HVH-280 Series
●High Current Terminal
Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3-Point Contact Design
for High Current
Fig.1
■Features
1. Rated Current : 30A,
Rated Voltage : 600V AC/DC
●600V Rated Voltage
Top View
2. High Heat Resistance
Pressure Resistant Rib
Contact
Suitable for use in 125℃ environments.
3. High Reliability 3-Point Contact Design
High contact pressure design enables high current
capacity.
4. High Vibration Resistance
The cable sheath is firmly secured to reduce cable
runout during vibration.
5. Lock Designed for Easy Operation
Creepage Distance (7mm)
Spatial Distance (5mm)
Stroke depth and long lock arm allow workers to
operate the lock with ease.
6. Clear Tactile Click and Stable
Connection
Clear tactile click during mating and firm lock
supports reliable mating operation.
7. Crimp Terminal Insertion Ensured
Fig.2
●Incomplete Insertion Prevention and
Retainer prevents incomplete insertion of crimp
terminals.
Crimp Terminal
8. Prevents Mis-Insertion
[HVH-280-1214SCF]
Designed to prevent reversed insertion of terminals
and reversed connector insertion during mating.
Reliable terminal
insertion and
suppressed cable
runout
Socket
[HVH-280-3S-HU]
Retainer
[HVH-280-3P/S-R]
Fig.3
2022.7
1
HVH-280 Series●High Current Power Connector for Internal Automotive Connection, Heat Resistant up to 125℃
■Product Specifications
Operating Temperature
Rated Current
Ratings
-40℃ to +125℃
30A (Note 1)
Storage Temperature Range
Rated Voltage 600V AC/DC
Storage Humidity Range
Items
Specifications
-10℃ to +60℃ (Note 2)
Relative humidity 85% or less (No condensation)
Conditions
1.Contact Resistance
100MΩ Min
Measured at 1000V DC
2.Withstanding Voltage
There shall be no dielectric
breakdown or flashover.
2200V AC applied for 1minute.
3.Voltage Drop
5mΩ Max
Measured at A (Cable cross-sectional area×5)
DC
4.Connector Insertion Force
45N Max.
Inserted at a constant speed of 50mm/min Max.
No damage, strain or deformation to components.
5.Connector Unmating Force
75N Max.
Removed at a constant speed of 50mm/min
No damage, strain or deformation to components. Max.
6.Connector Retention Force 110N Min.
Max.
Voltage Drop : 5mΩ Max.
Contact Resistance : 100MΩ Min.
No electrical discontinuity of 1µs or more.
components.
[Vibration]
Random vibration frequency 5 to 1000Hz
(Acceleration/1.81grms)
8 hour test in each of the three directions under
the above conditions
[Shock]
Acceleration of 35G, 10 times in both directions of
the 3 axes
8.Thermal Shock
Withstanding Voltage:No dielectric
components.
Temperature -40°C → Room temperature →
125°C → Room temperature
Time : 30 → 5 → 30 → 5 minutes for 100 cycles
9.Temperature Cycle
Retention force between contact and
connector : 50N. Min.
Withstanding Voltage : No dielectric
components.
Left for 40 cycles at a temperature of -40 to
125°C, and relative humidity of 80 to 100%
components.
Left at a temperature of 125°C for 1008 hours.
7.Vibration/ Mechanical
Shock
10.High Temperature
Storage
Note 1 : The rating current depends on operating temperature and cable used. Please contact a Hirose Sales Office for inquiries.
Note 2 : This storage temperature is for long-term storage of unused products.
2
■Materials/Finish
Component
Header
Socket
Part
Material
Finish
UL Standard
Housing
PBT Resin
Black
UL94V-0
Crimp Terminal
Copper Alloy
Tin Plating
Retainer
PBT Resin
Dark Gray
UL94V-0
Housing
PA Resin
Black
UL94V-0
Terminal
Copper Alloy
Tin Plating
Solder Tabs
Phosphor Bronze
Tin Plating
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Connector
HVH-280 − 3 P 6.5 DS
❹
❺
●Terminal
HVH-280 − 1214 SCF
❻
❼
Series Name:HVH-280
No. of Pos:2, 3
Connector Type P : Header
S : Socket
Contact Pitch:6.5mm
Termination Form DS : Right Angle DIP
HU : Housing
Applicable Cable Size 1214 : 12 to 14 AWG
❼Form Type/Packaging SCF Socket Contact/Reel
3
■Product Configurations
●Header
Right Angle Header
●Socket
■Assembled Socket Connector
Socket Housing
Socket Crimp Terminal
Socket Retainer
■HVH-280 Series Mating Table
Header
Socket
Configuration Product Name
HVH-280 *pos. Header
(Board Side)
HVH-280-*P-6.5DS
HVH-280 *pos.
Socket
HVH-280-*S-HU
HVH-280-*P/S-R
HVH-280-1214SCF
4
■Right Angle Header
20.85±0.7
16.85±0.5
3.65±0.3
3.65±0.3
12.69±0.5
3.65±0.3
A±0.7
B±0.5
2.3±0.3
6.5±0.5
13±0.5
8.1±0.5
11.07±0.5
Part No.
HRS No.
No. of Pos.
Number of tray
packages
Finish
A
B
C
HVH-280-2P-6.5DS
778-0703-0
2
700
Tin Plating
21.2
16.85
19.03
HVH-280-3P-6.5DS
778-0700-0
3
560
Tin Plating
27.7
23.35
25.53
Note : Tray packages must be ordered in multiples of 560.
■Socket Housing
A±0.5
0.95±0.3
22.3±0.7
9.09±0.5
13.6±0.5
C±0.7
P=6.5±0.3
Part No.
HRS No.
No. of Pos.
A
HVH-280-2S-HU
778-0704-0
2
12.6
HVH-280-3S-HU
778-0701-0
3
19.1
Note : The product is sold in packs (100 pieces per pack) so please order based on number of packs.
5
3.575±0.3
3.55±0.3
A±0.5
6.5±0.5
■Socket Retainer
15.85±0.5
Part No.
HRS No.
No. of Pos.
A
HVH-280-2P/S-R
778-0705-0
2
10.565
HVH-280-3P/S-R
778-0702-0
3
17.065
Note : The product is sold in packs (100 pieces per pack) so please order based on number of sets.
■Socket Crimp Terminal
3.9±0.5
B
2-3.5
B
A
B
A
A
5±0.5
A
B
19.5±0.5
25.47±0.5
2-3.5
P=16
Part No.
HRS No.
Type
Amount
Finish
HVH-280-1214SCF
778-0502-0
Reel Terminal
1,700 pcs/reel
Tin Plating
Note 1 : The applicable cable's conductor is a tin plated soft copper wire.
Note 2 : Any problems that occur from using tools other than those specified by Hirose are not covered by warranty.
Note 3 : The applicable cable size is 12 to 14 AWG (2 to 3.5mm2).
■Applicable Crimp Tool
Type
Part No.
HRS No.
Applicable Contact
Applicator
AP105-HVH-280-1214S
901-5244-0
HVH-280-1214SCF
Note 1 : Any problems that occur from using tools other than those specified by Hirose are not covered by warranty.
Note 2 : Crimping work shall be conducted in accordance with the "Crimping Standard" and "Crimping Conditions Table".
6
How to Extract the Terminal
●Terminal Extraction Tools : Precise screwdriver (flathead screwdriver)
●Applicable crimp terminals : HVH-280-1214SCF
●Operation Method
Repair Method
To repair, press the mold lance with the terminal extraction tool in the direction shown in the diagram
below. While pressing extract the terminal. Make sure not to deform the terminal lock or contact part.
Caution : Do not push the terminal locking feature or contact. It may lead to deformation or damage to
the housing and other parts. When damaged, please replace it with a new one.
HVH-280-1214SCF
Lance
Screwdriver
Push lance upward.
Usage Precautions
1. Pulling out the connector with force may result in damage. If it is difficult to pull out, lightly push it once
and then operate the lock to pull it out.
2. When inserting or extracting the terminal, always disconnect from the power source first.
3. Do not touch the terminals while the power is on since it is very dangerous.
4. Contact a sales representative for harness instructions and handling manuals.
5. Do not perform insertion or extraction with a live wire. (Live wire insertion/extraction refers to inserting/
extracting while electricity is running)
Usage Environment
Please consult with your Hirose Electric sales representative if your system environmental conditions
repeat high and low temperatures.
7
MEMO:
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
8
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 07/2022. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“HVH-280-3P-6.5DS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.552151+4.34618
- 10+28.4763110+3.68868
- 100+24.20003100+3.13475
- 560+21.42963560+2.77589
- 1120+20.407461120+2.64348
- 国内价格
- 1+22.08600
- 10+21.60000
- 30+21.27600
