09 67 001 9972
09 67 001 9972
    HARTING(浩亭)
    HARTING - 09 67 001 9972 - FIXED LATCH
09 67 001 9972 数据手册
D-Sub – H Directory chapter 07 D-Sub – Housing range for subminiature D connectors Page 07.02 Thermoplastic top and side entry hoods with knurled screws . . . . . . . . . . . . . . . . . . . . . . . . . . 07.04 Thermoplastic side entry hoods with knurled screws . . . . . . . . . . . . . . . . . . . . . . . . . . 07.05 Thermoplastic top entry hoods with knurled or locking screws . . . . . . . . . . . . . . . . . . . . . . 07.06 Full metal top and side entry hoods with knurled screws . . . . . . . . . . . . . . . . . . . . . . . . . . 07.07 Full metal top and side entry hoods with short screws . . 07.08 Full metal top and side entry hoods with different screw options . . . . . . . . . . . . . . . . . . 07.09 General information – hoods for spring or slide locking . . . . . . . . . . . . . . . . . . . 07.10 Thermoplastic top and side entry hoods for spring or slide locking . . . . . . . . . . . . . . . . . . . . 07.11 Full metal top and side entry hoods for spring or slide locking . . . . . . . . . . . . . . . . . . . . 07.12 D-Sub - H General information – hoods for screw locking . . . . . . . . . . . . . . . . . . . . . . . . . 07 . 01 Housings for D-Sub waterproof (IP 67) see chapter 06 D-Sub DIN 41 652 · CECC 75 301-802 · IEC 60 807 HARTING – Guarantee a secure connection Modern electronic applications demand a high degree of mechanical and electrical security. To meet these requirements, continuous screening from the cable to the PCB via the connector is achieved by using state of the art components to DIN 41 652. HARTING offer many solutions. These utilise various combinations of male and female connectors with hoods, featuring either screw locking or latching facilities. Only 2 examples are shown: • Continuous security screening and grounding with screw locking and metallized hood. • Continuous grounding and vibration proof latching system with metallized hood. Female connector with protective metal shell D-Sub - H Male connector with dimples Screw lock Cable with protective screen Strain relief Grounding contact between protective metal shell and PCB Metallized hood Female connector with protective metal shell Spring latch Strain relief Cable with protective screen Metallized hood 07 . 02 Male connector with dimples D-Sub Connector hoods for screw locking d oo h try n c e e lastic lasti d i s p op o m d n rm er p a ck theed th o T la alliz B et M ed url kn s rew c s th wi d o ic tic ho ast las pl op y ntr ermotherm e th d p To lack lize ed url Kn rew sc g r ho s ith in ck t lo s rew c s D-Sub - H B etal M w od stic astic o l a h l ry op op nt rm erm p e ck theed th o T la alliz B t Me alternative k loc hood w t cre hou s it le se w a u M r fo w cre k loc th wi t nu s ale m Fe 07 . 03 D-Sub Top and side entry hoods with knurled screws Identification No. of contacts Part No. Top entry hood Drawing Dimensions in mm max. Ø 1 Black thermoplastic 9 15 25 37 50 09 67 009 0424 09 67 015 0424 09 67 025 0424 09 67 037 0424 09 67 050 0424 9 15 25 37 50 B 15 15 15 15 19 C1 34 34 40 40 40 C2 max. Ø 1 max. Ø 2 38 8.0 11.5 38 11.5 11.5 40 11.5 11.5 40 11.5 11.5 14.0 C2: metallized max. Ø 49 D-Sub - H max. Ø 2 A2 32.5 41.0 54.5 71.0 C1: non-metallized UNC 4-40 A1 Top entry hood A1 31.5 40.0 53.5 71.0 67.5 Metallized thermoplastic 9 15 25 37 09 67 009 0425 09 67 015 0425 09 67 025 0425 09 67 037 0425 max. Ø Thread UNC 4-40 A2 Cut appropriate cable entry to fit actual cable diameter Top and side entry hood Black thermoplastic 9 15 25 37 09 67 009 04341) 09 67 015 04341) 09 67 025 04341) 09 67 037 04341) 9 15 25 37 Top and side entry hood Metallized thermoplastic 9 15 25 37 09 67 009 04351) 09 67 015 04352) 09 67 025 04352) 09 67 037 04351) Grommet for top and side entry black thermoplastic hood 07 . 04 1) 2) A 31.5 40.0 53.5 71.3 max. Ø max. Ø 09 67 001 9968 37 ways is only side entry Cable clamp kit for two outputs is available with Part No. 09 67 001 9988 (it includes: screw, metal clamp, plastic insert and grommet) B 15 15 15 15 C 40.0 40.0 43.0 42.5 D-Sub Side entry hoods with knurled screws Hood1) grey thermoplastic RAL 7032 grey thermoplastic with internal tin-plate screening No. of contacts Part No. 9 15 25 37 50 09 67 009 0571 09 67 015 0571 09 67 025 0571 09 67 037 0571 09 67 050 0571 9 15 25 37 50 09 67 009 0573 09 67 015 0573 09 67 025 0573 09 67 037 0573 09 67 050 0573 9-37 way for packaging density of 3 TE (15.24 mm) Drawing Dimensions in mm D-Sub - H Identification 15 25 37 50 a max. 39.62 53.52 69.80 67.41 b c 33.3 47.0 63.5 61.1 15 15 15 19 d max. Ø 9.1 Ø 11.5 Ø 12.8 Ø 14.5 Knurled screw Thread UNC Thread M3 9-50 4)09 67 000 99714) *09 67 001 9965* Grey head / Nickel plated steel Thread UNC Thread M3 9-50 4)09 67 001 9978 *09 67 001 9977 Full metal part Tooling6) for assembly of hoods Top part Bottom part *09 99 000 0215* *09 99 000 0216* 07 . 05 * Not normally kept in stock 1) Order knurled screw separately 2) Before assembling the hood, the knurled screws must be inserted into the lower hood part. For retained nut when using slide lock or female screw lock 9 way 1 per hood – 15-50 way 2 per hood 5) Screw driver type ISO PH 1 for philips screw No 1 ISO norm 4757 6) Additional tooling (bench press) see chapter 32 3) 4) D-Sub Top entry hoods with knurled or locking screws Identification No. of contacts Part No. 9 15 25 37 50 09 67 009 0442 09 67 015 0442 09 67 025 0442 09 67 037 0442 09 67 050 0442 9 15 25 37 50 09 67 009 0443 09 67 015 0443 09 67 025 0443 09 67 037 0443 09 67 050 0443 9-50 9-50 09 67 000 99252) 09 67 000 99302) Drawing Dimensions in mm Hood Black thermoplastic with short locking screws D-Sub - H Hood Metallized thermoplastic with short locking screws Knurled screw for metallized hood Thread UNC Thread M3 07 . 06 1) 2) Use of knurled screws is possible. Please order separately Order 2 for each hood 15 25 37 50 a b c d 40.0 53.2 70.0 67.5 34.7 39.7 39.7 39.7 15.2 15.2 15.2 18.2 33.3 47.0 63.5 61.1 min. 3.3 3.5 3.5 9.3 e max. 8.5 11.0 11.0 12.0 D-Sub Full metal top and side entry hoods with knurled screws No. of contacts Identification Part No. Drawing Dimensions in mm Top entry hood 09 67 009 034 09 67 015 034 09 67 025 034 09 67 037 034 . . . . 4-40 UNC or M3 A 31.2 39.5 53.4 69.7 B 39.9 41.5 48.6 53.6 D-Sub - H 9 15 25 37 Poles 9 15 25 37 Grommet set halves Please insert digit for screw option Knurled screw, thread 4-40 UNC Knurled screw, thread M3 þ 3 þ 8 Grommet dimensions Number Diameter 1 4.0 2 5.0 3 7.0 4 10.0 5 10.2 Side entry hood 4-40 UNC or M3 1) 91) 15 25 37 09 67 009 033 09 67 015 033 09 67 025 033 09 67 037 033 . . . . Poles 9 15 25 37 A 31.0 40.5 53.7 69.8 B 38.0 41.1 41.8 41.8 Grommet set halves Please insert digit for screw option Knurled screw, thread 4-40 UNC Knurled screw, thread M3 1) þ 3 þ 6 9 pole hood provided with only one screw on the opposite side of the cable entry. Grommet dimensions Number Diameter 1 4.0 2 5.0 3 7.0 4 10.0 5 10.2 07 . 07 D-Sub Full metal top and side entry hoods with short screws No. of contacts Identification Part No. Drawing Dimensions in mm Top entry hood 9 15 25 37 50 09 67 009 034 09 67 015 034 09 67 025 034 09 67 037 034 09 67 050 034 . . . . . D-Sub - H Please insert digit for screw option Locking screw, thread 4-40 UNC Locking screw, thread M3 þ þ 4-40 UNC or M3 4 9 Side entry hood 9 15 25 37 50 09 67 009 033 09 67 015 033 09 67 025 033 09 67 037 033 09 67 050 033 . . . . . Poles A B C D 9 15 25 37 50 31.8 40.3 54.0 70.2 67.8 42.4 43.5 47.7 50.4 50.5 20.8 23.3 31.7 48.2 45.8 15.4 15.4 15.4 15.4 18.2 Ø F1 Min. Max. 3.0 9.5 3.0 8.5 3.0 8.5 3.0 12.0 3.0 12.0 Ø F2 Ø F3 6.5 6.5 8.0 9.0 9.7 – 12.5 12.5 15.0 15.0 * Cable diameter without rubber bushing = Ø F1 Cable diameter with rubber bushing = Ø F2 Cable diameter without rubber bushing and without cable reduction plate = Ø F3 Please insert digit for screw option Locking screw, thread 4-40 UNC Locking screw, thread M3 þ þ 4 5 4-40 UNC or M3 Locking hook Front mount 09 67 002 9031 Locking hook Latch lock bolt Front mount thread 4-40 UNC thread M3 09 67 002 9041 09 67 002 9042 thread 4-40 UNC thread M3 09 67 002 9032 09 67 002 9040 thread 4-40 UNC thread M3 09 67 002 9044 09 67 002 9045 Rear mount Cable to cable 07 . 08 Latch lock bolt Rear mount Cable to cable D-Sub InduCom Full metal top and side entry hoods with different screw options Identification No. of contacts Part No. 9 15 25 61 03 001 . 013 61 03 001 . 014 61 03 001 . 015 Drawing Dimensions in mm D-Sub - H 40° side entry hood No. of contacts 9 15 25 A B C D 31.0 39.3 53.0 25.0 33.3 47.0 35.0 35.0 35.0 15.0 15.0 15.0 No. of contacts 9 15 25 37 50 No. of cable entries 1 (top) 1 (top) 3 3 3 A B C D 31.0 39.5 53.0 69.5 67.2 25.0 33.3 47.0 63.5 61.6 38.0 35.0 43.0 43.0 43.0 15.0 15.0 15.0 15.0 17.8 Top/side entry hood 9 15 25 37 50 61 03 001 61 03 001 61 03 001 61 03 001 61 03 001 . . . . . 010 016 017 1) 018 1) 019 1) Please insert digit for screw option Knurled screw, thread 4-40 UNC Hexagonal screw, thread M3 with captive washer Hexagonal screw, thread 4-40 UNC with captive washer Knurled screw, thread M3 1) þ þ 0 1 þ 2 þ 3 Part No. contains two blanking pieces Accessories see page 07.14 07 . 09 D-Sub Connector hoods for spring or slide locking tic c sti plas a l op mo d thermd ther o Ho rey allize G et M tic c sti plas a l op mo d thermd ther o Ho rey allize G et M g e lid s or D-Sub - H ng ic tic pri plast oplas s o m or d f erm her o th d t Ho lackallize B et M h atc r Sp l ing e ic ev gd kin oc l e d Sli alternative h atc l ed x i F olt b ing ck Lo 07 . 10 kin loc D-Sub Thermoplastic top and side entry hoods for spring or slide locking Identification No. of contacts Part No. Drawing Dimensions in mm 9 15 25 37 50 Thermoplastic grey Thermoplastic metallized 09 67 009 0411 09 67 015 0411 09 67 025 0411 09 67 037 0411 09 67 050 0411 09 67 009 0413 09 67 015 0413 09 67 025 0413 09 67 037 0413 09 67 050 0413 9-37 way for packaging density of 3 TE (15.24 mm) 9 15 25 37 50 Side entry hood 9 15 25 37 50 Thermoplastic grey Thermoplastic metallized 09 67 009 0511 09 67 015 0511 09 67 025 0511 09 67 037 0511 09 67 050 0511 09 67 009 0513 09 67 015 0513 09 67 025 0513 09 67 037 0513 09 67 050 0513 Thermoplastic black Thermoplastic metallized 09 67 009 0452 09 67 015 0452 09 67 025 0452 09 67 037 0452 09 67 050 0452 09 67 009 0453 09 67 015 0453 09 67 025 0453 09 67 037 0453 09 67 050 0453 a b1 b2 c d 31.0 39.4 53.3 69.7 67.1 23 28 34 43 41 28 28 34 43 41 12.8 12.8 12.8 12.8 15.8 10 10 14 20 20 a c d 31.0 39.4 53.2 69.5 67.0 15.4 15.4 15.4 15.4 17.9 7 7 9 9 9 e min. max. 5.75 9.0 5.75 9.0 5.75 9.0 5.75 9.0 5.75 11.6 D-Sub - H Top entry hood 9-37 way for packaging density of 3 TE (15.24 mm) Top and side entry hood 1) 9 15 25 37 50 9 15 25 37 50 1) 9 poles is only side entry Accessories see page 07.13 e min. max. 1.7 7.5 1.7 8.0 1.5 8.0 1.5 8.0 1.5 8.0 07 . 11 D-Sub InduCom Full metal top and side entry hoods for spring or slide locking Identification No. of contacts Part No. 9 15 25 37 50 61 03 001 00221) 61 03 001 00112) 61 03 001 00122) 61 03 001 00212) 61 03 001 00202) Drawing Dimensions in mm D-Sub - H Top/side entry hood with spring/slide locking No. of contacts 9 15 25 37 50 No. of cable entries 2 3 3 3 3 A B C D 31.0 39.0 53.0 69.5 67.0 22.6 30.6 42.6 59.2 55.0 40.0 40.0 40.0 40.0 40.0 14.8 14.8 14.8 14.8 17.6 07 . 12 1) 2) Part No. contains one blanking piece Part No. contains two blanking pieces Accessories see page 07.14 D-Sub Accessories for spring or slide locking hoods Identification No. of contacts Part No. Drawing Dimensions in mm Spring latch corrosion resistant steel 9-50 09 67 000 99071) Fixed latch corrosion resistant steel 09 67 001 99711) 09 67 001 99721) D-Sub - H 9-37 50 Slide locking device corrosion resistant steel 9 15 25 37 50 09 67 000 9914 09 67 000 9915 09 67 000 9916 09 67 000 9917 09 67 000 9918 9 15 25 37 50 a 35.6 44.0 57.8 74.3 72.0 b 25.0 33.3 47.0 63.5 61.1 c 12.0 12.0 12.0 12.0 14.8 d 10.0 10.0 10.0 10.0 13.5 Locking bolt tinned 9-50 09 67 001 99731) 07 . 13 1) Order 2 for each connector D-Sub InduCom Accessories for full metal hoods Drawing Hoods for 9-37 pole D-Sub Hoods for 50 pole D-Sub 61 03 000 0062 61 03 000 0063 61 03 000 0064 61 03 000 0065 61 03 000 0066 61 03 000 0166 61 03 000 0067 61 03 000 0068 61 03 000 0069 61 03 000 0070 61 03 000 0071 61 03 000 0165 61 03 000 0072 61 03 000 5062 61 03 000 5063 61 03 000 5064 61 03 000 5065 61 03 000 5066 61 03 000 5166 61 03 000 5067 61 03 000 5068 61 03 000 5069 61 03 000 5070 61 03 000 5071 61 03 000 5165 61 03 000 5072 Crimp ferrule D-Sub - H 61 03 000 0045 61 03 000 0046 61 03 000 0047 61 03 000 0048 61 03 000 0049 61 03 000 0050 61 03 000 0051 61 03 000 0052 61 03 000 0053 61 03 000 0054 61 03 000 0055 61 03 000 0056 61 03 000 0057 61 03 000 0058 61 03 000 0142 61 03 000 0059 61 03 000 0127 61 03 000 0060 61 03 000 0061 Cable clamp cable-Ø appr. 5- 7 mm 61 03 000 0141 cable-Ø appr. 7-10 mm 61 03 000 0044 cable-Ø appr. 10-12 mm 61 03 000 0143 61 03 000 0145 cable-Ø appr. 11-14 mm Blanking piece for hoods 61 03 000 0042 61 03 000 0041 Hexagonal screw 07 . 14 thread 4-40 UNC x 17.58.8 with captive washer 09 67 002 9020 thread M3 x 17.5-8.8 with captive washer 09 67 002 9019 Knurled screw thread 4-40 UNC 09 67 002 9018 thread M3 09 67 002 9017 Tooling see chapter 31 Dimensions in mm D1 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 D2 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 D3 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 11.0 11.5 12.0 12.5 13.0 13.7 14.0 D4 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 11.0 11.5 12.0 12.5 13.0 13.5 14.0 15.0 15.0 D3 Crimp flange Part No. D1 D2 Identification D4 D-Sub InduCom Mounting details Crimp flange termination instruction 1. Strip the cable sheath to the correct length (approx. 35 to 40 mm, depending on interface type). 3. Place the crimp flange over the wires covered by the remaining foil shield. Push and twist the crimp flange under the outer screen and cable sheath until the end of the cable sheath touches the crimp flange. HARTING has developed a special tool for optimised installation of the shielding over the crimp flange, part number 61 03 600 0017. D-Sub - H 2. Place the crimp ferrule over the cable sheath. Bend the outer screen backwards over the cable sheath. Cut screen approx. 2 mm from the end of the cable sheath. 4. Move the crimp ferrule back onto the crimp flange and crimp the two parts together with the special service crimp tool part number 61 03 600 0020. For an optimised crimp process the tool should to be positioned as close as possible to the crimp flange sholder. 5. Cut off the internal screen foil and push the crimp flange inside the metal hood. HARTING offers to test and define the best crimp flange and ferrule combination for customer specific cables. 07 . 15
09 67 001 9972 价格&库存
很抱歉,暂时无法提供与“09 67 001 9972”相匹配的价格&库存,您可以联系我们找货
    • 1+5.33520
    • 200+2.12760
    • 500+2.06280
    • 1000+2.03040
