07FPZ-SM-TF(LF)(SN)
07FPZ-SM-TF(LF)(SN)
    JST
    Connector, 1.0mm Pitch
07FPZ-SM-TF(LF)(SN) 数据手册
FPZ CONNECTOR 1.0mm Emboss Tape Connectors for FFC pitch Features –––––––––––––––––––––––– • Easy and reliable connection Connection can be made simply by inserting the leads into the connector and pressing the slider. Once the leads are inserted, they are held by the 4-side guides located inside the slider so that they will not dislocate or come off. • Emboss taping for automatic mounting The FPZ is supplied in the form of emboss taping for automatic mounting. • Heat resisting design suitable for surface mounting This surface mounting type is designed to meet the needs of surface mountable devices inside electronic equipment. The housing is made of highly heat resisting resin to allow reflow soldering. The FPZ is a Zero Insertion Force (ZIF) connector designed for surface mounting of FFCs with a lead pitch of 1.0mm. With its mating slider serving as a guide, the FPZ connector ensures easy and reliable connection. It also features high heat resistance, which is suitable for surface mounting, and can be supplied in the form of emboss taping to facilitate automatic mounting. • High-density design, with a height of a mere 2.9mm The circuit pitch at the soldered portion is 1.0mm and its mounting height is 2.9mm when locked. The FPZ is a compact and low-profile design. Specifications ––––––––––––––––––– • Current rating: 0.5A AC, DC • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/30m Ω max. • Insulation resistance: 800M Ω min. • Withstanding voltage: 500V AC/minute • Applicable FFC: Conductor pitch/1.0mm Conductor width/0.7mm Mating part thickness/0.30±0.05mm FFC to be actually used should be checked for applicability. JS 0L T1 * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 1 Recognized E60389 Certified LR20812 1 FPZ CONNECTOR Connector ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– 0.75 2.75 A 1.5 6.5 2.1 1.5 1.0 JST B Q'ty / reel 07FPZ-SM-TF 6.0 13.0 2,000 08FPZ-SM-TF 7.0 14.0 2,000 10 10FPZ-SM-TF 9.0 16.0 2,000 11 11FPZ-SM-TF 10.0 17.0 2,000 12 12FPZ-SM-TF 11.0 18.0 2,000 13 13FPZ-SM-TF 12.0 19.0 2,000 14 14FPZ-SM-TF 13.0 20.0 2,000 15 15FPZ-SM-TF 14.0 21.0 2,000 16 16FPZ-SM-TF 15.0 22.0 2,000 18 18FPZ-SM-TF 17.0 24.0 2,000 20 20FPZ-SM-TF 19.0 26.0 2,000 24 24FPZ-SM-TF 23.0 30.0 2,000 25 25FPZ-SM-TF 24.0 31.0 2,000 Model No. 7 8 2.0 2.9 B Dimensions (mm) A Circuits Material and Finish Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Reinforcing metal: Brass, tin-plated (reflow treatment) Housing: PPS, UL94V-0 RoHS compliance This product displays (LF)(SN) on a label. Note: The products listed above are supplied on embossed tape. Lead section dimensions of FFC –––––––––––––––––––––––––––––––––––––––––––– 1.0x(N+1)±0.12 1.0x(N-1)±0.1 1.0±0.15 0.3±0.05 Reinforcing layer 1.0±0.1 5.5min. 0.7±0.1 (10.0) 1.0±0.15 Conductor Base layer Film cover layer Note: N --- Number of circuits 3.7±0.1 1.7+0.2 0 2.5 6.5 FFC Conductor surface Note: 1. Tolerances are non-cumulative: ±0.03mm for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. 2 1.5 2.9 1.0±0.03 6.5max. 0.6±0.05 2.8±0.1 PC board layout (viewed from component side) and Assembly layout ––––––––––––––––––
07FPZ-SM-TF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“07FPZ-SM-TF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
07FPZ-SM-TF(LF)(SN)
    库存:2000
    07FPZ-SM-TF(LF)(SN)
    07FPZ-SM-TF(LF)(SN)
      • 1+9.646331+1.24526
      • 10+5.6897610+0.73450
      • 50+5.1382950+0.66331
      • 100+4.77940100+0.61698
      • 500+4.70062500+0.60681
      • 1000+4.648101000+0.60003
      • 2000+4.621842000+0.59664
      库存:1096
