150066RV54050
150066RV54050
    WURTHELEKTRONIKIBE
    150066RV54050
150066RV54050 数据手册
Dimensions: [mm] Recommended Land Pattern: [mm] Absolute Maximum Ratings (Ambient Temperature 25°C): 0,5 ±0,1 2 0,5 1 0,4 4 Value Unit Power Dissipation (Red) PDiss R Test conditions 48 mW Power Dissipation (Bright Green) PDiss V 48 mW Peak Forward Current IF Peak duty/ 10 @ 1 kHz Continuous Forward Current 0,8 3 0,4 ±0,1 Properties 0,4 ±0,1 Junction Temperature 0,8 0,8 ±0,1 Reverse Voltage 40 mA IF 20 mA VREV 5 V TJ 115 °C Optical Properties: Chip Technology 4 1 AlInGaP Emitting Color 2 Red & Bright Green Lens Type 3 1,1 ±0,1 Diffused Scale - 15:1 1,5 ±0,1 4 - 1 General Information: Operating Temperature V R -40 up to +85 °C Storage Conditions (in original packaging) < 40 °C ; < 90 % RH Storage Conditions (for single parts) -40 up to +100 °C Moisture Sensitivity Level (MSL) + 2 - 4 Polarity Mark 1,6 ±0,1 1 0,55 ±0,1 0,19 ±0,1 Schematic: 2 3 + 3 3 Scale - 15:1 CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE PLD 001.000 2019-09-24 DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WL-SBCD SMT Bi-color Chip LED Diffused ORDER CODE 150066RV54050 SIZE/TYPE BUSINESS UNIT STATUS PAGE 0606 eiPal Valid 1/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Electrical & Optical Properties: Properties Test conditions Viewing Angle: Value min. typ. max. Unit Peak Wavelength (Red) λPeak R 20 mA 632 nm Peak Wavelength (Bright Green) λPeak V 20 mA 575 nm Dominant Wavelength (Red) λDom R 20 mA 624 nm Dominant Wavelength (Bright Green) λDom V 20 mA 573 nm Luminous Intensity (Red) IV R 20 mA 45 100 mcd Luminous Intensity (Bright Green) IV V 20 mA 25 60 mcd VF R 20 mA 2 2.4 V Forward Voltage (Bright Green) VF V 20 mA 2 2.4 V 80 Spectral Bandwidth (Red) Δλ R 20 mA 20 nm Spectral Bandwidth (Bright Green) Δλ V 20 mA 15 nm Viewing Angle Phi 0° IREV 5V 2θ50% 20 mA 10 130 Certification: µA ° Relative Luminous Intensity (%) Forward Voltage (Red) 90 Reverse Current 0° -70 10° 100 20° 30° 40° 45° 70 50° 60 60° 60° 50 40 70° 30 20 RoHS Approval Compliant [ 2011/65/EU&2015/863 ] REACh Approval Conform or declared [ (EC)1907/2006 ] Halogen Free Conform [ IEC 61249-2-21 ] Halogen Free Conform [ JEDEC JS709B ] 80° 10 -90 -45 0 10 20 30 40 CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE PLD 001.000 2019-09-24 DIN ISO 2768-1m 50 60 70 80 90 90° 100 PROJECTION METHOD DESCRIPTION Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WL-SBCD SMT Bi-color Chip LED Diffused ORDER CODE 150066RV54050 SIZE/TYPE BUSINESS UNIT STATUS PAGE 0606 eiPal Valid 2/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Spectral: Forward Current vs. Forward Voltage: 100,0 90,0 80,0 100 70,0 Forward Current [mA] Relative Intensity [%] 80 60 40 20 60,0 50,0 40,0 30,0 0 400 450 500 550 600 Wavelength [nm] 650 700 750 20,0 10,0 0,0 1,5 1,6 1,7 1,8 1,9 2,0 Forward Voltage [V] CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE PLD 001.000 2019-09-24 DIN ISO 2768-1m 2,1 2,2 2,3 PROJECTION METHOD DESCRIPTION Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WL-SBCD SMT Bi-color Chip LED Diffused ORDER CODE 150066RV54050 SIZE/TYPE BUSINESS UNIT STATUS PAGE 0606 eiPal Valid 3/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Luminous Intensity vs. Forward Current: Derating Curve: 200,0 30 180,0 25 160,0 Forward Current [mA] Luminous Intensity [mcd] 140,0 120,0 100,0 80,0 20 15 10 60,0 5 40,0 0 20,0 0 10 20 0,0 0 5 10 15 20 25 Forward Current [mA] 30 30 40 50 60 70 80 90 Ambient Temperature [°C] 35 CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE PLD 001.000 2019-09-24 DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WL-SBCD SMT Bi-color Chip LED Diffused ORDER CODE 150066RV54050 SIZE/TYPE BUSINESS UNIT STATUS PAGE 0606 eiPal Valid 4/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Packaging Specification - Tape and Reel: [mm] P0 A K0 P2 W3 T W1 close to center E1 D0 A W F N D B B0 E2 C Top Cover Tape D1 A P1 T1 A0 T2 Polarity Mark End W2 Feeding direction Start detail B Carrier Tape B Cover Tape Cover Tape Chip Cavity Sprocket Hole No Component min.160mm Components No Component min.100mm Embossment Cover Tape min. 400mm Tape Type 2a A0 (mm) typ. 1,65 B0 (mm) typ. 1,75 W (mm) +0,3/ -0,1 8,00 T (mm) ref. 0,23 T1 (mm) ref. 0,10 T2 (mm) typ. K0 (mm) typ. 0,70 P0 (mm) ±0,1 4,00 P1 (mm) ±0,1 4,00 P2 (mm) ±0,05 2,00 D0 (mm) +0,1/ -0,0 1,50 D1 (mm) min. 0,30 E1 (mm) ±0,1 1,75 E2 (mm) min. 6,25 F (mm) ±0,05 3,50 Material Qty. (pcs.) Polystyrene 2000 165° - 180° A (mm) ± 2,0 178 B (mm) min. 1.5 C (mm) min. 12.8 D (mm) min. 20.2 N (mm) min. 50 W1 (mm) +1,5 8.4 W2 (mm) max. 14.4 CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE PLD 001.000 2019-09-24 DIN ISO 2768-1m W3 (mm) min. 7.9 W3 (mm) max. 10.9 Material Polystyrene PROJECTION METHOD DESCRIPTION Pull-of force Tape width 8 mm 0,1 N - 1,0 N Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WL-SBCD SMT Bi-color Chip LED Diffused ORDER CODE 150066RV54050 SIZE/TYPE BUSINESS UNIT STATUS PAGE 0606 eiPal Valid 5/8 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Classification Reflow Profile for SMT components: Classification Reflow Soldering Profile: Profile Feature Tp tp Max. Ramp Up Rate Max. Ramp Down Rate TL Temperature Ts max Ts min Ts min 150 °C Preheat Temperature Max Ts max 200 °C Preheat Time ts from Ts min to Ts max ts Ramp-up Rate (TL to TP) Liquidous Temperature tL Preheat Area TC –5°C Value Preheat Temperature Min max. 60 - 120 seconds 3 °C/ second max. TL 217 °C Time tL maintained above TL tL max. 60 seconds Peak package body temperature Tp see table Time within 5°C of actual peak temperature tp max. 10 seconds Ramp-down Rate (TL to TP) 6 °C/ second max. Time 25°C to peak temperature max. 220 seconds refer to IPC/ JEDEC J-STD-020E tS Package Classification Reflow Temperature: Volume mm³ 350-2000 Volume mm³ >2000 PB-Free Assembly | Package Thickness 260 °C < 1.6 mm 260 °C 260 °C PB-Free Assembly | Package Thickness 260 °C 1.6 mm - 2.5 mm 250 °C 245 °C PB-Free Assembly | Package Thickness 250 °C ≥ 2.5 mm 245 °C 245 °C Properties 25 Time 25°C to Peak Time Applied cycles Volume mm³
150066RV54050 价格&库存
很抱歉,暂时无法提供与“150066RV54050”相匹配的价格&库存,您可以联系我们找货
