09456002003
09456002003
    HARTING(浩亭)
    T1 SPE CABLE SF/TP 1X2XAWG26/7 P
09456002003 数据手册
HARTING T1 SPE S/FTP 1x2xAWG26/7 PUR Field of Application IEEE 802.3: 10Base-T1; 100Base-T1; 1000Base-T1 T1-SPE cable assemblies Perfectly suited for combination with the HARTING SPE connectors Suitable for flexible installation in industrial application Power over Data Line (PoDL) Standards IEC 11801-3 IEC 61156-12 Cable design Conductor Insulation Twisting Pair screening Overall Screening Sheath Tinned copper wires, AWG 26/7 Foamed polyethylene, Ø 1,04 mm 2 wires twisted to a pair, Color Code: blue, white Alulaminate foil overlapped Braid of tinned copper wires, Coverage about 90% PUR Mechanical Characteristics Bending radius Operating temperature range Color Overall diameter Weight about Single Repeated fixed installation moved 4xD 8xD -40°C to +80°C -25°C to +80°C yellow (4.7 ± 0.2) mm 27 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING T1 SPE S/FTP 1x2xAWG26/7 PUR Electrical Characteristics Loop resistance Insulation resistance Capacity Characteristic impedance (500 V) 1 KHz 100 MHz 290 Ω /km  5 GΩ *km 48 nF/km 100 ± 5 Ω max. 100 V Operating voltage Test voltage (DC, 1 min) Wire/Wire and Wire/Screen Electrical Data (nominal at F (MHz) 1 4 10 16 20 31.25 62.5 100 155 200 300 600 at 20°C± 5°C Attenuation (dB/100m) 3.1 5.6 8.7 11.0 12.3 15.4 21.9 27.8 34.8 39.7 49.0 70.7 1000 V 20°C) Return loss (dB) 20.0 23.0 25.0 25.0 25.0 23.3 20.8 19.0 17.4 15.6 14.3 12.3 acc. IEC 61156-12 Material Characteristics Flame retardant acc. to IEC 60332-1-2 Oil resistant acc. to DIN EN 60811-404 (7x24h/90°C) UL Style 21815 (80°C / 300V) RoHS compliant (2011/65/EC) Halogen free UV resistant Printing: HARTING SPE CABLE SF/TP PUR 1x2xAWG26/7 E333435 AWM Style 21815 80°C 300V 094560002000200 "year/internal order number" "sequential length in metres" Order Informationen Length 10m Ring 50m Ring 100m Ring 500m Roll Partnumber 09 45 600 2004 09 45 600 2003 09 45 600 2002 09 45 600 2001 All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons.
09456002003 价格&库存
很抱歉,暂时无法提供与“09456002003”相匹配的价格&库存,您可以联系我们找货
      库存:21
