQV
H[FHSWIRUDOLJQPHQWSLQRSWLRQ
[1RRI3RVLWLRQV
LEAD STYLE
–01, –L1, –T1
A
B
(3.05) .120 (0.51) .020
–03, –L3
(1.91) .075
(0.41) .016
DOUBLE ROW
SURFACE MOUNT
THROUGH-HOLE
Notes:
Severe Environment
Testing qualified (SFM);
Some lengths, styles and
options are non-standard,
non-returnable.
–SH
–DH
–A
–LC
–DS
View complete specifications at: samtec.com?SFM & samtec.com?SFML
A-224 (Rev 04APR24)
很抱歉,暂时无法提供与“SFM-110-02-STL-D-A”相匹配的价格&库存,您可以联系我们找货
