09 66 152 6612
09 66 152 6612
    HARTING(浩亭)
    Conn D-Subminiature SKT 9 POS 2.74mm Solder RA Thru-Hole 9 Terminal 1 Port
09 66 152 6612 数据手册
D-Sub DIN 41 652 · CECC 75 301-802 Number of contacts Mounting height Standard Versions 9--37 50 Stamped solder pins, angled with grounding board locks Identification D-Sub Performance levels Explanations see page 05.04 Other performance levels on request þ No. of contacts Part No. Performance level Performance level 3 2 Male connector metal shell with dimples 2.84 mm pitch 9 15 25 37 09 65 163 781 09 65 263 781 09 65 363 781 09 65 463 781 2.54 mm pitch 2.54 mm pitch 9 15 25 37 09 65 162 781 09 65 262 781 09 65 362 781 09 65 462 781 . . . . 09 65 162 681 09 65 262 681 09 65 362 681 09 65 462 681 2.84 mm pitch 2.84 mm pitch 9 15 25 37 09 66 153 761 09 66 253 761 09 66 353 761 09 66 453 761 2.54 mm pitch 2.54 mm pitch 09 66 152 761 09 66 252 761 09 66 352 761 09 66 452 761 09 66 552 761 09 66 152 661 09 66 252 661 09 66 352 661 09 66 452 661 09 66 552 661 . . . . 1) 1) 1) 1) 2.84 mm pitch 09 65 163 681 09 65 263 681 09 65 363 681 09 65 463 681 . . . . 1) 1) 1) 1) . . . . Female connector metal shell 9 15 25 37 50 Please insert digit for flange thread or fitted female screw locks Ø 3.1 mm hole þ 1)01) þ 1 M3 4-40 UNC þ 2 fitted screw locks 4-40 UNC þ 3 05 14 1) Not normally kept in stock . . . . 1) 1) 1) 1) . . . . . 1) 09 66 153 661 09 66 253 661 09 66 353 661 09 66 453 661 . . . . . . . . . 1) 1) 1) 1) 1)
09 66 152 6612 价格&库存
很抱歉,暂时无法提供与“09 66 152 6612”相匹配的价格&库存,您可以联系我们找货
  • 1+35.09667
  • 10+34.40850
  • 100+33.70847
  • 250+33.04403
  • 500+32.36772
库存:862
09661526612
  • 14+44.9911014+5.82792
  • 20+41.2210320+5.33957
  • 40+38.1959040+4.94771
库存:132
