SH3-SH3-28300
SH3-SH3-28300
    JST
SH3-SH3-28300 数据手册
SH CONNECTOR Crimp Emboss Tape Disconnectable Crimp style connectors 1.0mm (.039") pitch Features –––––––––––––––––––––––– • Ultra-compact, low profile design The SH connector is very small with a mounting height of 2.95mm (.116") for side entry type. • Compatible with the SR insulation displacement connectors The same shrouded header can be used for the SR insulation displacement connector. • Housing lances The contact retention lances on the resilient housing allow the confirmation of contact lock-in for easy and secure insertion. The world's first 1.0mm (.039") pitch crimp style connector. Specifications ––––––––––––––––––– • Current rating: 1.0A AC, DC (AWG #28) • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/40m Ω max. • Insulation resistance: 100M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: AWG #32 to #28 Insulation O.D./0.4 to 0.8mm (.016" to .031") * Contact JST if Lead-Free product is required. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. 15 14 13 12 11 10 9 8 7 6 5 4 3 2 Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 SH CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Model No. 3.9(.154) 2.0(.079) 1.6(.063) 0.5(.020) 0.8(.031) 1.55(.061) Applicable wire Q'ty / Insulation O.D. mm(in.) reel AWG# mm2 SSH-003T-P0.2-H 0.032 to 0.08 32 to 28 0.4 to 0.8(.016 to .031) 23,000 1.35(.053) Material and Finish Phosphor bronze, tin-plated Note: Contact JST for gold-plated contacts. 0.45(.018) 0.8(.031) Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– With protrusions 1.0(.039) 2.8(.110) 2 Circuit No.1 3 N 4 3 2 5.0(.197) 5 6 7 8 9 Without protrusions 10 2.1(.083) 11 B A 12 1.0(.039) 2.8(.110) 13 Circuit No.1 14 N 15 3 2 5.0(.197) 20 Dimensions mm(in.) Q'ty / B A box With protrusions Without protrusions Model No. Circuits B A With protrusions Without protrusions SHR-02V-S-B SHR-02V-S SHR-03V-S-B SHR-03V-S SHR-04V-S-B SHR-04V-S SHR-05V-S-B SHR-05V-S SHR-06V-S-B SHR-06V-S SHR-07V-S-B SHR-07V-S SHR-08V-S-B SHR-08V-S SHR-09V-S-B SHR-09V-S SHR-10V-S-B SHR-10V-S SHR-11V-S-B SHR-11V-S SHR-12V-S-B SHR-12V-S SHR-13V-S-B SHR-13V-S SHR-14V-S-B SHR-14V-S SHR-15V-S-B SHR-15V-S – SHR-20V-S-B 1.0(.039) 5.0(.197) 3.0(.118) 2,000 2.0(.079) 6.0(.236) 4.0(.157) 2,000 3.0(.118) 7.0(.276) 5.0(.197) 2,000 4.0(.157) 8.0(.315) 6.0(.236) 2,000 5.0(.197) 9.0(.354) 7.0(.276) 2,000 6.0(.236) 10.0(.394) 8.0(.315) 2,000 7.0(.276) 11.0(.433) 9.0(.354) 2,000 8.0(.315) 12.0(.472) 10.0(.394) 2,000 9.0(.354) 13.0(.512) 11.0(.433) 2,000 10.0(.394) 14.0(.551) 12.0(.472) 2,000 11.0(.433) 15.0(.591) 13.0(.512) 2,000 12.0(.472) 16.0(.630) 14.0(.551) 2,000 13.0(.512) 17.0(.669) 15.0(.591) 2,000 14.0(.551) 18.0(.709) 16.0(.630) 2,000 19.0(.748) 23.0(.906) 21.0(.827) 2,000 Meterial PBT, UL94V-0, natural (white) Note: SHR-20V-S-B is not CSA approved. 2.1(.083) Shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––––––––––– The shrouded headers are interchangeable with those of the SR insulation displacement connectors. Top entry type Circuits 4.25(.167) Circuit No.1 1.0 (.039) A B 0.7(.028) 1.5(.059) 2.9(.114) Side entry type 2.9(.114) Circuit No.1 1.0 (.039) A B Model No. Top entry type Side entry type Dimensions mm(in.) Q'ty / reel A B Top entry type Side entry type 2 BM02B-SRSS-TB SM02B-SRSS-TB 1.0(.039) 4.0(.157) 1,500 3,000 3 BM03B-SRSS-TB SM03B-SRSS-TB 2.0(.079) 5.0(.197) 1,500 3,000 4 BM04B-SRSS-TB SM04B-SRSS-TB 3.0(.118) 6.0(.236) 1,500 3,000 5 BM05B-SRSS-TB SM05B-SRSS-TB 4.0(.157) 7.0(.276) 1,500 3,000 6 BM06B-SRSS-TB SM06B-SRSS-TB 5.0(.197) 8.0(.315) 1,500 3,000 7 BM07B-SRSS-TB SM07B-SRSS-TB 6.0(.236) 9.0(.354) 1,500 3,000 8 BM08B-SRSS-TB SM08B-SRSS-TB 7.0(.276) 10.0(.394) 1,500 3,000 9 BM09B-SRSS-TB SM09B-SRSS-TB 8.0(.315) 11.0(.433) 1,500 3,000 10 BM10B-SRSS-TB SM10B-SRSS-TB 9.0(.354) 12.0(.472) 1,500 3,000 11 BM11B-SRSS-TB SM11B-SRSS-TB 10.0(.394) 13.0(.512) 1,500 3,000 12 BM12B-SRSS-TB SM12B-SRSS-TB 11.0(.433) 14.0(.551) 1,500 3,000 13 BM13B-SRSS-TB SM13B-SRSS-TB 12.0(.472) 15.0(.591) 1,500 3,000 14 BM14B-SRSS-TB SM14B-SRSS-TB 13.0(.512) 16.0(.630) 1,500 3,000 15 BM15B-SRSS-TB SM15B-SRSS-TB 14.0(.551) 17.0(.669) 1,500 3,000 20 – SM20B-SRSS-TB 19.0(.748) 22.0(.866) – 3,000 Material and Finish 1.5(.059) 4.25(.167) Contact: Copper alloy, copper-undercoated, tin/lead-plated Housing: Polyamide, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin/lead-plated 0.7(.028) Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the headers with gold-plated pins. 3. Contact JST for the top entry type headers with suction cap. 4. SM20B-SRSS-TB is not CSA approved. 3 SH CONNECTOR Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– Feeding direction Feeding direction [13(.512)dia.] 380±2.0(14.961±.079)dia. Carrier tape W1+2.5 -1.0 -.039 ) (+.098 Cover tape leader area Leader part 100(3.937)min. The end part Connector 160(6.299)min. mounting part 400(15.748)min. 2.0±0.5(.079±.020) Top entry type Side entry type Feeding direction Taping dimensions mm(in.) F Reel dimensions mm(in.) W Q'ty / reel W1 Top entry type Side entry type 13.5( .531) 1,500 3,000 13.5( .531) 13.5( .531) 1,500 3,000 12.0(.472) 17.5( .689) 13.5( .531) 1,500 3,000 16.0(.630) 16.0(.630) 17.5( .689) 17.5( .689) 1,500 3,000 7.5(.295) 16.0(.630) 16.0(.630) 17.5( .689) 17.5( .689) 1,500 3,000 7.5(.295) 7.5(.295) 16.0(.630) 16.0(.630) 17.5( .689) 17.5( .689) 1,500 3,000 8 11.5(.453) 7.5(.295) 24.0(.945) 16.0(.630) 25.5(1.004) 17.5( .689) 1,500 3,000 9 11.5(.453) 11.5(.453) 24.0(.945) 24.0(.945) 25.5(1.004) 25.5(1.004) 1,500 3,000 10 11.5(.453) 11.5(.453) 24.0(.945) 24.0(.945) 25.5(1.004) 25.5(1.004) 1,500 3,000 11 11.5(.453) 11.5(.453) 24.0(.945) 24.0(.945) 25.5(1.004) 25.5(1.004) 1,500 3,000 12 11.5(.453) 11.5(.453) 24.0(.945) 24.0(.945) 25.5(1.004) 25.5(1.004) 1,500 3,000 13 11.5(.453) 11.5(.453) 24.0(.945) 24.0(.945) 25.5(1.004) 25.5(1.004) 1,500 3,000 14 11.5(.453) 11.5(.453) 24.0(.945) 24.0(.945) 25.5(1.004) 25.5(1.004) 1,500 3,000 15 11.5(.453) 11.5(.453) 24.0(.945) 24.0(.945) 25.5(1.004) 25.5(1.004) 1,500 3,000 20 – 20.2(.795) – 44.0(1.732) – 45.5(1.791) – 3,000 Top entry type Side entry type Top entry type Side entry type 2 5.5(.217) 5.5(.217) 12.0(.472) 3 5.5(.217) 5.5(.217) 4 7.5(.295) 5 Top entry type Side entry type 12.0(.472) 13.5( .531) 12.0(.472) 12.0(.472) 5.5(.217) 16.0(.630) 7.5(.295) 7.5(.295) 6 7.5(.295) 7 Note: 1. Specifications conform to JIS C 0806. The tape width, connector loading recess square hole dimensions, etc.are determined by the number of circuits and external shape of the connector to be loaded. Note: 2. Specifications are subject to change without prior notice. 4 Carrier tape 8.0±0.1 (.315±.004) 12.0±0.1 (.472±.004) Circuits Cover tape W±0.3(.012) 4.0±0.1 2.0±0.1 1.55±0.05 (.061±.002)dia. (.157±.004) (.079±.004) Carrier tape 1.75±0.1 F±0.1(.004) (.069±.004) Cover tape W±0.3(.012) F±0.1(.004) 4.0±0.1 2.0±0.1 1.55±0.05 (.061±.002)dia. (.157±.004) (.079±.004) 1.75±0.1 (.069±.004) Feeding direction SH CONNECTOR PC board layout (viewed from component side) and Assembly layout –––––––––––––––––– Top entry type Header outline 0.7±0.1 (.028±.004) 1.2±0.1 (.047±.004) 2.9 (.114) 2.95 (.116) 6.3(.248) 1.0±0.05 (.039±.002) 6.25(.246) 0.2±0.1 (.008±.004) 0.6±0.05 (.024±.002) 1.0±0.05 (.039±.002) 1.8±0.1 (.071±.004) 4.0±0.1 (.157±.004) 5.55±0.1(.219±.004) 0.6±0.05 (.024±.002) 0.2±0.1 (.008±.004) 0.7±0.1 1.2±0.1 (.028±.004) (.047±.004) 1.8±0.1 (.071±.004) 2.65±0.1 (.104±.004) 4.2±0.1(.165±.004) Header outline Side entry type Note: 1. Tolerances are non-cumulative: ±0.05mm(±.002") for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. Applicator for the semi-automatic press AP-K2N ––––––––––––––––––––––––––––––– Contact SSH-003T-P0.2-H Crimp applicator MKS-L-10-3 with safety cover without safety cover APLMK SSH/L003-02 APLNC SSH/L003-02 Compact crimp applicator MKS-LS with safety cover without safety cover – – Strip-crimp applicator MKS-SC with safety cover APLSC SSH/003-02 5
SH3-SH3-28300 价格&库存
很抱歉,暂时无法提供与“SH3-SH3-28300”相匹配的价格&库存,您可以联系我们找货
SH3-SH3-28300
    • 10+11.92649
    • 2500+11.74443
    • 5000+11.48930
    库存:3970
    SH3-SH3-28300
    • 10+12.29214
    • 100+12.25655
    • 500+12.20909
    • 1000+12.16163
    • 2500+12.11417
    • 5000+11.85314
    库存:23756
