04FM-1.0SP-1.9-TF(LF)(SN) 数据手册
1.0 mm
FM CONNECTOR
Emboss Tape
Connectors for FFC and FPC
pitch
Features
● Compact
Having no complicated cam or slide mechanism, this
connector is small with a mounting height of only 4.4 mm
and a width of 3.0 mm.
FM CONNECTOR
● Double-sided contact
This connector has highly resilient phosphor bronze contacts,
each of which has two independent mating spring members
that ensure continuity even when subjected to severe
vibration. Because each of the contacts simultaneously
mates with both sides of the FFC or FPC, the engineer has
greater freedom in designing his circuitry.
● Simple snap-in action
The FFC or FPC are securely connected by simply inserting
their leads into the connector.
● Surface mount model (SMT)
The FM connector, a miniature connector
with a thickness of only 3.0 mm, was
developed to connect flexible flat cables
(FFC) or flexible printed circuits (FPC) with
a lead pitch of 1.0 mm to printed circuit
boards. It is ideally suited for connections
inside high-density equipment or between
mechanical units. The contact is constructed
to ensure a stable connection and high
reliability even under vibration and impact.
Connection is easy with a simple snap-in
action.
This connector is also available in a surface mount
configuration. Its housing is made of heat resistant resin
so that it is not adversely affected during reflow soldering.
Because of its tiny size and ability to be surface mounted,
this connector meets the demand for high-density mounting
of components inside electronic products.
Specifications
• Current rating: 0.5 A AC/DC
• Voltage rating: 50 V AC/DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 20 m Ω max.
After environmental tests/ 30 m Ω max.
• Insulation resistance: 800 M Ω min.
• Withstanding voltage: 500 VAC/minute
• Applicable FFC and FPC: Conductor pitch/ 1.0 mm
Conductor width/ 0.7 mm
+0.02
Mating part thickness/ 0.33 ― 0.03 mm
• Applicable PC board thickness: 0.8 to 1.6 mm
FFC/FPC to be actually used should be checked for applicability.
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
Standards
Recognized E60389
Certified LR20812
1
FM CONNECTOR
Connector
●Through-hole type
Top entry type
Side entry type
4.4
1.0
Insertion
depth
2.0
Circuit No.1
Circuit No.1
0.4
●SMT type
Top entry type
2.8
4.4
挿入深さ
Circuit No.1
Circuit No.1
4.35
2.0
0.5
Side entry type
B
C
A
1.5
Insertion
depth
2.8
B
C
A
4.4
1.0
1.5
Insertion
depth
2.8
4.4
3.0
3.0
1.0
1.5
3.0
0.4
2.9
3.0
2.8
B
C
A
3.0
Insertion
depth
3.0
1.0
1.5
7.3
0.5
B
C
A
Circuit No.1
2.0
0.4
1.9
Circuit No.1
0.4
Through-hole type connector
Model No. of Through-hole type
No. of
circuits
Top entry type
Side entry type
3
03FM-1.0BT
4
04FM-1.0BT
5
Dimensions (mm)
Q'ty/box
A
B
C
03FM-1.0ST
2.0
5.0
4.1
2,000
04FM-1.0ST
3.0
6.0
5.1
2,000
05FM-1.0BT
05FM-1.0ST
4.0
7.0
6.1
2,000
6
06FM-1.0BT
06FM-1.0ST
5.0
8.0
7.1
1,000
7
07FM-1.0BT
07FM-1.0ST
6.0
9.0
8.1
1,000
8
08FM-1.0BT
08FM-1.0ST
7.0
10.0
9.1
1,000
10
10FM-1.0BT
10FM-1.0ST
9.0
12.0
11.1
1,000
11
11FM-1.0BT
11FM-1.0ST
10.0
13.0
12.1
1,000
12
12FM-1.0BT
12FM-1.0ST
11.0
14.0
13.1
1,000
SMT type connector on embossed-tape
No. of
circuits
Q'ty/reel
Dimensions (mm)
Model No.
Top entry type
Side entry type
A
B
C
03FM-1.0SP-1.9-TF
2.0
5.0
4.1
2,500
4
04FM-1.0BP-TF
04FM-1.0SP-1.9-TF
3.0
6.0
5.1
1,000
2,500
5
05FM-1.0BP-TF
05FM-1.0SP-1.9-TF
4.0
7.0
6.1
1,000
2,500
6
06FM-1.0BP-TF
06FM-1.0SP-1.9-TF
5.0
8.0
7.1
1,000
2,500
7
07FM-1.0BP-TF
07FM-1.0SP-1.9-TF
6.0
9.0
8.1
1,000
2,500
8
08FM-1.0BP-TF
08FM-1.0SP-1.9-TF
7.0
10.0
9.1
1,000
2,500
10
10FM-1.0BP-TF-A
10FM-1.0SP-1.9-TF
9.0
12.0
11.1
1,000
2,000
12
12FM-1.0SP-1.9-TF
11.0
14.0
13.1
2,000
3
Material and Finish
(Through-hole type) Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment)
Housing: PBT, UL94V-0
(SMT type) Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment)
Housing: PPS, UL94V-0
RoHS2 compliance This product displays (LF)(SN) on a label.
2
Top entry type Side entry type
FM CONNECTOR
Lead section dimensions of FFC and FPC
FFC
FPC
1.0×(N+1)±0.12
1.0 ±0.15
1.0×(N-1)±0.07
1.0 ±0.05
+0.02
0.33 ー0.03
0.7 ±0.1
1.0 ±0.15
0.7 ±0.1
0.33
R0.3
10.0
3.0 min.
1.0 ±0.1
1.0×(N+1)±0.07
1.0 ±0.15
Conductor
+0.02
ー0.03
Conductor
7.5
1.0×(N-1)±0.1
3.0 min.
1.0 ±0.15
Reinforcing layer
Reinforcing layer
Film cover layer
Base layer
Note: N --- Number of circuits
PC board layout and Assembly layout
●Through-hole type
Top entry type
Side entry type
2.0 min.
3.0
3.0
2.9
2.0 ±0.05
Circuit No.1
4.4
5.0 min.
φ0.75 ±0.05
4.4
φ0.75±0.05
2.0 min.
1.0±0.05
Circuit No.1
Soldering side
2.0 ±0.15
1.0 ±0.05
2.0±0.05
3.0
0.9 min.
2.0±0.05
Soldering side
●SMT type
Top entry type
Side entry type
1.5 min.
1.0±0.05
3.0
Connector mounting side
1.5 min.
0.6 ±0.05
4.4
3.0
1.9
3.6
1.2
2.0
4.4
0.6 ±0.05
3.0
1.0 ±0.05
Note: 1. Tolerances are non-cumulative: ± 0.05 mm for all centers.
2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline.
3. It is recommended that surface mount connectors be secured using thermosetting resin or something similar. Contact JST for details.
3
04FM-1.0SP-1.9-TF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“04FM-1.0SP-1.9-TF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.927081+0.37855
- 10+2.4902010+0.32205
- 50+1.9397450+0.25086
- 100+1.58150100+0.20453
- 500+1.50286500+0.19436
- 1000+1.450431000+0.18758
- 2000+1.424222000+0.18419
